Mazda MPV: Problems & Solutions
MB
For an analogy, consider water skis. (okay, so it's really a counter-analogy since water skis are *designed* to hydroplane, and tires are just the opposite, but bear with me here.) When a water skier is awaiting "take-off," the skis are slicing through the water just fine--the skier has to work to keep the tips above water. As the boat starts to go and speeds up, it gets easier and easier for the skier to keep the skis above water, and once the skier is up, it takes almost no effort to keep the hydroplaning effect. Now, that really demonstrated the effect of *speed* on hydroplaning, but let's go one more step. The typical water skis are two narrow, flat sticks with one boot in each ski. Slalom skis, on the other hand, are designed to have both feet in one ski, and they are wider than the normal skis. Why? Because at low speeds, the skier needs the extra width to keep hydroplaning.
Are we having fun yet? I swear I haven't used my brain this much since college.
-Dave
Mike
I'm not a Mazda tech, but I seem to have the equipment in my garage to flush my brakes. A couple of quarts of brake fluid, some flare or box end wrenches to turn bleeder screws, a special $2.99 brake bleeder cup with two fittings, and a vacuum pump.
Wonder why they didn't want to take your $75 or so per hour plus fluid, enviromental bunny protection charges and so forth?
Hmmm
TB
I do believe the tire is still rotating, but full blown hydroplaning has the entire tire (rotating or not) floating on the water.
I was thinking along the same lines as the evaddave, like water skis.
So if hydroplaning is the water actually supporting the weight of the vehicle on then, to me at least, it makes sense that a wider tire would begin to hydroplane sooner (at lower speed) than a narrow tire.
(I'm in stream of consiousness mode here 8^) )
I'm not sure I can go back to the skis here because there is too much changing. One ski versus two, the weight on each ski is different. And we don't know the surface area of the ski.
But what we do know, is slow down in the rain 8^)
TB
That's exactly what I thought. I, too, have the tools. Just need to buy a bottle of ATE Racing Blue brake fluid and pump the old stuff out. Does anyone know the "pattern" for bleeding?
Rears first, obviously, but more specifics would be helpful.
Mike
Hydroplaning? Just get a set of X-Ones for your MPV and plow right on thru the puddles! BTW, I'm still looking for a nice 16" alloy set for the van. When I find them, I'm going to take the almost new 15" X-Ones off the van and put them on my Accord. Yes, they will be wider than the current MXV4+ on the Accord (205 vs. 195), but the tread patterns between the two tires are drastically different. If you've never seen their tread pattern before, check them out X-Ones
I'll have to admit though that I've given a more-than-cursory glance at the Dunlop SP Sport A2
Welcome back Prof. Tboner! Trying to make up for lost time, er, posts? ...hehe. Could you share your Dunlop experiences again with me? I'd appreciate it!
I really like Dunlop as a budget minded performance tire. The only really bad experience I've had was I thought the SP4000's wore out too quickly.
It looks like the Buick will get about 30K enthusiastic miles on them. I suspect I can get 25K or so on the van.
Michelin makes a good tire as well. Very consistent quality. I have the Sears equivalent of the RainForce® MX4, the Weatherwise on the Buick during the winter.
They are good enough for winters here, but go to where they really get snow, and you'ld probably suffer. And since Sears is very convenient to my home, and those rotations are not so painful while I cruise the mall ...
Going back to Dunlops, I've had the D60's on other cars in the past and felt they were a good tire.
Personally, between the X-One and the A2, I'd pick the Dunlop A2's because the traction and temp ratings are more favorable. I've never been a fan of tires that can go 100K miles.
TB
Whether hydroplaning will occur depends both on the ability of the tire to push water out of the way (related to contact pressure in turn related to vehicle weight and tire size) and the time over which water can be pushed out of the way (related to tire size).
Given equal "contact pressure," I think a larger tire would hydroplane more easily than a smaller tire since the water would have to be moved further to clear the contact area - only if the two tires had no tread! (I.e., the water must be pushed the full width of the tire in order to avoid hydroplaning.)
But given that we're usually dealing with intact tread on good tires, the situation changes. Water only has to be moved a distance equal to the separation of the grooves so it's not obvious, to me at least, that one size has any intrinsic advantage over the other.
The key here is "equal pressure." Generally, you put larger tires on heavier vehicles to support the greater weight and the contact pressures turn out to be roughly the same. Also, tread design matters.
My point? The physics isn't all that simple!
tidester
SUVs; Aftermarket & Accessories
Thanks, partner!
Steve
Mls64, my general rule of thumb when bleeding brakes is to start with the corner farthest from the reservior, so that'd usually means the right rear, then left rear, right front, then left front.
/j
Of course, none of the above takes into consideration tread pattern, actual water paths and speeds, etc. Just a general tendency...
I hope it makes sense.
Of course, that only happens on the first 4 revolutions, so the nail factor loses its power quickly. Now screws, that is a different matter, they hang in there for at least 20 revolutions before they get shoved in too deep.
Hope this clarifies the confusion.
Mike
Mike
Update on my 2002 ES breakdown (still on its first tank of gas).
Basically, the dealer found a loose wiring harness from the factory. Pushed it back into the "brains" and van ran fine. There is a much more detailed account of my full service events at the YAHOO forum group discussing the rental, tow, calls, etc.
thanks,
Excalibur
No, I replaced the OEM SP4000s when they wore out with the SP Sport A2s. Huge difference, and a great upgrade. What size X-Ones do you have on your MPV?
Mike
If I can't find some 16" alloys for the MPV soon, I'll just leave them on the van. The Mich MXV4+ on my Accord only have a few thousand miles left, so any way you slice it, I'm going to need some new tires before long. Probably the only thing that is keeping me from getting the Dunlops for the Honda is the question in my mind regarding their rain performance. I've had some pretty vivid experiences in the past driving on FL highways during 2-4 inch/hour downpours, so an excellent rain tire is important to me.
I agree with you 100% that those high (60k - 80k) tires give up performance to tread life. I say more than that. Rubber ages and with time changes gripping characteristics. Therefore, if you buy 60k tires and you make 10k a year they are worthless before they are even worn out.
MB
Hydro-planing occurs on bleeding brakes when the shift lever is stuck between 3 and D with loose harnesses.
Did I miss anything?
/j
Oops, wrong car.
BTW, I do know how to spell brakes. But I can make spelling mistakes with the best of them.
TB
http://groups.yahoo.com/group/mpv2000/message/3146
I hope this helps.
MB
I also got a rock chip on the hood just after 1 month of driving. Anyone have good pointer with fixing paint chip?
Mark
I had smell for about first 1000 miles but not really bad. I could smell it only sometimes while standing at the stop light. No big deal. Now the smell is completely gone. I have 2700 miles.
MB
Anybody else in So. Cal. ever had the stinky pipe?
Dennis
malt: I'm sure if you went downtown, you could find all sorts of stinky pipe, LOL!
Vehicle - 26874.91
VA Processing Fee - 220
Tax - 812.85
Business License tax, registration, etc. - 92.25
Total - 28000.01
This was for an ES with sunroof, cd changer, fog lights, 4 seasons, roof rack, and bumper plate.
I am not sure if the $1000 incentive money to dealers is still being offered. It was when I bought and I used that knowledge to get a lower price.
When looking for your van, go to the mazdausa website and check the inventory of allthe dealers in your area. If you like one, your dealer can probably trade for it.
RBB
Invoice: $26,645
Vehicle--25945.00
VA Processing Fee- 220
License, Registration, etc. 92.25
Sales Tax--787.75
Total=27,045
This was for an ES with Fog lights, 4 seasons, roof rack, bumper plate, rear spoiler, and cargo mat.
I also used the $1000.00 dealer incentive. As you can see, I still did not get as good of a deal as I should have, but the dealer was nearby, and who is going to quibble over $100.00-200.00?
:-)))) MB
Called the dealer service department and they said it must have been damaged and it will be about $100 to have it replaced.
Could this just be that I need to have it sync up with my van since I had the battery out?
Any help? Thanks
Before you try that, look HERE for assistance on reprogramming your remote. These are instructions for adding a third remote. I haven't done this, so can someone give me an assist... can you reprogram the remote if you just have one other working one... or is it not an issue?
/javadoc
I live in CA & today is a hot day(90+).
For driving my 02' ES 10 miles with air condition on and fan set for 2, it takes about 15 min and I park my car in my company's parking lot.
Everything is normal and temp sense is in the middle.
But 2 min after I park my car, I see water dripping to the ground about the location little behind the middle of two front wheels under the chasis.
It's not from the reservor, doesn't look like from the coolant.
Is it normal or a problem?
Thx for your help
ps. my ES milage is 399 now and I don't experience it before.
Steve
