Mostly I empower/authorize my employees to do the very best work they possibly can. Occassionaly I tweak the company's trimtab vernier.
Although I am no longer on the company payroll I do get to sleep with the BOSS.
Check us out at strobedata.com
Your could also learn about us by searching "pioneer 10" and "Osprey". Currently a little short of 8 billion miles away, launched in 1972, NASA used an early version of the Digital PDP-11 for the Pioneer 10 communications packets. Last PDP-11 failed about 3 years ago, Digital had discontinued product set, no project funding from NASA (program, funding, expired in 97).
Strobe Data donated a brand new PDP-11 "clone" to NASA and communications were re-established in the spring of 01.
30th anniversary of launch date was celebrated by sending outbound message one day before anniversary so return packet from Pioneer 10 would arrive the next day at approximately the time of launch 30 years before, 22 hours each way.
If you watch ESPN during the upcoming 24 hours of Daytona you might get a glimpse of our logo on each of two Lola/Nissans, or the dash placard in front of the in car camera.
BUSY, aren't we?
You can obtain lap pledges at teamseattle.com. ALL proceeds go directly to Seattle Children's Hospital.
Some great achievements. Congratulations on them. I wish you could get Flint 350 and I some time with the Hubble.
Honestly I don't have that A/C problem and I always have the climate control set to auto. Can't remember having that problem on the 95 or 98 LS400's nor is it a problem on the LX470.
Do we assume the Boss fired you and gave you a good consulting deal.
when i leased my ls i thought i had the 16', now i look at they are 17 225 55 17 at 23k miles i may have another 5-8k miles left so i'm looking for replacements. sam's wants 150-200+ per tire, tirerack notmuch better what others will fit. how about 225 60 17? will that work. 60 vs 55 aspect Suggestions????
Based on this an adequate replacment for 225/55/17 tires would be 205/60/16, but this would be a fairly narrow tire for summer or all season use. 225/50/17 would be close but not ideal replacement size. 225/60/17 tires might work, but would cause a roughly 8-10% speedometer error. This may work, but I would suggest keeeping the change in rolling diameter to within 5%.
flint, I understand your position and it used to be mine, too. Now it's no contest; just think about it and consider all ramifications and trust that you are not the next innocent victim.
WWest comented on the Bridgestone Turanza tires as the best tires for a LS400 type of a car (my is a perfect condition 1995 with 65000 miles) and the question is especially for you WWest. Thank you.
Currently I have Michelin MXV4 Plus tires but unfortunately on the way back from North Carolina to Atlanta a side of one of the tires was raptured - likely due to an object on the road. The tires have 15000 miles.
1. Would it be appropriate to install a single new tire.
2. If installing all 4 new tires is advisable then I am considering Bridgestone turanzas. I am happy with the Michelins but I suspect that they are not the quietest.
The MXV4 plus is a very good tire. I've used them. In my experience, the Turanza proved better for my purposes. I put the Turanza LS-H on my wife's LS400. She is thrilled with the diference compared to the OE. Both the V and H have tread wear rating of 400. The V may give a little better performance. (check out Tirerack's (tirerack.com)survey on this tire)
I recently upgraded the tires on my LS430's 17 inch rims. Sadly, the Turanza LS series offers no 225-55-17 tires. The LS-V would have been my choice.
LS400 - V8, 290 real ponies, 300Ibft of torque, vvt-i, 5-spd, very fast, smooth, quiet, luxurious without pretensions, RWD, full-size, ultimate in refinement from Toyota/Lexus.
A low mileage CPO LS400 ('99 or '00) fully loaded Nav/HID/heated seats/etc.. should price in the mid-30's. Worth every cent. Unless you like the smell of a new car.... Always buy higher not lower, IMHO.
Just got my 2001 LS430 back from the shop. About two weeks ago "Check VSC" warning message came on. Dealer had problems getting it corrected - took them 9 days!!! I have just now tried the car out in some recent snow and question if they solved the problem or just disabled the VSC.
Prior to the check VSC message, whenever I was on some snow or ice and tried some turns that were too aggressive the VSC would kick in and the VSC chime would sound. Tonight, no matter what I tried in the snow, nothing happened, no chime - no dash warning icon.
So I am wondering if my dealer is dumb enough to try something like disabling the vsc or am I missing something? Any suggestions?
I don't own a LS but just a suggestion: is there a switch or button that you can use to enable/disable the VSC? If so this may restore the operation to the previous condition. Otherwise I would read the owners manual on this function and if your car does not respond the way it's supposed to then I would have the dealer try again.
I would agree that the better car is the used LS. I bought a 90 LS in 1992 and am still driving it today. I don't quite understand the idea of the ES being more "pretentious". Even as a happy LS owner, I still think the ES, which I drive as a service loaner each year, is a nice luxury car. I made this same decision in 1992 when I chose a used LS over the first model year ES. That was before they had a certified program and I have no regrets. Not only do you now have to pay some premium for the "certified" distinction but I would wonder about buying a non-certified vehicle from a Lexus shop wondering why they thought a particular 3 year old car didn't merit certification.
Yes there is a switch and when the "check VSC" message came on it did not matter what position the switch was in; the VSC did not come on.
After the repair the switch toggled the dash display between on and off. So the switch now does have an effect. Last night I know I had the switch in the on position.
Today (now even more snow here in Illinois than last night) I did detect that the VSC might be doing something but still no chime - instead a very faint buzzer sound came on when the VSC started to kick in and the swerving car icon comes on on the dash.
I am wondering if the software change that the dealer said they had to do has the effect of not kicking in the VSC as soon and switched the warning sound from a chime to a buzzer. My 2001 was a relatively early model; perhaps later releases of the S/W changed the sound and the point of correction?
I guess you'll just have to ask your dealer if the software update was supposed to include a change in the audible tone you're getting from the previous chime to the faint buzzer sound. I can't imagine why it would also include a DELAY in the response time when it activates. I have however read several vehicle reviews that were critical of VSC systems that were too obtrusive, coming on too strongly in situations where they were not needed for a good driver to maintain speed and control. It's possible that the new program that the dealer installed attempts to remedy this, or as you suspect it's also possible that the new "fix" left you with a system that's only semi-operational.
As a footnote I have an Audi allroad quattro (AWD) with winter tires, and on mine it's pretty difficult to get the system to activate, even on snow-covered roads. If I purposely use too much throttle around a sharp curve, and try to get the vehicle to "slide" around it, the VSC button on the dash will blink real fast and I can feel and hear the system activate as a type of "clatter" which I believe is the ABS applying braking pressure to the wheel(s) losing traction. Bear in mind that I've done this only as a way to test it out in situations where there was no traffic - otherwise I drive quite conservatively, especially in slippery conditions (which we get plenty of here in Minnesota!).
Coming from a 99 GS 300 it's time to upgrade to an LS. Drove a 2000 one with air suspension and Nakamichi (my GS had the Nak) and then an 01 with Nav and Levinson. Wow, these cars are the nicest driving, quietest, bank vault solid cars I have ever been in. I liked the 01 better for the features and the way it drove. It is so quiet and smooth. This one was white with ivory and I was only there to try them out and not to buy. Sales man was very patient and understanding. I asked about an update and he said for 04 the front end is going to be freshened up and a total new design for the 06 model year. ANyway, gotta start checking out the used classifieds for 01 and 02's with Nav and Lev. I asked about the black cherry color and he says even though it is very popular and sought after, Lexus only buids a small percentage of them in that color as well as the dark blue and pine green. I say wake up Lexus, build them if the customer wants those colors. He said by far the most popular at least here in Seattle is the white, silver, and black colors. I have also seen quite a few of the light green and never a light blue one. Anyway, just thought I would add my thoughts after being an avid reader of the board for weeks. Oh yes, the 2000 was a nice car too and drove flawlessly and both cars had about 30K on them and were certified.
There is more complete list based on images off a Lexus TSB that list all the CBEST settings for several models over at clublexus.com which I have used for some changes.
Well - I called my salesman the other day as I have an LS and LX coming off lease by January and family members want to buy them out at lease end if I don't do so. For those who may be in the same situation with family or friends his answer was that it would not be a problem.
Anyway I asked about the LS430 restyle rumor and his answer was there would definitely be a front-end restyle to a more sporty look in 2004. As well AWD would almost certainly be an option (this is not yet definite but a 80-90% certainty). 18" wheels may also be an option as will a 360hp engine. The latter may be packaged into a separate Euro suspension option at first, and then the 360hp engine would likely be offered on the base suspension model a bit later. They will also likely tweak the current engine to get the HP up to 310 or so.
There will be a major re-design in 2006 with short and long wheelbases. The LX470 will also be redone completely in 2006 on the Sequoia platform as a superlux SUV. In my opinion it already is one.
On leases - an interesting game is being played. The interest rates have dropped so low that Lexus (as well as everyone else) has reduced the residuals particularly on SUV's. This may be the reason that the new GX470 (as per posters on that board)is getting only a 55% residual value in 3 year or 39 month deals. With lower rates they don't have to roll the dice on residuals for the time being. You still benefit from a lower payment than before, say in 2001 - just not as low as it could have gone. So that brings into question whether to buy or lease and buy after 3 years. With a low residual a buyout after a three year lease may be a better option than buying up front. At the same time it provides the luxury of making a decision to re-up on a new lease or buyout at lease end.
The new GX470 - for anyone interested is very difficult to get and waiting lists remain long - at least here in NJ.
ljflx, did you ask when (which month) the 2004 model will be introduced? I also wonder what the base price on the 360 hp AWD Euro model might be - I'm guessing $65k or so(?).
Found the website, but could not navigate to get to the info on CBEST settings. Can you show us the path, please? I, too, ran into the dealer telling me I had to plow through the book to figure out what could and could not be changed. You would think that these dealership that get the elite moniker would whip out a booklet they had put together. Thanks for the help.
No - I didn't ask but based on the tone of the discussion it should not be later than normal - say mid or late October. Pricing will not change much if you stay with the base engine and non-awd. But I forgot to note that Lexus may make an air suspension standard on all LS cars so that would also have a price effect. But that's all he knows as of now on pricing. I'd expect a euro and AWD would be more of $67-68k+ price target - $62k+ now plus about $3k for the awd and $3k for the bigger engine. But that's just my speculation and it could be higher if the air suspension is included. I would also think that a Euro sport 360hp LS will be a hot car, maybe harder to get than the GX470 is now. And who knows what mix of these cars Lexus will make early on. I remember how impossible it was to get an ultra in 2001. So you may need to get in line early. He did say that Lexus may up production so that they are ready for 40k+ annual LS sales and that Lexus expects to take more market share based on their research. What bothers me is I forgot to ask if they are changing the nameplate to the LS500. Lastly he did say the V-12 will be a 2006 intro on the LWB model - I would assume as an option.
ljflx, why didnt you go with the S500 if you were so taken by it? You mentioned a 3 year lease. During the lease all repair problems would be covered under the normal 4 year warranty. They also give a loaner car (Atlanta). So if you liked the looks and I know there is more driving excitement and "feel" to the handling and steering why not give it a whirl? You only live once and if you didnt like it turn it back in in 3 years.
What makes you say I was so taken by it? That was hardly the case. I found it to be a great car but not an overwhelming car. I was afraid of its reliability regardless of the three year free maintenance. On close comparison road tests I found the LS430 to be the better car for my preferences. I had no doubt whatsoever about it's reliability - and it's been a perfect car. The fact that the lease payment are about $12k cheaper over 3 years is an added benefit.
Granted you wanted opinions from people with 95-00 Ls cars, but please allow me to express mine.
I would suggest a set of Michelin Energy MXV4+ tires, preferably V-rated. Why? Just a personal opinion, based on the replacements I had to get on my 2003 LS due to a bad set of original Dunlops. The dealer suggested the tires saying he has never had a complaint about Michelins. I wouldn't trust the "never" completely but I think that these tires have a very low incidence of problems and offer good performance.
I bought a set of T-rated X-One Michelins. They are very quiet, handle nicely in the dry and wet, and I thought it was better for me to put a limiting factor on my immaturity. T's are maxed out a 112 or so. In a car with a 150 mph top speed I needed something to keep me from trying it out. They also have a 60,000 mile treadwear warranty.
with a very cupped set of Michelin run flats. They were totally shot so there is no comparisn. The X-ones are nearly silent running though. I have the 225/60/16's the only problem is the T-rating which means I'll never know what she'll run wide open.
I had the original OEM Dunlop SP5000s that were causing a vibration despite balancing. Yes, I do find the Michelins quieter and better riding. I drove only 800 miles on the new set though, before putting on a set of Michelin Pilot Alpins for the winter. I can't wait to go back to the MXV4s in the spring.
gee35coupe: I am not sure putting on T-rated tires is a good idea. Even if you do not run over 112 mph, there are a number of other factors, including design parameters for the suspension, not to mention possible legal issues if you burst a tire on the highway. Please be careful!
supensionwise. They are the right size. i just can't run it up to 150 mph. As long as I know what I am getting myelf into there's no problem. I think I'm probably in more danger having the OEM shocks still on a 120,000 mile LS400.
There's much more to tires than the size. Speed ratings are based on heat buildup and distortions in the tire carcass during sustained high speed running. The sidewall compliance is also different, as is the flex rate during cornering for different speed ratings, all of which is taken into account by the engineers when designing a suspension. You can check Michelin's website, plus several other manufacturer's sites where they explain why it is important to maintain the original speed rating or better for a car's repaclement tires. If you feel okay ignoring this, by all means!
I would agree with you that the shocks might need some attention by that mileage.
Hey, it's your car and I fully respect your right to put whatever tires you want on it.
I mean the circumference of different brands of the same size can be different. So is the construction of the tires. There are several different wear rating and traction setting of the same size and rating.
So if you want to take it to an extreme you can say don't put any tires on a car other than the OEM model. Or don't upgrade a size or two. What will those folks buying 22" rims say to that?
Just the speed rating will have negligible effect compared to Eibach springs and set of 255/30/20's.
All I was trying to say was that there are several variables. Please note that what I said applies to UPgrades, that is meeting or EXCEEDING OEM specs, not DOWNgrades with specifications INFERIOR to OEM.
And of course, I continue to fully respect your right to do whatever you want to do!
My wife wanted a different driving experience, after four years of trouble free rx300 driving Her first thought was a bmw 325 convert. While in showroom I checked out 7 model. One thing I liked over ls430(my car) was the auto trunk closer. You press a button on underside of trunk door and it closes. Outside styling is subjective. The inside had a quality feel to it.Next to Mercedes, and 320clk conv. She had a respectful salesman and the car is quiter with a much more padded and thicker top. Mercedes has always had a super conv. top. That is what she got. Mercedes is trying to catch up to Lexus, in the niceness department , and if my observations are right they are doing well. I want to give the rx to my daughter, and because of small children , I asked about disconnecting the front pax airbag. Against the law. I think they should have a switch to de activate bag, but maybe that would cut a new or used car sale . Poor dealer. The speal is to get a car for every need. I at one time had a truck with the switch. Answer is there is no other place for child so that is ok for truck.. I remember hearing about a seat that did not activate a bag un less there was a certain amount of weight. Does anyone remember that? It is sort of frustrating with all the new changes. Tony
I recently got new polarized sunglasses, and to my disappointment find that they block the light from the nav screen. If I turn my head to the left about 45 degrees, I can see the nav fine; if I turn 45 degrees to the right, the nav display looks totally black. Do any of you know if there is something in the nav system that can be changed to solve this problem? Or do I have to get non-polarized sunglasses?
When purchasing tires, there are several considerations: 1. Speed rating (T,H,W) doesn't just apply to the speed limit of the tires, it also indicates the amount of traction, performance and cornering ability. Normally the higher the speed rating the better the traction and performance capibilties. 2. Different tires in the same size can have different over-all diameters, e.g., both the 16" and 17' OE tires have a diameter of 26.7' with 780 RPM, whereas the Michelin Pilot Sport W has a 27.1" diameter with 764 RPM revoluyions per mile). Thus the speedomter would show a slower speed than the actual (1 1/2%error) and the computer generated MPG would show lower than actual. Just the opposite direction for the Michelin T with a 790 RPM.
My opinion is to not limit the perfomance ability of the Lexus by getting cheap low performance tires.
Just T-rated. They have separate ratings for traction and load carrying. If anything knowing my tires are T-rated is safer for me since I won't try out the 155 mph top end. Believe me I would.
After being assured by the dealer that Lexus no longer offers tan seat belts...only black for my 92 ls400 I called the Corp customer assurance number. Thanks to the board I mentioned the seat belts are supposed to be guaranteed for life. He has promised to talk to the dealer and get back to me. I have mixed thoughts about black seat belts in a tan interior...and one or a pair. Any thoughts would be appreciated. finclguru
I gave up on polarized lenses cause I couldn't see the LCD screen on our LX470. So, last time I got clip ons I deliberately stayed away from polarization and can see the screen just fine. I was told once that polarized lenses were not a smart thing to use because you can't see the glare of ice on the roadway.
My advice: find the best tire and wheel expert you can in your area. A good one like the legendary Paul Ross at RNJ tires in Pickering ON will work through all the tradeoffs with you, including your own driving style and expectations. Paul put H rated Continental CH95s on my 92 LS400 after he concluded that I would be happy sacrificing some performance for better ride quality and tread life. Fabulous tires, standard on many upscale European sedans and about half the price of comparable Michelins.
BUSY, aren't we?
I'm too willing!
Suggestions????
fredeverhart@comcast.net
Which turanza would be best:
Turanza 225/60-16 LS-H
Turanza 225/60-16 LS-V
Turanza 225/60-16 ER33 (OEM)
Shouldn't that turanza size fit your 17 wheels?
I'm considering buying a new '03 ES 300 -- $35, $39k if I get the ML/Nav option.
Nice car.
But here's my question. I could also buy a used (certified) LS 400, '99 or 2000, low mileage -- for the same price range.
Both probably pretty good options, but any thoughts on which might be the better way to go? Pros and cons?
When I asked my dealer for a list of settings that can be changed by the dealer, I was surprised to learn that no such list exists.
The owner must read through the manual (418 pages) and look for “Ask your Lexus dealer for options” comments.
Here’s a link to a list of settable options:
http://home.attbi.com/~benandmarsha/LS430.htm
Fortunately, the navigation system doesn't require such a list. All options are viewable and settable by the owner.
Also, check out user reviews at tirerack.com.
If you think that, fine, so be it. I will not argue.
However, I think I would choose the Z-rated Kumho, everything else being equal or better.
finclguru
The LS 430 will not top out at 155 mph. It is electronically limited to 131. But that's fast enough for me.
