Mazda MPV: Problems & Solutions
I hope they fix everything.
I've had a vibration at highways speeds since day one (05/31/99). They replaced the tires 6 months ago, which helped somewhat, but it's still not perfect.
My second question concerns the driver's seat:I am concerned about the flatness of it and the lack of lumbar support for long trips. Any comments?
As far as the seats, they are the most comfortable of any car I have ever driven. We went from SF to Tahoe, not a real long trip, but about 3 hours in one sitting, and I was not sore or uncomfortable at all. Others have taken longer trips and have noticed the same.
Hope this helps.
We do understand the limitations. In our case, 90% of our driving is around town, stop and go, less than 40MPH.
TB
The car is vibrating so much that I am afraid that the bolts can become loose. Does nayone have faced the same problem?
Engine - Transmission under certain conditions can get a little busy. At times you may need to rev the engine. Under most driving conditions the engine is quite smooth. I don't see engine strength as a major issue. My only complaint is wanting a little better gas mileage in town. I don't like 15 to 17 mpg.
Take care.
I took it into the Mazda dealer and they machined the rotors, which didn't take care of the problem. The problem is definitely more pronounced when the van is warmed up, or even hot. The only other time I heard this noise was in my fiancee's previous car, a '93 Intrepid. That ended up requiring new tie rods to fix.
Does anybody else hear a low-frequency "beating" while driving with the rear windows down? I'd almost liken the sound to that of a helicopter.
Also, as far as seat comfort goes, we have taken "Maxine" on a number of long trips (God bless that entertainment system) and the seats are perfectly comfortable. That being said, they're no match for the seats in my Solara!
but this is not unusual since my old 1990 nissan axxess (which was actually the 1st van to have rolldown windows on the sliding doors) had the same problem too.
just either crack one of the front windows or moonroof.
Anyone have any issues with their rear defogger? I am not sure if the lines on the back window are working. Anyone have a way of checking?
I think the fan is loud when I am outside the vehicle, but I can't hear when inside. Not really an issue for me. Our heat index has been hitting 100 by 10 am lately, so the AC is ALWAYS on. Not sure what it sounds like with the AC off.
No call yet from the dealer on the "spring selection kit" arriving, but I'll be patient for a while. I do have a very slight pull (no vibration) to the left, and I'm hoping that it's attributable to the lean.
Anyone else have this problem and actually got it fixed. Like I said, we love the vehicle, but these noises are driving us nuts. I appreciate any help or suggestions.
Shannon
Read thru the other subjects there are a few postings that talk about spring adjustments. My 92 & 95 Olds 88 had that problem. A shop tore the rear completely apart and couldn't find the source. Every time we would park it in the garage and get out it would pop. No I am not that heavy either! Maybe Mazda will find the problem soon.
Buh-bye
Just another angle...
TB
- Gary
Cheers,
TB
Not sure about you, but when I put down $25,000 for something, I want it to work correctly...
Thanks for the info. My dealer called today and they are going to replace the inner tie rod ends on Thursday. I suspect this will be the final fix since I got a message from Mazda saying that their quality engineering group knew about the problem. Too bad they didn't pass it on to the dealers before we all had to call them.
This was actually our third run in with quality issues on this vehicle. First was steering wheel covers that rubbed when you turned the wheel creating a loud scraping noise, second was a disintegrating drivers side sun visor (surprised my wife), and last was these noises. I agree that these are all minor, but very annoying.
I also agree with you on the complaining issue. Just an opinion, but Americans accept mediocrity way too often. I'm with you that when you pay this kind of money for a vehicle, you expect it to work and not have weird problems. That's why my wife and I went back to the Japanese after years of American ownership (tainted by Chrysler and Ford, no offense, you can get bad in anything).
Great to hear all the experiences on this forum. This is why we're finally getting our van fixed. I'll post after it's done to let you all know.
Thanks again,
Shannon
Anyone? Bueller? Bueller? ;-)
--Java
and all of a sudden the rpm will go up and almost reach the red zone. is this normal? do you also experience going uphill and the speedometer almost stop at 50 mph and no matter how much you
step on the accelerator, it still stays on 50 mph.
please respond to this. thanks.
That's my thoughts not yours.....
Thanks in advance,
Steve
1) Some vans pull. This seems to be an alignment issue, easily fixed.
2) Some vans lean an inch or so down on the left side. Mazda is said to be issuing a fix
3) MPVs won't do a 10 second quarter mile. Shucks. Get nitros and a small V8 if you want. :-)
4) Looks like some white vans are having a small paint problem, but I haven't seen much of that on the forums.
Am I forgetting anything?
People are comparing manf. dates to try and see if certain issues are more common with the earlier vans. Mine was made in 7/99 and I have had no problems, except my rear brakes glazed, from too much city driving. I have 10k miles now. The 2.5 motor does great at hauling the ven. Don't believe the car mags about a smaller engine.
Problems for the MPV seem minor compared to the Honda van. Lurk there for a while and you'll see horrific problems. The MPV is a great rig, and you'd probably be very happy with one, as most everyone on these forums will attest to.
Helps?
--Java
That and getting used to the tranny shift. They say its smooth but its not when compared to my old 95 Olds 88. That was smooth.
Great van!
Take care.
On another transmission aside - does anyone notice a harsh shifting from 1st to 2nd under light load conditions??
I have noticed an occasional abrupt shift from 1-to-2 when accelerating lightly. Mostly before everything is all warmed up though. It's almost as if the engine revs a bit too high, then goes into 2nd, like it's confused or something. Maybe the tranny wants to be drag-raced? Where's my nitros bottle? j/k
--java
designed for PREVENTION OF unintended acceleration a la audi
BTW, they corrected my pulling problem. Seams much better now. Of course one problem replaces another and I think the front tire has a leak now!
On the other hand, God sent me a message today. My Subaru with 145k on it decided that because I left the ignition on it wouldn't start. I jumped it got a mile down the road and got a flat. No sooner did I get the Flat fixed than the car died again and I had to wait until someone jumped it again. I rarely ever have a problem with my legacy! To my fortune, there was an accident on the way home that could have but didnt involve me, due to the delays!
