I haven't tried the following yet but maybe soon.
Several companies have wireless remote controlled relays, say for fog lights. Maybe one of these could be wired to remotely "open" and close the dvd door and thus avoid the message.
Hopefully they will also correct their web site to prevent misordering in the future.
You can check your version in one of the screens...I think it was the information screen, then push DVD...it will tell you which version you currently have installed.
http://www.lexus.com/assets/navigation_systems/Broadband/lexus_na- v.htm
I'd like to know what radio station is playing (on nav-equipped cars) without having to push the 'audio' button or changing stations using the steering wheel switch. Instead of having two outside temp displays, perhaps one could show the station frequency.
Put louvers in the moonroof inside shade so that you can run with the moonroof tilted open and get ventilation flow through the closed shade louvers and avoid baking the top of your head. My ex-MB had this feature.
Some first observations -
Can't believe they packed so much more into the 05 for only around $1500 more than my '01, and that I have such a large learning curve again with smart key and other features. Love how the car recognizes different drivers by key and will go directly to their settings.
Wheels - Was happy with the 16" wheels on my last LS and wanted 17" on this one because of the ride, tread life and replacement cost issues, but it seems the ML/Nav cars are coming in with 18"s. A $220 option that I wasn't being charged for, but still not what I wanted so I had them swapped off with 17's from another car. Besides the aforementioned factors, the wheels are slightly different in style (5 vs 6 spoke) and finish (a little "chromier" with the 18's while the 17" finish matched my mecury metallic body color perfectly) and I liked the overall look more. The 18's went to a black car, and I think looked better than 17's on it.
Nav - The DVD version was 4.1. I'm not sure this means it has the same data as the 10/10/04 disk upgrade for pre-2004 cars, but the fact the version numbers are the same suggests it.
Since I don't (yet) have an LS with bluetooth-enabled setup, I'll be installing my own workaround in-car hardware for my bluetooth phone/headset. Sort of like I'm in an '04 LS without actually owning one....
They do not yet have software to download the phonebook to the car, so you have to enter the entire number when dialing from the car screen.
The sound quality is rather poor; it seems that they have channeled the phone sound entirely to the one speaker under the driver's side dashboard.
When bluetooth is connected, the phone no longer rings, and neither does the car. You have to notice that the screen suddenly comes up with the phone display, or else you'll miss the call. I usually try to have the radio on, because when a call comes in it pre-empts the sound and so I notice that the radio has suddenly gone quiet, then I check the screen and see that I have a call.
You cannot dial while the car is in motion, except for any numbers that you have in speed-dial (max. 6).
Because of the reduced sidewall (1" less rubber and more metal)the tires are stiffer and ride a little harder. There is a shorter tread life and higher replacement cost. In fact the cars with 18" wheels have a warning decal (RR window) that tires may not last as much as 20K miles, while the 17" wheel cars don't. I'm not an aggressive driver, and have an SC to scratch that itch if necessary. I was happy with the 16" wheels on my 2001, so didn't see any need to jump to 18. For me the decision to go with 17's was also aesthetic. While many feel the 18's look better, I felt the finish on the 17' wheels matched the mercury metallic paint perfectly, while the different style and finish 18's didn't. Probably not an issue for any other exterior color. Sport suspension is a separate item. For 2004 the 18" wheel was only offered with the sport model. One of the few changes for 2005 was to make them available on all versions of the LS. Lexus generally produces cars in a small number of standard configurations that are a mix of packages and individual and options. What I've seen on the ground at my dealer (5th largest worldwide) is the mod luxe cars (a $4980 option with a bunch of stuff including ML/NAV/park assist and other goodies) are all coming in with smart key, 18" wheels and the preferred accessory package also (another $1429).
Bluetooth - Right now there is no Verizon phone that Lexus endorses as being compatible. There endorsement is based on 100% functionality. While the V710 is probably 80% there it still has some compatibility problems. Lexus endorces a website (not sure if it's theirs or a third-party) http://lexus.letstalk.com/brands/lexus-bt/mlh_splash.htm?brandId=- - - 201&cmpId=224&to=3840 to go over compatible phones/plans as well [non-permissible content removed] give detailed instructions for setting up the car and phone (by each phone type). Great resource. I'm on Verizon, so I'm hoping they get their act together soon, but won't buy a new phone until it makes the Lexus list.
http://www.lexus-parts.com/
Bluetooth- I have the Motorola V710. I am not too pleased with the LS430 bluetooth. The sound pick-up, I am told,is TERRIBLE. The microphone is above the head at the garage controls which does not allow a very good pick-up of the voice. I use a plantronics earpiece which has an xlnt microphone. I use the bluetooth connection only if I am calling my voicemail and use the phone buttons while the car is moving!
Floormat purchase - try EBAY! I bought a second set of Lexus factory mats for $50.
My dealer just replaced my Laser with Radar...I had broken the glass in the unit replaced.
In my situation my insurance will pay the $1650..minus the deductable.
If I am wrong I hope wwest will correct me.
-thanks
Thank for the information...that is far more information then I was able to get out of My Lexus dealer. (they tried they just don't know)
Make an appointment with a shop in your area and they should be done while you wait in less than 25 minutes.
I am located in San Diego, CA, so naturally, everything is expensive here
Hope this helps
Great car...wouldnt drive anything else.!!
http://www.llumar.com/na-eng/Automotive/auto.html
http://www.huperoptic.com/consumer_auto.cfm
http://www.formulaone.com/index.html
Good luck
Jerry
Can you guys tell me that maybe some mondo rock hit it and not little rocks. I haven't been using mine on the highway much do to break-in restrictions but I wouldn't like to see a $1700 bill later on.
Sean
I hadn't thought about having insurance pick up the tab to repair it....not a bad idea. I pay over $2K / year to insure the car so I might as well get some value from it.
