-June 2024 Special Lease Deals-
Mazda MPV: Problems & Solutions
I figured that since it wasn't that bad, I would wait to take it in for service when a fix was found.
After reading a previous post about a 2/18 fix date, I decided to call the service center of the dealership (Country Mazda on Long Island, NY)where I purchased it. According to the person I just spoke to, he has never heard of any problem or of any service bulletin coming out. He said that I would need to bring it in.
I guess I will continue to wait and see what happens.
Two weeks and counting I guess.
My mileage has also dropped like a rock. I get about 15 MPG's now where I use to get 20 in the spring, summer, fall. I do NOT warm my car up either! I get in and drive, so no lost gas idling there. Wondering if the mix of gas to more alcohol formula for winter here affects it. I'm thinking of trying Premium just to see what changes. No gas smell of a leak either....
Funny, when I first read the threads about the MPV back in 02 prior to buying my 03, the talk was all about sulfur smells from gas...since the 03's came out, it's now all about tranny problems. Usually, a vehicle get's refined after being out for a couple years, the MPV is reverse logic on that theory...it's worse now than back in 00 and 01!?!?! I don't hear much about the older MPV's having problems other than that dog engine they had.
He did say that the problem seems to affect some areas more than others. He mentioned Cleveland, OH as another city that seemed to have a lot of the problem. Of course, pure randomness tends to create clusters - a perfectly even distribution wouldn't be random.
Steve.
I'm setting up a service next week for our first oil change and will discuss the tranny issue.
Let's hope this is good news.
Steve.
I wish you the best of luck!
Steve.
Scott
I just had to ask.....did I read your last post correctly? Have you really had 3 trannies installed in your MPV? Holy cow, please tell me that can't be true. I just keep getting more and more scared the more I read about the problems everyone has been having with their MPV's!
Sharon
Steve.
Also, I just got an e-mail from my district rep. This is what he wrote:
Scott, I wanted to let you know that the new programming is now available and was tested successfully. Please talk to Shawn about getting an appointment.
Thanks for your patience.
Let's hope this "fixes" the problem once and for all.
bottgers,
The answer to your post is: I don't know...I have a feeling that they will just wait for everyone to go to their service dept. to find out!
Scott
BTW, ours is still doing the hard shift consistently. My 3K mile theory was wrong.
Service manager says the fix appears to be on general release. He has absolutely no idea what was done to the software.
Steve.
Good luck!
It did feel a touch tighter in the 1-2 shift, but that could just be my imagination. No obvious difference elsewhere - let's hope there is one in that the 2-3 bang disappears. One thought that occurs to me is that the transmission will be learning a different "me" this time. I'm driving more aggressively now than I did when I first bought the van.
Dawn, I got it back fast because the dealer and I both agreed it was best for *me* to see whether it was really fixed or not. So they just flashed it, drove it about 20 miles to check nothing dramatic had happened, and let me have it back. (I had a 6 as a loaner too, bright yellow - my 3 year old loved it. I thought performance was OK for a 4 cylinder; the V6 must be a lot of fun. But fitting the 2 car seats was a back-breaker!)
Steve.
My latest theory is that some internal tranny "widget" is sticky under certain conditions, and the software change is geared (if you excuse the pun) toward either masking the condition or somehow "unsticking" it.
I say this because my MPV is running Mobil1 synthetic ATF and seems to have benefited from it. Synthetic fluids are known to help sticky situations such as noisy hydraulic lifters in some engines. Except for one hard shift two days ago, it has run smoothly across the -8 to 40F temp range experienced in that time.
In the meantime, I noticed that when my MPV was in for this problem, they noted on the work order that they "Could Not Duplicate..." it, even though when they kept it over night - the next morning it did the hard shift from 1st to 2nd. They only admitted this verbally. So, I called them on it, and he's supposedly modifying my work order and faxing it to me so I have a paper trail.
I suggest everyone do this so we can "prove" it when it comes time to Lemon them or get the fix, whatever comes first. I'm waiting on the fax.
Do the duratec engines really need the 3k interval pampering to last 100k? Are there any tell-tale signs to look for? Anyone with "iffy lube" issues out there or any insight at all on this would be greatly appreciated. Thanks
On the issue of Gippy Lube, I don't think they do great work. My experience has been that they don't let all the oil drain out before they refill the engine. They also tighten the oil filters way too tight. Also, I had a friend who worked for one of those quick-change places (may have been Gippy Lube) and he seemed to think the quality of oil they use is iffy. That being said, I still doubt that their work will have caused damage to the engine, especially if it was changed every 5000 miles.
Just my opinion.
Incidentally, if I didn't have the problem, I sure wouldn't want my TCM reflashed.
Steve.
Chances are good that the van will run OK until 100K miles.
If you buy the van, you way want to run a good fuel injector cleaner through the system (e.g. Chevron Techron or Valvoline Synthetic).
Thanks, dave.
My guess is that they'll reissue it in the very near future.
Steve.
1. Outside temperature (the colder the worst the mpg)
2. the way a person drives
3. how long you let your car idle
4. type of gas (regular vs.premium)
5. winter gas reformulation (while it is better for the air we breathe, it is not the most efficient for some cars)
6. type of driving (city vs. hwy, bumper to bumper traffic, etc)
7. type of roads - flat vs hilly
I'm sure there are more factors as well. These are just the ones I cam up with off the top of my head.
The best advice I can give you is, the more city driving you do the closer to the city estimate you will be. Even if you did 80% highway traveling at 55 mph the whole time and did 20% city, your avg mpg for that tank of gas would mostly likely be below the sticker estimate for highway. How much below? I don't know. There is no scientific way of determining gas mileage except to drive the vehicle.
For example, when I drive the MPV, I go about 380 km between fillups (~16 mpg). My wife, on the other hand, usually gets to 420-430 in the same driving conditions, giving about 18.5 mpg. If we lived farther from the city and had to commute daily on highways, that could be about 20 mpg and over. If we lived in Toronto and had to sit in traffic jams for hours, that would be lower than 14 mpg. And that's pretty much about the difference.
Seriously, I accidently filled up with premium once (not paying attention - looking at some blonde...). I didn't see any difference in my '01. Gas mileage seemed the same - nothing dramatic took place to warrant the premium cost.
read
http://www.usatoday.com/money/autos/2003-07-30-premiumgas_x.htm
USATODAY may not be the best source of high-quality journalism, but this article quotes a number of chemists and engineers from Honda, GM, Nissan, Toyota, and the FTC. Bottom line: they all say if your car/engine was built to run on regular, it's not worth it to use anything else.
I expect TomJ will chime in shortly with his contrary perspective...
It would actually be interesting to hear from someone who has tried them both in the same vehicle under the same real-life conditions and kept track to find out.
vehicle. 92K miles. I have metal fillings in
a tranmsission filter/oil change. The dealer
says 100K is about right (sounds like a std
answer).
Any one put >100K on a MPV mid 90s tranny?????
How about the engine >>100K miles?
Tell there are some long life MPVs out there.
THANKS
