I suggest you continue to do so.
Ride quality will be different between the 04 and 05 LS models. '05s have a different suspension system. I noticed it when I test drove both model years (used 04 and new 05) and personally preferred the 04 'ride'. The dealer didn't have any with heated seats so I went with a new 05 model.
Have you moved to a different area, with different road materials? That can make a big difference in ride and noise levels.
OBVIOUSLY , NO TO THE ES 350 . KEEP THE LS 430 .
Recently the display format for this page seems to have changed to a bit wider than it used to be. I have my screen set for 1024 x 768 pixels and the page is a little too wide so I always have to scroll it horizontally to be able to see the last few letters on each line. Is there some way that I can change the display format to accommodate 1024 pixel width? It appears like it is set for 1080 pixels wide -- is there such a standard?
Why don't you drop by the Forums Software discussion and post there. Perhaps one of the Forum admin types can help you with this. Scan through the last few pages - you'll see where others had this problem at 800x600 and that the techies fixed that the middle of this month.
I'm sorry, I know how aggravating having to scroll from left to right to read each line on the page is.
Check out the article below. It seems like Ford's got themselves a CEO with some mojo.
http://www.freep.com/apps/pbcs.dll/article?AID=/20060906/BUSINESS01/609060459
increasingly harsh and feel every small bumps and drain covers on the road; feel like it doesn't have shock absorpen and the air suspension is not working properly, I tried to use the normal or sport mode, it doesn't make a difference. Took it to the dealers(2) total 4 times, multiple test drives and inspections, both stated nothing wrong with the suspension system, stated original tires in 85% new without flat spot and no need to change tires per dealer, I had the tires balanced. I seeked assistance from Lexus customer care with phone calls and a letter, all stated nothing wrong with the car and they won't do anything about it, one head mechanic stated the ride quality is poor compared to 05 or above. Tires balance and alignment done recently. Paid $70k for this car, ride was like butter when I bought it, and noticed the change a year later, and now the ES loaner car takes bumps better than my own. Does anyone have the same problem or suggestions? Please advise, thank you. swiftm001
Update: Taken my car to Mission Veijo in S.Cal three times, same complaint with harsh ride, they said "nothing wrong with your car and that just the way the car designed", brushed me off completely. Again, I requested Lexus customer service to intervene; referred me to Tustin Lexus, service tech diagnosed the problem in the first 15 sec of test drive, found strut seal leaks to the right front air suspension system, fixed it and checked all other area. The car now ride like it was new, I reported Lexus of Mission Veijo to the BBB for the shaddy service, which I asked them to open the suspension system to check it three times, they refused. Focus on the strut seal leaks if you have problem with the harsh ride. Swiftm001
Sugar pills come immediately to mind.
"Ultra Luxury Selection (requires Interior Upgrade Package) - $11,320 [2]
- Mark Levinson® [3] 11-speaker 240-watt [4] Premium Audio System
- Lexus voice-activated DVD Navigation System [5] with backup camera [6] and Bluetooth® technology [7]
- Perforated leather seating surfaces
- Dynamic Laser Cruise Control [8]
- Adaptive Variable Air Suspension....."
Your posts are always so informative (if succinct), but this one went over my head:
"Air suspension, strut seal, leaks....
"Sugar pills come immediately to mind."
Are you saying those things are just placebos? What am I missing?
Best regards -- Renny
Did the service tech who fixed the "leak" feed you a sugar pill?
If the wind noise you are experiencing is NOTICEABLE enough to concern you, then there is probably something wrong.
I'd take it to a Lexus dealer for inspection.
One of the greatest benefits of owning this car (for me, at least) is that I can shut out the world around me and drive in peace and quiet. That is, unless my two little toddler "angels" are making a racket in the back seat!!
Don't let this issue go unresolved -- you're missing out on one of the BEST features of this car.
take the car back for a refund . the car has been worked on incorrectly , and you'll never find what's missing . just take it back and get another one . THE CAR SHOULD JUST BE A QUIET WUSH ......
That means that I spent $1000 for the system plus payed for 5 years of service with one year free. This will also devalue my car and I won't get as much for it when I sell it. This ticks me off. Any attorneys out there or is thia a grin and bear it?
Bill
Northwest Indiana - 01 Ultra
It does seem "un-lexus-like" that they'll dump link customers without at least a free service visit or something else as an "I'm sorry" or something.
I'm sure if you write Lexus corporate they'll do something to ease your pain a bit... give it a try!
Not trying to be harsh here - just realistic. I'm not a lawyer but I am well experienced in business law.
The above link provides a run down on Lexus Link and the changes. Their is a "more information" button at the bottom which tells much more about the older model cars with Lexus Link and their fate.
I have only tested the 460 on the "3 mile test drive" so far, but agree totally, the steering is the best I've ever felt.
Any suggestions on what I should do now? For example:
1. Put in some high octane additive? or
2. Put in more premium after every few gallons are used up? or
3. Burn the tank down to empty to get all the regular gas out of the tank, rather than trying to mix it with premium? or
4. Go to the dealer and have them change some engine settings and then burn the whole tank down to empty? or
5. Do nothing?
