Visitor Agreement.
Hopefully I'll have time to call in the am and update everyone waiting on the news.
We are not holding our breaths right now though after hearing that danog's started doing it again. How many miles did you put on it when it started again, danog?
I dropped it off this morning and was able to read the bulletin from Mazda but wasn't allowed to get a copy, yet.
It listed the procedure of re programming the tranny. I wasn't able to commit to memory every step but I did recall part of the procedure after the flash was performed.
It mentions allowing the tranny to shift at least 6 times under light, medium and heavy exceleration along with a few other steps. Anyone have any idea why the tranny has to "learn" the shift pattern? If properly controlled the software should already know when to shift.
They called and told me that it definitely has a problem even after performing the update again and will be supplying a rental until they have discussed the matter with Mazda.
He also told me that he "thinks" this re program was only a temporary fix anyway and that Mazda would most likely have a major fix where the TCM is replaced. This should exactly like the Acura TL debacle we went through 6 months ago.
I'm calling Mazda to discuss this issue directly with them maybe it'll let them know their credibility will take a hit just like Honda/Acura did with the tranny issues.
And for those who always post that users in forums only post to whine about problems, what would others do when major corporations don't inform their customers about widley known problems? I'll be glad to post good information when it becomes available but at the moment this is all I will be posting!
So there you go, the bad news. Hopefully it'll be just our van and those of you who have had the service will continue to enjoy trouble free ownership as your supposed to.
Make sure your documentation is in order.
Dano
I have always used Shell gas - and Mobile 1.
It's too early to change the plugs since the recommendation for platinum factory plugs is to change at 100K.
What could be causing this ?
Does anyone experience or has experienced the same problem?
What is the probable cause of this ?
The reason why I ask is that it could be one of the cooling fans on the radiator could be out of balance. The vibration can then be felt in the cabin. But, since it is thermostatically controlled, it cycles on and off. It is most pronounced in the conditions you mentioned since that is when the fan(s) normally come on...
RBB
The idling is very rough ... almost shuddering but the drop in RPM in the tach is small --- but is still present.
So I dont think this is the fan.
This happens regardless if the engine is warmed up or cold. The engine is OK if in the Drive position so right now, I keep it at D for the most part.
Do auto-parts store check the computer codes?
I never thought Kraggen does this... do they charge for this ?
Is this something that is covered by Mazda under their warranty program (van is still very much under 3 years and 50,000 miles) ?
Is this normal ?
Should I be worried ?
I am bringing my MPV for warranty check up due to the very rough idling at N or Park (almost a shuddering). I think it's the air valve or something similar - as I am not sure of what to call this part.
I don't know if the tranny codes get read somewhere else than the OBDII connection though?
The official word from the service person is that the code they used over three weeks ago given to them by Mazda was the incorrect version. Since I did not get anything stating the actual version I cannot compare the two updates which really frustrates me to no end. I did speak with the Service manager and was able to get a fax with all but steps 1-10 on how the re program is performed. It does list the road test procedure and offers a explanation on the adaptive learning process.
A call to Mazda will follow to open dialogue with them on a warranty extension as well as their official explanation as to dealers not getting the correct information in a timely manner.
Only time will tell if this service proved beneficial and I'll keep posting any updates as they are available.
Steve.
Mazda told me today that the latest update was made available on 1/26/04 and my service was on 1/24/04 which can only mean the service department didn't contact Mazda as they should and said they did. There was no record of contact around that time frame.
I'm a techie and I never get the luxury of making these mistakes. It really shows how a break in communication can exacerbate a problem.
So this gets curiouser and curiouser.
Steve.
I checked the paperwork for both service visits and the tranny section list the exact same description even with the same tech performing the work. The only thing I don't have, and this is subject to misinformation, is the version information from the first re program. I do have the second, hand written on the document listing steps 11-14 of the procedure.
Does anyone else have any information listed on the service record or otherwise we might be able to cross reference for verification? Check your service receipt and see if it lists Update TSB 05/011/02 to Update TCM. The first lists the TSB as 05-011/02 and is the only difference that I show.
It seems not enough air is getting into the chamber - thus the rough idling at Park, N --- and in some cases during Drive not unless I step on the gas.
I should get my MPV by tomorrow - they said it will only take 2 1/2 hours to replace the part. I did get a loaner from the rental car agency ... unfortunately, I did not get a Mazda3 --- all they had were Hyundais and Dodge Neons.
Thinking about buying an extended warranty now ... I think I will go for one that covers the transmission - although my shifting is butter smooth right now.
XX431XRX SB 05-011/02 MIL AND O/D OFF OR DTC
P0757
20 WMO
Which seems to match your first reflash. But the numbers on your reflashes are really the same, aren't they? It's just the formatting that changes. You'd think if Mazda had come out with a second version of the fix that they'd change the bulletin number.
Me, I'm just gonna wait and see what happens.
Steve.
Yeah, when I look at the "old" NOTICE No: MT000003925 which describes the 2-3 flare, it tells the dealer to use 05-011/02 for TCM re-flash *procedure*.
So the key is to know which code got used and that info doesn't seem to be available.
Steve.
XX431XRX 6X/9W .7 PNMC AJ51-18-9E1 TYPE A
XX474XRX 64/94 .50 PNMC FP01-19-444 QTY 0
REFLASH PCM AND ADJUST RANGE SENSOR
Some of the numbers you were mentioning are there, but what's the PCM and what's with the range sensor adjustment? My reflash was performed on 2/02/04. Is this the old or new reflash or does anybody know?
Same goes for the other work order (TSB 05-011/02R).
Warranty Type: A
Symptom Code: 26
Damage Code: 9J
Part number Main Cause: AJ51-18-9E1* (the star denotes the calibration letter BEFORE reflash.
(ie letter on TCM J, K, M, etc) see above
Quantity: 0
Operation Number/Labor hours: XX531XRX/0.7hrs
The service manager hand wrote this file name that was used, FHEAF46.XHO. If anyone can get the file version or name from the servicing dealer we could check them against each other.
Fingers are crossed; my fix was on 2/6.
I think the job is remove the TCM under passenger side dash & downloading a new program.
That's what I saw from www.Mazdaworld.org forum
Good Luck
I posted the Mazda TSB link but Edmunds kicked it off saying "..you can't post links per agreement when you signed up".
Huh?? Steve?
Chat Reminder
Mazda chat starts in about 2.5 hours. Link's on the left.
It doesn't seem to me that disallowing access to valid and complete information serves the best interest of Edmunds users.
Alldata has full text and lots of libraries subscribe to the service (mine does). Most dealers will give you a copy if you ask the service manager nicely.
For those not familiar with TSBs, it's considered a better practice not to demand that your dealer to perform a TSB, but just describe the problem:
You, Your Vehicle and the Technical Service Bulletin
Even now, several years later they list only 37 TSBs for 2000 MPV even though there are at least 65... That's definitely not the service I would suggest anyone to subscribe to...
