Visitor Agreement.
Liven up your evening and join your fellow enthusiasts every Tuesday from 6-7pm PT/9-10pm ET for our Mazda Mania Chat!
We'll be testing your knowledge with some automotive trivia questions as well, so be prepared! Hope to see YOU there on Tuesday!
Mazda Mania Chat Room
PF Flyer
-Brian
Will report again after another 500 - 600 miles. Below is the description on svc slip. Svc rep didn't say a word of 'cannot duplicate'.
CONCERN : Customer reports transmission sometimes has hard upshifts.
CAUSE : Internal Fault.
CORRECTION 1: Reprogram TCM (Hour 0.7)
CORRECTION 2: Reprogram PCM per Mazda Cust Assist. (Hour 0.7)
rumor24, I updated my profile to include my email address. Thanks for the information and I will discuss the matter with the Dealer. Sounds like you found a good one and I imagine they are respected in your area.
Now, my gas peddle sticks when I first press down on it...causing harsh take off to get past the sticky point. Called dealer and they will clean the linkage to the throttle body. I had a similar situation with my old DC. Is this common with anyone else here? Mine has 22K on it and the dealer said it's NORMAL.
We'll be testing your knowledge with some Mazda-related trivia questions this week, so be prepared! Hope to see YOU there on Tuesday!
PF Flyer
Not sure how that relates to a sticky throttle linkage on the MPV but it's probably similar. I suspect it's easy enough to fix d-i-y and save the dealer expense. Try a Discussion Search in here.
I picked up a new air filter today. With about 10K miles now and living in a very dry climate (it's very dusty here), I figured it was time to change the filter. It's obvious these vehicles aren't designed for ease of maintenance for DIY's. Just changing an air filter shouldn't be a 30 minute job, but it is.
Considering my air filter needed replacing, I figured it might also be time to replace (or at least check) my cabin air filter. First I decided to find a replacement. Apparently, these filters can only be obtained from the dealer because I haven't been able to find any of the filter companies (such as Fram or Puralator) that make them. This is nuts! I wonder why none of these companies make these filters?
I'll see if I can find that link....
Edit: Looks like one is in the pipeline but not available yet for '00 to '04 models: (link)
A Mazda rep called to say that Mazda has come up with modified catalytic converters that they will install in smelly MPV's - free. Then my dealer called to say that they are waiting on the parts and they'll do the work. Yea! Good-bye smell!
b
Recently the check engine light (CEL) came on for the first time in our 2000 mpv. Seems to be driving fine in every way. Tried the usual fixes (gas cap, oil cap) to no avail. We live far from the dealer and I was wondering if there is a way to retrieve the codes from the computer to tell use what is wrong? I have done this before in my other car, a Honda, and it was simply a matter of shorting the two prongs on the service ports with a wire, and then counting how many times the CEL blinks and looking up the code... Anybody done this for the MPV? I would like to check this out without the long drive unless it proves major.
OBDII does not allow for a reset like you use to do by shorting a couple of wires. You either reset it via the battery or via an interface into the OBDII computer, something like http://OBD-2.com or what AutoZone (or similar) has.
Also, typically the CE light doesn't just go away quickly. It usually takes 3 or 4 driving cycles or even a couple of days before the CE light *may* go off, only if the condition that triggered it is ok. So, even a gas cap not being tight may keep the CE light on for a few days.
Lastly, if the CE light is blinking, that indicates a misfire in the engine. Do not drive it if this is the case. If it's just on steady, then it's an emission issue (gas cap, vacuum, etc.) and can be driven usually if driveability isn't noticeably affected.
-Brian
Help! Can somebody please point me to the right spot? I've been doing my own maintenence for years and have never had this happen before (course this could be due to lack of sllep courtesy of a 5-week old baby).
-Brian
and he said yes I have heard of the hard shift and that he had the download. So thanks again everyone. Youdirtyrat.
I seem to remember someone having this problem a long-long time ago, so you might want to search the archives. If I remember correctly it had something to do with the rear A/C unit. Is the moisture more on the passenger side than on the driver side? That's where the rear air equipment is.
I am looking for a shop or service manual for DIY stuff for my 00 MPV... does a haynes or chilton manual exist for this car? I cannot seem to find one. Anybody have any ideas on this, help appreciated.
Lately, 6 months or so, it is very harsh on bumps.....even on small ones. I checked air pressure & it is correct. I have no idea...why it is so harsh on bumps. On the other hand, my Outback feels so soft on ups & downs
Pls let me know if you experience the same thing.
Leather seats have no cushioning & it hurts....
Pls help me if you have faced the same issue.
I must say it was a bad buy & will never look at Mazda again.
Even though the car felt peppy and light, it didn't ride smoothly over the bricks. I also own a Subaru Outback and the rode over the same road and it was much smoother.
It's also a shame the MPV isn't just a bit wider and longer. My husband and I felt cramped in the front set and we are average in height and weight.
Oddy/Sienna is a much better Van.
Or wait for the Subaru 7-seater coming up soon
You basically test drove a wrong car. You should try out the Sienna, Odessey or the new Quest for wider and longer. They are long enough barely can fit into garage. MPV is the shortest minivan in market.
Bumpy Ride
As for the bumpy ride, Mazda names the MPV as SPORT-WAGON. The sport suspension is firm for better handling performance. The ride is personal taste. Some like the soft ride of Town car while some like the firm ride of BMW (for stick to the corner, min. body lean).
I'd switch to a different tire guage to double check the pressure if the pressure is right and the ride is not right. There may be other factors to affect the ride like shock leaking.
Our conclusion? While the Honda was bigger, it was much more difficult to manuever in the parking lot, and it was not equipped as nicely, for several thousand more dollars. The ride? The Honda was not softer over bumps, but handled terribly. Lots of leaning and swaying in turns. Basically, we felt the Honda handled more like some sort of sloppy, soft-suspended truck, while the MPV handles and rides much more like a car.
One thing you MUST do before you purchase a vehicle is to take it for a VERY LONG test drive to make sure you are going to be happy with it. Drive on as many bumpy and curvy roads as you can find.
Ride and seat comfort are very personal items on any vehicle. I personally find lots of Toyota seats to be uncomfortable.
Sorry you don't like your MPV. We absolutely love ours. It is the perfect size for us, and we don't feel cramped at all. Both of us are six feet tall. I totally disagree that the Ody/Sienna are better vans. Different, but not better. You made a mistake. That's too bad. Your mistake does not make the MPV a bad vehicle, just one that you are not happy with.
I'll do the air pressure or go to the dealer
In the car buying, this means I test drive vehicles several times and not just short rides. Back in 1988 before I purchased my Chevy Nova, I rented one from a car rental agency several times before I made my decision.
In my opinion, of the Honda, Nissan, Dodge, Mazda and Toyota vans, the best handling and driving was the Nissan Quest. It was a smooth ride and did everything with ease. The only thing that I thing would be difficult would be parallel parking since it's the longest van out there.
I live in Western PA where we pay high taxes and have the worst roads in the country and I can say driving a MPV you feel the bumps and wonder if something is going to fall off the van.
