For the past year, I have had idle and starting problems with my '97. First it started to be really hard to start after warming up, then irregular idle, slow then high. Took it to a dealer and after $1500 worth of parts and labor: idle air control valve, mass air flow sensor, throttle body, vacuum lines, egr valve and no improvement, I bought a Haynes manual and read the trouble shooting section. It suggested to test the cool temperature sensor. I replaced it and it has run like a top since. Cost a whole $36.00 at auto zone. Apparently, it was telling the computer the engine was cold and enrichening the fuel which would flood the engine because the engine was hot from running. As a mechanic (my dad) once told me, always start with the cheapest and easiest first. Wonder why the dealer didn't? Anyway it is fixed!!!
I have a Diamante 01 LS with 56525 miles and I went to do the oil change. The guy suggest me to change the transmission oil as mantenance. The car is running great no problems at all. I dont want to change someting thats its working fine and then have to take the car to fix the transmission.I just want to make sure what to do? Please help.
to tell u the truth,i just picked this host bcause i didnt know or see where to start? i have a 1994 mistubishi diamante sedan,sohc v6,tranny problems. when jacked up it will go into all gears,i put pressure on lead tire it will act like it is slipping. is there a solenoid or some kind of device that will keep the gaers engaged.i posted the same thing yesterday but dont know if i did it right. any advice would be helpful.
You are doing it right, but no one has responded to you yet. You might try posting in the Technical Questions discussion. That's not Diamante specific, but there are some very knowledgeable people hanging out there who may not see your question here.
I haven't seen vivona around in quite some time. If no one here can help you, you also might want to post in the discussion I linked in the post just before this one.
I just bought a 2000 with 113,000 miles on it. It runs great!! It has always had premium fuel since day 1. If I put regular in what affect will it have? Will it decrease the gas mileage? Will the performance suffer? Will it ping?
Depends on what Mitsu mandates. Is premium fuel "required" or "recommended"? If the expensive stuff is simply recommended, then, by switching to regular grade, you will experience slightly less performance and it may ping a little under hard acceleration. Not sure about the mileage though. Seems like it would take a little bit of hit too. Hope this helps.
I have this issue where my plugs are flooding and i had it at a dealership for a whole day and they said they checked everything out and cannot figure out what's wrong with it. It has started a little rough since the dealership replaced the plugs the first time but after it starts, it runs fine no rough idling. I am using this as a "last-ditch-effort" to see if you guys might have any ideas of what the problem might be. If so please get back with me ASAP. I have spent over $600 to get this "fixed" but it still isn't obviously. So, please help!!
i own a 98 diamante and love it. i cant get into my trunk(key and button on driver door wont let me) the back seat doesn't come down either. how do i get into the trunk?
I own a 2000 Diamante with a power sunroof. My son and friends did some hanging out of the opening and eversince I have had problems with the sunroof closing. I played with it some and now it slides smoothly and the front of the glass rubber seal slides all the way to the front but the back of the glass will not pop up into a sealed position. The back of the glass hangs down and allows the wind and rain to blow straight in. I would guess the sliding track belts have slipped a few kogs and it just needs to be re-set. Does anyone have a schematic of the assembly of the power sunroof or have any ideas? I would try to tackle disassembly and /or removal if I had some guideance on it. Thanks.
The mechanic also said that he has seen many of these cracked heater coils, & that Mitsu. Should/Might issue a Recall on them & if they did I would be issued a refund!! Boy I hope that happens
Just took my 03 into a mechanic because my 03 was fogging horribly & the defogger wouldn't defog the windshield nearly at all, also the car was registering all the way to the max on hot, so I put a whole bottle of 50/50 Prestone into the radiator . I did this about 2 times as it seemed to work, keeping the cool level down for a few weeks, but when I turned the defreodt on high, I noticed that there would be some kind of Fog coming from under the passenger side dash.
Someone recommended to me that it was my Heater(ing) core. Does that sound right to anyone else.
The carshop mechanic just called & verified that it was cracked & they would have to pull out the entire dash & also put in 2 new drive belts, total bill @ $1,900.
I only have @62,000 miles on my '03. I just however got in a wreck in Dec. & I remember that the radiator was smashed up into the engine.
Also would this all have to do with the excess fogging, or would the new windshield I had installed be the more likely villain??
Wow. You've got a lot going on with that car. Here's the link for recall info Office of Defects Investigations So is the cooling system leaking? Cracked hose or radiator, maybe. I assume that the radiator was replaced/repaired after the accident. Good luck.
I am having extreme difficulty finding a mechanic in the mountains that is able to work on my 2001. I have two problems. 1) After reading a blog I do believe the front rotors are warped after over torquing and the fact the mechanic turned the rotors instead of replacing them. I am experiencing an extreme amount of vibration in the front end when braking. Also there is a lot of road noise when traveling at speeds from 30 and up. The noise sounds like something out of balance. The tires are new and I replaced a wheel that was warped. Any suggestions will be greatly appreciated
2) The heat in the car has a sweet heavy odor and does not work that well at all. When the defrost is on the front windshield just fogs up. The air condition does not get cold and the two front vent do not dispense any air. I have been told that it might be a faulty heat exchange and was wanting suggestions with typical expense comparisons.
I have had this since 2001 and bought it with 10,000. I now have right at 100,000 and just want to get it back to were it was a comfortable ride. Thanks for any suggestions.
your mechanic should b able 2 return rotors w/out any extra charge,also make sure he freeed up the slides on your calipers this will also cause brakes 2 stick creating a constant pressure on rotors which will also cause them too warp right away,havw him use a torque stick or torque wrench when putting your rims back on.on your heating smell sounds like your heater core is leaking,common problem on your particular year.have system pressure checked(cooling system).
Hopefully you have solved the problem, but in case you haven't. I would check the windshield if you had it replace. Usually there will be a small leak. The way to check for it is to turn up the radio inside, shut all the doors and windows and take a short piece of garden hose, put one end by your ear and go around the windshield frame. Where the sound gets louder is where you have a leak, Have the company thar installed your windshield re-seal it and that should eliminate the fogging. Hope this helps.
I have a 1999 Diamante doing exactly what was described in Stemog's posting a couple of years ago. Do you think the parts are the same for mine (1999)? If so can you post the OEM part numbers you changed, so I can get this problem taken care of real soon. Thanks.
I have a 2002 VRX with 38K, which I bought two and a half years ago, when it had only 6k on it-it had been sitting in dealerships and auctions for awhile. Only issue is constant wind noise from rear drivers window. Window rolls up properly and rubber looks good. Cannot figure out how to stop noise. Tried a couple of auto part places to see if I can get something to seal it better, to no avail. Any ideas?
Car is great, only issue has been some brake grinding when cold. Gas mileage on recent trip was 29 and I get 19-20 in city. Only wish is that ride was a little softer. Had a 2001 LS that was totaled prior to this one.
I just purchased a 2000 Diamante. I love the car, but it came without an owners manual. I was wondering if anyone knew of a way to get the owners manual in order to keep up with all scheduled maintenance.
I'm worried because i dont have the car's maintenance records and i want to head off any problems i may have in the future or fix what may have not been done.
I just purchased a 03 Diamante. I already have a 97 and love it. The 03 didn't have an owners manual with it. There is a toggle switch on the dash with TCL on it. Can anyone tell me what this switch is for?
I had the same problem with a 2002 Diamante LS - I bought it new and within 3 months a rock went through the window. Window was replaced with new rubber wind noise was very loud at highway speed- rubber was replaced. Finally after a real window professional noted that adjustment that tilt window are minimal and window needs to be set in perfectly as this is a frameless window. Also there has been defective factory replacement windows.
Yours might have had a replacement window while setting at the lot Good luck p
My '97 is supposed to use 'premium' gas. Snce the price of fuel has skyrocketed I have been using 'regular' gas. This works fine. There is no pinging since the 'knock sensor' sets the ignition to not allow this. I have run the D at the local 1/8 mile dragstrip with 'regular' gas: 70.05 MPH. After using 'premium' for several weeks (to allow the computer to reset) I ran again: 70.17 MPH!! It's OK to use 'regular', just slight loss of power!!
Just bought and '02 with 28K! Love this car. It's my second Diamonte. When I go over speed bumps or other large bumps, the front end squeaks. Anyone know what causes this and / or how to fix it?
My Diamonte is a red LS with power everything. Love the torque! 60 to 90 takes about 3 seconds and pushes you back in the seat! Fabulous!
Help with the front end issue is much appreciated.
My check engine light indicates there's a problem with my O2 sensor. I was told that instead of first replacing that, I could install a Motor Vac, which might solve the problem without the large expense. Does this sound right?
For the most part my '02 Diamante LS has been very reliable. Recently however when there is a tight left hand turn on the highway my car feels like is beginning to swerve out of control. It never actually swerves but it feels like it could. Right hand turns feel completely normal so I thought it might be a bad tire. I had the tires rotated but it feels exactly the same. If anybody has any thoughts or ideas I'd sure appreciate the help.... Thanks!
my diamante it will crank but not start then out the blue 4 to 5 days later it starts right up and drives fine for a week or so then it just wont start up again
hi, got a weird one. 02 3500 v6. ck eng lt on, code p0153-o2 sensor slow response, bk2, snsr 1. replaced snsr. lt stayed off for a day but came back on.same code. note: appears that bank 2 is in front of car cuz rear bank is toward front of engine. called dealer and they confirmed, bk2 on left side of engine toward front of car. swapped new snsr to bk 1 and drove for a day and lt came back on but now also has code p0133, o2 snsr slow response, bk 1 snsr 1. now what???????
My '97 D has a water leak. It drips from the right rear of the block below the power steering pump area. I have removed the power steering pump mount completely and tried to find where it was originating. Not a thing to be seen! I pulled both front and rear timing belt plastic covers and scrutinized the area behind the belt and around the water pump. I checked around the tube that connects the thermostat housing to the back of the pump. NOTHING!! Is there some softplug down behind the crank pulley, or something? :confuse:
Heya, KevinsDiamante here, the other site wont let me log in anymore, I have had numerous accounts there, I did, in fact, replace the front thrust "O" ring without removing the water inlet. I ground off the top of the bolt (loosened it first) which allowed me to remove the bolt and cover. I replaced the "O" ring and added some non-hardening gasket sealer to the "O" ring landing and then replaced the bolt with a slightly shorter version, walla, one leak down, scads of them to go. cheers, Kevo
I finally broke down and took it apart. Argh, what a job. Took me three days. :sick: The little hole that the water was dripping from leads directly to the water pump. It's there as a drain to keep water pump leaks away from the timing belt!!! The water pump seal had gone bad. Car only has 65000 miles on it. Replaced water pump, timing belt and all the other stuff in there.
Gee, I thought I was the only slow one, it took me 3 days too, but my D made it to 100k before my water pump failed. Now I am dealing with oil leaks on all fronts. Best of luck, Kevo
hey how are u...i know its been almost two years but i was wondering if u still remembered what sensors you changed to fix your problem... thanks a lot
Hi guys! I've got a 2003 Diamante that I need to adjust the headlights on. I found the up & down screw for the low beams and what appears to be a large and small gear to control L & R. But nothing happens when I move the geared wheel. And I don't seem to find any high beam adjustment. Also what bulbs do you recommend for giving the best light output distance? THANKS!! :confuse: :confuse: :confuse:
Hello! I have a 2003 Diamante and I will lock the car walk away and within one hour the anti-theft system will be going off. Then I have to walk all the way out to the car to turn the alarm off. I unlock it and then lock it again, with in the next hour it will go off again. I saw somewhere there was a recall or something posted about this but I just want to know how to fix the thing! I have changed the battery in the clicker, but of course that didn't help! All the windows are up, sunroof closed, trunk and hood down. I just don't get it! It's so embarrassing especially when they announce it over a loud speaker that the alarm is going off! UGH! Any suggestion would be wonderful!!
The little gear on the shaft that you turn to adjust the lights is only pressed on and it loosens and then doesn't drive the mating gear that actually does the adjustment. Simple turn the second gear directly with a long screwdriver.
hi everyone new to the forum. i recently become a diamonte fan . have a lot of issues with this car but the car was free to me so im not complaning(much).my younger brother who has a used car dealership in the mid west sent me the the paper work and keys with a note stating.all i had to do was repo. it from the previous owner who by default, not only has not made one payment sense leaving the lot but left the state. for him (my loving younger brother) its personal.because of the cost to get it back there.from sunny ca.(fresno)it was mine,if i was up to the task. and what timing i had just gottin mine repoed a few days pryor. it was like paying it forward. its really a classy car. but it needs work..now im not a recovery expert, i dont do it for aliving. but hey (what could go wrong).after all i got the keys.unfortunatly i found out on that suggested early morning recovery.but thats a different story.but i will say in my brother note he did mention that the couple, who defaulted on the contract were absalutely angels.boy i wish i had paid attention to that statement a bit more.so thats why im here im in need ofyour help if possible on answers to a few mechanical defects. and i dont mean mine. like when starting the car putting it in reverse it has waay to long of a delay before actually kicking in to gear and after raceing the rpms.to an (awakening) high it moves (oh crap) so slowly? the same result when in that (ah jesus) shift to drive? to describe: its like having that nightmare of a dream were everythings slow motion for you but everyone around you are responding in a normal motion. plus everyone can fly with winged jackets. i hope i described the the symptoms enough to get a response.thanks
I need to replace the number 1 fuel injector on my 99 diamante. When we replaced the distributor cap, the numbers on the cap didn't match the firing order of the cylinders. Which cylinder is number 1? Thanks!
My battery dies in some time while driving. I have bought a new battery, alternator has been checked 2 times. All the fuses have been checked and show OK. The car may be running with no problem for couple of days, but at once it may uncharge the battery and the car would stop. I jumpstart it and it would go for a while and stop again, or may be driving for couple days again. my mechanic is confused...
I had the same exact problem for years with my 97 Diamante, I bought alternator testers, new batteries, spent much time on the net trying to troubleshoot it myself, so, I finally broke down and took it to a dealership who, after days of hunt and peck($$$), found the culprit to be my auto-dimming rear view mirror, they unplugged it and took care of the problem. best of luck, no one seems to know anything about these cars in my area. kevo
I am enjoying every mile in my Diamante. In one year, I must use its sale as a down payment for a truck to tow my RV as a full time traveler.
Adios,
Jerry
Jerry
Thanks for any & all responses.
any leads would b appreciated
jjlex
This is a bit late-
Good luck p
Matt Clark
NOTHING!!
cheers,
Kevo
Best of luck,
Kevo
kevo
