Hyundai Sonata 2005 and earlier
1212224262758
  • astrolastrol Member Posts: 312
    I've had the panels off many times before in my efforts to silence the slight buzzing vibration near the rear armrests when traveling over unsettled road. I know what you mean about the regulator design. It took me awhile to figure it out the first time I saw it in the rear doors.
    Man, I can't wait for T-H-C to come back up again so I can find out the status of my brake rotor claim. The Hyundai Consumer Advocate, Paul911, got back from vacation on the 6th but he can't retrieve his communications until the site comes back up. Jeesh, what gives with that webmaster?
  • prodoprodo Member Posts: 2
    Hi guys,
    I just bought my 2001 sonata GLS. wow it's a really nice car. Smooth driving, good acceleration, nice handling, and quiet inside. Most of all very good PRICE!!
    Actually, I went to a dealer shop to buy a Elantra GT(5-door hatch back) but after I did test drive, I felt sonata is much better car. And amazingly, sonata is even cheaper! For the sticker price, sonata is $2500 more expensive, but there are alot of cash back and rebate in sonata so I could buy $4000 less than sticker price. My car is sonata GLS v6 with mud guard and floor mat and side door protect(?) and the car price is $14300 (sticker price was $18560). I live in chicago, and jacobs twin is very nice. you don't need to waste your time, they just tell you the price. If you like it you get it, if not just don't buy it. In fact, I had a bad experience in Rogers Hyundai dealer shop but jacobs was so nice.
    My first car is 98 Honda accord EX (not v6) but I feel sonata GLS is better car. And it's $8000 cheaper. man this car is amazing.
    Mic
  • waxywaxy Member Posts: 8
    Took delivery 2 weeks back of a 2001 Sonata GLS to replace my 92 Camry which was about to expire. Could not be happier to date with the new car but I have a question (which may not apply to US owners). In Canada, the Sonata GLS comes with a fixed antenna, not the power variety I was used to on the Camry or is standard on the US GLS, I believe. Any advice re putting the car thru automatic (soft) car washes - should I attempt to remove the antenna first or are they flexible enough to survive? Anyone have any experience replacing this type of antenna with a telescoping type?
  • mpgmanmpgman Member Posts: 723
    Well...I have an Elantra GT so I have joined the power window crowd, but given the choice..I'd crank. A failure in power locks I can live with, but I don't want to experience power window failure.
    Your antennae retrofit is not difficult. You will have to run the power lead back to the fuse box or the head unit, if you prefer, as you probably do not have the pre-wiring. More than likely, the fuse box will suffice but you will sacrifice the 'intelligent' antennae non-deployment when CD is active. :>( It will be a simple on-off switching.
    I did it on my '95 base Sonata in about 30 minutes including the wiring. The stereo in that car has no CD, only cassette, so I don't mind the 'lack of intelligence'. :>)
    You might also consider using only touchless washes. Good Luck with your GLS.
  • sonatavasonatava Member Posts: 75
    11 months ago when I got my white pearl GLS, I was lucky to see even 1 Sonata ('99-'00) per day, here in Northern VA. Now it seems like I see at least a dozen per day, and at least 4 the same color as mine. Has anyone else noticed more Sonata's in their neighborhood than a year ago? I kinda liked the idea of having a unique car, as I had seem soooo many Elantras out there.
  • acelinkacelink Member Posts: 106
    I drove my mother's 1999 Hyundai Sonata (V4) to one of Hyundai service centers known as Green Service (A name I presumed to be given to show people how Hyundai is friendly toward the environment) to have the oil changed and have the tires rotated.
    Here is how the service technician treated the car.
    For the oil change:
    First, the technician raced the car to the lift with such a speed and lack of care that resulted in a big whacking sound as the car hit the ramp and caused the car to bob up and down as it become rested on the ramp making me fear of possible front wheel misalignment or something worse. Then he removed the oil filter before the drain plug causing the oil to splatter all over the place. And even as the dirty oil was still oozing out he put the oil filter and the drain plug back on in a flash. He put a new oil and to my amazement, shut the hood without even checking the dipstick. When I got home and checked the oil level, it was well below the minimum level.
    Now about my tire rotation:
    I didn't get one. The technician said the tires are in a good shape that there is no need to rotate the tire. I showed him the service manual which recommends rotating the tires every 7,000 miles (actually 10,000km in metric). To which he replied, "wheel rotation is done when the front tires show more wear than the rear tires on a front wheel drive vehicle such as yours. Why bother doing it, when the front tires are as good as the rear tires? The manual just states formalities." But isn't the point of wheel rotation is to evenly wear out all 4 tires to maintain traction evenly on all 4 tires? Do a tire rotation when the front tires are more worned out than the rear tires?
    I am truly disappointed with technicians for their lack of sincerity concerning customers' cars and their lack of professionalism.
  • tonykrapiltonykrapil Member Posts: 211
    Doesnt it just make you sooooo mad that you do your best to folow recomendations designed for your car and some idiot does not take any of it seriously?
    ALSO, you take good care of your car and the same jerk does more damage in a few seconds than yu have done in 6 months !
    From experience I can tell you I have avoided front wheel drive cars for as long as I could. They have a tendancy to 'cup' the rear tires if not rotated at suggested intervals. When a tire 'cups' it actually starts to have low spots in certain areas and in time, this cupping is sooo bad it will make the tires sound like you are going over rail road ties instead of a smooth road.
    Not saying that what I do is the BEST thing, BUT I rotate my tires at every oil change. I do it all myself. Until I find someone that can drain oil with more care than I do, or can clean all the under carriage parts after an oil change than I do, OR someone that can make sure no oil is spilled anywhere or wiped up if it does happen... until then, I will continue to do it myself.
    One more thing about cupping, once your tires get this disease as I call it, there is no way to undo it other than finding a place that 'trues' tires. A place here in town does it for 25 bucks a tire!!! What a rip.
    Again, you cant rotate them too often.
    Because of a cupping situation I had many years ago, I avoided the FWD cars... only way to avoid this reality is to rotate. I have a 01 Elantra and a 00 Sonata.... so far the tires are great!
    Too bad Mr GoodShaft works in your area too
    Tony
  • satzsatz Member Posts: 15
    When i brought my sonata gls 14 months ago ,mine was absolutely only one in and around boston and i do drive around a lot.As i remember the first sonata i saw was a trip to vermont and that too a v4.Now they r every where .i think hyundai is coming good.It will be strange but i brought the car without seeing it .I drove a test car and loved it so much i payed and saw it on the day i took delivery!!.As i owned a hyundai before there was no question as far as i go on realablity issue.I had a santro(they r not for us market) and this was real nice and ran at 100-120f heat day in and day out for 3yrs i had without any problem .My dad accord engine ceased in the heat and he now drives a suzuki.
    I have a gls with pkg 11 and i am thinnking of a cd changer .My deck has a cdchng button is it possible to add a changer and use this features.
    any ideas help me guys!!
  • annaliseannalise Member Posts: 3
    Hi all, I have just hit the brick wall with my car. I was the most happiest person when I bought my Sonata in May "01" with 48k as of last week the car has 62K. Even though it has run 14k total miles, it has treated me nicely.
    Until as week when I was driving down the highway as I was getting of the ramp the engine just shut off. Being about 55 miles away from home I had it towed to Firestore, long story short...the engine is junk (exact dealers words). Apparently the pistons or rod must have gone bad. Had I known it was a Mitsu engine in there, I would have not bouth it. Lesson to be learned....check Edmunds before you buy. I'll keep everyone posted later on the result. in the mean time the temp is 102 here in Rhode Island.
    Until as week when I was driving down the highway as I was getting of the ramp the engine just shut off. Being about 55 miles away from home I had it towed to Firestore, long story short...the engine is junk (exact dealers words). Apparently the pistons or rod must have gone bad. Had I known it was a Mitsu engine in there, I would have not bought it. Lesson to be learned....check Edmunds before you buy. I'll keep everyone posted later on the result. in the mean time the temp is 102 here in Rhode Island.
    What year is your Sonata? I4 or V6 engine? The new Sonatas are '99+ and do not have Mitsu engines. If it were a new one, you would likely be getting an engine replacement free under 10yr/100K miles drivetrain warranty. How much of it is transferable upon non-family sale I can't recall.
    Did you have a good idea of the previous service history? Without it, used cars are a real crap-shoot.
    Please let us know the details of the repair.
    I believe you will have to use the Hyundai CD changer available through dealerships. This issue was raised some time ago and I believe aftermarket changers were found to be problematic with the Hyundai head unit as controller... possibly a connection/harness issue, I just can't remember.
    Thanks astrol , i am sure this is going be one expensive mod ,the piece 350$ + + dealer installation .wow i am thinking i can get a sunroof which i always wanted and use one of those mp3 players with a car kit.......
    anyway thanks again i thinking of getting the 2002 if i get the 5 speed fully fully loaded -but i heard its going to a shiftronic system --i only wish thet release a 5 spd.This market is like open . if sonata comes with 17" tires , a branded systems, 5 spd -i will bag one for sure.Atleast if the Tib looks good has the above i will get one.Its been 14 great months and i will hate giving this car up when in another couple of months i change for a new manual shift car.
    It looks like we will get a 180Hp 2.7L with 177lb/ft of torque in the new Sonata GLS. This Canadian source also says the tires/wheels grow to 16" with the same series rubber.
    Go here:
    http://www.globeandmail.com/globemegawheels/20010809/hyundai.html
    My dealer doesn't have any yet but expects shipments to arrive in the next two weeks.
  • majorthomechomajorthomecho Member Posts: 1,331
    I had seen the new Sonata at the KC Auto Show back in March, but I saw my first new Sonata actually on the street yesterday when I was in St. Louis. Definitely a departure from the previous Sonata.
  • lagrrrllagrrrl Member Posts: 1
    I've had my GLS 6 cyl for little over a month. Has leather & sunroof. I've enjoyed driving it and think it handles very well. But I'm having some very annoying problems both with the car and Hyundai service here in L.A.
    2 weeks ago airbag light came on. Then, the day before I took it in, the sunroof jammed. If you press the retract button, it retracts fine but when you close it, it then also tilts up when it shouldn't. So it can't be reliably closed. The tilt button would not work at all. When I took it in, they said they fixed the airbag light problem, and to come back when they got a replacement switch for the sunroof in.
    2nd visit: Went in to get the sunroof switch. Waited an hour, then was told the switch didn't fix my sunroof problem. The mechanics don't know how to fix it till they call a special "hotline" and find out. They will call me to come back (again) when they do. Also, there's a possiblity they may have to replace the entire sunroof. Then, when I picked up my car, there was sticky black tar all over the inside of the doors. They were very sorry and cleaned it off.
    Today: The airbag light came on again.
    I have to say I had misgivings about Hyundai but was persuaded to buy it for the great value, the warranty, and the excellent financing. I got a few raised eyebrows from friends and at work (the usual honda/toyota crowd) but was determined to show everyone that I got a quality car. Now I'm having misgivings not only about the car, but that the service department knows what it's doing. If they can't fix a light, diagnose a sunroof problem, and keep my car clean, how do I know they can replace the sunroof correctly and be sure it doesn't leak, screw up the other electricals, etc. I am losing confidence quickly here.
  • sonatafansonatafan Member Posts: 171
    First off, congrats on the GLS Sonata. I'm sorry your'e having problems with your car and the dealership does sound like they are somewhat inept.
    Inexperienced service departments are unfortunatly everywhere and obviously aren't limited to Hyundai. The dealership I bought my Sonata from had serious issues even though they had several "Factory Trained" certificates up on the wall. I had 3 dealers to choose from here in Columbus, OH so I just went to another one which is by far the best I've ever been to.
    One of my first experiences with the horrible service was when my driver's side mirror started sticking. Now, I'm a certified electronics engineer and I think I can tell if it is the switch or the mirror mechanism itself that's bad. The tech looked at it, operated it briefly and said "I'll get a switch on order right away". I said fine and left and never went back. Got the mirror replaced at the other service dept and it now works beautifully.
    Are there any other dealers you can go to in LA? You are absolutely not limited to the one you bought the car from for warranty work. I would get a second opinion from another Hyundai dealership if possible.
    Good luck!
  • hbund216hbund216 Member Posts: 162
    I have a 2000 Accord that initially had several problems. Most people who buy Honda's and Toyota's don't talk about the problems. My co-worker's Accord keeps using up oil. It took several months for all of my car's problems to be come out and get solved. After 8 months the car was perfect. I can imagine how frustrating it must be. Just hang in there.
    Hi Buddy sonata is a nice car.I brought it against all advices from friends.My friends cirlce`s is only camry with a few accords and a odd maxima .I am first and also the one to drive 25k miles a year and the car has held up great.I am a rough driver and i drive my sonata always good .I know the initial reaction ,i brought mine in june 00 and they were unknown then.But everyone who has come in my ride have acknowledged it as a great ride and its unique too.In every party the only one in the parking lot.It been such a hit many have recommended it there friends and we have a few now in my friends cirlce.Its a mechanical thing so things may go wrong but i guess once to fix em and get over the initial problem u will love the car as much as i do.I am thinking of 02 when it comes out as i want TCS/ABS so i will post as soon as i come up with dough.i think coming chrsitmas i am going to gift myself a 2002 sonata with 5 spd and everything loaded onto it.
  • jbsolomonjbsolomon Member Posts: 3
    Just wanted some opinion about the price of the Sonata I just bought. It was a 2000 GL V6 with 10,500 miles, a CD player and alloy rims for $11,000 total with tax and tags. No scratches on the outside and the interior is in good shape. I feel like I got a great deal, but just wanted some other imput from other Sonata owners.
    Sounds like a great buy. See if you can verify whether the recall work was done on the MAF sensor. If not, you may encounter low speed stalling for no apparent reason. It is easily repaired.
    Also, remember the 'at least three clicks' rule on the gas cap or the 'Check Engine' light will activate and/or hard starting episodes can ensue.
    Good Luck with a great car.
  • csandstecsandste Member Posts: 1,866
  • giowagiowa Member Posts: 599
    Sorry about the problem. If it makes you feel any better, my loaded '00 Sonata GLS w/Pkg 13 has run like a top. One burned out headlamp in 23,000 miles. Compare that to my '00 Lincoln LS. Was in the shop about a dozen times in the first 23,000 miles. Paid $18,400 for the Sonata (which I use for business) and $36,500 for the LS. Go figure. But I didn't give up on the LS. She's been running like a top for past 10,000 miles (now has about 34,000).
  • har1bushhar1bush Member Posts: 207
    Sounds like the new Sonata will be worth the wait with that larger V6. However, Hyundai has turned into the self-destructive market strategies of GM and made the Sonata mimick its cousin Optima too closely. Now both will have that Shiftronic tranny, the exact same interior, and with the new Sonata's more attractive looks, the Optima doesn't seem to have any advantage to justify a higher price. I think people should also check out caranddriver.com for the Optima's road test. Most of the article was positive, but they seemed to dislike the structure rigidity of the car. While the Sonata/Optima offer great values, they still seem to lack a bit compared to its competition and that lower price still means you are getting what you paid for.
  • compensatecompensate Member Posts: 212
    I just happened to hear something from the shuttle driver of my local Hyundai dealer when I was having them look at my Elantra GT.
    We were riding shuttle in a 2000 Sonata. As we hit the highway, I began hearing a noise from my door/window (passenger side front door) that sounded like either the door or widow was not quite shut all the way. When I asked, the drive told me that some of the 2000 Sonatas have weak power window motors and need to be replaced under warranty.
    Just wanted to let you know, in case you experience this same problem. Make 'em fix it for free.
    I had my power window motor fall apart about 10 days ago. When it did, the drivers door window fell out of site into the door. We were about 700 miles from home and on tour at Duke University in NC.
    While most folks were enjoying the sites, I had to pull over in the shade and remove the door panel, and other stuff to get to the cables that sprung and got tangled in the mechanisms. The window would not budge one bit.
    After about 45 minutes of unraveling things I was able to free the window and raise it by hand and shim it in place with some cardboard for the long ride home.
    Took it in and Vic, (best Hyundai mechanic in Florida) made it all like new with a new motor.
    This is the FIRST time my 00 base sonata has been in 18 months or 13k miles.
    Works like new now.
    If you hear a noise from the windows when operating them, you may want to bring it in NOW before some happens like it did me.
    IF I had opened the window several hours earlier It would have been a mess as we were driving thru the tropical storm in Florida.
    Tony
    Thanks for the tip about the recall. I will bring it to the dealer to get fixed. I have heard you can order a chrome grill...I was wondering if anyone knew where to get one and if they look good. I was also wondering if acid rain is covered under the warranty. I have a small round spot on my trunk that the dealer said was acid rain, and said that it wasn't covered under the warranty. Other then that, I have put over 2,000 miles on my Sonata in two weeks and I love it.
  • dougndodougndo Member Posts: 136
    Sorry about the problems, LAgrrl. I've had my Sonata GLS Leather (w/ sunroof) for about three months now, and so far, zero problems. I'm not sure what part of LA you're in, but I can tell you of a couple of dealers you might consider for service. Lamar Hyundai at the Cerritos Auto Square has a first class facility and they take very good care of your car. It always comes back clean.
    However, they're a long way from San Pedro where I live, so another choice is Cormier Hyundai in Carson, where I've only had one experience, but it was quick, insightful, and free. My girlfriend's Hyundai Tiburon had the dread "check engine" light come on, and, since we hadn't bothered to read the manual, we thought it intoned major trouble. The first dealer we went to kept the car over night, did who knows what, and returned the car "fixed" with no explanation. Two days later, the light was back on, it was late in the day, and we didn't want the hassle of another overnight delay. We stopped at Cormier because it was close, and even though the service department was closing down, the manager took the time to listen to us and he quickly, correctly diagnosed the problem. He walked over to the car, checked the gas cap, and told us it wasn't put on properly. He took it off, replaced it correctly, and told us the light would go off in a day or two. It did. Now we put the cap on properly. Since he could have blown us off at the end of the day and kept the car overnight, I have to credit him and the dealership for giving us an instant solution and getting us back on the road. How they do on day-to-day service is a question I can't answer (yet).
    I figure acid rain damage should be covered under the body rust warranty (unless there is some exclusion and provided this damage had caused rust).
    I'd check the warranty detail just to see.
  • jsapiejsapie Member Posts: 28
    Hello All:
    Just traded in a 2001 Elantra, Package 2 with Automatic, 10,500 milles on a new 2001 Sonata, Pearl white with Automatic, California emmissions, carpets and mud guards.
    MSRP was 16,476
    I gave them 3600.00 and my Elantra "Out the door".
    I think I did well.
    Does anyone know more about this?
    I'd look closely at the spot to see if it's just etching from bird droppings, which only needs to sit on their a few days before it eats into the surface a little. In the trunk, I carry a sprayer bottle full of plain water and do a quick once over about once a day.
    The rust warranty is an "anti-perforation" warranty, which means any rusted spot has to actually make a hole to be covered.
    Why would acid rain damage, if that's what it actually is, be covered under warranty?
    How is it Hyundai's fault that your car has been exposed to acid rain?
    Paint finish from any manufacturer can be damaged by acid rain and doesn't necessarily denote a manufacturing defect.
    Now if the damage was there when you purchased the car, or if you can provide some kind of proof that it happened on the dealers premises you may be able to get the *dealer* to pay for finish repair.
    Good luck!
    I agree with your point, Sonatafan. But the spot was on the car when I bought it and I asked the dealer and he said that it wasn't covered. I bought my car used, it is a 2000 with 10,500 miles. I'm not complaining...I love my sonata, but I just wanted to know if the dealer was not being honest. Thanks.
    They really need to change the headlights on the 2002 Sonata. I don't think it looks very good. I know there is a Mercedes model and the Chrysler 300M that have similar headlights, but they are more balanced in the look.
    Overall Hyundai has done a fairly reasonable job of putting together all the different looks they swiped from other cars.
    Pardon me if this came up in earlier discussions, but has anyone installed the fog light kit on the '99-'01 Sonata? I see a couple of kits are available, both of which claim OEM status. Is it a daunting task or one which a reasonably skilled hobbiest mechanic can tackle?
    Has anyone changed the oil filter on their 2001 Sonata with the 4 cylinder engine?
    It looks hard to change. I do all my own oil and filter changes but since I just purchased this it looks like the filter is in a tough area.
    Any help out there?
    Go to Sonatafan's site:
    http://www.geocities.com/sonatafan/index.htm
    He was the first to put up very useful pics on his various Sonata installations.
    I have been doing mine for some 18 months now. I recall the first time also thinking it looks quite tough.
    Because I rotate my tires at each oil change I remove the front right tire.
    There is an access panel which comes out with 4 bolts
    This gives you a clear shot of the filter.
    Also take some newspaper or tinfoil and place on suspension parts so oil doesnt get all over them. You may have to do it once without bothering to keep it clean so you can tell which areas need protection.
    I think SonataFan has a picture procedure of this oil change process. Check here http://www.geocities.com/sonatafan/
    Good luck
    Tony
  • protectsecondprotectsecond Member Posts: 13
    Thanks for the info on the fog lights. I can do that.
    One more question, though: how do they work?
    I don't know if anyone else noticed but Edmunds put up the MSRP and invoice for the '02 Sonatas... Looks like the 2.7L V6 is definitely replacing the 2.5L. Plus, the prices are once again nothing short of expectations... A fully loaded LX V6 was less than 21K MSRP.
    Looks like the first shipment in St. Charles County Missouri was a fairly large one. Had a full truckload of cars, didn't spend a lot of time looking at them because it was raining. What's with the three trim levels? Does that replace the leather option. Not sure whether the new car is that much better looking than the '01. It does pull together a family resemblance with the Elantra and XG300(350) though.
  • diploiddiploid Member Posts: 2,286
    was getting a 3.5 liter engine and being renamed the XG350. Right? See posts 669 and 670 in the XG thread.
    Yes, I have read from sources outside this thread that the XG will get a bigger engine and be renamed the XG350.
    The new Sonata also bears a striking resemblance to the Jag family almost as if it were an unclaimed sibling. ; )
