Hyundai Sonata 2005 and earlier
1151618202158
  • giowagiowa Member Posts: 599
    So if the sunroof or leakage damages the car, does the ASC warranty fully cover? Do you void all or part of your Hyundai warranty?
    Did you talk with Nissan before having installed? Have you talked with Nissan since it was installed?
    Aftermarket sunroofs often are more expensive. And you might have warranty issues. If you really want one, why not take the time to find one on a dealer's lot or incoming and just buy that one???
  • sonatavasonatava Member Posts: 75
    davroth-
    I got my GLS in Sept 2000 also, and have noticed that the brakes could be a bit better, but I try to drive defensively as best I can, and am certainly not a "late-braker". I don't have ABS on mine, but maybe those that do have better success.
    sunroof-- As long as it's a decent company that backs up their work, I don't see the problem. A co-worker of mine plans to have an aftermarket sunroof put in on his son's Accent, but has concerns about the roof buckling, etc.
  • stickyfrogstickyfrog Member Posts: 4
    It runs about 50-50 in the argument for or against installation. I've checked the company that will do mine and they have a decent track record. Called another Hyundai dealer and asked about the warranty. He said that as long as the dealership approves the addition then it will be covered. Again, it's a car dealer and who knows if he's telling the truth.
    The way I look at it is that life is short, enjoy the extras that you can afford. Ten years from now I won't give a crap if the roof leaked or not. Ha Ha. Anyway, I'll give you all a report after Thursday when the roof is put in.
    To giowa: I really appreciate your concern. I did look at five dealerships in Northern Florida and three of those checked other dealerships in Georgia and Alabama. No one could locate a 5 speed with Option 2. In fact, it was a task to find a 5 speed at all. I guess our market is full of old fogies that don't have the energy to shift. Ha Ha. Just kidding. Don't want to offend any automatic enthusiasts.
  • justinjustin Member Posts: 1,918
    it was in the car financing.....all over all of the dealer ppw.
    i had no problems at all. the reason i got one added was because at the time in 98, there were NO GXE Altima with ABS and roof. One or the other...but could not locate one anywhere in GXE form with both.
    Definitely get a ASC one though...they are a big company that stands behind their work. They do the drop tops for the Camry/Solara and countless other cars....fairly reputable..
  • andycnkandycnk Member Posts: 3
    Hello! I purchased a 2000 Sonata GLS for my sister last November. Since it was the end of the year, I guess we got a decent deal.
    While she absolutely adores the car, there has been one annoying problem with the car going for a few months now.
    Randomly my sister has to crank the starter for about 4 seconds (no kidding) for the car to start.
    We first thought it was due to the cold weather, but that obviously was not the case.
    I took the car to Fairfax Hyundai (in VA) last month for them to have a look at it. They said they made few minor adjustments on the engine; nevertheless, the car still had the same symptoms.
    I took the car back to the dealership 2 days ago, and I have not heard from them yet. I crank my 96 Toyota only twice before it starts, and although I know very little about cars, I don't believe a new vehicle such as this should have such problems.
    Service manager made it sound like this was not all that uncommon with Sonatas. Has anyone else experienced the same problem?
    -Andrew C.-
  • ramadaramada Member Posts: 27
    I've read of the new 2002 model coming out from the http://www.santafeforum.com What do you think of the new model?
  • astrolastrol Member Posts: 312
    My wifes' GLS is a one twist of the key starter. The only time it didn't was when the fuel line got crystals in it on the coldest day of the year.
    I definitely think 4 secs. is too long to crank.
    If you don't get much in response, try over at
    http://www.t-h-c.org/station-a1
    in the Sonata forum. There is a Hyundai mechanic named Duke who posts there. Enter a post about this to him directly with his name in the title.
    We're all waiting to see if it matches the Korean EF when it gets here. I'm especially interested in the dash/console changeover. It appears the Sonata got a few Optima dress-ups while the Optima got almost the entire Sonata package.
    I put a picture of the interior provided by Yoon (yk911) as wallpaper on the 'puter and the first time my wife saw it she said I was tempting her.
    Then I substituted the exterior shots and she just fell in love. And she is already quite in love with her '00 GLS. Naturally, I had to explain the economics of trading a two year old car.
    Thanks for the info.
    After 3 days of testing, Fairfax Hyundai was finally able to duplicate the problem.
    "Tommy" said my car was "really acting up this morning." Well.. duh! Did he think I made it all up and left the car there for 3 days for nothing?
    They told me they were going to order a fuel pump.
    Does that sound right? (thanks to my ignorance)
    Engine wasn't getting enough gas? Hmm...
    Anyway, I will check out that t-h-c forum.
    Thanks again!
    -Andrew-
    Yes, the fuel pump would have been a logical thing to check with your symptoms. There are only so many things which could be contributory.
    Ask the tech if he found the fuel pressure to be 37 psi @ idle or 46 psi without vacuum hose. These are spec. Sometimes fuel pumps go bad on an intermittent basis and it takes awhile to trace. Several pressure tests might have to be done over a longer period.
  • mietushmietush Member Posts: 7
    Hey guys, I just posted my note 2 weeks ago about my new Sonata GLX dying on me at 2500.Kms because the fuel pump burned out....
    There is a lead here for some of you maybee.
    Please check my note some 2 weeks ago.
    Sorry about the information, it was 1 week ago that I posted my fuel pump failure.
    Cheers
  • patpat Member Posts: 10,421
    mietush's post is here - mietush Apr 16, 2001 4:48am
    Pat
    Sedans and Women's Auto Center Message Boards
    I was mistaken by saying that Hyundai was going to replace the fuel pump. They are ordering an "oil pump" (I guess there are several different kinds of pumps used in cars).
    Tommy in service dept. said something like, "oil pump pressure was too high, which caused ???(don't remeber what he said) valve to open up and engine had no compression built up."
    Basically he was talking over my head (again), but does that make sense to you?
    Anyway, I guess I will have to take the car back to Fairfax Hyundai on Monday to find out. Fortunately, they promised to provide me with a rental this time. (I guess they felt sorry for me after having the car for 3 days)
    I will let everyone know if the replacement oil pump really fixes the starting problem.
    Thanks. ^^
    -Andrew C.-
    could you post the repair description details that they finally do. I have a feeling you'll get a lot of paper on this one. TIA
  • madison1212madison1212 Member Posts: 1
    I have a 2000 GAS Sonata. I have had starting problems 2 times - Appararently due to pumping the gas pedal ONCE before starting, which flooded it????
    At about 25,000 miles started have idle problems, thought it was bad gas. The idle turned into major bucking & almost stalling at stops. After the car spent the day at the garage, where they claim to have found nothing, I took them for a ride and within 5 minutes I was told I needed a NEW TRANSMISSION. While this was being repaired they broke a steering column pin. I love this car, but once the garage has worked on it one problems leads to another. Unfortunately they are the only Hyundai dealership in the area. That makes me think twice when I think of trading in the future.
  • fern4fern4 Member Posts: 2
    I'm picking up my 2001 Sonata (5 speed 4 cyl) this evening. I have option package 2 (single CD and moonroof)
    I was told it has 6 speakers but I can only find 4....Does anyone know if there are really 2 more or the dealer is mistaken? He said that the other 2 are in the top right side of door panel; it just looks like an oval (with no sound coming out???) I paid 15,500 bottom line (tax DMV and all) Did I do OK with the price? I was hounded to get the extended warranty for 859.00 but I didn't think it was necessary. Does anyone think so...I can change my mind when I pick up the car. Thanks so much for your help...
  • jpvwaudijpvwaudi Member Posts: 139
    DO NOT BUY A HYUNDAI. If you go through with your decision, you will be one of the many fools who have thrown their money away on these Korean junksters. These cars depreciate at twice the normal rate. I have never traded a Hyundai, in which the owner had any equity. If you do buy the car, I would definately buy GAP INSURANCE. If you total the car within the term of your loan, the balance will automatically be paid off. Without Gap insurance, you will be given wholesale value for a settlement and will wind up owing a lot of dough. A quick example.....99 Hyundai Elantra GLS, 24500 miles. The guy owed 10 grand and its worth 4...........caveat emptor
    What is an Audi owner and apparently Audi/VW afficianado doing here on a Hyundai site? And you leap in to insult us all and our cars? Nice guy. NOT!
    I would concur, however, that the smart Hyundai buyer plan to own and drive the car for at least 4 years and 50,000 miles, if not more. Don't buy a Hyundai or Kia or Daewoo and intend to trade it in in 2 years or so. You will likely get a heavy depreciation hit.
    Smart buyer negotiates a good deal, goes for the discount financing, and then holds onto it. You pay way less up front in current dollars knowing you may get less back in end in future (i.e., depreciated dollars).
    Current Hyundais, esp. Sonata, Sante Fe, & XG300, are competitive vehicles at great prices! (I'm not a fan of anyone's economy cars, Hyundai, Honda, Ford, or otherwise. My bias.)
    Madison1212,
    You need to RUN to another dealer for service...OR...go to a service shop that does the scheduled maintenance in competition with the dealers. They should specialize in foreign cars, however. I have had great success with this service option and I routinely find a more personal relationship can be formed with the owner/techs. They treat your car with respect because you are usually allowed to wander around or at least use the see-through window.
    Fern4,
    There are at least six speakers. I haven't popped any covers off to see if any of the larger ones are two-way piggy-back but your missing ones are right there in the A-pillar. They are tweeters.
    And you can buy an extended wrap-around(the 10/100K drivetrain)warranty to take your bumper to bumper coverage to the same. Just go on any any search engine and type in Extended warranty.
    Jpvwaudi,
    Thanks for the useless input. The only VW that is worth anything as a car is the Passat. It is still German built. But then you've got that lovely 2/24 to keep you happy. And when 'parts' time comes...oh those lovely German prices! Volkswagen ranks down in the lower half of quality with Hyundai and a lot of others. Get a brain...then come back.
    Giowa,
    Don't take umbrage. These guys are like kids with a new toy. You just have to wait for the batteries to die.
    Does anyone see a problem with my decision in buying a 2001 sonata? see msg #867. Did I pay too much???
    Chill out for a sec. Go to the Edmunds new car site and run the numbers for yourself. You are the only one who knows all the details of your purchase. Find the TMV and compare with all your options and add-ons, if any.
    this seems like an excellent time to change the subject... :-)
    Now that we have moved to our new platform, we no longer have the requirement to stop and restart discussions after the numbers of posts exceed a certain limit. To keep from confusing our newer members down the road, we are going through the discussion list bit by bit and dropping the "part" numbers associated with some of our extended discussions.
    Since this will be the permanent home for discussion of the Sonata, I have removed the "3" from the title of this discussion and altered the archived version to distinguish it from this one.
    Please continue.... but play nice.
    Pat
    $15,500 OTD (out-the-door) I think is a fair price, especially for the option package you mentioned. When I was shopping around, I was willing to pay that much (the most I could afford) for just a Base w/o the option package, but fortunately found another dealership "desperate" for me to buy and ended up getting a GLS w/pkg 10 for the same price, but it cost me in customer service (next time I'll pay a fair price for better treatment).
    GAP insurance-- I only recommend this for anyone financing through the dealership or other institution that charges "simple interest", which gets calculated sort of like sales tax, in that you owe the entire interest even if you pay it off the very next day. My credit union's deal was better, in that the interest is charged more like a credit card, saving me money if I want to pay it off early or the car is totalled. The GAP insurance the dealership offered me was about $500, which amounted to about $20 extra per month, which wasn't worth it for me.
    Resale value: I'm pretty sure most people who shop for a Hyundai know that it's not like a Honda or Toyota in that department.
    Extended Warranty--probably not needed, but some people might prefer it.
    Transmission replacement--- I'd definitely get a second opinion.
    I wasn't trying to insult anybody, just offering some free advice. Most banks won't even finance a used Hyundai or Kia (besides their captive finance banks) because if the buyer defaults on the loan the bank can not recoup the money at auction.
    As for the Gap insurance issue, at least in my state (NJ), there are no pre payment penalties (extra payments reduce the principal.)I'm not familiar with the banking laws elsewhere....
    I went to rotate my tires and the damn wheel won't come off. I don't mean the lug nuts---I mean the wheel! I tried popping off the center cap on the alloy but it is glued into place with some very strong mastic. I thought maybe there's a hidden center nut. What the heck is going on? I feel like such a rookie. This is so weird.
    P.S. I only tried the right rear as my starting point. It was getting dark and I was only using the car jack so I couldn't do much more than feel around from behind.
  • sonatafansonatafan Member Posts: 171
    Sometimes alloy wheels will stick to the hubs when they have been left in place for awhile. What I usually do is take off all the lug nuts and slowly let the jack down some, using the weight of the vehicle to break the bond. Only let the jack down until the rim is free to avoid causing damage to the rest of the suspension.
    tell you not to do that in the dark??? You had me LgOL. Changing your tires in the dark!
    Kind of like people who mow their yards at night and wonder why they look so poorly mowed the next day.
    Sonatafan---
    You shoulda seen me out there with my mallet banging on the back of the tire and inside the wheel on the spokes.. Anything to get some movement. I told my neighbor who was parked beside me working on his car at the time that it seemed like there was a heat bond that had formed. So your suggestion makes perfect sense. I just couldn't find a good pry spot as the alloys are easy to scratch.
    Giowa---
    Now you know I have more sense than to do anything like that in the DARK. I said it was gettin' dark...at least a half hour or so left of light. Just enough time to do the rotation if the damn things had come off! But you should've seen the look on my neighbors face when I started whacking on that tire!
  • wxeyewxeye Member Posts: 9
    I have never purchased a foreign made car until last year when we got my wife a 2000 Elantra, She loved it. We drove it only 10,000 miles before she fell for a 2001 Sonata GLS dark blue with sunroof and leather. We were on the lot when I purchased a new Santa Fe SUV to replace my 1999 Ford Explorer. I have owned Ford's all my life but that Explorer was terrible, recall after recall and lousy ride. The Sonata is a well built car that I believe will last. I know Hyundai made cheap cars in the past but no any more. Those that post negative on this site and on the one about the Santa Fe just don't get it because they don't drive one. Driving is believing and I myself would never have thought that my garage would have two Hyundai's parked in there. They look and drive great. I plan on keeping them for several years so don't worry about the resale value at this point. I appreciate the positive comments from those of you that own a new Hyundai.
    That color (thinking it is DiNapoli Blue) is very, very sharp. Add leather and sunroof, and you have a nicely optioned car. Did you get Pkg 13? With ABS/TC? That's the one to have, if you want to have it all!
  • serpentkiserpentki Member Posts: 20
    Low resale value is a myth. No car dealer will give a decent trade-in for ANYTHING. Do you know where there is a used Sonata, Elantra, or even a Sephia being sold for a bargain price? -SK
    An Optima owner myself, I was curious if the corporate twin, Sonata, has the same trunk hinge struts as the Optima. I hear a number of good comments about Optima's trunk struts but have not heard that mentioned regarding the Sonata. -SK
    I don't know about the 2001, but my 2000 has the crappy load crushing C arms.
    The current EF Sonata in Korea has them from the pics I've seen. Hopefully these will be carried over to the '02 Sonata in the US. It seems there is to be a lot of design sharing between the Sonata and Optima as Hyundai/KIA move to minimize the total number of corporate vehicle platforms down to 8 or so. We can expect to enjoy the benefits of well-engineered, feature-rich designs for many years to come.
    Check out the Edmunds review and pictures of the Optima. Think one shows the non-intrusive multi-link hinges used by the Optima. The '99-'00-'01 Sonatas use the el cheapo space intruding C hinge. All cars should use the non-intrusive hinges!!! Hope the '02 uses 'em.
  • jawabeanjawabean Member Posts: 12
    sonata GLS v6 2000
    1. I have a smell when I turn on airconditioner. sometimes even "smoke". It started last fall. any ideas?
    2. my car pull left. i have to always keep the steering weel. if I release it, it always pulls to left. dealers said that it's different pressure in tires or balancing. but it's not.
  • liljonsonliljonson Member Posts: 109
    it might be your allignment.
    Have you replaced the HVAC filter yet? How many miles on your car? Filter should be replaced around 12K but this flexible. If you live in a high pollen area it could be 9K. Very little dust or pollen you might go to 15K. The 'smoke' you report could be an initial dust blow or the result of icing and thawing of the condensor which will blow light mist into the cabin. If you're handy with tools, go to Sonatafans' site and check out the installation procedures:
    http://members.nbci.com/sonatafan/index.htm
    Also, I agree with liljonson...it sounds like an alignment problem, especially if the left drift/pull is fairly quick. Balancing problem would give off tell-tale vibrations and noises in front end. Inflation difference which causes a quick drift/pull would be fairly obvious and easy to check.
  • john0john0 Member Posts: 17
    I've had this occur on my Lincoln, it's the heater core leaking. Don't do what I did and ignore it because it doesn't get any better. I thought it was smoke from oil on the manifold from having the oil changed. But definitely take it in and have it checked.
  • killerkkillerk Member Posts: 55
    Hi, guys. A quick question regarding Air Filter (not HVAC filter) change. I just picked up the Hyundai filter for $20 (Purolator doesn't carry one for 2000 Sonata) from the dealer.
    I always thought that I was supposed to change the air filters every 6,000 miles but when I read the manual, it recommended changing every 30,000 miles. So I'm a little confused about how often I should be replacing it. BTW, I commute to NYC from NJ. Your expert opinions will be greatly appreciated. Chao.
    I say follow the manual. That includes determining if you drive the car under abnormal conditions (e.g., heavy dust). Even if you only change the air filter at 30,000, you should still have it periodically inspected before that. If the inspection reveals a need to change, then change. Otherwise, save your money and get it changed at the recommended interval.
    thanx for advices.
    1. 13k miles on my Sonata.
    2. "smoke" is white. when I see smoke I smell it. Not every time I smell I see "smoke".
    3. my car pulls left consistently, I wouldn't say too quickly. It was very inconvinient when I drove to Florida. I had always my hands on the weel to keep it straight. dealers couldn't fix it.
    You may have to bite the bullet and take it to a service shop to get a proper alignment. At least a second opinion, maybe from another Hyundai dealer.
    And if you are truly smelling smoke and seeing white puffs sometimes then you have to get it checked out. The heater core may be leaking, as John0 suggested. You should rule out any electrical problems.
  • mtbfmtbf Member Posts: 3
    Have the service shop swap the front tires. If the car still pull left, you need alignment. If it pulls right, one of the front tires has "radial tire pull". Put it back, or toss, or ask some authorized tire dealer for replacement if it has warranty.
  • uttutt Member Posts: 16
    I'm hoping to get a Hyundai Elantra GT when they are released. I wonder if anyone has experience with the Hyundai Service Centers in the Puget Sound (WA) area? A long warranty is great only as long as they treat you properly. I'll be posting this question on all Hyundai model boards, so thanks for bearing with me!
  • r_sonatar_sonata Member Posts: 8
    Been a while since my last post, 2000 Base auto. Black Sonata now has 6063 miles running Great. Wondering if anyone here has had rear brake squeal when coming to a slow while in traffic stop ?
    Local Hyundai Service center cleaned drum brake dust and lightly sanded brake shoes. Still hear squealing sound. Hyundai service center even noticed front brake vibration > removed Rotors > turned them and no more vibration. Brakes work great, Just wondering if other Similar Sonata owners experiencing a brake noise...
  • tonykrapiltonykrapil Member Posts: 211
    I hope to never have to bring this car into the dealer for anything as it is running soo good and without any problems.
    Some of you old timers of this board may recall when my wife told me the window washer didnt work and showed me by pressing the button. I pressed it too and nothing sprayed out.
    I took it in waited an hour and felt like a fool when the guy pulled the lever back to make it spray. I havent used my encyclopdias since we have been married and figured why question the button SHE was pushing now? How could SHE be pressing the wrong button!
    Anyway, my 01 Elantra is doing well too with 5500 miles on it. It went through a period of pulsating and noisey brakes but seems to be fine now.
    Tony
    Nice touch in mail today. Had an envelope with no return address. I had no idea who it was from. I opened it up and inside was a one-year anniversary card from Hyundai. Shows a barefooted man jumping high off the ground. Words on front are "Feeling Free?" Then inside says "Must be the car. Happy One Year Anniversary." Well after about 18,500 miles and absolutely no problems, I am jumping for joy!!!
  • bri70bri70 Member Posts: 147
    that this would be a better link. Hope this is what you meant, astrol. The other link did not work for me.
    http://www.prnewswire.com/comp/424987.html
