Visitor Agreement.
Truckude-
Now I have a problem, though. The clear coat on the roof of the car has started to peel back at several different locations. Each site is about two inches long by about a half inch wide, oriented parallel with the length of the car.
I have maintained this car's finish well. I have used Meguiar's waxes and cleaners frequently. I always hand wash -- no machines (except two or three times a year in the dead of winter). I am careful with the finish in part because the car is generally NOT garaged (though I wish it were).
So, why is this happening? The rest of the paint is fine.
Anyone have any advice? I don't see that there will be any localized fix; I'm mostly interested in a diagnosis and a determination of what help, if any, I can hope for/demand from Toyota on a repaint.
It's a burgundy red, for what that's worth.
Thanks for any help.
Ken
If anyone in SE Michigan, looking for a good Toyota dealer, talk to Larry Cutler at Rinke Toyota. He will give you the no-B.S, straight to the point deal.
Yes Edmunds invoice is the "final" invoice...
Mackabee
MSN Carpoint also has ignition coil as the most frequent problem for camry
This is one in a series of articles on Edmunds.com in a new category "Generations" under Reviews. You can check out other histories here.
Pat
Sedans Message Board
I have linked this discussion into that folder, but it will always reside here in Sedans.
Looking forward to meeting everyone!
KarenS
Owner's Clubs
I have always followed my own maintenance schedule(Toyota Dealerships):
-oil/filter change every 3k when new now about every 4K.
-Spark Plugs/Wires Distributor every 50K
-Timing belt and belts at 60K
-Battery at 5 years needed or not
- Transmission service at 50K Should do more like 30K
-AntiFreeze at 50K
Other than brakes, Tires, thermostat etc.. the only repairs/failures have been (all at Toyota Dealership):
-Water Pump at 90K
-Engine Mounts at 140K
-Front Left ABS sensor at 120K decided not to replace.
-Power Radio Antennae broke at 155K not replaced
-LCD Light on radio 130K not replaced
In the past month I was having a problem with the transmission. It was upshifting great but at sometimes the downshifting or reengaging after coasting it would bounce.
I took it to one Toyota and they didn't even recognize the problem. I then called a long time Toyota mechanic that left the Toyota Dealership near my house for another dealership 30 miles away. He came over my house and said it probably is just age related and that a this paper thin sheet toyota uses to smooth out shifting is probably wearing. But he suggested a power flush just ot make sure.
Well since he is the mechanic I trust I took a day off of work and went to him. He used quarts of transmission fluid, detergent and power flushed it. He did find some brass and chrome type filings but overall the transmission is in great shape.
It now shift like new although there is still a little slippage when reengaging after coasting.
Overall the car has been great. It has its creaks but it is trouble free.
One footnote - I put Michelin Xone's on and the they are great tires. Handling, noise and ride. Wet and dry. Waiting to see how they do in the snow.
I am sure GM 3800 V-6 engine is an excellent engine, but when it sits in soft and floaty (and later on rattely/squeaky) Buick Regal, it is not as good as Toyota's V-6 sitting in a Camry. I get about 29-32 with premuim gas doing about 70-75 on highway. I do use premuim gas all the time, but I have used 87 or 89 octance before. the engine ran fine with no knock. Since the owner's manual says to use premuim, I will use 91-93 Octane gas. I doubt very much the 3800 engine gets better gas mileage than my Camry's V-6 when driven the same way.
I just bought a 92 BMW 325i 5 speed with 87K miles. the difference between Camry V-6 and this car's 2.5L L-6 is like night and day. Both are great cars with totally different ride and handling. Switching between the cars is quite an interesting experience.
In my opinion, 92-96 Camry V-6's are some of the finest cars out there. If you can find a clean one, and it is for sale, grab it.
Mackabee
Good luck on this and let us know what you end up doing. BTW, I had a keyless remote added to my Toyota Tacoma recently from Circuit City for about $165.
Mackabee
I will keep you posted as I find out more!
Mackabee
Thanks for the nice summary of all the noises. I have been driving my 2002 XLE V6 Camry for about 3 weeks now and have noticed the a "tick" sound coming from under the hood only first time I shift in the morning. I also hear the "thud" somewhere in the back, generally when I start moving (after the car has been parked for sometime); but only once during the ride. These two noises did not bother me as I read in the manual that this is suppose to be normal. I am not much of a race driver, but I have noticed delayed shift from second to third speed on ocasions.
On the positive side, I do not get the dashboard noise. The car ride is very soft and I am very happy with the car's performance.
Good luck
To answer your question, I recommend Carsdirect.com. You can configure a car on line and the price is calculated as you change options. The car is delivered through a local dealer (possibly the one who can't figure out how to do it himself).
Take a look at www.carsdirect.com.
Mackabee
~alpha
Toyota has done an outstanding job of making this new Camry. I was disappointed at 97-01 generation, as they were not built as good as the older 92-96 models.
The car felt very solid and roomy. Fit and finish was quite good. The 4 cylinder auto was quiet and smooth even when pushed to 70-75MPH. It did not have get up and go of the V-6, but it was acceptable.
My complaints are: Number#1:gages; The temp and gas gages are too small and are cramped into tach and speedometer. Toyota could have used slightly more spread out design. Number #2: the other problem I feel is the shape of the hood, that has that crease/curve that reminds of previous level Altima. Number#3; Spoiler. I much rather pay Toyota not to put it on! It cheapens the car. No four door sedan needs a spoiler. Spoilers look good on BMW M3's and Porsche 911 Turbo's.
After driving both Altima 2.5S and this 2.4SE, I should say Camry is a better car than Altima. When considering resale value, Altima will never match Camry's reputation in reliability and resale value, no matter how sporty or aggressive looking Altima is.
