Visitor Agreement.
I do not know if I agree with this statement. To my knowledge, the Lexus ES and Camry use similar if not the same, structural design... And the Lexus got 5 stars with the Head Curtain, while the Camry obviously managed only 2. If there is something to be said about the Head Curtain in this instance, more so than the cushioning factor, I think the restraint of motion factor may play a role.
In anycase, I'm wondering if we see NHTSA retest the Camry next year, without Toyota making any improvements, how that will go.... Anyone remember how the Avalon initially got only 3 stars for the driver in the frontal impact? Tested again the following year, with no changes (to my knowledge), the car earned 4 stars. Variences in the test itself and the vehicles can easily change ratings. I even remember one time when the IIHS had to retest a minivan because the impact speed was 40.4 MPH instead of 40, and this didnt give the car a fair shake.... but I digress, and theres no making excuses for 2 stars.
Cliffy, what are your thoughts on this? Is this going to be a problem for the dealers? Do you think it would be worth writing Toyota Motors a letter?
~alpha
I'm afraid it doesn't invalidate my contention that the side curtains add little to the NHTSA front side impact test. Please remember that the ES300 in the NHTSA side impact test was equipped with conventional, front-side air bags meant to protect around the chest (thoracic air bags). Whereas the Camry was not so equipped.
The side curtains are relatively high and do not do much for restraint of motion. Most of their padding is up around the head area, as that is what they intend to protect.
As I stated before, NHTSA does not use head-sensors in the dummies used in the side-impact test, unlike EuroNCAP, which does.
I don't mean to downplay the usefulness of side curtains, however. They do play a major role if one is hit by a taller vehicle, like an SUV or a minivan.
"To my knowledge, the Lexus ES and Camry use similar if not the same, structural design ..."
Let's hope that is true. But is it, really? Do we know for sure? Did Lexus add any additional structural members to improve handling and reduce body rigidity? Thus helping with side impact protection? Look at the Acura TL, which for years people have been assuming is just a dressed up Honda Accord EX V-6. Acura ended up adding some more structure to reduce body flex, and in so doing, significantly improved upon the Accord's IIHS offset frontal crash test score. I realize that's not the same as the side impact, but it shows how sometimes there are more differences than one might think.
"... but I digress, and theres no making excuses for 2 stars."
Sadly, I am in agreement with you here. With or without thoracic side airbags, or side curtains, there's no excuse.
I honestly don't know the specifics involved in this particular test. I do know that a car tested one day can test completely differently another day. The same is true to EPA mileage estimates. I've seen those change by up to 4 MPG from one model year to the next without a single change to the engine or body.
Were I a consumer, I would look at this data and use it in a decision. I would NOT make it the only criteria by which to qualify or disqualify a particular car.
The previous-generation ES300 also tested significantly higher for side impacts than the previous-generation, non-side-airbag-equipped Camry. Even though the margin wasn't as large as it is this time around, it seems more like a consistent trend than a fluke here. If the trend holds up, the side-airbag equipped Camry would be 3-stars, perhaps even 4-stars. We'll have to wait until NHTSA tests the side-airbag-equipped version.
We should also know more whenever EuroNCAP performs its crash tests on the Camry.
Good question. I'm not sure what NHTSA's policies there are. I know that manufacturers can ask IIHS for a re-test.
Best way to find out is to ask them. I've emailed NHTSA-NCAP and will post back here if I get a response.
Also, what if anything can I assume about the safety of my own car, which DOES have side airbags?
E.g. please see:
http://www.nhtsa.gov/NCAP/Cars/2002MidS.html
You'll notice that for vehicles that have side airbags optional, NHTSA will often test both versions, and note the ones with it with the "w/SAB" option. E.g. the Ford Taurus, Honda Accord, Mercury Sable, etc. are listed as being tested with the side airbags, and without.
I'm sure that NHTSA will eventually test the Camry version with the side airbags. Not sure when, though. And EuroNCAP will likely test the one with side airbags eventually too.
Anyone who's looked at the side profiles of new sedans can see that car designers are making them "high-waisted". Why? I assume it's cause they are trying to make the cars more resistant to T-bone strikes by SUV's. ("SUV's - ethnically cleansing American roads of pesky sedans since 1988" :-)
So what happens when one of these sedans, with side impact structures positioned high up to protect against Ford Exterminators get whacked by a low NHTSA barrier (or a another sedan)? Well, apparently not what you'd like.
The solution? Ideally, you'd like to have a standard height (or at least tighter range of heights) for front impact structures on all vehicles - that way you'd know *where* to put the side impact protection. But, of course, getting that to happen isn't something engineers are going to do ...
It's strange that a Ford Taurus gets the same rating with and without side airbags. They don't help at all on that car?? I sure hope that Camry passengers are shown to get some real protection from side airbags. I guess I'll sleep tonight by pretending that the Lexus is the same as the Camry.
R134A started in 1994
~alpha
And there's the enigne mount locations from the JZ and MZ engines.
After that, I have no idea how Toyota will introduce the engine into the Avalon, Highlander, and ES. Perhaps instead of putting the 3.3L in the Camry they will finally give it VVT-i and tune it to the specs currently posessed by the HL and RX (220hp and 222lb-ft.)???
This is all speculation based on posts I have read on these edmunds boards.
~alpha
Are the 3.0-liter's sludge problems the reason for the new 3.3L engine?
http://www.thecarconnection.com/index.asp?article=5037&sid=173&n=156
check out the past 30 posts. The Camry 2 star driver's side impact is a major issue, and if the Accord is going to have Side Curtains as standard for 2003, Toyota sales will CERTAINLY suffer, and rightly so. I love our 2002, it is an OUTSTANDING car- a luxury ride at a lower price point, but this is a sad rating. Thats great that the rear passenger got 5 stars, but that seat is often unoccupied. It should be noted that this was a test of a non-Side Airbag equipped model.
Among non-Side Airbag models in Side Impact Test
2002 Accord: Driver 4 stars/Rear Passenger 4 stars
2002 Altima: Driver 3 stars/Rear Passenger 4 stars
2002 Camry: Driver 2 stars/Rear Passenger 5 stars
As for frontal impacts, there is data for all three from the IIHS (but not NHTSA)
40 MPH Offset
2002 Camry: Good-"Best Pick"
2002 Altima: Good
2002 Accord: Acceptable
Overall, it seems if you are on looking at a bread and butter 22K family car, in terms of safety, the way to go is the Altima. Especially since you can get side airbags in the Alti at a reasonable cost, packaged with ABS.
~alpha
~alpha
There are lots of LEs out there with side bags, but seemingly very few with both side bags and ABS. Deals around here on XLE 4s [I'm talking Northern CA] are awfully good, and the differences in equipment levels can make the step up worthwhile - but only if your budget permits, obviously, and I realize that is not always the case.
If the version without side airbags tested with 2-stars, it's quite possible that the version with side airbags will only test with 3-stars. Not consistent with the previous generation, of course, but the current generation already has an issue.
Just my 0.02.
Curiosities indeed
~alpha
alpha.. I hope your right!
However, I would think that someone who wants the comfort level of being sure might want to wait. If someone is confident, then they have no reason to wait. It's an individual choice.
After all:
1) The previous-gen Camry with side airbags (SAB) did not perform quite as well as the previous-gen ES300 w/SAB. So that would imply that the new-gen Camry w/SAB won't do as well as the new-gen ES300. The question then would be, how much worse?
2) The new-gen Camry wo/SAB does worse than the previous-gen Camry wo/SAB. That might imply that the new-gen Camry w/SAB also does worse than the previous-gen Camry w/SAB (4-stars front).
3) Sure the new-gen Camry wo/SAB test could have been an anomaly. But does a conservative purchaser who is worried about side-impact protection and believes in crash-test scores, want to take a chance speculating on a crash test score, rather than seeing it? Especially given the 2-star result already posted? You've already said that you will not buy another Toyota without seeing the scores first. Thus, can we guarantee that the new-gen Camry w/SAB will indeed score 4-stars for the front (if that's what someone is looking for)?
"And finally, what would cause such a wide difference in the performanc of the driver as compared to the rear passenger, especially since the pelvic forces on both those dummies are nearly identical? "
It is quite possible. If you check NHTSA's site, there are a few vehicles that have had three-star variations between the front and rear passengers. It depends on many factors in the vehicle's structure, including how far back the rear passenger is relative to the barrier, what is inside the doors themselves (front vs. back), B-pillar strength, C-pillar structure, etc. In those (admittedly fewer) vehicles with 3-star differences that I looked at, the delta in the pelvic decleration between front and rear was actually a lower percentage than it is for the tested 2002 Camry!
Sure it can fit. As discussed here previously, side curtain airbags may do little or nothing of benefit in the NHTSA side-impact test. Due to the height of the NHTSA's barrier, and because of the fact that NHTSA doesn't even bother to measure head injury in the side-impact test.
We'll have to wait and see. Which is my original point here. That the Camry with side airbags (including curtains) may be much better, or just better. Those who want the comfort level of proof should wait for the NHTSA test results on the Camry with side airbags, and not simply buy into the speculation here (including my own speculation).
And the monsoon should soon be upon you - we can hope, anyway...
V6 owners, what do you use?
~alpha
Both enignes are equipped with dual knock sensors (one for each cylinder bank).
You can use 87 octane, but you may see some performance and fuel economy losses.
It was designed for 91 octane, using using 87, the ECU will retard the timing a few degrees.
As Steve has indicated [above], that shouldn't stop you from investigating any and all aftermarket solutions. And if money is no object, consult with any speed shop about replacement seats such as Recaro or Scheele. They make adapters to fit just about any set of OEM seat rails, and my test sits at various car shows tell me that the solution to your problem is out there. A trip through the yellow pages should get the process started.
~alpha
jrct9454 - No, I won't blame the trial lawyers, though they are an easy target. Toyota cannot possibly incur any liability by telling me what if any seat will fit my car, which is all I asked them to do. I did not ask them to recommend anything. Of course if they advised me that a, say, Lexus ES300 seat would fit my car, and it did not, they they might be liable for my cost of buying the ES300 seat - though they could avoid even that liability by asking me to agree in advance that they would not be so liable. I guess I should add that I am a retired trial lawyer. As for the speed shop, I have tried to go that route, in particular with Recarro, but could not find any shop which had one available for me to sit in. I will look into Scheele, and will try again to find a shop, perhaps in Phoenix (I live in Tucson) or even, if necessary, in southern California (it's 400 miles to San Diego, 500 to L.A.). I really do like the car and have no idea what else to look at, as I looked at everything in the price bracket before buying the Camry. (My son says the Volvo S60 is very comfortable, but it is double the price.)
Cliffy 1: Can you recommend any particular conversion van shop, either a national chain or one located in Arizona or California? I did call such shops here in Tucson, but couldn't find one which even understood what I was talking about.
Alpha01: Any recommendation would be most appreciated. My email is ggoldberg@sprintmail.com.
Thanks to all again.
Anyway, in answer to your question, no, I don't have a specific recommendation. Have you actually walked into one of these stores or has everything been done over the phone? It is possible that face to face interaction would help you convey your needs. In order to narrow down shops, you might want to talk to a local Ford of Dodge store that sells conversion vans and ask who they use. Then, go to the shop and hopefully, speak to somebody who understands you.
Here is one other suggestion that might help. I had a customer who needed to add a seatbelt to a Solara convertible and I discovered that the shop here in VA that installs our leather kits also did custom seat modifications. Sure Fit was the name of that company and I don't know if they could help you or even if they have stores in your area, but it is something to look at.
I live in Mesa AZ. and if you are ever up this way I would be more then happy to let you take a long drive in my Solara so you can get the feel of that seat if the Solara is a car you may be considering buying in the event to do end up selling your Camry.
I hope you are able to resolve your problem.
