My car also has three other problems that have been covered here. In order of importance to me, they are: the occasional sulphur smell in the cabin, the clunk going into drive, and the faint thunk from the rear when starting off.
I'll be bringing three of these matters to my dealer's attention when I go for my first service at about 3,000 miles, and will post again to relate what happens. The thunk from the rear may be the gasoline in the tank shifing -- I've noticed it happens with a full tank, but goes away after you've used a few gallons, so I'm probably not going to bring that up.
I'm enjoying the car in spite of these issues, but do hope to have them corrected by the dealer. I especially like the acceleration of the v-6 and just the overall feel of the drivetrain -- strong and responsive. I also like the roominess, in front and back. A very nice car overall, but the rattles need to go.
Mackabee
Mackabee
I actally got this press release off the Edmunds site in November, I printed it out for reference when I spoke with Toyota.
I just cut pasted the link and release here:
http://www.prnewswire.com/cgi-bin/stories.pl?ACCT=104&STORY=/- www/story/11-08-2002/0001837619&EDATE=
TORRANCE, Calif., Nov. 8 /PRNewswire/ -- This statement is being issued by
Toyota Motor Sales, U.S.A., Inc.:
In survey results publicized by Consumer Reports, the 2002 Toyota Camry was rated average due to complaints about minor issues with some aspects of the car's interior and exterior trim.
Toyota responded to customer reports of uncharacteristic squeaks, rattles and loose trim in early production of the redesigned 2002 Camry. Internal surveys and independent reports confirm Toyota's confidence that the issues have since been resolved and that Camry initial quality is back to its normal high levels. Functional reliability is not an issue. In fact, Camry scored
well above average in all major operational categories of Consumer Reports' survey including engine, transmission, brake and electrical systems, etc.
Camry remains a recommended model and Toyota and Lexus models continue to be at or near the top of their segments as rated by Consumer Reports and many other independent quality, reliability and customer satisfaction surveys.
SOURCE Toyota Motor Sales, U.S.A., Inc.
Now between you and me this is all becoming old. The car has been out a full year and I have seen no solution to the door pillar problem. If there was one you'd think we'd of heard of it in the forum. If you know of anything or the techs you know do then please post it and you will be our hero!!!!
~alpha
So which model was it that you saw, and what was the price exactly?
~alpha
Mackabee
Mackabee
Of Note:
1. LE and SEs got standard power drivers seat.
(XLE already had this, should note that at beginning of MY 2003, keyless entry became standard on all models as well, an upgrade from 02)
2.XLE V6 and SEs got power moonroof std.
3. V6 models (FINALLY!) got VVTi, boosting output to 210hp and 220lb ft torque, increases of 18 and 11 respectively.
4. V6 models got a 5sp auto standard.
5. Spoiler no longer standard on SEs.
-alpha
I wonder it would be the same for Camry SE in Canada.
You probably didnt pay more for less; depending on your equipment levels and options, you probably paid more for the same.
Our 2002 Camry LE had an options package that included ABS,keyless,power drivers seat, and floor/trunk mats. Now the keyless and pwr. drivers seat is standard. (We also opted for the split 5 spoke alloys and locks).
So, compared to the 2003, we paid more for the same. Of course, this is all MSRP based. If you can get a car close to invoice, then you're ahead of the game anyway.
Just because a few features are now standard, that doesnt make our Camry any less of an outstanding value for us.
~alpha
Mackabee
Mackabee
*Term used loosely--Camry isn't a bad looking mid size design in my opinion.
I' also mention about the dash rattle...actually sound like a popping sound when cold.
THANKS!
I'm an Edmunds regular but this is my first time posting here. I'm doing some research for a friend and I'm hoping that you knowledgeable Camry owners can answer a couple quick questions:
a. Are there any known reliability issues with the 2001s?
b. Have any 2001 owners experienced problems with their auto trans popping out of gear while driving?
Thanks in advance for your assistance!
-Frank P.
Mackabee
I own a 2001 Camry, V6 Collector Edition. I had absolutely no problem with transmission or any equipment of the car. It's a great car! I think it looks sleeker than the newer model.
The only concern I have is that the paint job is not as tough as I wanted it to be, but if you take care of the car and wax it often it should be ok.
Good luck!
Tony
In the Northeast it has been really cold. If I park the car all day at a certain work location and pull out onto the highway when engine and transmission are ice cold the car turns really high revolutions at 50 miles an hour till it warms up. This is the only time it does it. The car is garage kept at night and does not do it if it has been warm out all day. The service manager says this is normal and that the transmission is designed to change the shift points when it is really cold to warm it up asap. I am slightly skeptical about this explanation although my Honda transmission has grade logic and will automatically downshift on a hill to maintain speed without braking so it is possible I guess. Anybody hear of this or experience it in their cars?
The car does not seem to coast or "glide" well when you take your foot off of the gas. I adjusted the rear brakes myself and it still seems to slow down quicker than other cars I have had. Could this be attributed to the way the transmission is designed to operate?
Last but not least what do people get for gas mileage with a 4 cylinder Camery that mostly drive on the highway? I am a little disappointed with my mileage but it may be due to the glide issue I described earlier causing some drag which affects my overall gas mileage.
Thanks to all replies. A poll of real world gas mileage could be interesting.
for the response!! HAPPY MOTORING!!
For anyone interested, check out the newest issue of Motor Trend magazine. A very good comparison test including Accord LX 4, Camry LE 4, and Altima 2.5S. The Accord did win, but MT praised the Camry for being true to its mission- a refined, well executed vehicle that takes the stress out of driving. Complaints included lack of sporty edge, and poor brake pedal feel. Interestingly, the boulavardier Camry actually posted better handling and braking numbers than the Accord.
~alpha
This also happens with my Solara V6, as well as my Mom's Corolla. This is a very nice thing to have, with the arctic colds we've been having lately!
That discussion has been kinda quiet lately -- with gas prices behaving as they are, it seems an excellent time to liven it up.
Mix in some highway miles and it shoots up to 23mpg. Several pure highway trips yielded 28mpg, that was in the summer with air going while driving at 65mph.
I am a little disapointed in the 'city' mileage, then again I wonder how much better it would be if I was not letting it warm up in the morning....it's been real cooooold this winter in PA!
This compares comparably to my old v6 Mystique which got 17 / 23 and 28 repsectively. You would think the 'just as quick' v4 Camry would outperform it but it is a bigger car which I'd assume weighs more...?
John
My car was requiring me to more force to apply the brakes than I was used to. The service manager told me these brakes are NOT self adjusting. I find that hard to believe in this day and age and besides they look like self adjusting brakes to me. That is what the lever is for inside. It turns against the grooved wheel to take up slack as the pads wear down. I have not yet bought the service manuals. They are very expensive.
After the adjustment the car brakes better for me with less force needed. The front brakes were doing most of the work.
numbers that appear on the dash indicating my
gas mileage? I have the four cylinder and the
computer tells me I am getting around 30 mpg.
I have not performed the manual mileage check,
but I somewhat dubious about this 30mpg, especially during this cold winter in Wisconsin.
You wrote: if you are within one year or 12000 miles all adjustments are covered under the new car warranty. Are you sure about this? Where can I double check the information? I don't feel the car has much coasting or gliding ability when I take my foot off of the gas. It slows down quicker than other vehicles I have owned. I would like to get this looked at as a warranty claim. This could be why my gas mileage is not up to par.
By the way it looks like I will be checking those service manuals out after all. I got a set on ebay at a very reasonable price.
I own a V6 and I'm very pleased with it. I had a 4cyl rental for a week. It's powerful enough, except when you want to pass quickly on the freeway or to 'squeeze the orange' (that's British for going through the yellow light).
On the other hand, the 4cyl has a better gas mileage than the V6., not to mention cheaper price!
I'm sorry I don't have accurate info about the 5-speed auto transmission. If I come across anything I'll let you know...
Good luck!
Tony
