My in-laws have a 99 camry with the 4 cyl. That did not have enough power, in my opinion.
Would like to know if it would be a really big difference in performance when using 87 instead of 92 (or higher). And would Octane 87 fuel be harmful for a 2003 V6?
Thanks for reading and would appreciate it a lot if you give me some feedback regarding this topic.
That said, for those who can afford the V6, and want one, I'd go for it. The car is simply quicker with this engine. Resale value increases as well(though perhaps in proportion to excess fuel expenditure).
~alpha
I have yet to take a long highway trip, I will expect MPG to be much better, and possibly display accuracy to improve in more consistent highway travel.
In 2001 I bought my Camry V6 Collector Edition, and for a year I used premium gas (octane 92). Then I switched to regular (octane 87). The difference in performance is very small and certainly worth the money you save.
Regular gas (octance 87) is absolutely safe and will NOT harm your car's engine in any way whatsoever.
Some people say that the recommendations for higher octance gas are "supported" by gas companies for their own profit!
Here's a good article on the subject from the AAA:
http://www.aaa-calif.com/westways/0302/overdrive_1.asp
Good luck and drive safely...
Tony
-alpha
By the way "1violinist", are you really a violinist? I play the violin too!
You're welcome! Enjoy the savings! :-)
Yes, I'm a violinist, but not professionally. Music is my first hobby, then cars!
Have you seen Yamaha EV-205 Electric violin? It has 5 strings compared to the regular 4 string violin -- kinda like V5 engine instead of 4cyl. LOL
Take care and drive safely...
Tony
Do you have an alarm system or engine immobilizer installed? Because usually these systems override the default set up of the keyless remote.
Does it happen after you start the engine or before?
If you give us some details, maybe we can figue it out.
Tony
As far as I know this function is not programmed from the keyless remote unit, but from the module in the car itself; and since the owner's manual does not mention it, I guess it has to be done by the dealer (if it's applicable in your case).
Good luck!
Tony
Yup I have seen the Yamaha Violin with 5 strings! Really cool! Don't know if you have heard of them, but it reminds me of violins used the the group named "BOND".
I don't think so because the difference is very small. Let's say your car averages 25 mpg using octane 92, it would probably drop to 24 mpg when you use octane 87 -- that's a 4% decrease. On the other hand, octane 92 is at least 12% more expensive than octane 87.
By the way, your 2003 car has 210 hp @ 5,800 rpm as compared to the 192 hp on previous models! Here you go: 18 hp more just for you! :-)
If you add some 'rosin' to the gas your engine will sound like a violin! Just kidding :-)
Tony
~alpha
-alpha
If you're doing 140km/h (87mph)that puts your RPM between 2,800 and 3,300 depending on the road condition and the car load -- that's an average load on the engine and shouldn't make it louder than usual. If you switch off OVERDRIVE, the egnine will revv up higher rpm's, but still within acceptable noise levels for the Camry.
Tony
However, I remember my old 97 Camry 4 cylinder was quieter at high speeds like that.
Around the Toronto region, they are really cracking down. Be careful.
It's now eleven years straight that the highest reliability in the bigest category of cars is a Nissan/Infiniti. It's been Maxima/G20/I35/J30 for each of the eleven years. Interesting that it's always a car built in Japan.
Now that the Maxima is built here, it will probably fall down a few notches.
I expect the Camry will move up quickly as Toyota addresses issues. They better soon. I plan on buying one as soon as they do.
Service rep says only Toyota can be used, Parts dept and technician say the green stuff is compatable not dexcool.
Does anyone know???????
By the way, it does not have to be Toyota brand name. My manual says "use Toyota Life Long Coolant OR EQUIVALENT..." -- any ethylene-glycol coolant would be ok.
According to my dealer, the Dexcool long life orange coolant is not compatible with Toyota, but with GM cars.
Good luck!
Tony
~alpha
Please read the following article; it should answer some of your questions.
http://www.edmunds.com/ownership/howto/articles/43860/article.htm- l
Good luck!
Tony
Your car should still be under bumper-to-bumper warranty. Toyota is under obligation to fix/replace the shocks.
My schedule maintenance log book goes up to 120,000 miles and there's not a single mention of 'shocks'!
I'd speak to the manager of the dealership, or even Toyota headquarters!
you can also get the same factory alarm the dealer put in your car on ebay or internet for around $200, and install it your self for about 3 hours. no wire cutting, it comes with pre-wired harness, just take apart the panels around dash, and plug and play.
Join us tonight, 6-7pm PT/9-10pm ET for another
round of automotive trivia and member-to-member chat.
Test your skills (or multiple choice guessing ability)
against other Town Hall members.
http://www.edmunds.com/townhall/chat/townhallchat.html
Hope to see you there!
I was wondering if I could use slightly wider tires (P215-P225) for better handling without fear of messing up the car or if it would be OK to "copy" the tires from the SE or XLE.
There is no auto window button, only a 1)lock, 2) unlock, and 3) trunk button. Is this considered the "cheap factory alarm"? should i get the VIP plus or the Viper alarm that everyone is talking about? thanks.
Compare with ES300 with the same engine / 5 sp transmission, the Camry has higher fuel consumption (11.9 vs 11.4 l/100km).
Does it make any sense ?
