Visitor Agreement.
(2) "Cold Shift Shock" -
When the RPM is high > 1500, you will experience this. Let the engine warming up (15 second in summer, if below 32F, 40 sec to 90 sec). Keep the parking brake on during shifting.
(3) Odor problems - Try different gas station
(4) Rolls backwards - You suppose to step on brake on up hill stop.
(5) Clunking noise - Gas moving in the tank, try it at near empty next time
(6) Rattles, rattles, rattles - They are getting worst at cold weather. Most of the problems at:
a- B pillar: around seat belt area (stuff some foam there).
b- Bottom windshield: Glass contact with metal frame (again, stuff some foam there)
c- Front passenger and drive's door: worst at driver's door, due to the contact of plastic to plastic
d- Door rubbers: Use good silicon lubricant
Most of rattles (95%) have gone in my car. I found it is too quiet now (maybe I should put back few rattles)
"The dealer I purchased my 04 SE V6 Camry from informed me Toyota last thrusday introduced a TSB regarding the front wheel misalignment. The car pulls left on its own. Dealers can do their best to rectify the situation for customers sensitive to this, however, Toyota engineers are still investigating the root cause to provide a solution to dealers.
The dealer told me no recall on this is expected because it is not a safety concern. However, the solution for the TSB should eventually surface. This does not occur on the 02 or 03 SEs. Not sure if this problem is evident on the LEs and XLEs.
Have any of the 04 SE owners heard of this and have info on when this issue will be resolved?"
Well Ando, my wife has an '03 Camry SE and we also have the problem where it seems to drift to the left. This problem seems only to be noticable on the highway. We had the front end aligned by the dealer, under warrantee and then aligned a second time by a tire dealer. The tire dealer gave me the printout of the specs, before and after. It was not within specs after the Toyota dealer, but the tire dealer brought it into specs. However, it still seems to favor the left. I'd be very interested in hearing if anyone else has any info on this problem. Our Camry has only 6500 miles on it and I'd hate to think that we'll have to live with this..
***Mooselook***
My check engine light came on after someone put gas in the car and forgot to twist the cap a couple of times. I took the car (99LE) to my father's mechanic who reset it off. From that point, I made sure that I put gas in the car. I asked why it came on and they said that the fuel-air mixture may have been affected by the loose cap, but also mentioned the possibility that the EGR Valve (I hope I remember this part correctly) might have failed. After having it reset, I decided to wait for a reoccurrence before doing anything else - 2,000 miles ago.
I'm expecting a slight power bump for the 2.4L, to 160 or 161hp, as in the RAV, Highlander, Scion tC.... I'd like to see more safety features made standard... the Solara has ABS and seat mounted side airbags standard, at a similar price, so why not the Camry? Personally, I think thats a fair compromise... leaving the curtains as optional...
~alpha
I simply can't imagine anyone wanting to pay $$ for side airbags and not pay $$ for curtain airbags.
I believe some cars have curtain airbags but no side airbags. There is steel door separating the chest from the intruder, but only glass window next to the head. So I think that arrangement is somewhat logical, but not the reverse.
BTW, in Canada the Accord sedan is doing exactly what I think is illogical -- all trims except the base DX has side airbags standard, but side curtains are not available even as options. I place the blame for this problem at NHTSA, which doesn't factor head injury into the side crash ratings.
I like what Toyota has done in the US spec-Solara, which is EXACTLY what I have indicated above.
~alpha
Strong door steel beam protects the chest, curtain protects the head, all standard features. Optional side chest airbags for extra protection. More logical to me.
~alpha
Yes I realize that. In fact I think all 1997+ vehicles have side impact door beams in order to pass the minimum government side impact standard.
Curtains alone are more expensive than side chest airbags alone, in terms of feasability.
I agree, and for this reason I agree that what I propose (making side curtains standard) will probably not happen in the short term. But Toyota is in a position to lead if it wants to. e.g. if my memory is correct, isn't Toyota making VSC standard in all its "trucks" (including even the cheapest RAV4)?
Looking at the NHTSA data, a head curtain would NOT change the Camrys rating of 3 stars/5stars ...
As I said in #6503, I lay the blame at NHTSA for the faulty side crash rating (not taking head injury into account), which tempts manufacturers into actions like making side chest airbags standard to get a higher star rating, but not head curtains because "no brownie points". As you pointed out, the Camry HIC result is good, but the NHTSA test is like being hit by a car and not a van/truck/SUV. Hopefully the situation would improve as IIHS publish more side crash results.
Tidbits:
NHTSA will test the 2004 Camry sedan, instead of carrying over 2003 results.
I read that side+curtain airbags will be standard in all 2005 Subaru Legacys. If Subaru can do it ...
We assume that side chest/curtain airbags will help ... check out the NHTSA result for the 2004 Nissan Maxima. It was tested with side+curtain airbags (standard equipment), and has below-average side-rear head injury result in the 800s (like the Accord Sedan that I griped about in the Accord forum).
No honestly, I really hope that for the 2005 refresh that Toyota siezes the opportunity and adds more standard safety equipment to the Camry. You are correct in stating that Toyota went the extra step and made VSC, Toyotas version of stability control, standard on ALL of its SUVs this year, from RAV4 on up. Its time Toyota paid attention to the frekin Best Selling Camry line.
With respect to the Maxima, even though the 800 HIC is on the higher side, it would still be a "survivable" crash (1000 is the threshold which indicates severe injury, possibly fatal in the words of Consumer Reports), and I'd rather have an airbag there to cushion the blow than not. (Also note that any HIC must be considered against the time duration of the "injury" infliction.)
The new IIHS tests will be very telling as well.
NHTSA is messed up? Why are they testing a 2004 Camry? Were there any mods to the restraint system? If not, I feel they waste their money. I'd rather see a retest of the side impact for a Camry with the airbags/curtains....NHTSA needs to get its act together, as well, and include the HIC in the side impact rating.
~alpha
P.S. My wife and I ended up getting an Accord LX V6 instead of the Camry, end though it has no side curtains ... If we are in USA we would be getting a Camry SE V6 with VSC+side/curtain package instead; in Canada we don't have that option without getting a fully loaded Camry with leather/moonroof etc.
Just got XM radio after also adding it to an 02 QX4. In a word--AWESOME. The QX4 sounds like a whole new high end stereo was added. Only had it in camry since last night. Not as dramatic a change, but still an improvement. Better sound quality and no commercials, plus over 100 channels to choose from. Highly recommended.
As for wheels, I guess if you know what you want, have the size figured out and have priced them locally, you might be better going with them.
I haven't replaced wheels on a car in a long time, and then it was to put Cragar S/S or American Torque-Thrust Ds on my restored muscle cars...
The wife's LE V6 needs something a little bigger and better-looking than the standard 15s, but she says no....Women!
Deke
i've also gotten quote from local good year and other tire store for the same tire plus installation, quoted for over $500, wut a rip off.
I am curious if anyone else ever heard of these? In fact I just replaced Craponental tires that came with my Camry for some Goodrich Traction TAs....they said they would have a better grip for the Camry than the Jetsons....still it was the 1st time in years I did not use the Jetsons, hope I made the right choice.
Also, does anyone know if the non-Toyota extended warranties are any good??
Certainly, different people have different preferences, and by all means, if it sets your mind at ease, purchase an extended warranty. But I'd be willing to bet that one of the reasons you purchased a Toyota in the first place is BECAUSE of its reputation. I think a NON-Toyota extended warranty is a COMPLETE waste of money, though, so if you do get one, get the Toyota package.
Indeed, as a brand, Toyotas are even HIGHER in quality than people already perceive them, according to a recent article in USA today: http://www.usatoday.com/money/autos/2004-01-15-quality_x.htm
Best of luck!
~alpha
We recently bought a 2004 Camry XLE V6 with adjustable pedals. There is a constant drive train vibration coming through the accelerator pedal when accelerating under load up hills or when maintaining speed on the highway. The vibration can be a distraction and a big nuisance--especially given the fact that everything else about the Camry is very quiet, smooth and vibration-free. We test drove a 2004 LE V6 and a 2003 XLE 4 cylinder, both without adjustable pedals, and there was no vibration problem. A dealer's service department said that the vibration occurs because the accelerator and brake pedals are not solidly secured to the the firewall like cars without adjustable pedals. Instead, they are somehow suspended and connected to an area that picks up the drive train vibration under load. The dealer has received several complaints and forwarded them to Toyota Corp. As of yet, Toyota Corp. has not issued any service bulletins with a fix.
Now if you are keeping the car for only 3 years or maybe 4 and won't go over the 36K then that is another story.
Also, Toyota's rep is not a shiny as it used to be. They had a sludge problem. I read more and more on head gaskets going. They cheapened the materials and the way they fasten their plastic parts together starting in 02 yielding many a rattle. I hope they have not cheapened other mechanical parts of the car as well...time will tell. Mine drives well, is fuel efficient, is VERY ppepy for a 4 cylinder, fits our family nicely and when not rattling down the road is a pleasure to drive. I hope to have it run flawlessly for years and if I never use my $675 warranty---well I can live with that!
As for the sludge problem, lets not blow it out of proportion as I think there have been approximately 3400 reported cases and there was a question as to if these people even had regular oil changes done.
Thanks again for the pollen filter information.
Andrelaplume, yes, there were some affected by the sludge issue that performed regular oil changes. However, as 2003SEV6 points out, many who experienced the problem DID NOT perform regular servicing. 3400 cases from over 3.3 MILLION customers to whom Toyota sent the SPA mailing works out to <.001% (ONE THOUSANDTH OF ONE PERCENT). Is it an issue to worry about? Not for me.
~alpha
Instead they just made exuses hoping the issue would go away..just like other automakers. I'd have respected them more if they just admitted they did not do a good job handling the ordeal because they never had a problem such as sludge before and further, that initially, their pride would not let them believe their car could have such an issue. Instead they just made exuses hoping the issue would go away..just like other automakers.
Yes, Toyota acted just like the others. They registered at multiple Internet bulletin boards, posted the official policy and stuck around with and high ranking person to personally answer consumer problems in public. They offered an 8 year/unlimited mileage warranty for sludge and repaid the few hundred folks who had already paid for new engines. Typical. Just like all the rest.
In the face of the reality that not a single car was ever found with verifyable oil change records, they started accepting any form of "proof" of oil changes once a year for those covered cars. Yeah, those typical automotive industry guys sure know how to stick it to you don't they?
[/good natured sarcasm mode]
The fact that your Camry rattles does not mean each of the 400,000 sold annually do. Most definitely, Toyota had build quality issues with the 2002 redesign, and some of the 2003s. But, reliability, according to both Consumer Reports and the JD Power Vehicle Dependability Study... continues to be excellent for most Toyota models. Indeed, the 2002 Camry had an unremarkable "Average" rating from CR, but the 2003 improved to "Much Better than Average". Toyota is not alone in initial redesign drops in build quality. The same thing happened to Honda in 2001 with the redesigned Civic, and to a lesser degree, the 2003 Accord.
I honestly do believe that the Honda/Toyota titans still offer better initial and long term reliability than their domestic counterparts. The gap has been significantly closened, however, and Honda/Toyota should be en guard.
~alpha
Not sure exactly where, but the instructions are in the owners manual listed under "Air Conditioning Filter".
You might want to check out E-Bay. They have the filters sometimes. I purchased a filter for the Highlander on E-Bay for around 13 dollars.
The folks at the Taurus/Sable thread also read Toyota's thread and comment about what they say is "decreased Toyota/quality". The fact of the matter is that the domestics have, to some extent, narrowed the gap but they're still far from building a Camry like quality car.
My Sable is pretty good in some respects; however since I bought it it has gone back to the shop numerous times for repairs. The car has, per CR, Average reliability. Repairs were not major ones but things that shouldn't have broken early on. It also always had rattles.
My Camry never in 8 + years of ownership returned to the the shop for repairs, only scheduled maintenance. That's reliability.
The number of sludge complaints as opposed to the number of toyotas on the road is minor. Toyota has not attempted to fraud the consumer.
Again, its about perception, you would not expect Ford to cover their screw ups, you would expect Toyoyta to. Perhaps they just reacted too slowly with a bit of a chip on their shoulders. If your heavy into Toyota you probably will not concur and you may be right but again its about perception and controlling it.
To be honest I only heard about sludge as I was looking into a 2001 left over Camry. I saw something on the news, heard talk at dealers and found a wealth of concern on the web. It made my decision to wait for the new 02 with a new 4 cylinder engine that much easier....hey maybe it was a marketing ploy to move an initial volume of the 02s...(more good natured sarcasm)
While I do not agree with everything Cliffy says, it good to hear from him again.
I'd also like his take on rebates. With Toyota continuing to offer rebates (now $1000) I feel it lowers the value of my 02 a bit. Do you think rebates are hear to stay or will eventually one of the big 3 (Toyota, Nissan or Honda that is) finally just drop the base price by $750 - $1000.
The Toyota store that did all the changes didn't notice this. This was and is a real problem. Just to bad so much skepticism about it.
This story is true, no matter who believes it.
The Sandman :-)
sandman- I believe you. I also lay blame on the manufacturers. 7500 miles, IMO, is too infrequent for normal servicing. Was there no time length qualifier with 7500 miles though? If I were you, I would strongly recommend servicing your Sentra at the 3750 intervals.
~alpha
Incidentally/ironically the decontenting did not last very long in Japan. Many consumers revolted by not buying Toyota vehicles. It didn’t take long for Toyota to reverse their strategy and quickly re-included features that had been removed.
It took a few years but Toyota seems to be doing a better job of hiding the savings obtained in their cost cutting manufacturing techniques. I don’t think they had much choice; it was starting to catch up with them. They are not the quickest to react. Slow and steady is their motto. Now, if they could only add a little styling pazzaz to some of their vehicles.
The bottom line is that Toyota’s reliability is tied to extremely high expectations (as others have stated), which includes vehicle convenience item content and types of materials used in manufacturing. Just my opinion.
Now lets change the subject by talking about the percentage of Camry owners or any other Toyota model for that matter that has put extremely high mileage on their vehicle.
A guy I work with has a 1997 Camry XLE V6 that currently has approximately 320,000km on it and without any problems. He doesn't even want to get rid of it because it is still such a good car and he thinks that he could easily double that mileage. One thing though. He changes his oil every 5000km and that is what I would recommend to everyone.
