-June 2024 Special Lease Deals-
Mazda MPV: Problems & Solutions
If you must go to court/arbitration, it would be important to label this a "defect" and cite the other examples on this bulletin board. Get the vin and mfgr. dates. In situations like this, there truly is strength in numbers. Keep me posted.
I have a second front wheel drive car and was doing 90 this weekend without any shaking.
I've been away for quite a while due to the birth of your second tax exemption (2nd girl). I was pleasently surprised to see the number of new members on these forums, not to mention all the reading just to catch up.
Just went over 1000 miles on the odometer. No problems thus far. Only a slight left lean when driving. Will post my gas mileage next time.
felix
I wanted to add my experiences with the shaking/vibration that other people mentioned. I have an ES, 3000 miles. I recently (in the last 1000 miles?) noticed a persistent shaking/vibration SOMETIMES, between 40-70 mph. I thought it was the road surface, but on a roundtrip I found that the problem went away on the way home . . . I took it in to the Mazda dealer. They pointed out two slightly bent right side rims (on the inside edges). We have not hit anything, and the car had 12 miles on it when new- so I'm not clear this is the problem. They said the front seemed out of balance when they spun it, and recommended buying new rims. I am presently asking the dealer I bought it from to look at it and consider replacing the rims, as I am sure my wife and I did not damage them. However, this may not even be the real cause of the shaking. It isn't always there, and only appeared in the last month.
On other topics, I do not have the left-ward pull that others mentioned. I do have a chunk of paint out of my bumper ( I slide a box out) and was surprised at how easily the paint scuffed off.
Please let me know if anyone is able to get the vibration fixed . . . it is annoying whenever it appears!
thanks,
gnobber@utm.net
Bfelt- I can't believe they are saying you need to buy rims! If anything, they should be covered under warrenty. Another poster on the cruisers club has had the dealer replace his rims trying to fix the vibrating and it didn't work. What is the date of manufacture on your van? I'm trying to find a link between all the shaking vans. Mine is 7/99.
my date of manufacture is 9/99.
The dealer showed me two flat spots on the inner edge (approx. 1/8" depression off of full round, flat spot was maybe 3" long)and claimed there had been impact. We definitely didn't hit anything. Curiously, the tire rubber in the area didn't show any markings- how could a rim get whacked if the tire didn't also show damage? Is the metallurgy such that the wheels are soft and tend to deflect?
This is the normal practice when you install new tires. Don't assume that your alignment was ok before and with the new tires, it will be ok as well.
Modiecast, do you agree if it may be the tires to blame?
My plain vanilla LX with 15" non-alloy wheel date of manufacture is 9/99 and I also have the left pulling problem. I havn't noticed any shaking problem yet but havn't really paid attention to it either. I must say the pulling is pretty annoying as I don't like to steer at an angle to make it go straight. From a previous post someone mentioned he tested drove the 9/99 with the pulling problem and the 10/99 without it. Someone also mentioned Mazda has no fix for it yet. Why? I expect Mazda should come up with a fix since the ones they make later don't have the problem. But when I called the dealership the service manager said he did not know about the pulling problem.
I went through 3 sets of tires on my previous MPV and NEVER had an alignment done in the 10 years I had the van. There was never any pulling or uneven wear. Alignments every time you get new tires sounds like a line to me.
The brake pads and rotors have been replaced by the dealership in an attempt to eliminate the pulling, but to no avail. The contract specialty shop decided it was NOT a tire problem because switching the tires around [to opposite sides?] did not alter the van's behavior. They ultimately decided the '00 MPV is just extremely sensitive to road crown. I don't buy that entirely because I can be on a highway sloped to the right, yet my MPV will still tend to drift to the left if I let go of the steering wheel.
I thought the 16" Dunlop tires were suspect, however, I also experienced the drifting left while using a '00 MPV LX dealership loaner, and it had 15" Yokohamas. Interestingly, everyone with the pulling problem reports it as being to the left; I don't recall anyone reporting a chronic pulling to the right.
My dealership's service department does not know what else to try. Mazda's tech line has not acknowledged that the problem exists, let alone post a solution for it. If enough '00 MPV owners report this idiosyncrasy maybe Mazda's technical department (design engineers?) will figure out the root cause and issue a tech note about it.
Vanfan2, you said the spin balance helped, but you're beginning to think it's the tires- has your van started vibrating again?
Also, another poster on the cruisers with the vibrating problem has had the tires and rims all replaced and it still does it! Last I heard they still hadn't fixed his either.
I reported several months ago about the pulling and vibration problem.
They did an alignment and the pulling seemed to stop, but it has since returned, although not too bad.
However, the vibration is absolutely terrible. At highway speeds above 65mph, the steering wheel shakes so badly, that after about 15 minutes, my fingers go numb. I kid you not!!!!!
The Mazda dealership will not help me because they say that they are not allowed to take the van above 65mph on the highway. The problem doesn't happen until closer to 70. They said it's a legal issue, since the speed limit is only 65mph (although most go about 80 around here!). Therefore, they will not help me.
For reference, my manufacture date is 7/99, I have an LX with the touring package which means 16" Dunlops on Alloy Wheels.
Based on all the responses so far, It seems that 7/99 and 8/99 have responded more often than anyone else about having this problem.
Could it be that there is a problem with a specific batch of tires or with a batch of rims???
I haven't rotated the tires, so I don't know what if anything that would do. What if I was to switch front to back tires???
Any thoughts as to what my next move should be? What is Mazda's number that I can call to complain?
Hope you find a solution to your problem soon!
You would think that unresolved vibration problems, as INTENSE as RRB describes, would qualify your vehicle for lemon law coverage. Sounds dangerous to me. Keep hounding Mazda!
This might sound like a dumb question but since things are always changing I'll ask anyway.. What's the best way to break in my new MPV? The old (not that Old) conventional wisdom said "Don't go over 55 mph for atleast 600 miles..." Any mechanic types have suggestions?
Silver (...I guess...) Driver
VERY annoying ! Will have it fixed at the dealer.
My dad, who has a 1996 Ford Windstar (with 210 HP) drove it for the first time last night and found it quite powerful... He was REALLY surprised when I told him that this marvelous van had "only" 170 HP !
BTW, when I went at the gas station yesterday, someone aboard an Odyssey looked at my marvelous MPV pointing. Probably saying to the driver: "Look at that marvelous van ! Too bad we didn't even give it a try..."
Silver (The Marvelous) Driver
1) Compression Ratio, so you would need different pistons (10.25:1 v 9.7:1 for the standard) I don't know what this would cost
2) Different camshafts, about $1350 for parts alone. I think the individual cams are over $450 times four.
3) Different flywheel (you might live without this one.
4) Extrude Hone intake manifold. It looks like you could go with the upper only, ($140) as the lower manifold looks pretty smooth already.
5) Different throttle body. I think 66mm vs the stock 60mm. Although, I believe I've read that the later model duratec's use the larger 66mm version.
Probably not worth the cost, just find a totaled SVT (hit from behind, and buy the engine.)
Cheers,
TB
By the way, I have noticed no vibration or pulling to the left problems. I believe my van has a 9/99 manufacture date.
I'd try that before bringing it up with the dealer.
Does anyone know if the 2000 MPV is the same tranny as older models? Like the 93's or the late 80's.
Does anyone that has read those posts have any comments about any of those complaints.
Being a new owner I almost wish I did not read all those posts.... but I would really like to hear Mazda has redesigned the tranny since those models.
Mine is one of the posts you refer to. The tranny in my '89 MPV failed after 88K easy miles, at a cost of $2000. Mazda gave me the corporate shrug when I expressed my sincere disappointment. That's the bad news.
The good news is that, aside from that one black eye, our MPV has otherwise been a very good vehicle and we still really like it. It currently has 113K miles, has developed a few rattles and quirks now, but still runs and looks great. The integrity of the body and interior has been excellent.
My point is, I would not have any qualms about buying a new MPV, and would be no more concerned about the tranny in the new MPV than I would be about the tranny in any other new vehicle.
We bought a 2000 Odyssey last fall because our top priority was size--leg room and cargo room (we've outgrown our MPV). But, if the 2000 MPV had been as big as the 2000 Odyssey, I'm sure we'd have two MPVs in our garage now.
