Creaking/starting problem
I was having the same problem with the creaking in the left hand side of the dash board. I brought it in to the dealership and they fixed it on the first try. I am still having problems with starting it every once in a while. It hesitates when i turn the key and i have to hold it for a few seconds. Did anyone else get that problem fixed yet? I brought it to the dealership and if they cant fix it im calling the main honda place and talking to them about it..
http://www.petitiononline.com/03Accord/petition.html
1) AS far as the friver seat goes, mine does the same thing, it may be inherint in the design.
2) Door not sure what the problem is
3) THe center console has been redesigned. Give your dealer a call.
Good luck
Here is the link to the TSB (Tech Svc Builletin) which you should print and take to the dealer.
This is a known, and frustrating problem on new Accords.
http://152.122.48.12/prepos/files/Artemis/Public/TSBs/2003/SB-100- 01480-3093.pdf
They ordered a new track for my power seat and a new center counsel door to fix the rattle.
I will check the links above and go back to them with that info.
What a hassle. I am regretting passing up the 0% financing on the domestic cars now as the only reason I went with a honda was to avoid problems like this.
Please keep us posted if replacement of fuel pressure sensor helps.
I was the one that started the petition mentioned above, the situation right now is that I have about 100 video clips of me starting the car over a 2 month period. About 20 of them show the starting problem. I'm going to contact Honda soon with my evidence of the problem and will try to get it settled, I will post results soon.
Alex
the chances are small, but why not just change it and be done. could also be a computer fumble on the edwards end, but I haven't seen them boast ^h^h^h^h^h apologize about one yet.
But don't worry, they don't keep your identity. Once they log off, it's done.
If these posts distress you, let me know where they are and I'll delete them for you.
MrShiftright
