on a good note, someone on cadillacforums for whatever reason put a 4.0 into his cadillac (used to have 4.6) it physically fit in and all, just the wiring didn't match up
funny thing is, in a luxo sedan comparo, the sts and aurora were in there, 4.0 aurora weighs 3800lbs. 4.6 cadillac weighs 4000lbs. the cadillac got better gas mileage.
http://www.fueleconomy.gov/feg/feg2000.htm
In 2003 they just list one. In 2004 the STS is rated 2 MPG's less than the SLS. The same is true for the DTS and the deville. The highway numbers for the 4.6 with the 3.71 axle is 24 while the 3.11 is 26.
It's also strange the EPA has a listing for the 2004 STS considering there is no 2004 STS.
Go figure...
The 275 hp 4.6 has its peak torque at 4000 RPMs while the 4.0 Aurora is at 4400. The peak horsepower is at 5600 for both engines. The point is that there is some tuning diffence there.
One real world difference is that the Aurora has the power mode switch on the transmission and Cadillac does not. So if the Aurora is always in the power mode, it could do more downshifting burning up more fuel.
They dropped the power mode switch. I found that useful (when I remembered to use it) for passing on two lane roads.
http://www.auho.com/contents/cars/Oldsmobile-Aurora.shtmlver .
sorry for any confusion.
The car also has the 'gold' option - any like to trade their silver badges for gold ones?
I'm about to finally get the '01 4.0 from the wife after buying her a new car. I have noticed that she managed to scratch the wood trim on the console but not badly. Is there a way to fix this up? Do you know what finish the factory supplied? spar varnish, polyurethane, etc.
Thanks in advance.
Well, I think mine is gone.
I just bought the car, and it seems that I have both side 'chin-straps' (about 12" long or so) but there is a long empty area between the two.
Should I go buy one?
Does it really matter besides looks?
Does it affect engine cooling?
Greg
'96 Aurora
Yes, it does affect cooling, and you should get it replaced. I don't have the part number handy, but it was $21 and isn't too difficult to put on (hardest part is laying on the ground for the 5-10 minutes to do the work, so if you have ramps to drive up on, this will be very easy).
--Robert
Thanks-
Greg
'96 Aurora
Hope this helps,
--Robert
www.petitiononline.com/GMolds
Peace.
ordered it from GM parts direct: It was I think $26 w/shipping.
I was also wondering if anyone knew how much labor/installation of the rear shocks would cost if I had someone do it. I dont have acess to a lift without paying a fee, so I didnt think that I could replace them. How many hour(s) has it taken you guys to change them out?
Ac Delco 504-96 is the part I think, I was going to order them and take the car to a dealer and have them do that along with plug and wires. Any $$$ estimations? (I'm a poor college student)
Thanks-
Greg
'96 Aurora
Unless you have a physical disability, there's no reason you cannot replace the shocks yourself. Lift not required. Removing the rear wheels (one at a time is fine) gives excellent access to the two lower attachment screws and the air tube fitting. You reach the two upper nuts for each side through the trunk. ACDelco 504-96 is correct.
BTW, what kind of reaction have you received when asking a dealer to install parts you provide?
Les
Total miles (first leg only) = 430
Average mpg = 24.4
Average mph = 51
total gallons used = 17.5
I am not finished yet, I am now in S.C. and the trip odometer now says 700 miles. I will update the stats as the trip continues.
The one thing I question about the DIC stats is the average speed. I was on the NJ Turnpike and Route 95 doing between 65 and 85mpg for 90% of those miles. How in haydes did the DIC get an average speed of 51 mph?? Does the program count the time you spend sitting in a parking lot? The 51 mph figure is just too low.
I know the computer on the 95's dont always record an accurate speed when you pull the history on the car from the computer. However, I always knew the computer to read an artifically high speed, not
one that was too low.
Persoanlly I think my average speed was closer to 70 mph.
Henri
Back in Michigan after 3 weeks in Wisconsin as part of a new job. I have been driving a 2000 Chevy Silverado for the entire time and as nice a truck as it is, it was a treat to be able to hit the highway with the Aurora this evening. It's nice to be home for a few days and really nice to be back in my car.
P.S. I think I've finally convinced myself to pick up the Corsa exhaust...I'm thinking around August or so.
-Brian
If you call Corsa, let me know what they say about the continuing/ongoing availability of the exhaust (since the old STS model, like the Aurora, is no more). I figure August would be a good timeframe for me to get one, too.
--Robert
I feel pretty confident that Corsa will continue to have the '99 Seville system available for some time. It's available from any GM dealer now and part of their GM Restoration/Accessory site as a licensed product, so I think it'll stick around. Once I get closer to picking it up, I'll drop some updates.
--Robert
The few GM dealers that I have talked to do not jump for joy when I mention the possibility of me buying parts and having them installed by them. After I told them they would be all AC-Delco/GM parts (plugs,wires,etc) they were a little more open to the question.
I dont think they have a problem with it as long as they are GM parts.
I explained the price differences and all, and my "college student" status, and they thought they could probably fit me in if needed.
Anyone else tried talking to dealers?
Greg
I actually saw a white diamond 98 with 51k on a lot down here. Even though my 95 has made me the Shop King, I still dont want to part with it, too much history (81k miles) with the car.
Henri
Only 81k? Heck, I'm up to 83k on my '98 (and it only had 27k on it when I got the car over three years ago). I obviously love driving the car, too (it's a great freeway cruiser, riding in comfort and style).
Wishing I could do my penultimate driving trip, circumnavigating the U.S. (one of these summers, since I have been at my job 11 years and have 4+ weeks of vacation that I don't all take, *sigh*)
--Robert
Hey Robert, when you get to the Northeast on your road trip look me up. Just look for the "champagne" Aurora with the stock exhaust.
Details to follow. . . .
Javi.
1) I thought 97's had the stiffest susp? That's doesn't include the bars?
2) Can anyone definetly say that the STS front bar will not fit?
3) I wonder if they were variations from year to year differences on the STS's like our Auroras? If so, what's the best?
4) I would need to know what else is required besides bars? I saw someone replaced the endlinks and bushings with polyureathe. I what like to do this as well. Anyone know where I can get them?
1) Stiffest of what? Auroras, yes. Cadillacs, I don't know. The Aurora rear bar is hollow 17mm; the STS bar is 22mm.
2) Don't know. I recall that Henri said the STS front bar is 29mm -- same as '97-'99 Aurora (earlier ones may have been smaller).
3) Don't know.
4) Try Energy Suspensions and Quickor for polyurethane bushings and end links. Our Auroras have bushing brackets that are P-shaped and retained by a single bolt, unlike most brackets that are U-shaped and retained by two bolts.
Les
Total gallons = 98.5
Problems encountered = (zero)
Times it did the 1 second start delay = 7
One thing I did notice is that the car is back to doing the 70mph "shake rattle & roll". Time for the tire rebalance.
Henri
P.S. The dealer in S.C. had sent out the white 98 to have the bumper painted when I returned during business hours. I never saw the car again because I left before it came back.
I wanted one last year but couldn't swing it financially. Things have loosened up and it's time to move.
Bryant, if your still out there, how is your holding up? I assume the one at your dealership is long gone.
--John
--Robert
who is using AutoTrader to keep his eyes open for a cream puff black '02 or '03
What'll you be upgrading from?
Hammen - Bryant sent me a lengthy email today alerting me of your find on ebay. I'm going there next to research. Thanks.
RJS- I currently have a '53 88 and an '01 4.0 that the wife won't part with even though I offered to buy her a new car. What wife would do that?
Certainly, I'm no stranger to Olds. This will add to my cars; not be a replacement. No, I haven't told the wife I'm NOT getting rid of the pick-up truck. Besides, I would never haul dirt bikes and quads on a trailer behind an Aurora!
I'm in no rush other than pure desire so I can wait for one. I have some leads to check on a 2003 at a dealer with less than 4,000 miles on it but the 500 is the dream.
John
It is far better to make your email address public in your profile than to post it. That way someone has to be a logged-in legitimate Town Hall member to see it. Posting it lets all the spam-bots in the world harvest it, but making it public in your profile keeps people who are not logged in from seeing it.
You might want to delete your message and repost without the specific address - you can make it public in your profile - that will serve your purpose without the headaches.
Trust me.
