I just installed the Borla exhaust on my 2002 Impala LS... It looks and sounds great, and the build quality is great. It's a dual exhaust and have dual rolled angle cut split rear tips. I love it, but it DOES NOT come with everything you need to install it! Since the Impala comes with single exhaust, you need to have another hangar on the driver's side to hold the second muffler. Well Borla gives you another hangar but there is no where for it to go! I am going to go to my dealer tomorrow and get another stock style hangar and mount it there. Check out this link to see what I mean.
www.impalahq.com has the directions for removing the instrument panel faceplate that extends from the driver side to the passenger side. it took me 20 minutes the first time, i recommend printing out his instructions and having them beside you while you do it. the Instrument cluster looks like it had a single connector to the cars electronics (though i havent complete pulled it out yet).
Is it a problem if I change the oil myself or have it done in a shop? Does it void the warranty? Dealer charges a fortune for synthetic oil so I'm thinking of going elsewhere.
Yeah, I have mine up with a coat hangar right now... but I'd like something a little more stable for my $700 Borla system and my $27000 new car! They will either send my a new hangar or reemburse my for whatever I decide to do.
Change the oil yourself! It can't void the warranty unless you do something wrong....
I want to replace my instrument cluster with the one from the Sport Appearance Package.... if y'all come up with anything let me know please! Thanks!
If you do change the oil yourself, keep all the recepts and maintain a good record (date of change, mileage, etc). It won't void your warranty, but if you need service, they will ask for proof that you kept up with the maintance.
I believe the police cars have the base instrument panel (no tach). Maybe they changed with the 2002 version. It should be a easy swap out, however the odometer does not auto-update. For instance, if your car has 10,000 actual miles on it and the gauge from the doner car says 30,000 miles when you install it in your car, the odometer will still read 30,000. The dealer can re-program it for you, the question is will they and how much would it cost.
Do not use Fram, Penzoil, or Quaker State filters (all made by Fram), and do not use Penzoil or Quaker State oil (They don't hold up well). Don't use any "no-name" generic filters or oil either. Stick with recognized brand names, except the aforementioned.
Mobil 1 is an excellent synthetic, available for a decent price at Costco. Mobil 1 oil filters have an excellent rep, as well. Amsoil synthetic oil and filters are considered to be among the best by many "experts", but are pricey.
What's wrong with Pennzoil oil? I'm just curious. That's what I've always used and we've had cars run well over 140,000 miles and still running great when we sold them. I'm not saying it's the best I've just never heard of any problems.
I guess it's OK, if you change your oil every 3000 miles or so. But, the prevailing opinion by almost all pro and DIY mechanics that I've encountered is that Pennzoil and Quaker State (both Pennsylvania crude) break down long before other non-PA brands. I don't know if they still pull oil out of the ground in PA, or if it's just a certain grade or refinement process. Does anybody else here know?
If your speedometer/odometer is changed usually because it is broken the last mileage indicated is suppose to be documented and a sticker or paper taped with the information usually in a visible location. Most often it is placed where you open your drivers door just below the lock mechanism. If you replace it with an odometer that already has mileage on it, this information should also be documented. The idea is to give an accurate mileage of the vehicle when it is sold and also for warranty purposes. I believe its the law.
I spoke to the service manager at the Chevy Dealership where I bought my 2001 Impala LS, regarding motor oils. This Chevy dealership uses Quaker State (peak performance motor oil) exclusively. I have a Quaker State oil container and it states that it exceeds all specifications that are required for a 5w 30 or 10w 30 motor oil. I went to our local auto shop and read the Penzoil label. Also exceeds all requirements.
Jeff Gordon #24 has been sponsored by Quaker State for the past few years in his Nascar Monte Carlo. Steve Park #1 Penzoil is his sponsor for his Monte Carlo. John Force is sponsored by Castrol GTX in is Mustang Funny Car. I personally believe that all popular name brand multigrade motor oil blends available meet or exceed all specifications that our Impalas' require. Its just a personal preference.
Its just like gasoline they all have their own additives. As long as you use at least an 87 octane gasoline for your Impala thats all that matters.......
I have also heard that for over 20 years. They emulsify faster than other brands. I used quaker state in my Camaro a couple of times and it literally couldn't take the heat. The oil pressure would drop after about 1000 miles.
Well, you can use what oil you like. But I certainly wouldn't view a paid sponsorship as some kind of personal endorsement. We don't really know what oil they actually put in their engines, do we? We do know what brand of oil is painted on the side of the car, though. Even if they did use it, they change it every race, along with many of the internal parts, no?
I'd be more apt to listen to mechanics and shadetree types like b4z than almost anything said by almost any dealership mechanic. Shoot, if it wasn't for warranty repairs, I'd never set foot in one.
BTW, Wal-Mart brand motor oil (powertech or somesuch) also says it meets or exceeds etc. Are you gonna pour that in your engine?
You can find a 100 different mechanics, and some will tell you that Fords are better then Chevys. Some will say Chevys are better then Chryslers. etc etc.... If ALL mechanics believed in one manufacture example FORD. Then ALL mechanics would be driving Fords. Its obvious you had a bad experience with your car. I know Camaros/Firebirds and Corvettes from the late 60's to the early 90's had poor engine reliabilty with the 350's that they used at the time. The California Highway Patrol (CHP)bought several Police package Camaros in the late 80's and most didn't make 6 months before the engines self destructed. They were probably using Mobil oil and that caused all the problems. Ya thats it!! Articles were in Motor Trend and Car and Driver at the time about Chevys 350 engines not being up to snuff. For years (CHP) refused to buy from General Motors because of the costly engine problems they had experiences with their Camaros. Many of the oils that stores like Wal-Mart etc sell are made by larger companies such as Mobil, Quaker State, Castrol etc. They just brand it with a different name, and make it to their specifications. As I stated earlier my General Motors Chevrolet Dealership uses Quaker State. Quaker State is the only oil company that offers a 10 year 250,000 mile warranty if you use their products in your new vehicles. As I stated I don't prefer one oil over another. If you are going to drive 50 miles to another GM dealer because you like the color of the label on the Mobil containers then I guess thats your perogative. I am no expert on oil, gasoline or any other part you need for your car. I do know that large companies like Fram, Quaker State, Penzoil wouldn't be in business for years, today if their products weren't bought by many satisfied customers. Its obvious you had a bad experience with your Camaro. Because they no longer make Camaros what does that say for them. Camaros major competetor The Mustang was there since 64' and sales are going stronger then ever.
If you go to Google and type in Pennsylvania Oils, read all the sights (I read several) I didn't see one negative comment about Pennsylvania oil products, as you state. Some sights compare to Alaskan crude and state that Pennsylvania oils are superior in many ways.
Maybe you should be less patriotic and just demand oil from Iraq....
Well I think everyone has made their point regarding oil. I was only wondering why garypen doesn't like Pennzoil. And despite his explanation, I think I will still use it. I'll let anyone know if my oil pressure goes down!! And since I actually have a Monte Carlo SS and not an Impala (as my parents do, which I have driven a lot), I will be able to tell because I have an oil pressure gauge. Hope nobody minds me participating on this board even though I have an MC, hey it's almost the same car!
Well I went by the dealer today to get my extra bracket for my exhaust and I saw an 03... The Rocker Panels are grey plastic!!!! Can y'all believe they would do that??? it's the cheapest looking thing I've ever seen..... I'd be pissed it I would have waited for an 03 and got that... I can't believe they did that... and I was petitioning for body colored side moldings.... HA!
You guys go ahead and put whatever you like in your crankcase. All the evidence really is anecdotal. But, personally, I will avoid something that so many people have recommended to avoid. Even if there's the slightest doubt, I will not take that chance. I don't care if these brands are recommended, especially by people who are paid to recommend them. After all, plenty of doctors did cigarette ads back in the 50's.
As for Fram filters, and Quaker State and Pennzoil filters which are simply repainted Frams, I would not ever put one on my engine. Ever. They are absolute crap. Poorly designed and shoddily constructed of cheap materials.
The can can be crushed in one hand. The filter element is too small. The bypass doesn't work. End the element end caps are CARDBOARD. It also says something to me that Pennzoil/Quaker State is willing tp put their names on that garbage.
Finally, Quaker State owns Slick 50, worthless snake oil that may actually do more harm than good for your engine, that is more suited to late night infomercials like its formulaic cousins, DuraLube and ProLong. Again, what does that say about the company?
There's really no difference what brand oil you use as long as it's a major brand name. Same can be said about gasoline. Here in Southern California, I use Arco gasoline because it's the cheapest compare to Chevron, Texaco, or Mobil.
It is highly unlikely that my Impala will break down because of the brand name I choose for oil and gasoline. Good grief. Go ahead and spend premium money on whatever brand you choose. Chances are my Impala will last just as long has yours regardless of what major brand name I use.
I think you guys may be reading too much into my Camaro experience. This is one type of car and one type of engine that runs at an extremely hot temperature. If my Impala were ever even get close to 220-230 degrees I would be at the dealership so fast it would make your head spin. In fact, if my Impala were to even got to 200 degrees I would run to the dealer. This is how I discovered that my upper intake manifold was warped. I had been smelling anti freeze on and off and noticed that while at a McDonald's drive thru the temp was slightly abve the halfway has mark. I had never seen it this high before. Our Impalas and Monte Carlos will never run as hot as my Camaro. It doesn't make a whole lot of difference to me what I put in the Impala. Because it will never stress the oil. But the camaro gets Valvoline HD Racing 20w-50. The only dino oil that I have tried that doesn't cause my oil pressure to drop. That is my experience from almost 70 oil changes and after trying Quaker, Pennzoil, Castrol GTX, etc. in the Camaro. The quickest oil pressure drop occured with Quaker State. In 1992 i drove from SC to Chicago and by the time I had gotten to Kentucky, (less than 400 miles) the oil pressure ahd already dropped. That's all I've got to say about that.
I still wait for my preferred oil brands to go on sale. I certainly don't believe in wasting money. They're all priced around the same, anyway, so money really isn't the issue.
As for gas, I definitely do notice a difference. I recently switched to 76 here in CA, as they don't use MTBE. What started out as a purely environmental decision turned out to have the pleasant side effect of boosting my car's performance. (XJS, not Impala. I haven't tried the it in the Impala yet.)
Ok - here is an update to last weeks discussion and solicitation for input. I used GMBuypower to find a black/neutral LS since I prefer the lighter interior. Its a tough call to pass up the exhaust/strut brace/gauge changes in the Sport app. pkg., but I prefer the lighter interior.
Here is the final offer: MSRP: $26,840 (neutral lther, sunroof, upgraded stereo) Sale Price: $21,265 (w/rebates/holdbacks) My GM card rebate: $4000 My trade: $9000 Final price: $8265
I am adding the tailight covers for $250 and may add 17-inch rims. Anyone know if the 1996 SS rims will fit this car?
Don't feel bad garyw, you did the right thing!! The LS has the same strut tower brace and exhaust system as the Sport! It's just the Sport has a chrome exhaust tip... The instrument panels are different, and I'm trying to upgrade my LS to the Sport Instrument cluster right now....
No the LS doesn't have Oil Pressure or Voltometer guages... Nor does it have a 140mph speedometer like the Sport Package.... I'd like to get one from the Sport Package to put in my car so I'd have those 3 features...
ATBEAR - at lunch I went and looked at an LS w/sport pkg. and saw that the gauges were not white faced (I thought they were). Other than that the changes are barely noticeable. The carbon fiber does nothing for me. Thanx for setting me straight on the strut brace. And I can throw a chrome tip on the exhaust for $100.
The rims...its all in the rims for dressing it up. I just have to find a good deal on some. I wish the 96 17's fit so I could keep it factory fresh. Oh well.
There is also another Borbet thats pretty nice. One of the guys on here but ICW's on, but they were 18's. You can also go to cardomain.com and look at some of the impalas there although I lot of them are too blingbling for me. I am not a big fan of a lot of chrome. I prefer the polished, silver or machined face like my '01 LS.
I use Fram and would never use Pennzoil. Fram filters have worked fine for me for 250,000+ miles. Pennzoil causes too much brown sludge. I don't like it.
Gotta put in my two cents.
Sounds like they're cheapening up the Impalas. Bummer. But, when I still have mine looking new in 20 years maybe it'll still be one of the best ones.
FWIW.......I've been a mechanic for 30+ years privately and professionally. I've built many engines from 1 cyl to 8. I've built/restored cars from the ground up.
Any oil can cause sludge or other related troubles if you do not change the oil often enough.
Customers of mine have used all of the main brands and off brands too. If you do not change the oil often enough there will be trouble.
Use the products that you decide make you happy. IF there was a major defect in certain filter designs , think about the large exposure to lawsuits if these designs did not function correctly in the real world.
With that said ....... yes there are some chaep filters and others that are greatly better in design and performance.
My father had a 67 Elcamino with a 327 V8. Nothing but Pennzoil and some STP went into the engine. At near 100k it burned a valve. He pulled the heads off (I helped, although I believe he used words "get out of the way"). The engine looked like it was new inside. Very little deposits on the internals of the heads or in the valley under the intake.
My father was a lubrication foreman for local construction company for many years.
Most drivers that rant about certain oils and filters (good or bad) would not know which end of a wrench to hold.
I am not flaming anyone here, just pointing out what I have seen as an owner / mechanic over the years.
Again......use the products that make you happy and you feel safe using them.
I don't drive my car regularly and it takes more than 6 months to obtain 3,000 miles. Should I change my oil every 3,000 miles or should I be changing it before 6 months? I know it is not good to leave the oil in the engine after a certain amount of time, but I do not know how long this is and that is the reason I ask the question stated above and since you are a professional, I thought I would pose the question to you for your advice. Anyone else's advice in the matter is appreciated as well.
Mixing different brands of oil will create no trouble. I have used 3 different brands at once to fill an engine of my own when I suddenly see that I have forgotten to buy oil! Several different lables are packaged by the same company. Valvoline oil is sold under many different brands as an example.
Mixing weights of oils does not hurt things. Mixing synthetics and dino oils is fine. Most of these manufactures will tell you not to mix oils, but I have never had or seen a problem with mixing and I have done it for years.
Mixing specialty oils may not be wise. Oils for 2 stroke type engines should be separate too.
There are different rated oils for diesel engines than gasoline engines. These oils deal with the by-products of diesel combustion better than oils for gasoline engine.
Changing oil by the length of time would be determined by the climate that you leave in. Here in AZ I would let oil go for 6 months or more, then change. I have a chevy motor that I have not changed the oil in for over a year and less than 400 miles on it. If you are in a most/cold climate then 4 months would be better in low miles , short distance driving.
Some of you middleaged folks may have heard of the mixing of trany fluids and things turning to gooo. This was true decades ago till the use of whale oil was banned in the early 70's (if my memory is correct).
On the subject of trannys..... late model Chrysler products function better with Mopar brand fluids. Primarily cold driving climates is where this fluid functions bettter. Some imports require certain fluids in the trannys. There are additives that modify Dexron fluids for these apps and sem to function fine.
Power steering fluids should not be mixed. Some of your imports will require appication specific fluids.
I agree with crosley4 but add--- be sure the oils you use meet manufacturer specifications as noted in your owner's manual. The manual states use oil with the API star burst symbol and the proper SAE viscosity for the temperatures you operate in. Also on the oil container there is a API service designation like SJ,SH,SG<SL. It is my understanding the higher the letter the better. SL is better than SG. The highest Ihave been able to find is SL. Mostly, I change oil 2500 to 3500 miles. Some 30+ years ago I bought a 1950 Cadillac with 80,000 miles. When I changed oil, I had to poke a hole in the sludge to get the oil to drain. I flushed the engine with GM engine oil flush, changed the oil a few times at short intervals and have no evidence of oil consumption ie smoking, plug fowling,blow by at the road draft tube etc. I only drive the car 200 - 300 miles a year so I can't get an accurate oil consumption reading. The oil has remained clean over the past 30 years. I change it each fall before I tuck it away for the winter. So far - no problems. My 1993 Cadillac which has a 350 Chevro0let based engine has 104000 miles and does not burn oil between changes which are also at2500 to 3500 miles. Keep it changed and clean is the secrete to engine longevity. Enjoy the ride.
I'm selling a new set of Eibach Pro-Kit Lowering Springs. Don't really have the time to put them on right now, so I'm selling them so I'll have a little extra cash. They're brand new- never installed, let me know if anyone is interested. Either leave a message, email me at atbear@cox.net, or check out ebay auction # 1864179677. Thanks
We have a base model 2002 Impala, 3.4L, purchased new.
Shortly after we bought the car (October 2001) we noticed that the temp. gauge (dash gauge) fluctuates a lot. More than any other vehicle I've ever been in. This car never holds a steady temperature. When warm, it will run around 185-190. However, the gauge will invariably "hop, skip, and jump" around even in short 5-10 minute trips. Often, it reaches the middle mark (200* F). It will only stay this high for a few seconds, then begin to drop again. On more than a few occassions, it rose well above the middle, reaching almost 215* F a few times.
I checked the coolant during the first week we owned it, and it was full (exactly at full cold line when cold). I checked it at least every month, and nothing changed for 1st several months. I figured perhaps the temp. sensor was bad or the thermostat wasn't very good, and I would just keep an eye on it.
However at about 10,000 miles (mid April), I noticed the coolant began to drop. It is now pretty low (at 15,000 mi), but there is still some coolant in the expansion tank, even when engine is hot.
I have never observed white "smoke", or any antifreeze dripping or puddles. But it is possible I missed this since it's only a small amount of coolant lost so far. I know the coolant did not just disappear! We have smelled something like antifreeze on a couple of occasions while driving.
I am about to take the car in for it's first warranty visit (the driver side "auto down" window feature hasn't worked since the first month- we didn't really care enough to take it right away, but want to get it fixed).
Anyway, what are your thoughts on the coolant issue? Anyone know what the problem is? Similar experiences? Does this engine (3.4 V6) have any common problems that could be the culprit (head gasket, intake manifold, etc)? All help is appreciated.
Any advice on how to approach the dealer with the problem (ie.- state the symptoms and act dumb or tell him what I think problem might be)?
Our '88 Buick Electra had no problems w/ the 3.8L V6. I like the 3.4 performance just fine, but I'm starting to wish we had looked for a base Impala with the 3.8 option.
http://www.lynoise.com/images/borla/driveHanger.jpg
My trade: $9000
Final price: $8265
Impala SS rims will not fit those are RWD rims not FWD.
Bill
There is even a Spring Break event in Daytona called, whatelse......."SpringBling".
Who was that great philosopher who once said, "I got my mind on my money and my money on my mind?"
Since you're a professional, what's your opinion on changing oil brands every now & then? Is it important to stick with the same brand?
I hope this helps some.
Tony
Thanks in advance.
