Toyota Tacoma: Problems & Solutions
Only advice (and I may be repeating myself) I have now is for you to write down exactly what the conditions were (e.g. had just washed the truck, been thru a snowstorm, whatever), and what you observed, and what happened between when it wouldn't start and when it finally did. If you've noticed different symptoms at different times, make separate lists, noting the details for each. Then, take a break, and come back to your list after a while and make sure it makes sense to you, and describes everything you observed. This will maximize the value you get from the independent mechanic as it will take him less time to understand what it is that you've seen/heard.
Cheers
I got a real nasty reply and they said they did not know if any productions were made.
Quote from them below.
("Technical Service Bulletin BO004-05, Front Cowl Water Leak Repair Procedure is dated March 17, 2005. We do not have any additional information on when any production changes may have been made, if any.
Toyota makes all TSB available to the public for purchase, through our Material Distribution Center")
kbshadow.
Here are some pics of my 05' Impulse Red, DC LB, TRD Sport... I use Zaino. First time user and now an ALL the time user. Since the pics, I have added 2 more coats and now even with a thin layer of California dust on it, it still shines like it was just waxed. The durability of Zaino is incredible.
A friend just showed me his black civic today with a "NuFinish" wax on it. Great look, very clean... you can tell it was waxed, but the "deepness" isn't there. There's something about the Zaino stuff that just makes the gloss have that "deep" effect to it... Check out the Zaino site for tons of info on washing. Also, do a search on the other forums and you'll get tons more on detailing and washing...
Anyway here are the pics... flip through them and pay attention to the reflections. The pics were taken on a very overcast day...
http://www.ofoto.com/I.jsp?c=ei9mlyj.e0gfn2r&x=0&y=i17mz5
-lomares
kcram - Pickups Host
The button on the gear shift will not compress to allow the trany to shift into any gear. We have rocked the vehicle, put on the emergency brake and pulled as hard as we are willing to pull on the stick shift with fear of breaking something.
If you have any experience with such a problem or any ideas of what to do please reply or call 707.894.5966 Major Thanks!!!!!!!!!!!!!! :confuse:
You put a screwdriver in a slot by the lever and push something down.
Don't have the manual here so can't look it up for you.
Best I can do, sorry.
kbshadow
The interlock will not allow the lever to be shifted from park to reverse until you have depressed the brake pedal. However, this interlock is "by wire", using an electrical solenoid motor to disengage the lock. If you have insufficient electrical power, or a bad brake switch (at the pedal), you may have to manually override by removing the small plastic cover at the base of the shifter, and using a screwdriver as described in the owner's manual. Then bring it in for repair.
I have found that if I don't press the brake before I put even the slight pressure of my hand on the lever, sometimes the shifter will not move unless I release the lever, press the brake and try again.
I had previously taken it in before the bulletin and they said "nothing was wrong." After the bulletin, they were able to detect the leak and seal the seams. You cannot tell the repair even happened, because it all happens underneath the windshield cowl.
I have two problems that I want to try to fix this weekend on my 1996 Toyota Tacoma 2.7L 4x4 pickup-- one is the starter, and hte other I think is the fuel pump. My questions are, do I have the diagnosis right, and is there anyone else out there who's done these repairs who can tell me how hard they will be to do myself or tips of things to watch out for.
On the starter, basically when I turn the ignition, all the lights are on and the battery seems okay, but I get a loud clack noise and then nothing. If I try this a couple times, the thing starts up. So I figure I need to replace the starter.
On the fuel pump, every couple of days, when I start up the truck this motor comes on real loud right near the driver's side in the dashboard, it sounds like. It runs for several minutes and during that time the engine sometimes sounds like it is going to cut out. I can't drive during this time. It sounds like there's some liquid rushing around. I am assuming this is the fuel pump, and that it needs replaced. Anyone have any suggestions on this?
I don't have a ton of experience doing these repairs myself (I've done sparkplugs, brake pads/rotors, oil changes, etc.) but I'd like to learn, so am wondering if these are too tough or hard to get to to do myself.
Thanks a lot,
Tacoma driver in CT
Thanks for any advice.
I have a 2004 Camry also and that car is probably the most air tight car I've ever had. I swear though by those VVTI motors. I had a 2000 Corolla and I never had any problems with it even after 210,000 miles.
He did a compression test and said the No. 1 cylinder is only compressing at 100 pounds while the other others are at 200. He said that's what could be casuing the misfires.
Now, he seemed kinda shady and as I was watching him, when he had the compression tested in the No. 1 Cylinder, he only spun the engine once. And when he put it in the other cylinders, he spun them several times. I was wondering if this was some kinda "shell game" just to get me outta there casue he didn't want to spend the time really troubleshooting it. He seemed kind of pissed off cause I mentioned to him that it was still idling a little rough and just wanted to get me outta there.
He said I'll be OK at high RPM's and since he cleaned the fuel injectors, I have to admit, it is running a lot better.
It's just when I idle, it's a litte choppy. And if I just bring up the RPM's another 100 or so, it stops. I was thinking maybe the idle is a litte to low. It's at like 750 RPM's now.
But I'll never get past inspection with that check engine light on.
I was thinking would "hotter" spark plugs or higher octane help with the misfires?
I appreciate any help
The problem: My Dad was cleaning the interior and went to wipe down the back window starting at the Sliding Window... He touched the latch and the thing fell off!!! He said it was like the latch was just temporarly attached with a preishable adhesive.
Has anyone else encountered this kind of problem? Has Toyota released any info about a similar issue? Any info on this is greatly appreciated.
(BTW, the dealer is going the fix it, but the found it really odd too!)
:confuse:
John
Good luck!
Boo
As for paint chipping, I haven't seen any yet on my Radiant Red. I agree with anyone that says that paint chipping happens, because it has on all my previous rigs and in strange locations. There is no spot a rock cannot hit it seems. Maybe some good wax would reduce the chances? The splash guards seem pretty big and do a great job keeping dirt off the truck.
There is a protective strip in the paint around the bottom of the rear fender flares. Maybe an identical piece extending to the area in front of it could be an option in the future.
You should have a case # now. Get out the warranty book and file for arbritration. That's where I am at. Haven't heard back yet.
http://www.geocities.com/toytruck86/paintchip.html
Is a paint job is the only fix?
Is a paint job is the only fix?<>
I don't know what else other than not driving it.
What dates & factory are your trucks from? I want to keep an eye on mine, no problems so far.
Good luck, the chipped Speedway Blue looks horrible.
Got mine in Silver, was to afraid to go with black or indigo blue just in case I was part of the unlucky few with the chip problem.
I read about the chips but hope it has been corrected, I figured it could have just been a bad batch of clear coat at the factory, its all about chemicals, you don't add something correct or don't bake on the clear coat it would cause it to be weak and chip. (Not sure what the process is at a factory for actually doing this but paint is just chemicals). Once had a vehical re painted and the guy let the clear coat sit to long and he couldn't get it to buff as shiny as he said he could have.
Cross my fingers and will just have to see. For all of you with pictures see if you can post them somewhere on the web and put a link on here I would like to see what you are all talking about.
Thanks in advance.
Check out my picture page too look at the chipping I am receiving around my rear fender flares. Click on the My Vacation album at this site
http://lee-mackey1.magix.net/
