If the wheel balancing tech uses too thick of a lead balancing weight, it will get a slow leak where that weight is unless you pressurize the tire high enough to compress the wire sidewall as to seal the leak ( not a finial solution). My tire guy used a sealing compound to seal the whole tire to rim area. Worked OK. Hope this helped.
A few things I have learned.
1. Never use the Security Sears Die-Hard in your 300M. You will end up stranded in the middle of nowhere! (use the standard Gold)
2. Burn the Goodyear Tires (at least the 225 17s that come stock.)
3. Have the dealer put in the "front end adjustment" shims as soon as possible. You will eventually need a front end alignment and it never fails that you are going to have it done when it is most inconvenient to get to the dealer!
4. Watch the break pads (especially on your daughter's car!) They don't make as much noise as other brands when they rest against the "low wear" indicator.
5. Never let your boss drive your car. They will try to borrow it whenever possilbe!
Was this a TSB?
Still loving this car.
Like BigMike, I check the pressure regularly and add air (for $30 or less you can buy your own compressor...). I'm at 66,600 miles with two of the original Eagles left (on the rear) and add air semi-regularly.
Currently car shopping: Acura TL, Infinit G35X and MB E320. Anyone have any thoughts on these?
Still love the M, though. Not sure if I want to part with it, but leery of carrying a first model year Chrysler into the 70,000 mile+ range...
Although I don't need four doors, do need the 4 seats. That does eliminate several tasty selections, doesn' it! But then again, so does my bank account. ;-)
I just wanted to introduce myself and say "Hey, I know why you love the car cause I do too"
So. It's all stock, (cept for the radio. I had to have my mp3 player which took negated my amp but i'll get a new one soon)
Any suggestions as to first upgrade(s) or should I have anything checked out first?
Open to suggestions.
I will get some pictures up for you all to see this thing.
Remove tire. Deflate tire. Lay tire on it's side. Inject "FLOWABLE SILICON" between tire and rim. Let sit for about 15 minutes. Flip tire over and repeat process. Reinflate tire.
Flowable silicon is also called windshield sealer. It's a small tube of silicon that is almost runny. It will seal the leaks between the tire and rim even on a rim that has corrosion.
You can also have a tire repair guy just break down the tire bead, smear silicon on it and reinflate the tire if you don't want to mess with it yourself.
I did this about three years ago. No more leaks. She just got a new set of tires early this year and one leaked. I, again, put silicon on the tire/rim and no more leak.
Meryl
aj86.
The tire dealer was very familiar with the problem. The Chrysler 300M has chrome plating over Aluminum rims. It seems as though this is not a good long term relationship. The Chrome on the inside edge of the rim where the tire seals, RUSTS, in large chunks and causes the tire to lose air. He showed me the rim when he broke it down from the tire, I could not believe the amount of rust.
Now the real bad news, I called my Chrysler dealership for rims and got a price of $780.00. I didn't think that was horrible until I found out that was for ONE RIM.
I had the tire guy clean up the rusted rims and put them back on the car. YOU CANNOT SEE THIS RUST until you break the tire from the rim. I know I didn't fix the problem only delayed the fix.
My car is a 2000, 300M with 106,000 mi. This is one of the best cars I have ever owned, and I would buy another one with no hesitation.
Instead, I just bought a new car! Really enjoyed my M, still miss it. Other than a few early, well known in-warranty issues, no problems (other than the chrome wheels). My M restored my faith in domestic cars. But, as it was a first model year Chrysler, I did not want to keep it past 70,000 miles. It was going to need work, something wasn't quite right in the front suspension... Plus, I just wanted a new car! As I do now... It's a disease.
Indy club sign-up and payment set-up
I have confirmed with the Indy 500 Festival that the Club will be able to get the same rate as last year for the Mayor's Breakfast on Saturday, 17 May 2008, which will include a lap on the Brickyard track if weather and qualifications permit. This is the same as it was last year and while a lap is extremely likely, we cannot guarantee on that point.
The Breakfast is a sumptuous affair that starts around 0830 and allows you to rub elbows [and other parts if you are lucky] with some of the festival Princesses and also perhaps interact with Indiana mayors and the race car celebrities who attend the Breakfast. You also get priority parking in close to the Pagoda, a special seating area in the stands behind pit road, and access to the garage areas where photos and autographs can be obtained sometimes. Bobby Rahal will be the speaker at the Breakfast. I will endeavor to try to get some photog work set up to commemorate the lap on the track and hopefully get it so that we can all kind of go as a group rather than the haphazard way that we got on the track last year due to some breaks in the traffic. I can make no promises on these two points but I will be trying to arrange it.
Last year there were upwards of twenty Indy cars running on the track after the Breakfast was over. There was also a commemorative pin handed out to those who got in line for one. That should happen again this year.
Arrangements have been made with a new hotel [Holiday Inn at the Pyramid] and the rate is $89 and just mention the Club when making your reservation.
Tickets for the Breakfast, etc., will be handled as follows, and like we did last year. Paulette Waters our Treasurer will take PayPal payments to her from all that are signing up if they want to go to the Breakfast and do a lap on the track [you don't have to go to the Breakfast to attend the meet] and payments of $60 should be sent to her at the attached Paypal link: Go to paypal and send $60 to: treasurer300mclub@hotmail.com
She will also take Checks:
Chrysler 300M Enthusiasts Club
c/o Paulette Waters
1270 Del Lilly Ln
Las Vegas, NV 89123-1480
Paulette will compile a list and at the appropriate time make a single payment to the 500 Festival. Tickets and waiver of liability forms will be sent to John, as we did last year, and he will distribute them the day before at the hotel or as other wise arranged for those who need it done differently. The waiver of liability is a must to run on the track. I urge you to check your schedules and make your reservations as soon as possible so that we will have a good frame of reference to deal with the 500 Festival people and can get the right number of 10 person tables for the club. As with last year, the event is a Black and White affair [checkered flag colors] so plan on wearing white and black clothing [Club jackets and hats were good] if you have it for the Breakfast. I will have assorted favors, lights, hats?, signs, etc. as appropriate to commemorate the event. Those wishing to attend the meet but not the Breakfast are welcome to do so.
I am hopeful that we can have another "once in a lifetime" event the second time around. :shades:
_________________
Mike
Anyhow, I'm in Denver Colorado & it would be cool to see some other owners who dig their 300m ride's as much as I do post on here. My goal is to make it a true 300m by modifying it to put out 300 horsepower . I'll keep ya posted! :shades: :shades: :shades:
