Jeep Owners Care and Maintenance
http://www.troublecodes.net/chrysler/
My name is Ian. I just happened to see your post on the problem with your '02 Jeep. I indeed have the same problem with my '03 Sahara. The dealer changed the Steering dampener, the shocks, and even had all tires rotated and balanced. Unfortunately, the problem is still there. Luckily the local dealer is very helpful. They are still trying to figure out what's going on.
Anyway, I did a google search and some one (who had the same problem) had the front drive shaft replaced and the problem is gone. So have you solved the shaking problem on your jeep yet?
I actually noticed that grinding noise on my 2003 Jeep, too. It is like that all the time. From what I heard, Chrysler put in a newer manual transmission since the year 2000 and everytime when we release the clutch, you will hear the grinding noise. It does not do any damage to your Jeep at all though. I think it's true because I have owned many manual transmission wranglers in the past; a '97 SE, a '98 Sahara, a '00 Sahara and now a '03 Sahara, the first two did not have that problem but the last two. Hope that helps.
I also remember something about having to go back into 2-Hi and then shifting smoothly right into 4-Lo rather than stopping at 4-Hi but that may have been my wife's Liberty manual using Select Trac 4x4 system.
Sorry I can't answer your question clearly...just trying to give you some ideas. Good luck.
Inserting the pen into each recess adjusts your clock to the desired time.
stugots39. :confuse:
I put a crank position sensor on it as well. when that didn't work I rented a code reader from local parts store. The code reader could not establish a link to the computer. there is no check engine light on, on the dash so I have no clue about codes that may be present. I re checked all fuses and most connections for corrosion and found nothing so far.
P.S. I have posted #20363 and #21372 under the Discussion Title: Jeep Wrangler. No response. If someone knows the correct place for me to post in order to receive a response, please advise. I did a search specifically and then generally on 'hardtop' and read through ten screens of messages, but none of them addressed my question even remotely. Thank you for your assistance.
Other than the Mopar stuff the dealer recommended I don't know. Anyone?
Thanks for the reply.
First, how many miles are most of you getting out of your OE tires? These aren't 'bald', but they're pretty worn, especially in the rear. I could probably hold out til Fall/Winter, as the car is pretty much only driven in the city and occasionally highway, never off-roaded, and my commute to work is about two miles each way, so it's only logging ~5k a year the past couple years. I live in Chicago, so snow/ice are issues sometimes. I realize wear on Jeep tires will vary widely because of the varied use of the vehicles, so I'll take that into account.
I recently saw some BF Goodrich Rugged Trail T/As on sale at Sears for $90 each, which seems pretty reasonable--most tires are in the $110-125 range. Anyone have experience with these?
I did find the following online from another website:
http://www.allpar.com/mopar/40.html
"I owned a 1992 Cherokee with a 4.0 -6. it had constant oil seepage from the rear of the engine. My dealer replaced the plastic valve cover with a die cast aluminum one with no success in reducing oil seepage. I finally traced the oil to the spin on oil filter mount. The o-rings that seal the oil filter mount are Nitrile (aka Buna-N, NBR) which have limited life at the 225 degrees that this engine operates at. Removing the mount, I found that the o-rings had taken on a set and were hard as a rock and cracking. Replacing the o-rings with the same size but with 70 Durometer Viton rubber solved the leakage. Chrysler at the time would only replace them with the same Nitrile rubber which would probably buy me 6 months.... My fix lasted the life of the vehicle."
I haven't investegate to see where I can purchase the 70 Durometer Viton rubber o-ring from. That's next on my to do list.
Thank you,
David
65 17's.
Kevin
keith
Question: Would hte engine have exploed by now? Is it likely the issue is with the pressure gauge; i.e. did i break it when I changed the filter? Or is it the actual pump? thanks
Charley
