Honda Civic Care and Maintenance
Have not really smelled the small lately. Temps are not as cold as they were when first noticed this.
Will be due for oil change sometime (not sure when I'll get it but won't wait too horribly long) and will have them check out car then.
Since I have heard Hondas can have a hard start problem I have turned the key just one notch (to let idiot lights go out) then started it up. Never have any problem with starting when I do this.
Thanks for the input.
BTW, mine's an '02 Si.
mine is a 2002 Si as well.
1. make sure the key is out of ignition.
2. turn all the knobs on the HVAC to the counterclockwise most position.
3. with the left hand hold the A/c and recirculation button.
4. while holding, turn the key to the on positon.
5. after 5 seconds you will see the recirculation button start blinking. keep holding both until blinking stops.
6. you can start the car.
when you select defrost you will be able to manually shut off the A/c. however, if you have the a/c on in defrost, it will not automatically shut off when you select other modes, but at least you have the control over a/c in defrost and defost/feet modes.
don't forget to run a/c once a week for 15 minutes to lubricate the seals, even in the winter.
Take care
option 1: spend $300-400 and get your self a decent radar detector with jammer.
option 2: Drive within the speed limit.
option 3: see solution for "Never fill up again"
Never running out of gas mode:
Stop driving vehicles with internal combustion engine and get your self a bike!
Also, replace the fuel filter and air filter. i assume it is carbeurated, have that checked out as well.
Any experience and reccommendation with the 'S' rated tires on a 'H' rated car. Appreciate all your help.
I wonder what was average milage you had on your Civic before brakes were replaced?
I have ~ 10k miles on my '02 DX 4dr and haven't bothered to check the pads.
Adding brake fluid on monthly basis is not a solution. It may cover up a future indication that brakes are worn. That's why when you get oil changed at either dealer or some other place, mechanic won't add any brake fluid. Also, bleeding process requires reservior tank being full prior starting.
I think first I'll check thikness of pads and shoes. If any are worn, replace as a pair, then fill up reservior and bleed breaks to make sure no air is present in the brake system.
Is there anyone familiar with this procedure?
...my Civic has 25K...
Part # 39466, SR4 FRL ABS.
I hope you may help me out with another question.
Let's say front pads are worn and get replaced. Will break pedal get adjusted by itself, after pads are replaced, or it has to be adjusted?
My understanding is that position (height) of the brake pedal is directly proportional to the thikness of pads and shoes (plus surface condition of rotors and drums). Therefore, while breaks are new or freshly replaced, pedal is at it's normal height. Soon as they get worn, pedal goes deeper and deeper with time. Is it so? Do you think that calipers get adjusted after/during pads replacement?
Thank you again!
myself for a friend's Civic. How much fluid is needed for each refill?
How do I get the headliner back in place at the backwindow. It has dropped
down.
As for the head liner, if it is the felt material separating from shell, you can reglue is with spray contact glue from a parts store. If the shell has dropped, swing by any auto body shop and they can help you out for a few bucks. Good luck.
That's too much money. There sin't anything special for 20K. Typical 30K costs you $200-300 bucks from dealer. You should check other dealer in your area. Most of the inspection just inspect for any wear and tear. Save your money and spend @ 30K service.
bjk
It seems to me that you are very knowelegable about car mechanics. Please see if I'm following the right path with my project. Basically, brake pedal feels deeper. I guess it's normal condition for a car with 25K. So I started from checking fluid. Fluid is fine.
Then I checked front pads and disks for thickness. All are in spec. No need to replace either(pads are 8 mm thick, disks 20.95 mm with linearity of 0.01 mm). Next I'm going to inspect rear shoes and drums. Let say those are good too. Would you say that all is left to do is just to raise the brake pedal to spec and adjust its free-play? I was thinking about possible air bubbles in the lines, but car is new from start and was never obused (hard braking, racing, etc).
Thank you in advance!
A coin has two sides as you know. One: you go back to dealer, pay the price and they "will check things" for you. I bet if you look at receipts from previous oil changes, you won't find any word saying: for example oil pressure is such, brake pads or disks thikness is such, etc. Why? Well it's too much work to do and too much to put on receipt. All it says "inspected" or "accoding to such service interval". I can give you receipt like that. Will you beleive me?
You can always verify if they do what they say. Once you get out from dealer, take front wheel off and see if they greased brake caliper bolt for example, or if you can mark oil washer prior them changing oil, you can see if they replaced it.
I know I sound very sceptical about what dealers do. I apologize if this offends any GOOD dealer or mechanic that I'm sure hard to find. But I "broke my foot" a few times...
The only positivity I have about dealer is that they do Hondas only so there is less or no chance that wrong parts or lubricants are used.
Another side of the same coin is to go to shop "around the corner" and cut the price to 1/2 or less. The problem is, you have to make sure that mechanic knows your car's specs and has appropriate tools for it. I almost had a bad experience like that to prove my point. I had Civic 00, was busy at the time - went to "arount the corner", place where my co-workers changed oil on their Hondas. Oh they were sure that mechanic knew everithing about their Hondas .So I stand in shop and watch my car's oil is ready to be filled. Then I see that a hose from the celing aproaches to the oil filling port. I'm like: "looks like same oil they put to other cars", so I asked mechanic what oil is that? It happens that oil was different from that my car needed. Then he's like "oh, you have to pay extra for the oil from the bottles". I said, I don't care that it costs me extra, as long as I know that is the right one. Can you believe that? It says right on the oil filler cap and [non-permissible content removed]__e deliberately puts wrong one anyway. Besides this, one of those co-workers paid price later at dealership for her oil change savings. Dealer had to replace oil gasket because drain bolts threads were messed up and washer was never replaced so it leaked. She had a new CRV not even a year old. So $5 change she had even for 10 times could not cover $300 bill plus headaches and lost day of work.
My advice to you is to invest $70 to buy service manual for you car, study it, may be do certain thing yourself. Even if you'll end up going to dealer or "around the corner", at least you may question and check of what they say and actually do.
Good Luck!
I've got an 1998 civic that's due for the 90000 mile service at the dealer. I was wondering whether it's worth the cost. They're charging about $450 for the service, plus if i get the timing belt changed (along with everything associated with it) it would be about $400+ more. (the belts were making screeching noises this winter and when they tightened them he mentioned getting them replaced at 90k). $900 seems steep to me but maybe that's normal?
The other thing is that I will probably be selling the car in another year or so, but i average about 20,000 miles per year so i maybe I should get it done anyway. This dealer has done good by me in the past so I generally trust them (and I'm not a car-guy mechanic, so I won't do it myself) On the other hand saving the $900 towards a new car downpayment might make more sense at this point. I just don't want the car falling apart during my summer road-trips. haha. What do you guys think?
-put the rear end up on jack stands
-spin each wheel and you should feel and hear some drag from the brake pads contacting the drum
-if there is no resistance, remove the tires and drums (you may have to smack the sides of the drums with a rubber hammer to break them free)
-adjust the calibers with a brake tool or a flat head screw driver to expand the the pads out
-only go a little at a time
-recheck each adjustment by re installing the drum and spinning it
-there should be some drag, but it shouldn't rotate to many times when you spin it
Now you can adjust any excess free play out of the pedal. Don't get carried away, it needs a little play. The only thing left after that is to bleed the brakes, but I don't think you will really need to do them. Good luck.
The official Honda Ownerlink site (http://www.ahm-ownerlink.com) answers this question in the FAQ on Motor Oils. It says your Honda is delivered with a special oil formulated for new engines and strongly recommends that you leave it in until the first oil change, as determined by your driving habits and the Owners Manual schedule.
I strongly recommend you register your Honda at that site, and enter your vehicle's VIN, as you can also get notifications from Honda concerning recalls for your specific vehicle.
Also took care into dealer shortly after I bought it and they painted areas that were scratched. Unfortunately there is some orange peel effects where they did the painting. (I had no idea what that was until someone recently pointed it out to me). Can this orange peel safely be removed and is the dealership responsible for this? (I bought it last November)
Thanks so much, really cherish my Civic and just want to take care of it...
Trust your Owner's Manual. Changing the oil more frequently won't hurt your Honda, only your bank account.
Take it back to the dealer and insist they repaint the affected panels. They did a poor job and you shouldn't have to live with it. If they give you any problem call the Honda office in your area of the country and complain. The number is in your Owner's Manual.
Good luck!
One thing I'm wondering about is the ride. For the last few years, the ride has been getting rougher. I know this may be a dumb question, but what can I do to get back the smoother ride I had when I first bought the car? Is it just a matter of replacing the shocks? I have no idea what kind to get... any suggestions?
Wm
2002 Civic Sedan DX
