Jon
I tracked down my sources, which were in recent Ford Technical Service Bulletins:
April 2004: "REAR AXLE DATE CODE INSPECTION AND SERVICE. VEHICLES MAY HAVE BEEN BUILT WITH AN IMPROPER MIX OF REAR AXLE LUBRICANT AND FRICTION MODIFIER ADDITIVE. IF SO, THE CUSTOMER MAY EXPERIENCE NOISE AND VIBRATION WHILE DRIVING."
July 2004: "MULTIPLE VEHICLES USING FEHP REAR AXLE FLUID. FLUID USAGE CHANGE"
This is after the earlier TSBs where they had not yet developed a fix other than to change the rear end out. So hopefully, the vehicles that are affected by this could benefit from a fluid change as long as it is done to the new specs.
I'm not really sure if you can just change the fluid in the rear diffs or if that fix would even improve one that had already gotten bad because of the improper fluid (e.g. same rear with new fluid). I guess they might still have to replace one. That would be something to ask the service advisors, it's beyond my technical ability. I'd definately want to ask if the rear they put on had the new fluid or if it had been manufactured before the change (to avoid a new (old stock) rear with the old fluid).
I just purchased mine a few minutes ago. It took about two minutes. Please be prepared with your credit card, VIN, and miles on the vehicle! I'M COVERED!!!!
Price was as stated above.
The seats in Explorer could use improvement. Ford should benchmark Lexus RX300 seats.
If we work out the price part, and I end up with the 03 XLT sport V-8, I will come back with tons of questions.
Thanks for the hints.
Joe
There have been numerous posts about the Ball Joints and Rear Axles on the Explorer and Mountaineer Boards, I thought I would try to clarify a few things. I realize that most of you are not mechanics as I am, and that you are mostly are the mercy of the car dealers, but some good information may be useful to help you understand what is going on with your vehicle and avoid some of the "run around" the dealers try to give you.
BALL JOINTS: The ball joint is designed to hold the suspension parts TIGHTLY with NO PLAY, the same as all other parts of the front end suspension system, including the struts and bushings. This is because the wheels are set at precise steering angles, and those angles must be maintained to assure maximum tire life and safety, even with very strong forces applied to them during accelerating and braking. Ball Joints are made of hardened steel, consisting of one part that is the ball with a threaded stem, that fits into a harden steel cup, a strong spring to hold the ball tight in the cup, has grease in it and sealed with a rubber seal. When new, it moves very stiffly and has no play. As the ball and cup receive normal wear, they remain tight to each other and have no play. As they get older and start to wear out, they begin to develop some play. With the vehicle raised up with front tires off the ground, there should be NO PLAY in ANY of the front end parts when the front of the front wheels are grasped and pulled together and then when they are pushed apart. Only the very SLIGHTEST amount of play should be detected at each wheel due to wheel bearing play. To check the Ball Joints, a jack has to be placed under the lower control arm close as possible to the wheel, raise the wheel off the ground, to "unload" pressure from the ball joints, then pry up on the wheel and at the ball joints to detect any play. ANY front end parts found to have ANY play should be replaced with new. The "acceptable amount of play" that is referred to in these post is a SAFETY ISSUE, meaning that the ball joint should be replaced before is actually FALLS APART. I maintain that there is NO ACCEPTABLE PLAY in the front end steering and suspension system for maintaining proper wear on the tires. Apparently FORD will allow your front end suspension system to get "loose" before they will fix it, as a safety issue, but I maintain that the BALL JOINTS and/or FRONT END PARTS are already worn out when they get to the point that they develop play.
REAR AXLES: Rear axles should normally operate quietly and reliably for the life of the vehicle. Only the very SLIGHTEST sound from a rear axle could be considered normal. Any sound from the rear axle that is noticeable or bothersome while driving is not normal. First thing to check is for the proper lubricant and to be sure it is filled to the proper level. There should be no sideways play at the pinion gear bearing (push/pull side to side where the driveshaft connects to the rear axle). Check Axle bearings on each side for play or noise. Other than that, there is nothing you can do without going inside the differential gears. Parts inside that can go bad or make noise are commonly the Carrier Bearings and the Pinion Bearings. When these bearings wear and become loose, they allow excessive play between the pinion gear and the Ring Gear (which is mounted on the Carrier), which most often creates the Whinning or Howling or Growling Sounds. Other parts may also fail, such as the spider gears and axle gears. It seems common at the Dealers to replace the defective axle with a new one, but often the problems reoccure. There seem to be a lot of failures with these axles. It would be helpful to know where most of the problems are occuring, whether in the bearings or in the gears. Those of you that are having these problems could perhaps inquire of details of the nature of the failure, and report your findings here.
Working or Vehicles should only be done by a qualified professional mechanic. Remember, Safety First.
I had the transmission solenoid replaced and the whining from the rear went away. It re appeared within 5,000 miles. As far as the rear end is concerned, it is whining at highway speeds between 50 to 65 mph. Any speed under or over these-it goes away. My dealer said it is not making enough of a noise to be concerned with. They said when they go really bad-they are really loud!! At any rate-I just purchased a Ford ESP warranty for around $700.00 that covers the drive train inc. the rear end. I didn't want to-but if you own one of these vehicles it looks like an extended warranty is called for!
Chuck1, that dealer is so full of it when he said "when they go really bad-they are really loud!!". That's just plain nuts! He is just trying to convince you that a little noise is "normal", or "acceptable", but he is a bald faced liar! A whine is NOT acceptable. If you test drove a vehicle and the Rear Axle was whinning, would you buy it? I don't think so. Most commonly, a whine that occurres at certain highway speeds is usually because the bearings are loose, causing a small misalignement between the Pinion Gear and the Ring Gear. The normal backlash between the Pinion Gear and the Ring Gear is usually about .008" to .010", with about a 10 inch/pound preload on the Pinion Gear Bearings. If the bearings loosen up, the backlash will increase and the Whine will start becoming noticable when backlash reaches about .030" or more. Most often the Pinion Gear and Ring Gear are not damaged, if correct lubrication has been maintained, and new bearings and new shims and new lubricate will return proper backlash to the gears, and the noise will disappear.
Don't misunderstand me, I agree with you. This noise is not normal. However, getting Ford dealers to perform warranty work is next to impossible. And it will only get worse as Ford continues to slip in their sales. So my wife and I work full time, what am I supposed to do? The only thing I could do is to buy an extended warranty, so I will be covered if/when it becomes worse. Yes, it's a sad state of affairs, isn't it?
-Chuck1
A) First, this isn't a "Problems & Solutions" board, there is one of those, but this isn't it.
You're right, this noise isn't normal.
C) I've not had any problems getting Ford to perform any warranty work - ever, I think your dealer is at fault.
D) Ford's sales aren't slipping at all - except to rental fleets, and even if they were, the cosmic result of that actually may bring them to become more concerned about customer image and service than not. I wouldn't worry.
When asked for a comment about Ford slipping behind Chevy in sales for the first time in some 20 years, the President of the Ford division said, "So, I guess I should congratulate Chevy for being first in Rental Fleet sales, huh?".
If your Ford is a dog, dump it. If your dealer is not treating you right, go to another one if you possibly can, there are some great ones out there. Ford just stepped up and did a complete brake job no questions asked on my truck at 24,000 miles for me, and I don't even know why. It was grinding, I took it in, when I went to pick it up, it had new linings, new rotors, everything new, no charge sir. And that's what I'm used to for years now. That's why I say, it may be your dealer. Good luck. YMMV, as always.
As far as "Ford Sales" is concerned, the real "acid test" will be when they discontinue the Taurus that is "DISCOUNTED STEEPLY" to COMPANY FLEETS-not rental car companies as much anymore. I know, my company just purchased for me a '05 Taurus, I can't believe what they paid for it. By the way-it's got the most uncomfortable seats of any car I have ever owned (twenty three plus cars...) but that's for another board!
The dealer makes half the difference in the ownership experience over the life of a car for me. There is one Ford dealer in town I've not been able to buy a car from since 1975 because of their abysmal sales attitude - I can imagine how much I'm gonna love their service attitude. So I know what you mean.
We agree and have found some common ground......
My wife's '03 is a V-8 auto, limited slip, 3.73. It has a very loud sporadic "clunking" in the transmission. It is not normal. It has had the transmission solenoid changed, but has not fixed the clunking noise. So far, I have not heard the rear-end whine (but, it only has 14K and it seems this problem occurs around 30K or later).
As far as Ford reliability, I can only speak for my previous 4 vehicles (all Fords) and my current 3 vehicles (1 Ford, 2 Chevys):
1986 Mercury Cougar XR-7 (purchased new) - 2.4L Turbo, 5-speed. Very fun to drive and driven pretty hard. Engine used about 1-1.5 qts. of oil every 1,000 miles at 70K when I traded it. Yes, it smoked.
1991 F-150 4X4 (purchased new) - 5.0L, 5-speed. Decent truck overall, but did have to replace the engine at 110K. Sold at 130K.
1993 Explorer (purchased new) - 4.0L, auto. Replaced transmission at 105K. No engine problems. Traded at 120K (transmission slipping again).
2002 Taurus (purchased new - fleet car) - brake problems from 15K. Electronic issues with engine (dies and won't restart). Had to replace right side front axle at 60K. Recently sold with 75K. Would never own another one of these.
2003 Explorer (purchased new) - 4.6L, auto. Transmission solenoid replaced at 14K. Still has a sporadic loud clunking in the transmission.
1992 Chevy Lumina Z34 (purchased used at 105K). Runs great. Now has 112K. Uses about 1 qt. of oil every 3,000 miles. No other problems so far (about 8 months).
2001 Chevy K2500HD (purchased new) - 6.0L, auto. It does have the infamous GM start-up engine knock (Chevy free extended warranty to 100K). 45K with no problems (there was a recall on the tailgate hinges). Doesn't use any oil between 3,000 mile changes. Plenty of power, but could do better on gas mileage. I am really happy with this truck.
As you can see by my townhall name (whatsachevy) I signed up with in 2000 when I was looking for a new 3/4 ton truck, I had always been a Ford man. I was convinced by a friend to test drive the Chevy. I liked it better than the F-250 at the time and thought I would give Chevy a try. At this point, I wouldn't go back to Ford. Only time will tell, but it may be time to start looking for a Trailblazer to replace the '03 Explorer. My lifetime experience with Ford reliability and Ford customer service would certainly be graded no higher than "C". So far with Chevy (although very short-lived at maybe 4 years), I would still have to give them at least a "B", if not higher.
Anyway, what kind of mileage should I expect during this break in period. I'm only getting 13 miles a gallon. My drive to work is 17 miles each way and 14 of it is non-stop. Wondering if I should be getting better mileage.
I also hear a high pitched whistle when accelerating and the noise changes when the transmission changes gears. The whistle goes away while cruising. Could this be some sort of air leak that is causing me to lose gas mileage? Dealer says he can't hear the whistle.
My 97 XLT 5.0L V8 Automatic 2WD get 14 mpg in town and 18 on the road.
How loud is the whistle? It could be a tranny whine because it changes at at shifts, or it could be a vacuumn leak that changes in pitch as manifold vacuumn changes.
the other thing that can make a big difference is tire pressure, especially in the front. what is the air pressure in your tires?
Given the numbers of Explorers on the road, I don't think that's at all indicative of a reason to panic. If you read back a ways, you'll find several of us who love ours, and have had several of them, like me. I have had 5, still have 2 of them. I think they're the best SUV on the market overall, and have had -0- bad ones. Make up your own mind about your's. Be a man! Remember, the passion for these boards tends to come from those who are mad at the time, the rest of us coast along generally, and only chime in to help someone who has a question - like you.
Oh, mileage? If you have the V-8, you're not gonna get much over 15-16 probably, it's what they do. There's nothing wrong, that's what they get. The Six would get you more like 20. At least that's what we get, but we still prefer the V-8. You'll need a few thousand on it to get to your average, and probably 7,000 for it to start to breathe easy.
My wife drives 16 miles ROUND TRIP (8 miles freeway) to work in her 2002 XLT SOHC V6 2 wheel drive. She has a very light foot. She has NEVER OBTAINED more than 14 miles per gallon city. By comparison, the '99 Suburban we traded in got between 11 and 12 mpg city-and NEVER more than 15 MPG highway with the standard V8! The Explorer ALWAYS get 20 MPG on the highway! Of course, in California we have to use that special recipe oxygenated gasoline.
Just Another Unhappy Individual
The XLT I drive is a 4.0L V6 4X4. So far I have only driven it in 4X4 auto mode. I set the tire pressure to factory specs of 35 psi per tire but the dealer just set it to 32 psi after my last visit.
Not sure if it means anything but the sticker says this is a duel fuel vehicle but I haven't tried to use Ethanol-only 87 octane.
I expect the mileage to be around 15-16 but 13 is pretty low. That's why I was wondering if the whistling sound from the transmission could be causing some of the low mileage. I'll switch the OD off tomorrow on my way to work to see if RPM's change.
I have to agree with nvbanker, because I feel he is including me in the group that dominates this board , even though he is the one who told me this one sounded like a lemon before I even bought it. These guys are very honest about these things, and you should definitely take their advice to heart.
I also happen to know several people who have Explorers, love them swear by them. I just happen to have a bad one.
Like they suggested, keep it, enjoy it, and buy that extended warranty, preferably a FORD warranty. Don't do like I did and go with a no name that sounded good.
I'm getting the ball joints replaced this week, and then maybe one of these days whatever is causing the antifreeze leak will "fail" so my warranty will cover it, haha. It's a great truck, not a rattle in the place, I love it's look and I have yet to find anything that fits me as well. I'm a pretty good sized ol' boy, so I need something with plenty of room and that is comfortable. I'm trying to give a little praise to this thing, hoping that maybe I can make it another year without any major problems. I'd love to see it make it to 70k before I get rid of it. My warranty is good until 67k. Who knows, it might get all it's kinks worked out and go on to be a great truck, just have to wait and see. As you know, I'm one to jump to conclusions, haha. I could take this thing and trade it right now for a Toyota or a Nissan, and it be even worse. All car makes have a lemon now and then, even the most reliable makes. As I've been told many times, "show me a car, and I'll show you a money pit."
I purchased the Extended Warranty from the Ford Dealer when I bought the car. However, it's not an ESP warranty but and EASY CARE warranty. Dealer said it has to be accepted at all Ford dealerships and is owned by Ford. Any idea if this is good? I didn't see any information on it in the Extended warranty forum.
http://www.fordwarrantys.com
I couldn't agree more! I love mine! Still, looking at some of the posts on these boards can be scary at times, but you have to put things back in perspective.
On the issue of fuel mileage, the V6 will not get much better mileage than the V8 because Explorers are heavy (4500lbs) and aren't aerodynamic at all. The V8 does not have to "work" as hard to accelerate and then keep the vehicle moving. The EPA ratings reflect this; only 1 mpg less for the V8.
I have the V6 and only get 14-15 mpg in the city and 18 highway, but I am a leadfoot as well!
APC is the Administrater of several "factory" warranties, including Nissan, Mazda, Volvo.
This is a way to get a warranty that will be accepted more readily at non Ford dealership shops, such as when you are on a road trip.
Also because Easy Care pays by credit card, the shop gets funded immediately and makes them more willing to honor the warrenty.
http://www.hoovers.com/apco/--ID__45185--/free-co-factsheet.xhtml
Hope this makes you feel a little better about the warranty you purchased. If it wasn't Ford owned, I wouldn't say any thing good about it.
Mark
Happy to oblige:
1994 Explorer 4WD Eddie Bauer 140,000, still own.
Bought from Ford dealer, obviously.
1997 Mountaineer 2WD V8, leased for 2 years.
1998 Mountaineer 2WD V8, leased for 3 years.
2002 Mountaineer 2WD V6, leased for 3 years.
2004 Mountaineer 4WD V8, still own.
All Mountaineers leased from same dealer. They have all been extraordinary trucks, really, I'd put them up against any Toyota service record you can find. I know there are bad ones out there there and there, but with the zillions of them on the road, that's gonna happen. It is the best selling SUV for the past what 13 years now? The important thing is, when one of them is a lemon, Ford needs to step up on the truck. They always have for me. It's very unfortunate when there is a dealer who doesn't, they hurt the whole company.
At least I know why you got that free brake job. Your one loyal customer!
I wanted to nominate you for being a good customer...
http://media.ford.com/article_display.cfm?article_id=19844
Chuck - I understand what you're saying about short term ownership not getting the full picture of the vehicle's long term performance, and I admit the furthest I pushed any of the Mountaineers was 65,000 miles, but really, not one of them gave us a minute in the shop. I never even put brakes on any of them except the 94. The only repair I remember ever needed to have done, was an exhaust manifold on the 97 that leaked, fixed in one day under warranty, and a squeaking pully on the 02, same thing. That's very minor stuff.
I only buy Ford vehicles because I like them, and because they treat me very well, generally. The dealer experience also has helped considerably. I have no other loyalties, no relatives, no super deals to claim, and not one share of Ford stock. At least, at this time.
