No. Do not drive the vehicle in 4wd on dry roads. You can drive in 4wd on wet or especially snow covered roads if there is slippage. Just don't make a habit of it. Center diff is fantastic. I'm sure many 2010 4Runner owners miss it already.
That is the main reason I paid extra to get the 2010 4Runner 4WD Limited for the awesome full time 4WD feature (hopefully there is no recall for the 2010 4Runner so far...)
From the way I read the factory documentation the newer 4runner's full-time 4WD system may not be as awesome as one might think, or buyers have been lead to believe.
Toyota stopped using the "torsen" term to describe their 4runner 4WD system some years ago now. In addition the transfer case differential drawings are no longer broken down to show the internal workings of the transfer case differential.
All that leads me to believe the 4runner's full-time 4WD system, at least the 2010 one, is a simple ONE-WHEEL DRIVE SYSTEM, just as the Highlander is and the RX series was until recently.
First, be aware that the salesperson doesn't know BEANS about the vehicle you are planning to purchase.
Even worse.
The RX330 was marketed as having a VC, Viscous Clutch, to help apportion engine torque to the rear with loss of traction at the front. The factory manuals indicated otherwise so I asked corporate who acknowledged, after I persisted, that the manuals were correct. I never saw an ad retracting the falsity.
The RX350 was advertised as having the VC but again the manuals differed. I was never able to get a corporate response on the true of the matter.
In point of fact when the RX series adopted VSC and TC across the product line in '01 the VC became useless even if included. The VC P/N for my '01 RX300 and the one for previous years is different so I suspect mine to be an "empty" VC case.
If the 4runner doesn't have the Torsen center differential, only a standard open differential, how would an owner ever know? Get stuck, lock the center differential, drive away.
PS: My '01 RX300 once spent 4 hours in the dealer service bay with the technicians trying to determine if the VC was actually still functional. End result...inconclusive....no known way to test and corporate could not advise.
The only way to determine functionality is on a 4 wheel dyno.
No kidding, and even some that are FALSELY labelled 4WD.
Lots of sins created under the AWD "term". Most are simple FWD with some minor level of part time, "automatic" part time, rear drive augmentation. With the rising public awareness of the patently unsafe nature of FWD vehicles for wintertime adverse roadbed the manufacturers are attempting a "bait and switch", "find the pea", sales technique.
Any "base" FWD vehicle, sideways mounted engine, that has some level of rear drive augmentation should NEVER be referred to as AWD, nor even 4WD as some manufacturers seem wont to do.
F/awd, awd only in lower case, is the only appropreate marketing designation, label for these patently unsafe FWD vehicles.
The sign could be more definitive, narrow the restriction, if F/awd vehicles were kept out that make use of TC braking to implement some form of F/awd, apportion some minor level of engine torque to the rear via the use of braking at the front.
Slow to a virtual stop, get stuck, TC instantly dethrottles the engine, call for a tow.
On the other hand should, when, the transaxle in my '01 RX300 finally fails, expected prior to 100k miles, now at 80K, I will be converting the RX to R/awd.
The center differential front drive spider gears will be removed and the rear drive spider gears will get welded into place. Eliminating front mechanical drive and SOLIDIFYING the engine drive coupling to the rear. I will also be installing a new VC from the 99-00 RX series so that torque coupling will automatically be coupled to the front upon/with rear wheelspin/slip.
So, my preference is quite clearly some sort of R/awd system such as is in my '94 Ford Aerostar. In the absence of R/awd availibility I would always choose RWD, tire chains on board, for travelling on wintertime adverse roadbeds.
I've been surf fishing the Outer Banks since the early '70s and it's more about knowing how to drive on the beach than it is the vehicle. We started out using rear wheel drive trucks with large nearly bald tires. Tread only aids in digging you into the deep, soft sand when a wheel spins.
I haven't taken my '10 HL Limited out yet, but there were a few older ones at Cape Hatteras 3 weeks ago and they were getting around. It's funny having 19" wheels now, after driving an '86 Subaru GL wagon with 13" wheels on the beach for 14 years. It's all about ground clearance and letting enough air out.
Take a tire gauge, a shovel, a board and a snatch strap no matter what you drive.
The new Sequoia, land Cruiser, FJ with a stick, and Limited 4runner, all use a torsen center diff that can be used on all surfaces. The Tundra, and tacoma still use a part time transfer case with no center diff. I have a 2006 tundra and it is really good in wet conditions in rear wheel drive. I know what you mean though. I keep saying if they put a full time transfer case in the tundra I would buy a new Crew Max. So I keep waiting and hoping. But yes the Torsen is still being used despite what "SOME PEOPLE" say.
Don't go through all those 2000+ post. Please forgive me if someone asked before.
Could some explain what the 4WD/AWD systems are in recently Toyota models? Are they full-time 4WD, full-time AWD, or just part-time/auto AWD? I am specially looking for Sequoia, 4Runner, Highland, and Sienna. The first post of this thread is from 2001 and lots things have been changed. Thanks.
The thing to keep in mind, REMEMBER, is that there is NO such thing as a FULL-TIME 4WD or AWD system for, in the manner, for which you wish to make use of one.
Yes, the Highlander, for instance, has a FULL-TIME 4WD system, right up until you reach the point of actually needing to make use of 4WD traction capability. At that point, wheelspin/slip, any one wheel or wheels, the HL reverts to it's true nature and becomes a ONE-WHEEL drive system.
Absent TC, Traction Control, capability you would now be STUCK...!!
But while TC might often be your savior in this situation in many instances it will operate to your detriment. Which is why most F/awd systems have a TC disable switch.
So be very careful of any Base FWD vehicle, crosswise mounted engine, that makes claim to having FULL-TIME "4WD" or "AWD" capability/functionality. What they most likely mean is that the "AWD" system is ALWAYS enabled, but only activates REACTIVELY once/after wheelspin/slip is detected.
The 2011 Porsche Cayenne, and likely its VW & Audi brotheren, are about the only R/awd systems available that I know of. These can be both pre-emptive and reactive, with SAFETY.
Pre-emptive in that like the new Sienna, Vensa, and RX350, they can and will automatically engage the front drive torque under the driving conditions which are most likely to result in loss of drive traction, low speed acceleration. But UNLIKE the Sienna, Vensa, and RX350 they have no need to REDUCE the drive drive torque during tight turns or acclerating turns since it is the rear wheels that provide the primary drive forces.
Good post, WWest. Always enjoyed reading your insights on this awd stuff.
Got a question for you: we recently got an accord crosstour with "on demand 4wd". The system works by using a hydraulic circuit to engage the rear wheels when there is a speed differential between front and rear wheels during slip.
The issue centers on the use of snow tires on dedicated rims...something we have always done for our cars.
In this case, however, we have a tire pressure monitoring system, and making it work with the snows on their own rims involves not only outfitting the rims with sensors, but also "re-registering" the different sets of sensors with the car's computer....something that costs about $70 at the dealer twice a year. Not very attractive.
Alternatively, Tirerack says about half of their customers just forget about the sensors with the winter tires and live with the TPMS warning light during the season.
Only problem is that in this car when the TPMS warning light is on you cannot disengage traction control. Am I correct that disengaging traction control might be exactly what I would need to do to get myself unstuck in the snow?
OK wwest - I haven't always agreed with your posts, but I've come to respect them. If you owned a 2008 HL Limited 4WD (gas), how would you operate it in Chicago's snow to get the best performance from it? Based on your responses, you would engage the SNOW button and turn TC off. Yes/no?
I strongly suspect that's because TC is automatically disabled with a TPMS warning light on.
Early TPMS's used the ABS "tone wheel" to judge that a tire was under inflated. TC also relies on those same ABS tone wheels to detect the onset of wheelspin/slip. The TPMS fault indicates that use of the tone wheel for TC functionality might be "suspect" so I doubt it would be, remain, active.
Check your owners manual.
But ABS might also be disabled for the same reason. If so it would not be a good idea to drive in adverse conditions with a TPMS fault indication.
For all practical purposes I do own a 2008 HL 4WD....
Mine just happens to be a 2001 RX300 "F/awd". With the advent of the use of TC starting in '01 the TC remains in the "mix" but with the viscous fluid reformulated to forever remain "flaccid".
So I have the very same drive train implementation as you.
The first thing I did was add wheel spacers all around and 17x8 wheels with the appropriate +1 summer use only tires, Brdigestone Turanzas, to be exact. The spacers not only allowed for wider tires, more roadbed contact area and wider "stance", but also room between the suspension and tire in the rear such that I could make use of tire chains in the rear initially and only add the front chains at times of real need.
I would NOT advise disabling TC as a rule of thumb, not, NEVER, on a FWD or F/awd vehicle. TC is a totally REACTIVE feature, only activating AFTER the fact, after wheelspin/slip has already become an issue to be dealt with, URGENTLY dealt with.
Engage the snow button, YES, indeed.
Tires..Mixed bag.
The following is my personal opinion ONLY.
I am of the firm belief that the clear majority of the time my summer tires provide superior traction, above ANY wintertime specialty tire. The "clear" majority being dry, wet, icy, or packed snow roadbeds. Specialty tires have less surface CSA, less traction on a "solid" surface roadbed. Winter tires are only advantagous on "soft" roadbed surfaces wherein that tread blocks have something to "dig" into.
But my advice to you is to buy the best all-season tires you can find and trade up to a R/awd or even a RWD vehicle ASAP. I had expected the new 2011 HL to have adopted the Venza, Sienna, and RX350's new F/awd system but apparently not. This new F/awd system could be easily modified to a PART-TIME 4WD system using a manual switch to over-ride, temproarily close the circuit to the rear clutch. Obviously that switch should ONLY be used in KNOWN adverse conditions, SLIPPERY roadbeds.
What is the advantage, cost, etc, of purchasing a set of dedicated wintertime wheels and TPMS sensors vs just simply having a tire shop swap tires twice a year..?
Reasonable question. The price for four BlizzaK Tires mounted on new steel wheels is about $650, and the TPMS monitors are $116 for a set of four (Honda sensors are inexpensive compared to many other brands for some reason). So it is about $775 for the whole shooting match including sensors.
The Blizzak's alone are $430. Mounting and balancing around here is about $20 per tire.
So here are my options and the prices:
Dedicated tires/rims and no sensors: $650 (one time charge-I change these myself) Disadvantage- either cannot turn traction control off, or --as you suggested--traction control is always off if system sees no TPMS sensors. I think that ABS still works in this vehicle under these conditions.
Dedicated tires/rims with sensors: $775 plus $80 twice a year for the Honda guys to reinitialize car's computer each time for the alternate set of sensors (winter vs summer tires).
Tire shop swaps tires twice a year: $430 plus $80 twice a year (this time the same $80 is spent on the tire changeover instead of the sensor re-programming) I guess I wasn't considering this because it is so convenient for me to just switch out my own tires in the driveway with a floor jack vs taking it to a shop and waiting. Also, my nice rims don't get mucked up in the winter.
Thanks for the comment about the possibility that traction control is already disabled with TPMS light on...I never thought of that and will research this more and comment back. Just read the post today.
1) You can get cheaper winter beater wheels. 2) You can get -1 or -2 size wheels. With those, you will need tires with taller sidewall which give better traction in snow and slush. Those are cheaper too, and the difference is significant for most brands. 3) I am not sure how much it costs to swap tires, say $50-$80. That's $100-$160 per year. Over a few years it adds up. If you keep your vehicle for a long time, it's proably cheaper to get the second set of wheels. Swapping wheels is something I can do myself in my garage, it takes me about 40-50 min., probably less than driving to a tire place (with 4 dirty tires in the trunk), and have them balance and swap the tires. 4) All that repeated swapping can't be good for tires. Etc.
My 09 HL one wheel drive is nearly useless in the snow and I am wondering how one would go about modifying it as you described using a switch to over-ride the the clutch.
In your opinion would this help substantially or is it just wishful thinking?
I am pretty handy with a tool and would seriously entertain this idea, realizing of course (hoping really) that it would be like locking in a tranfer case.
Sorry, but I was referring to the NEW F/awd system now used in the Sienna, Venza, and RX350. Those have an electromagnetic clutch just forward of the rear diff'l that is used to dynamically apportion engine torque to the rear drive.
In those a simple switch might be used to fully engage the rear clutch provided that there is absolute certainty of a non-tractive, slippery surface.
Is there a way to override the TRACS and VSC system? I was heading up a muddy slope and it felt like the rev limiter kicked in and I couldn’t power up the rest of the way – it felt like it was trying to get traction and slowing the revs of the motor to do so.
Am I able to flash my ECU, pull a fuse, or snip a wire? Did I just buy a soccer mom taxi?
Thank you in advance for any insight or explanation anyone can extend.
In a true 4X4 if you lock the center "diff'l" that automatically disables TC and VSC. Sounds like in the conditions you had you needed to be in "locked" 4X4 mode.
I am looking for a simple explanation describing the applicable conditions (when to use each and why) for using the (1) Auto LSD System; and (2) (when and why) to disable VCS or A-Track. This will sound dumb, but the Owner's Manual I think needs some interpretation to become clearer...Trac Off mode, Auto LSD mode, VSC off mode. Am I supposed to advance from Auto LSD to VSC OFF mode when I am trying to get unstuck, which I seem to be reading is a 2 -step process? Am I close to understanding this?
The base problem arises from the fact that selective frictional braking is used to implement Trac, LSD, and VSC. If a condition requiring consistent, continuing, selective braking were to occur and the engine not be automatically dethrottled you would end up with warped brake rotors soon thereafter, or possibly engine failure of the drive train due to the extreme stress involved.
Since the driver cannot be trusted to lift the gas pedal to the point of "feathering" when one of these modes activates the system does it automatically for you.
So the only method for getting unthrottled wheelspin as a last resort to get unstuck, etc, is to disable ALL of these functions.
Ok, so I guess I forgot to turn my 4wd on once a month on my 2005 toyota sequoia. From what I read online it is in the owners manual. Would have been nice for the dealer to tell me that when I bought it. Now when I hit the button it just blinks on the dash and never locks in or changes. The dealer wants to charge 92.00 just to look at it. I read on this forumn about a fix for my back window (got the defrost and wiper working which is all I wanted, so thanks to all for that). Any idea on my new issue? Hoping there is a way to reset it or get it to engage without a dealer charge. I wasn't able to find anything online other than one guy who took it all apart and replaced a bunch of stuff. I am not mechanical but also not an idiot so I could do minor things.
It's sometimes easier for the 4WD clutch to "slip" into engagement accelerating, EASY acceleration, from a full stop, at a low speed, stopped, or even driving slowly, DEAD slow, in reverse.
It's even worse if you have new tires at one end vs the other.
I have a 2003 4runner 4x4 v6 and just went through an ordeal with this but don't dispair. The problem lies in the actuator that is within the transfer case. It along with the front diff actuator are 9vdc and NOT 12vdc. This actuator inside the transfer case drives a pin that makes the transfer case go into 4wd high and then into 4wd low. The actuator is 1200-1300 alone. Aparently this is a weak link on these vehicles. I also am looking at a solution to this issue. For now I have a 4runner with this issue. With a lack of use the pin inside the transfer case becomes gummed up in its housing and gets stuck in one position or another. Mine was stuck in the 4wd low and required removal and rebuilding of the transfer case to free this pin. Sometimes a tap with a rubber mallet can free the pin but this didn't work for me. Good luck.
I am having the same problem... I have an 07 Highlander and the back has the 4wd emblem, however, there are no switches that indicate whether or not it is engaged. I recently had to drive through about 6 inches of snow, and I was all over the road, was kinda like riding a Squirrel. I also am not sure what the ect snow button does or does not do. When I had this turned on, the highlander was not any better driving in the snow.
Yes, about all you get with an HL F/awd is that emblem.
The HL uses three fully "open", free-wheeling, diff'ls, front, center, and rear. The only time you will hav decent 4WD functionality is when all four tires have roughly equal traction......a whole lot of good that is.
One wheel/tire loses traction and limits the engine drive torque to ZIP, ZERO.
As of 2010 the RX350 adopted the new Venza F/awd technique, not as functional as would be the Honda/Acura SH-AWD system, but a substandual improvemnt none-the-less.
In the class/price of teh HL look to the 4runner, R/awd, for a much more functional AWD/4WD system
Highlander has very effective AWD system that had proven itself to pretty much every HL owner. wwest never owned or rode a HL but has his own, not shared by anyone home grown conspiracy theories about Toyota AWD implementation in HL.
HL doesn't have any switches to engage AWD, it on all the time. Use common sense, make sure that your tires are good and suitable for snow/all weather driving. If road really icy and slippery then no AWD in a world will compensate fully for hazardous road conditions. I own 2008 HL and really like 'snow' button functionality under heavy snow. It changes transmission shifting points so car feels more steady when accelerates on the snow.
Yes, I do not own an HL, but I do own the exacting(***1) equivalent, a 2001 F/awd RX300. Previously owned a 2000 F/awd RX300 which in retrospect I wish that I still had(***2). Due to pretty severe transaxle stress problems, premature failures, with the '99 and then less so the 2000 this early, more functional, F/awd system was abandoned. Those early failures proved to be the result of the rear drive being "automatically" engaged via the use of a VC, Viscous clutch/coupling design used to "lock" the center diff'l.
By the time the HL went into production the F/awd functionality had yet again been lobotomized, the VC was eliminated entirely.
"..home grown conspiracy theories..."
For years now, 10 or so, I have paid the substantial annual subscription fee (techinfo.toyota.com) for full and complete access to ALL Toyota, Scion, and Lexus models. The information I publish here is derived directly as a result of my access to the appropriate factory service/shop manual set.
If you suspect otherwise the daily access fee is quite affordable.
"..it on all the time..."
Pure BS. Anyone with even the most basic knowledge of AWD systems will understand that this just simply cannot be the case. Driveline components would be overstressed, so overstressed, that component failure would result within ~50 miles. Even "partially" automatically engaged, or even "part-time" automatic engagement is proving, right at this very moment, to be a problem with all reasonably functional F/awd system...the best of the best, the SH-AWD system, for instance.
No, it's ENABLED 100% of the time. The HL's F/awd system only activates AFTER-THE-FACT, only after FRONT wheelspin/slip is detected via simultaneous monitoring all four ABS "tone" wheels. And while one might think that the process of Trac activation would involve quick drive coupling to the otherwise "free-wheeling" rear tires. But due to serious safety concerns unique to FWD vehicles that is not the case.
The first action taken via Trac activation will be braking of the front wheels in order to most quickly restore front traction and thereby alleviate the otherwise strong possibility of loss of directional control. To facilitate even quicker front traction recovery and to prevent overheating of those front brakes should the driver not quickly release the gas pedal the system will also automatically and simultaneously FULLY dethrottle the engine.
Many later models, including the HL, using a F/awd technique of this type now have a Trac/VSC disable system so the driver might often have additional resources to get unstuck or initially moving forward on a slippery (uphill) surface.
***1 My '01 F/awd has an absolutely USELESS VC mounted across the center diff'l, purpose being to automatically "lock" the center diff'l under conditions of consistent wheelspin/slip. So useless that it was dropped entirely from the RX and HL with the advent of the RX330.
***2 My '00 F/awd RX300 not only had a fully functional VC, Viscous Clutch/coupling, it also had the then optional rear mechanical diff'l. I traded up to the '01 to get HID and VSC not realizing that I was giving a more functional, MUCH more functional, F/awd system.
Looking for some opinions here. I'll be buying a Toyota soon (Land Cruiser, Tundra, or Sequoia) and have been debating between RWD and 4WD. I pretty much decided I have no need for 4WD here in TX. When I lived in the upper midwest, it always made sense to have the 4WD for the inevitable winter storms. In fact it was hard to find trucks and SUVs that were only RWD. Now that I'm living in TX I don't really see the need for 4WD yet I often see these trucks and SUVs optioned out with 4WD. Why? What am I missing? You add $3 -$4 grand to the price, add more items that could wear out or fail, and reduce the gas mileage. I've only been in TX a few years so maybe I'm missing something. Can someone tell me why I might need 4WD when living in the South?
The only reason I can come up with is I may need it if I take winter trips to visit family in the UP or if I ever move back.
You might need 4WD to tow a future boat or travel trailer. If you ever decide to sell your vehicle, 4WD is like selling a house with a swimming pool. If the house is good, someone who must have a pool will buy your house over the one without. 4WD is great for off road, but if you have no desire.....not much point there. If you buy the vehicle without 4WD, you can never install it later, should your needs change. 4WD rarely goes wrong in Toyota's but, it does adversely affect the fuel mileage, by maybe 2 gpm's.
The thing you are missing, as you say, is this.......there is a huge community of "guys" out there who love to drive off road. If you want to drive in the bush, thru the muck, across streams, and generally cross country, then you have to have 4WD. I have a 4Runner, a serious off road vehicle. It has 4WD, with low and high and differential lock, it sits up high, and isn't too big, so I can get between trees in the woods. When I went to buy it, (used), there were a ton of 2WD's out there. I passed over all the 2WD's to find this 4WD. If your plan is to drive your vehicle to the office on the interstate, and you never plan to sell it, or move it back up north, then perhaps, your wasting your money on a 4WD.
Good points. I'm definitely not planning on moving north again, but of course never say never. I can see the need for 4WD for pulling a boat out of the water, but RWD for general towing on the highway should be fine. I'm leaning towards the Sequoia and I don't think too many people take them off-road since it's much bigger than your 4Runner. I also typically keep a vehicle for 10 years or more.
How could you possibility miss the fact that you are now DEEP into Red-neck territory. Those 4WD/4X4 fully decked out trucks and SUVs, gun rack and gun included, are a societal requirement in your region. They may NEVER go off-road, off-road hunting, but they MUST look capable of same.
You don't "need" anything beyond RWD. Travel back north, take tire chains along.
My question would be why something as HUGE, weighty, and gas-guzzling as are your seeming choices. Wouldn't something in the 4runner class suffice?
"My question would be why something as HUGE, weighty, and gas-guzzling as are your seeming choices. Wouldn't something in the 4runner class suffice?"
The answer is 3 teenage sons. The oldest is already 6'-4". The 4Runner doesn't get much better gas mileage and is much smaller. For basic trips, the 4Runner may be fine. For family vacations, it just won't cut it.
Do you have any REAL facts to back up the statement? Are you guessing?
I'm not saying you're wrong, but how is a person supposed to make a purchase decision based on some internet guys guess?
Even worse.
what kind of awd/4wd vehicles do you recommend in snow?
EXCEPT on ice or packed down snow. At that point I immediately install rear tire chains and add the fronts if conditions(***) warrant.
*** Conditions might involve surrounding traffic, INCOMPETENT driver traffic.
please note that it is dated 1/09, so not all the model information is entirely up to date.
did a little search and found the updated version:
http://www.majormedia.com/4WD_Version_7_1/4WD.html
4Runner: no multi-mode 4runner. limited would be full-time 4WD. other 4runner would be part-time 4WD.
Sienna: on-demand AWD.
all bad things for me.
Tires..Mixed bag.
Many thanks.
Etc.
Basically a "part-time" 4WD system.
Please help as winter is here in Wisconsin.
linky
We've been around this number of times. Just stop posting your useless technical mambo-jumbo and drive a HL in a snow for a change.
Is the HL still available with the I4..?
Because I can .
