Need Advice about repair
My Chrysler Sebring Convertible seems to constantly have problems. It is currently in the shop for transmission trouble. The warranty went out a few thousand miles ago and all of the sudden it quit shifting gears. We found out there is a sensor that has gone bad and two different Chrysler dealerships that we called immediately knew what the problem was because they have so many problems with the sensors in the 99 Chrysler Sebrings. Is there someone I should call to report these problems. If so many other cars my type are having problems with the sensors, why don't they replace them for free?? It's going to cost me around $200 + to have this repaired and it really upsets me to pay this if it's a common problem with cars of my type. Please advise. What should I do???
Check this for TSB's
http://www.alldata.com/TSB/9912_mo.html
you will be suprised at helpful they are, especially with a problem that you have described. they are like the IRS to auto manf. that try to rip people off. to put it another way, i now have a 5yr/100K warranty from my truck manf. because of their support.
Find a local repair shop that specializes in Lexus and/or Toyota. Their prices will be cheaper than the dealer. You can use the dealer if you like but with a 10 yr old car, a dealer won't give you much additional benefit. Everything there is to know about the ES250 is out in the open.
I only mention all this because some people expect too much of BBBs. They have limits as to what they can do, since a dealer can tell them to go to hell and they can't do anything about it. They can't even tell a phone caller t the nature of the complaints against the renegade dealer, but they can mention that there "were some complaints filed".
BBBs should be used early in the game, before arbitration or court.
May I suggest you access this website regarding defective Chrysler tranmissions :
http://mypeoplepc.com/members/tjk/home.htm
Also, more importantly, maintain a log of all your discussions with Chrysler along with all of your service receipts. Best of Luck and please post to let us know how everything works out.
also how can i reset the light?
thx.
luckily got the Jetta to the side of the Interstate, steering locked up, engine light came on.
No oil-all over the bottom and rear end of the Jetta. Checked the oil stick, pulled to check-
steam from the oil stick receptical. Called 24 Volks service-waited 2-hours for tow truck
back to VOLKS dealer. Mechanic put another plug, filled up with oil and said"car is fine-
you're ready to go! Am I crazy or what? I refused to take the car (has 16,000+ miles-perfect
condition until now). Service mgr, noone calls until I call the next day to find out what is
going on. CAR is ready, checked out - OK. No diagnostics, no verification of engine ok,
owner refuses to acknowledge problem for 2 days. Volkswagen Customer Car Service tells
me they have NOTHING to do with this-must deal with the guilty party. Dealer says "his people
say the car is OK, same people who failed to replace oil plug back. Anyone know how to force
a dishonest dealer and a really lousy Manufacturer such as Volks to step up and replace this
now damaged engine with a new one? Please advise if anyone has any ideas. THanks.
I'm not an expert on this kind of stuff, but if I were you, I would keep the receipts (both for the oil change itself and the refill) so you have some documentation, take the dealership to small claims court, and sue for the cost of a new engine.
As for the dealer saying the car is OK, as they say on Car Talk, "bo-o-o-o-gus!" The engine was run with no oil to the point that it shut itself down. Maybe it's OK, but maybe something was damaged due to lack of lubrication and it's going to fail next week. The dealership screwed up big time, and they should be forced to foot the bill to rebuild or replace the engine so you can be sure you don't have a time bomb on your hands. That's my take on the issue, anyway. Good luck!
-Andrew L
-Andrew L
M.
