We are semi-retired, so we have no regular "commute", but in our typical around-town driving here in Austin we average 22 mpg (our 2001 Honda Accord V6 automatic got 19 mpg in the same driving), and on our one long highway trip we averaged 29.5 mpg. That was 500 miles to New Orleans and 500 miles back, generally at 75-78 mph, virtually dead flat. (The Accord used to get 27 mpg on the same trip.) If we had an auto, I would expect trip mileage to be about the same, perhaps 1 mpg less, but city mileage to be 2-4 mpg poorer. We are obviously pleased with the Legacy's mileage, especially for an AWD vehicle.
One thing that I did soon after getting the car was put a bottle of fuel system cleaner in when fueling up, and the engine got considerably smoother within minutes (!), especially in off-idle response. I didn't measure fuel mileage before that, so I can't say whether it improved or not, but based on experience with previous cars I would expect an improvement in city mileage after 57,000 miles.
City mileage is so dependent on trip length and traffic conditions that it is difficult to compare between vehicles unless you changed vehicles and didn't change anything else (as in our case with the Accord above). I'd check the little things to be sure they are okay (clean injectors for $5 or so, be sure tire pressure is 32-35 psi COLD, all maintenance done per schedule), then check mileage on a long road trip to get a number that can you can believe. If it is around 24-28 mpg, that is as good as you can expect from a 3500-pound AWD vehicle, and far better than you'd get from a SUV with similar accomodations and room. Then you can just accept your city mileage as being what it is because of the trip length and traffic conditions.
Let us know what you find!
I do notice that oil makes a difference on the tendency for my car to "tick" when I first start it up. It shuts up quickly after 30 seconds or so, but only ticks when I have "cheap" oil in it - some generic stuff from Sam's Club. I usually put either Penzoil or Castrol GTX in it, and it is smooth as butter then unless the oil is more than 1 quart low. But, with the generic stuff, it always ticks upon startup, even with the oil "full." I can only attribute this difference to the oil. My car leaks about 1/2 quart every 500 miles, so I have to watch it pretty close. If your ticking is very pronounced, I doubt the type of oil will 'fix' the problem, but mine is pretty mild/quiet.
Good luck. -Wes-
Unless the exhaust system is cleaned off, it may continue to smoke for quite some time. An easy way to clean it is to spray down the undercarriage with brake or engine cleaner, let it sit for a few minutes, and hose it down with a pressure washer. All of the residue may not come off, but the stuff that burns will be gone.
Once you've done that, if the smoking comes back, you know you still have a leak!
ive also noticed that when i make a sharpish right hand turn, ie. an off ramp, or into a parking lot, that it makes this loud clunk/grinding sometimes when i step on the gas.
Sounds like you either have a differential going out, or a CV joint. I suspect it is probably a CV joint on the passenter side front, but if you inspect the boots and one is torn open, that's your culprit. I think replacement axles run about $200 (for the part).
Doh! I need to start reading instead of skimming.
I had just assumed I needed an O2 sensor, but the CEL code (P0065) said "air assisted injector not in range or performance", and listed a series of things to check out. Meanwhile, the CEL light reset itself (went out) and has not returned, so the problem must have been an intermittent or "glitch". Reading the diagnostic list, I checked out the air assisted injector solenoid and its associated hoses and they seemed fine, so I assumed I may have had a bit of crud come from one of the injectors, since I was running a little bit of injector cleaner still in the tank at the time. A dirty injector was on the list to check.
Another tidbit which may be common knowledge here, but I'll contribute anyway: you can get Subaru electronic service manuals on CD on eBay very cheap; I paid about $15 for mine. A bit slow to read in Acrobat, but worlds cheaper than what it would have cost in hardcopy. I assume it is legal copy, not pirated; the label looks legit.
Stanton
Was this "air assisted injector" for the catalytic converter, or for the fuel system?
-Wes-
it probably is the cv-joint, because today i noticed that when i go over bumps while turning (i deliver mail with it, and the roads i drive are full of them lol), that theres a definite rattle going on down there. im guessing thats another sign of the problem? it doesnt feel quite as tight as it did when i first got it, but thats to be expected when it goes from an older couple using it for groceries, to well...me
and the leak was definitely oil, not the tranny. i had originally thought it might have been the tranny based on where i saw it accumilating, and the hard shifts though. hopefully that new o-ring will hold up for awhile, $160 a month gets a little pricey lol.
Well, I just hope that it will run like new.
Thanks for those of you who tried to help.
M1ax
There's a pic of this injector in the manual, and it has a small "shroud" on the injector tip, with fuel injected from the top, which mixes with air from a port in the side, then the mix shoots out the bottom. Clever design.
The manual said these injectors are used only on auto trans cars, but then at another point says all California-spec cars, both auto and stick, used them. (This was for the 2002; for all I know, they may all do it now.)
After getting the error code, I checked the solenoid and hoses for plugging and dirt, but they were fine. But the shrouded injector tip design reinforced my guess that a bit of built-up fuel crud (gum and varnish) had sluffed off one or more injector tips as a result of the fuel system cleaner I still had in the tank, causing the temporary condition that set the error code. Anyway, the CEL light is off and the engine runs like silk (well, very smooth for a four-cylinder, anyway), so all is fine.
Stanton
At any rate, when I bought this vehicle got a good deal on 100,000 mile extended warranty, -0- deductible for $899.
I have my car in for 3rd oil change today, 9200 miles (had a deal with free oil changes for one year so why not continue to do them often). The dealer trying to tell me to "maintain warranty" next time I am in they want to perform "Service B" (recommended at 7500 miles) for which they charge $99.95. That includes oil & filter, install BF MOW supplement, check fluid levels, inspect hoses, tires, rotate, install BF fuel system treatment, battery service, lube locks & hinges, inspect drive axle boots, brakes exhaust, steering, test vehicle emissions & wash & vacuum Suggested I need to do this to maintain warranty. Their Service "C" recommended at 15,000 miles is somewhate more extensive & the cost is $225. They do the same stuff again & turn up the vehicle including replacing spark plugs, etc. (why would this have to be done at 15,000 miles). Then for the Service "D" recommended at 30,000 miles they hit you for $420
Other than frequent oil changes, what other work is absolutely necessary to maintain the warranty? All comments would be appreciated.
I've been reading through posts, and you seem to be a well spoken fellow..
By chance, would you happen to know the location of the 0@ sensor & Knock sensor on an 97' 2.5 Outback ??
My error codes state that they need replacement..
Thanks for the help, Ken De..
Performing unnecessary services to "maintain your warrantee", is pure BS.
My 99 GT has 122k on the bare minimum service intervals. Oil Change at 3-4k, rotate tires (at a local tire shop - $15) at 7.5k, and regular 15,30,60k services. The only deviation is that I have all fluids changed every 30k (thanks Paisan!). Other than a couple oil leaks, and the power antenna breaking, there have been no repairs or problems. The car runs as good as the day I bought it. Just my opinion. Rob M.
I am also exploring just removing the decal altogether. It would be cheaper, but may look odd, and the paint may be a different color underneath the decal, due to being protected from sun damage. (The car is dark blue.)
Stanton
The O2 sensors are located and look as Stanton described on the '97. I am not sure about the knock sensor as I haven't hunted it down. If I think about it, I can check in my Haynes book for '96-'98s and see what it says....
-Wes-
I do not think you are unreasonable to consider replacing the decals, it just was not my priority....
Stuck my head under the hood and saw the O2 Sensor on the passenger side before the converter ( thats the one that's failing ).
Haven't located the knock sensor yet, but it's bolted to the block somewhere !!!!
I appreciate your input SWEXS & Stanton...
Last week I decided to change the headlight bulbs in my 10-year-old Ford Aerostar - they were getting pretty weak, a result of plastic lenses getting yellow/foggy and bulbs getting dim with age. At the parts store I found Sylvania XV bulbs that claimed to be up to 20% brighter, so figured I'd install them on the Subie as well - at $9 each, why not? It took 2 hours with screwdrivers, Torx driver and lots of cursing to swap the bulbs in the Aerostar, involving removing the headlight /parking light trim surrounds and the grille. It took about 3 minutes with no tools AT ALL to swap bulbs in the Subie. Several of the Aerostar's fasteners were plastic things that were probably easy/cheap to install at the factory, but stubborn and break-prone 10 years later.
The Subie air filter, fuel filter, belt adjustment points, alternator, etc., are all easy to get to. Spark plugs seemed hard until I pulled out the air induction box and windshield washer reservoir (two screws each), then they were easy. To get to the Aerostar's plugs, you have to jack up the front end and reach in over the top of the tires to get the front four, then pull the "doghouse" cover inside the car to get the back two. And changing plugs in my 1990 Taurus SHO was a three hour process involving scraped knuckles and every flex extension tool in my socket set! Recently, when a CEL code in the Subie referred me to the air assisted injection system, its solenoid was right up on top of the engine, removed with two screws. Wow!
If you don't work on your own car, this may seem irrelevant to you. But if you prefer to do your own maintenance, this matters a lot. And even if you pay to get work done, it is more likely to be done right if the poor mechanic doesn't have to scrape off all his knuckles to do the job.
Stanton
I hope I am submitting my question to the right spot! My mechanic and I are completely stumped.
I have a 97' outback legacy wagon - 2.5 liter 4 cylinder, awd, abs, 140K on it.
Every time it rains, I get stranded!
We have replaced a lot of stuff at this point. Over the course of the last month, we have replaced the cat converter, both o2 sensors, the ignition coil pack, the spark plugs and wires, and the fuel filter - and threw an injection system cleaning treatment in for good measure. My mechanic and I are runing out of ideas, and I am desperate to figure out how to fix this thing - I love this car :-(
When it rains, or if I go through a puddle, I am done in about 5 minutes after I go through it. In a heavy rainstorm, about 10 minutes into I am done. I will get to a stop sign and its all over. The car sputters and jerks, will not respond when I step on the gas and will stall. I can start it - it starts like a dream - but it wont stay running. No fun!
The first time I got stranded (during a heavy rain), I was told it was cat converter/o2 related. We changed that.
The next time I got stranded, again during heavy rain, we let it sit from about 8 at night til 3 the next day. I managed to get it about 2 miles, and it started jerking again. Thats when we found a parking lot, and changed all the plugs, wires and coil pack.
The next time i got stranded during light rain - found a parking lot again and let it sit. We went back the next day, and I managed to get it the 5 miles back to the house. We changed the fuel filter. That was about 6 days ago.
It rained tonight for the first time since. It died in traffic on me, and once again, i found myself on the side of the road, stalling out, jerking, sputtering, and not moving. I limped it about a mile, it quit completely. I pushed it into a parking lot and with my mechanic on the phone, managed to get it started and wiggled every wire I could see. Nothing. After about 30 minutes, I hoped whatever it was was dry, as it was starting to smooth out again. But it didnt last - I made it about another mile and had to leave it in a parking lot and call for help. We went back a few hours later to check on it, but things are aparently not dry enough. I came home carless.
We have racked our brains, and hoping that someone on this site may have a few suggestions... a few people though maybe vaccum hose, but we have checked that. Besides, it only happens when it rains - our guess is electrical. Maybe a fuel injector malfuntion or short, maybe the alternator is going - maybe another wire we havent thought of. I am desperate! whatever ideas anyone may have, I sure would love to hear.
Thanks in advance for whatever help you can offer. Up til a month ago this was the most dependable vehicle I have ever owned, and I am heartbroken at the thought of having to get rid of this car.
:sick:
Similar problems will happen if the pump craps out for any reason, but the only thing about the fuel pump that would be related to rain would be wiring.
The other thing to try -- on a dry day, start the car and let it idle. Strategically spray water here and there and let it soak until the problem happens. You should be able to isolate the problem area if you are careful, and trace it from there.
All this assumes it is truly related to water, but I wonder if that is a red herring....
Craig
Very refreshing after struggling with some of the others.
Stanton
I would agree with you on the water being a red herring, but I have been stranded during the last 4 rainstorms in the area.
I might also add that the simple fact of having the car get rained on or sprayed with a hose is not enough to do it - It sat in a rainstorm all day yesterday. And started and ran fine until I got a few miles up the road and went through some puddles.
Also, while I had it running with the hood up, I placed my hand on fuel line, the side coming from the pump. It was rhythmically pulsing, like I would expect - no jerkiness in the feed of the fuel.
I am thinking electrical... today once the thing dries out a bit, we plan to get it running and spray the alternator with a mist bottle - that and a few other things.
I'll accept Honda's filter issues in return for their reliability and resale value. I have a 97 OBW with 157,000 miles on it, and it's been a good car but our new Accord EX-L V6 has 75 more HP and a significant portion of the interior volume. With Nokian snow tires it went everywhere the Subaru did this winter.
The only hard part to access are the spark plugs, especially on the more narrow Forester/Impreza. But even on the Legacy, you have to remove part of the intake and the windshield washer reservoir just to get to them.
-juice
Ken
Interesting choices and priorities: you just bought a new Accord, and I just sold an '01 Accord EXV6 to get an '02 Legacy L wagon. The Honda was a fine car, but not perfect; we had a few glitches to get fixed, but fortunately none was expensive. I hope we get similar service from the Subie.
We could talk back and forth about why one or the other is better for our particular purposes and we could never agree because our priorities differ, but my original points still stand: Honda sells the "car as refrigerator", wherein they don't encourage the owner to do their own maintenance. Open the Honda's hood and you see a smooth, stylish engine cover and a battery and an air filter box; little else. They even put a plastic cover over the center of the V6 so it looks like a monolithic appliance and hides many parts. Subaru puts lots of stuff out so its easy to find and easy to work on. Subie's fuel filter is up top alongside the air filter; Honda's is inside the fuel tank(!) The list goes on and on.
Stanton
I know we can solve this issue - I don't think it is a ghost.
Kia is funny, one of their covers makes its V6 look like it's mounted longitudinally even thoug it's not! They copy Audi/Subaru, but the actual engine is transversely installed.
-juice
In all this, I assume all fender liners, etc., are still intact; otherwise a minor puddle could put water in lots of places you might not expect, such as the air intake, etc. Please check this carefully. My '02 Legacy came without one of the plastic covers under the engine compartment, causing dirt to appear in all sorts of funny places on top of the engine. I got underneath and found the tiny parts of the cover left after the previous owner had ripped it off on a curb or big rock.
I am inclined to suspect some component or part of the wiring harness that is exposed on the underside of the car. I had a wiring gremlin on my old SHO that drove us crazy for a while: the a/c compresson fuse would blow while driving the car. But when I put in a new one, the engine would run and idle indefinitely without problem. But as soon as you drove off, the fuse blew. Eventually, I found that part of the wiring harness behind the engine had become chafed by a metal bracket on the firewall, and had rubbed through the a/c wiring insulation. At idle, no problem. But as soon as the engine rocked in its mounts under torque, it contacted the chafed wire and blew the fuse.
I would definitely focus on the underside of the car, with the car on a rack or over a pit, and push/pull/wiggle every wire, hose, or connector I could get my hands on. Look for chafed/split boots over connectors. Run a hose on everything.
Let us know what you find.
Stanton
In the case of Kia, falsies.
-wdb
If you painted them, how did you make sure the paint would stick? Could you find a good color match?
If you replaced them, where is a cheap source?
I apologize for leaping to a hypothesis, but water into the air intake would be consistent with the observed behavior of the car. Driving through water (but not standing in the rain, even overnight) would put water into the intake, eventually saturating the air filter so it wouldn't flow enough air to keep the engine running, so the engine stalls. Then after the car dies, air seeps into the filter box providing enough air to start the car, but as soon as the engine is running, it runs out of air again and stalls again. Or perhaps enough water gets past the filter to wet the MAF sensor and throw the readings off. Again, on restart, the heated wire mesh in the MAF dries itself until you drive over water again. Does that logic hold up, guys?
Car manufacturers go to a lot of trouble to keep water out of the air intake. My '02 Legacy air intake system is fairly typical: it takes in air high up under the leading edge of the hood and is entirely contained within the engine compartment. It has drain holes in the underside of the entry scoop to handle rain and spray that get in, then again further downstream near the resonance box. Those holes are in parts of the system that are large in cross-section so air flow is slow enough to let droplets settle out.
A leak or a broken plastic part are certainly feasible on an 8-year-old car, and especially suspect if the air intake system runs through the fender well where it is subjected to lots of spray from the front tire.
Stanton
Is your mechanic a "Subaru" mechanic? It sounds like you get along with him but, if you need to come here with questions he can't answer you may want to go somewhere else. Dealers do charge more (sometimes) but, with good reason. They send their mechanics to classes and they're constantly updated.
I don't know if you listen to NPR but if this continues to be a problem for much longer you could call Click and Clack from "Car Talk". 1-888-CAR-TALK. You just leave a detailed message of your problem and they call you back if they want you to go on air.
Colby
So, my thought is that if something is failing with the "shield" in the wheel well, then there could be additional water getting into the cavity that holds this intake tube. If the joints are not good between this piece and the intake opening or air filter housing, or if there is a crack in the tube itself, then sufficient water could get in the intake to cause problems per Stanton's description. In fact, the way Stanton described it makes me think that the intake could more and more be the cause of this problem.....
2 Questions.
1. Does the dot pattern around the windshield serve any function? Or is it just some way to tell that the car has the original windshield?
2. Do the windshield people know that when they replace my windshield, it should have the wiper de-icer?
3. Any one recommend a windshield company in the San Francisco Bay Area (Pleasanton)?
They send installers to your home or workplace to do the repair. They ask for all the details when you schedule the appointment.
HTH,
Jim
-mike
Now that the nicer weather is returning, I'm considering a project that the boss has requested: changing the heated mirror switch (on the driver's arm rest) since she misses the pilot light (which died last autumn). Car is a 2k OB Ltd wagon.
This will be my first shot at this multi-switch panel (which is plood in my car), and I'd like to know where to start the pry-off process for this little plood trim piece (rather than use the old trial-and-error method and crack the little sucker).
Also, if anyone has performed this same switch swap-out and has some useful tips, I'd appreciate it!
Thanks in advance,
Ken in sunny/rainy/snowy/windy Seattle (psychotic month)
-mike
Insert key, turn to "On" position
Latch/unlatch driver seatbelt 20 times
Turn key to "off" position, remove
You should be able to do a search and locate it (them) quite rapidly.
