does their radio/cd work. Most dealers have an authorized
out of store shop who only does this for Ford. If it is
under warranty they can do it free, if not under warranty, they might tell you how to get it done. If you are replacing it with a non-dealer unit, get the unit from Best Buy, or a local auto sound system dealer and they will take out
and replace. Good luck, good listening.
Thanks in advance,
Bob
HAS anyone had a problem with brakes / traction control? The dealership plugs mine into the computer but there are no codes. I think its because the computer thinks its doing what is right although it doesn't. They can't duplicate the problem and it does it very random too. They won't even open the hood or do anything but drive it and return it with an empty tank of gas ( and I usually have a full tank when the problem happens and have to take it in). :lemon:
Mark
There is a TSB out for a similar problem. I suggest calling your Ford service mgr. first and then be prepared for them to "dirve it around and try to duplicate the problem". This could be futile since I never could determine what series of events needed to occur before the AC cut out. I have resolved myself to the fact that the vehicle is possessed.
Anyway, once I popped that cover off, the switches were easy to access and are only attached by a screw and a harness clip. Good luck!
TIA
I almost forgot... the 6-disc cd changer id so MESSED UP!... it plays what it wants when it wants and has trouble loading and ejecting... it says BAD DISC on brand new cd's :confuse:
190,000 is 3 years is 63k+ miles per year!
5,200 miles per month!
You Expedition should have had 38 oil changes, about 1 per month
3 Transmission services. about 1 per year.
Mark
I truly appreciate any advice. We will be towing a 19 ft travel trailer and we guess it's almost 6,000 lbs loaded with everything.
Good Luck,
Craig
Craig
I think that's called an oxymoron.
SUVs and Smart Shopper
The O/D (Overdrive) light started blinking. I manually pused the overdirve button and was able to shift the car in and out of overdrive, so it was working.
When I tool the Expedition in for the 60,000 mile service I told them the O/D light had been blinking for a couple weeks. When they checked the codes they said it was a sensor on the transmission. Then they called back and explained that when they opened up the transmission they found metal chunks that were fairly large. They tore apart the transmission and replaced the torque converter and 4 clutch bands (I think that is what the said). They said the front clutch was burned up?
I paid $1200 and picked the car up. Within a few miles.....guess what? The O/D light started blinking again. I called back and they said bring it in the next week. I did and now they found that the PCM is bad. What is interesting is that the same codes showed up the second time. The new PCM is covered under the 8/80k warranty.
Now I have asked the dealer to consider that the damages that I paid for before were caused by the failed PCM. He disagreed (no surprise) and said that he has never seen a PCM cause transmission problems. Is that true? Can I get them to pay for part of the transmission repair? I think you call that "consequential damages" ? or something like that.
Help!
John
I just purchased a 2000 XLT RWD Expedition with 78,000 miles. I have no mechanical history on the car except for the carfax report which doesn't offer very much.
It runs well, but I've noticed a few eletrical ticks. I'm most concerned about the recall that prevented the cruise control from starting a fire. Is there an easy way to check if this car was fixed during the recall or do I need to have the dealer do it?
Also, are there any tips for a new owner?
If so can you explained how you did it
cost time and parts?
Thanks in advance
We have an 05 Expedition with the larger of the two V8's. My wife exited the highway on Saturday and felt a rough idle and thought maybe she was low on gas even though the gauge showed half full. After filling up, the engine would crank but was very difficult to turn over. After getting it to start a huge plume of white and then blue and then back to white smoke came out of the tail pipe and was very - very rough in idle. She brought the vehicle to a Firestone across the street where they initially diagnosed that the #8 cylinder had dropped, the ignition coil, plug, wires and O2 sensors all needed replacing ($985.00). Then upon restarting they realized something much worse must be bad as a distinct knock and more smoke continued to emanate from the engine. The said the engine was running unbelievably rich and tons too much fuel was being let in to the chamber.
In there opinion the engine would need to be replaced.
I went to speak with the dealership I purchased the vehicle from (no extended maintenance agreement) and they said it sounded as though this may be related to the Ford issue with Fuel Injectors being stuck open on the same engine as was in my Expedition and also the F150 of that year. They said to be careful to not even try to drive it to the dealership as it might bend rods, etc. Apparently Ford had extended the warranty for the injector and issues caused by stuck injectors which I was still covered on.
After I went back to Firestone, they agree that the car s/b towed to the dealership (yesterday).
The dealer called me today and said they were able to determine that the #8 injector was stuck open, they reported it to Ford, Ford instructed certain repairs which after performing them still had the dealer recommending engine replacement.
Ford has now said they will not approve replacement until the dealer pulls the engine, breaks it down, inspects certain components and reports back to them - at which time they (Ford) may still require an independent inspection before approving. Here is the rub...the dealer wants me to approve the work as I WILL HAVE TO PAY FOR IT IF THE INSPECTION DOES NOT PROVE THE INJECTORS HAD ANYTHING TO DO WITH THIS!!!
This is where I am calling foul.
It is my opinion that the symptoms, the voluntary Ford warranty extension, and the professional opinions of two different Service Shops (A Ford Dealership "Landers" and Firestone) provides enough just cause to assign cause of damage and if Ford requires the engine be pulled and broken down it should be at their own expense.
This is the second model Expedition in a row that has had the engine or rear end roll over on me (01 Expedition before this one) and I believe Ford is skirting the edges of a full recall.
I am very interested if anyone knows of pending civil or class action activity I can join if it comes down to it (certainly hope not though) and if there are any groups within Ford or external - Consumer Reports, Attorney's, etc you would suggest I contact.
The Expedition is a wonderful vehicle on the inside it just unfortunately has not been very reliable mechanically for me.
Thanks for your time and any insight you can provide.
:sick: :mad:
any type of stuff. It may effect the oxygen sensors and screw up the mixture where it will cause the car to run foul. This may have caused the catalytic converter to get fouoed up. I think its better to leave a dirty engine
When I fill it the fronts work fine, the rear doesn't squirt, the fluid is dripping under fwd and rear end of the running board.
Your replies are appreciated, Thank you.
