Regarding Continental tires. I finally bought new Michelins for my 03 Expedition. I had 56,000 miles on them with between 1/4 and 1/2 the tread left. But, since going on an extended trip in the winter, decided to replace them. While I had no real problems with the Continentals, I have noticed that the Michelins are a big improvement in ride quality (quieter and not nearly as intrusive).
Thanks for your help
Local Ford dealer dodged replacing the one very bad Contitrac TR tire until many miles had run up and a new tire would not have matched due to wear on the other three. Three worthless attempts to balance the tires by the dealer. Dented those wonderful chrome clad steel wheels on the 2004 NBX more each time. (see earlier post)
After I described how dead the battery was when I first looked at my new 2004 Expedition and how apparent it was that the vehicle had not been driven in months and months, my local Firestone store manager friend said the time on the lot might be the problem. He went on to say the one bad tire would not get much better based on his many years experience. Some Ford dealers rotate the stock excessively to make it look like sales are booming (Ha!) and other dealers don't move the unsold inventory around at all.
Because of the automatic lights shut off on new Expeditions, there is little reason for a battery on a new unit to be so cold stone dead that it will not even operate the door locks. Buyer beware!! Lumpy tires on long parked unsold inventory might not get any better anytime soon.
has NOT been any further contact from Continental to assure the problem was corrected
P.s. no follow up by the Ford dealer either even though I emailed them after the third balance attempt stating that the one tire was still bumping...also no response to my complaint that my lug nuts were twice over tightened by the Ford techs (150+ lbs the last time per neighborhood Firestone store)..then I'm the bad guy for going to Ford dealer management...unsupervised misfits do not need to be changing tires anywhere...
This is the programmed indicator that your battery is not fully holding a charge and you have low voltage during startup. Change out your battery, and this will go away. It may also solve some or all of the other gremlins as well. Don't know for sure about those, but clearly, you have a failing battery. To this day, the dancing guage needles is a low-bat indicator by design on these trucks.
4L1Z 2001 BA Kit, Brake Shoe $233.00
2L1Z 2B164 CA Clip $ 20.62
2L1Z 2C150 AC,Kit guide pins & bolts$ 32.20
2L1Z 1V125 AA Rotor Assy (2EA) $201.52
Labor $119.95
Shop Materials $ 5.00
Tax $ 50.19
In case you add that up and get a differnt figure than the $747.48, there was another item that came to $85 that I couldn't decipher. That may have been for turning the rear rotors, as I only had the two front rotors replaced. The kit comes with all four pads, the rear rotors were barely worn. I had this done last week and so far no appreciable brake dust noted. I had this done because the brakes needed replaced (64,000 miles), not necessarily because of the dust issue. However, since I was going to replace the brakes any way I figured "why not"! My wife was upset because she sees these stupid adds in the paper for "life time brake service for $89.99 for most cars and light duty trucks".
Anyone have any hard evidence to show my dealer????
Anyway, they only charged me $200 to do the front brakes.
Ceramicool(True ceramic premium pads) D934, I purchased mine from brake world .com
Question. Could you remove the lugs with your standard Expedition factory supplied lug wrench after the 150 lbs installation? My 400 lb (fairly decent quality Lowe's Professional series)impact wrench with my nearly new oil-lube 20 gallon compressor set at max 120 lbs would not even begin to loosen the lug nuts tightened as described in my original post. Same for long single handled Ford supplied lug wrench. At 235 lbs and very strong arms and hands from a lifetime of working on things and sports, etc., I'm way stronger than the average guy trying to change a flat with the factory lug wrench gear. Might have been able to get lugs off at home with a jumbo sized 4-way lug wrench. Don't know? Firestone store's Ingersol type pro wrench at 600 lbs backed them right off. Still, the Firestone tech was way surprised at having to reach for a 4 foot power handle to move them by hand. No need to have a spare tire at these excessive lug nut torque specs.
Thanks for your reply!
"Fuse panel and GEM are under the dash on the left side. There should be a cover or two over them. The GEM is bolted to the back side of the fues panel... the assembly is held in by 4 10mm bolts on the front side and two big electrical connectors that are also held in by 10mm bolts. There are three other connectors on the GEM that are simple press to release type. The water, or evidence there of, will probably be most easily seen inside the big connectors."
I just started to here a "clank" from the front end when i turn the wheel during parking.
I did a search and did not find anything.
Could it be the ball joints... is there a inherent problem?
Jeff
the brakes do hold, can not find an adjustment
at all on brake cable.
