i can sleep better at tonighzzzzzzzzz.
YES! It worths your time. It will tell you whether your Honda has any recall on it. Also other helpful information too.It's free and take advantage of it.
bjk
www.herbchambers.com
It was a Canada made unit.
Has anyone investigated installing a sunroof on the Odyssey 2002. I've been told that it is not possible to do so without compromising the rear AC/heat ducts in the roof.
However a local dealer was willing to install it for me suggesting that there would be no problems.
I would also like to get heated side mirrors and was hoping it is possible to have that installed considering the option is available in Canada.
It is very dissapointing that Honda does not offer these options in the USA. I believe the sunroof is available in Japan.
Any guidance would be appreciated.
IIRC, they have done Odyssey sunroof installs. They have locations nationwide.
As for the heated mirrors, when I inquired about my 00 Ody, I was told that it uses a different wiring harness and it would be cost prohibitive.
Good Luck.
I would suspect that they would install the roof for me and even given me a lifetime warranty on the sunroof. But I am worried about the AC/heat functioning in the rear.
If anyone has got a sunroof installed on their Odyssey(from '99 onwards) I would appreciate hearing your experience with it.
Could you tell me what company gave you the quote and was it them that did the 30 installations you mentioned?
Thanks a bunch for the info.
J
I'd really appreciate your thoughts!
Alexis
For a used car the warranty is usually not a Honda warranty. It has big loopholes in it that you will not be able to find. Also used cars often sold with rolled back odometer, been in wreak, been in flood, abused, so hard wear.
Why take the risk for such a small difference.
I see it has the lowest service cost of any minivan at $1,956 for the total 5 yrs. Highest Pontiac Montana $3,066, for the standard front wheel drive. All-wheel Montana is higher then that.
Service cost defined as maintenance and unscheduled repairs over 5 years.
Best resale value of 69%/53%= 2yr/4yr. The average for the four Chrysler minivans is 45%/32% = 2yr/4yr. Those numbers are % of average MSRP.
So it looks like the Odyssey is reliable and is a good deal cost wise to buy, for a minivan, considering all the other factors.
Safe travels to you over the holidays. I am comtemplating a trip which will require the use of the luggage rack. How hard are they to install? What is involved in installation? This is basicly a one time event of hauling the head board (Fullsize bed - six foot tall) and two dressers which is too large to get inside.
We just purchased some Michelin X-Radials. I was surprised that they may not be as loud as the Firestones, but you still feel the joints in the interstate concrete slaabs. They were only $400 at Costco.
Thanks for your comments.
Thanks for any infom you may have!!
David
The rear tether points can be installed on the rear trim just beneath the door.
Good Luck.
David
hope this helps.
http://www.car-safety.org/odyssey.html
Question on service contracts: Is Honda Care better than "Easy Care" by APCO that the dealer pushes? I wasn't offered Honda Care.
Great mileage, btw!
The HCW tells you what is not covered, and everything else is covered. The non HCW tells you what is covered and everything else is not covered. That is a big difference. That's because with the non HCW you are not going to be able to find what is not covered and has been left out.
Also with the HCW it is excepted by the Honda dealers without question. With the non HCW they have to call the other company to get an OK. Sometimes the other company says no. They say it is your fault that the car broke because you did not do something you were suppose to or were to hard on the car and so on. They also go out of business sometimes. Also with the HCW you get a car to drive while your car is in the shop being repaired, if it is there overnight or longer
My dealer sold me a non HCW and told me it was a HCW. When I got back home I read over the warranty and became suspicious. I called Honda and found out it was not a HCW. The HCW warranty says on it it is a HCW.
Since you have quite a while to cancel the contract I took it back and the dealer then sold me a HCW. The Odyssey location where I bought the car does not sell HCW, but the dealer also sells other Honda cars. He was able to get me the HCW through one of his other locations where he sells these other Honda cars.
You can buy the HCW from any dealer in the USA and at a big discount. You have a year or more to do that.
How often should I buy? Once a month, twice, etc?
Thanks a lot.
If so, how much do you all think I should pay?
Thanks again.
I querried the finance officer about it and was given a song and dance about how it covered more, but I still felt unconvinced.
I would find a refiner that puts detergents in all their gasoline blends (ie. Shell Canada) and just stick with them.
As far as the lender of your auto loan is concerned, I very much doubt that the loan was made to you based on your having an extended warranty. Even if it did he should be happy to have you go over to the HCW.
I know that there the risk of running down the battery, but sometimes I'd like my Ody to work like every other vehicle I have ever owned.
Also... a couple of years ago, I read of someone who had modified the power doors so that they would operate without putting the vehicle in park. Apparently there are two interlocks, one tied to the speedometer, and one to the transmission/gear-shift. This would allow you to open/close the doors without shifting into park, as long as you are at a complete stand-still.
Can anyone point me to the web-site or forum entry that gave instructions as to how this was done?
This has happened twice on our '00 Ody (133k miles). Both times it was the same problem - plugged EGR valve. The last time a "kit" was installed. Ask your service writer about this. There is (was) a service bulletin on this problem. I believe Honda covered part of the charge the last time and refunded the whole cost for the first time. They say that with the "kit", it shouldn't happen again. I believe the "kit" is a new, redesigned EGR valve or certain parts pertaining thereto.
