In any case good luck.
As for Honda being willing to take your money for service work - that's the dealer, not Honda. They are independent businesses.
Thank you for your help and advice in advance.
- Can the Odyssey take some off-road driving? It would be about 1/4 mile each weekday, nothing bumpier than half curb height.
- How about ground clearance when pulling out of a steep driveway nose first (our Saturn scrapes it's nose)?
- How well can three older kids fit in the second row?
I'm brand new to this forum, which I'm excited to have discovered, but have no knowledge of minivans or brands, aside from what I've read concerning Oddys, Siennas and T&C, so I would really appreciate any and all comments/thoughts/suggestions/advice!
great car.
Did you ever buy your boat? I own a 2002 odyssey and am looking to purchase a boat with combined 3,500 boat and trailer weight. Wondering if anyone has done this. Also, the trailer has 4 wheels, don't know if this makes a difference. It is very hard to get good info on this.
Kaziii
If it does fail again before 160,000 km is it still under warrantee?
One thing you might want to do is file a report with the NHTSA. Click the link to go to the complaint form:
Report a Possible Defect with Your Vehicle or Child Restraint
Hope this helps :-)
I had a new tranny in at 70K, and then a new electrical wire at 82K because some furry friend chewed through the wires somewhere. My van has 83,000 miles right now.
Then again amongst the 2002s, its probably luck. Mine was probably done on a Friday afternoon, when the QC guys were in a rush to get out of the factory and my friend's Ody was probably built on a Monday afternoon, so the QC guys weren't in so much of a rush to get out.
Look for a certified pre owned one. They have the Honda Certified warranty up to 100K I think, and they should have passed a factory inspection.
Welcome to Edmunds' Town Hall.
I have tried and tried to get an answer from my local Honda dealer as well as customer service as to when to change. My local service manager says 50K. He says Honda does not want to say this because they want to stick to the 100K first service. If you see what they found in it at 90K you probably don't want to wait.
Call your dealer before you just show up to have it changed. The parts dept said there wasn't one until I showed them the filter on their computer.
Sean
Sean
Push your dealer to check some things. They will. They also found an O2 sensor that was slightly out of range.
Good Luck!
Sean
I believe your converter should be covered till 100,000 miles. It is a federally mandated item.
So, is the dealership just wrong? Or is that psi specific to that tire? Still 30 psi seems low. Thanks for any assistance. :confuse:
Or
What the dealership says?
Ody recommends 35psi cold. A lower pressure would give you a softer ride at the expense of fuel economy due to increased rolling resistance. A higher pressure, but less than max tire pressure, would give better MPG, rougher ride due to lower rolling resistance.
The PSI choice is personal.
With the very high cost of the repair (about $1000), has anyone done this themselves? Can you comment on the difficulty of this and what is required? I am fairly handy but not a trained mechanic.
I did find some law that says any purchased new in the state of Maine should last, under normal use, for 4 years from the date of purchase. In mentioning motor vehicles specifically....it says that mileage isn't an issue as long as it is considered normal use.
Any one heard of this? Here is the link:
http://www.maine.gov/ag/index.php?r=clg&s=chap4
Thanks for any input.
There may be other sensors, related to pollution controls, to look at as well.
Now looking for a 2006 EXL-RES
I notice that there are a lot of problems with the catalytic converter dieing in the Odyssey. Has anyone found out what the culprit of this problem actually is? I was thinking that it would be the oxygen sensor, but bwear, you make me think otherwise. I certainly don't want to be out $1000 in a year by guessing incorrectly.
Also, what is an EGR valve?
A fraction of the exhaust is mixed into the input manifold--a technique used to reduce carbon monoxide. The valve regulates the flow, depending on engine conditions. I think the valve closes at low rpms and opens at high...
'03 Ody EX
