then there was the ignition coil fiasco...not a problem for TDIs (no spark plugs).
The TDI engine is not problemic, there are known issues (intake crud that requires cleaning).
MAF sensor failures...happens to both gas and diesel
Any recommendations?
Goodyear Triple Tread (700 utoq vs400 for oem Michelins) T rated
Goodyear Comfort Tread (700 utoq vs400 for oem Michelins)T rated
Kumho Ecsta HP4-716 H
BF Goodrich Traction T/A H
Falken Ziex ZE 512 H
Yokohama Avid H4S
As you probably have read, the GY Triple Treads and the Falken 512's are "directional tires" so if you plan to stay with the oem recommended rotation pattern, no problems or concerns.
I have implemented a 5 tire cross rotation, I am at 46,000 miles on my oem Goodyear LS-H's and am projected to go a min of 85-95,000 miles.
You can do a sort of modified 5 tire rotation with directinal tires. If you decide on this combination let me know and I can describe who what why when and how.
The dealer wanted just under $600 for the Michelins.
Many thanks.
Pirellis are a good choice - and the Tire Rack web site has a wide variety of reviews and user comments. Take a look.
Also, do not forget that most TDI owners put some kind of diesel fuel addititive in at each fueling. The additive virtually eliminates water in the fuel. (It also improves MPG, reduces smoking and keeps the injectors clean)
Any suggestions?
www.duralt.com
the EGR mod helps reduce the liklihood of intake crud. The other side is a Mann Provent for the PCV system.
Overall it's pretty reliable.
The MAF problems is on the gas engine also
While I have driven and ridden in the Focus, (I didn't like it) I do not have a sense of how it has worn on you. I also don't have a feeling as to price appropriateness for your area and demand level. However, I was almost shocked to find that my 2003 VW Jetta TDI actually sells for MORE than what I paid for it new.
For sure do the EGR mod. As for crud in the MAF sensor, use the oem air filters. I would not use the oiled gauze or foam aftermarket products.
I personally divide the maintenance issue into scheduled and unscheduled. the major key maintenance points seem to be at the 100k intervals (or 2.86 year marks for you). This is a timing belt change. (seems the bell shaped curve is app 90-120k miles) Since the coolant system is breached during this procedure, while you can reuse the G12 product, it actually is a good time to change the coolant. While water pump changing is not required at this interval due to the mk4 design it is highly recommended.
If you are not a clutch grinder, useful life can be as high as 450,000.
After the meager mileage warranty (50,000) I am good to go to 15,000 and or 20,000 miles between oil and filter changes.
So tire rotation (10k) and brake pad checks will seem to be the majority of the items. Of course air filter changes (40k), cabin filters (20k)and fuel filters (20k) need changing also. Brake fluid bleeds (2 years)
My goal is to run this thing 500,000 to 1,000,000 miles. With proper care and maintenance I see no reason why you can't do it also.
Most assuridly you can use #2 diesel at truck stops. I would not use the high flow pumps unless you know what you are doing and are alright with an occasional spill! But at every truck stop I have fueled, there is an auto diesel area.
Since you live in the winter area, you might probably want to get into the whole additive discussion. Bottom line is you "might" want to do a winter fuel additive (anti gel)..(Primrose (and others) makes a winter fuel treatment. I use Primrose 405 which is a cetane booster, H20 emulsifier and fuel lubricity agent. I honestly can not tell a performance difference between treated and untreated fuel
I would be remiss if I didn't mention that the VW has a reputation for weird part's failures. You of course have alluded to it with the MAF failures. While the 2003 as been absolutely flawless for me, my sense of it is: the VW corp has a begrudgingly slow constant improvement policy
oiled filters, OEM paper filters...they both kill the MAF. I have a K&N on mine-- 90,000 miles and on the original MAF. Though I do clean my MAF regularly. Takes a couple of minutes to do while I let the oil drain during oil changes.
One thing also that needs regular maintenance is the "snow screen". Chances are, it has not been cleaned. This is located at the front of the car, behind the headlight. It is a fine mesh screen that prevents snow from entering the airbox, and acts as a pre-filter
I feel that the 18500 price is high. The salesman has called me 3 times since Monday. I know they're eager to sell due to the fact that there are approx. 30 used VW's on the lot as well as 15 04's as of 12/30/04. Price seems to vary quite a bit between my area and the DC/Baltimore metro. A co-worker priced a '04 Golf GLS TDI at the same dealer on Tues. and he was quoted 18100. So maybe I'll pursue that route.
I really need the longevity of this type of vehicle along with driving confort and 4 doors. The Focus ZX3is a fantastic handling car. If you test drive 1 again take it on a mix of high speed freeway and fast curves driving. The ST model has the same motor/trans. set up as the Mazda 3. The drivers seat has gotten increasingly uncomfortable lately. It seems to closing like a clam shell. Not much..maybe a few degrees, but enough that my 1 hr. commute gets uncomfortable. The only issue with the Ford was a power window switch fixed under warranty. The auto trans shifts well and gas mileage has been a consistant 30 mpg.
My last experience with VW was with the mid-80's rabbits. They handled great, got good mileage and had numerous electrical woes. When my sister traded her '86 Rabbit in '94, it ended the VW legacy in our family. We previously owned 2 Beetles, and 4 Rabbits, so I'm a little hesitant on taking the VW plunge again. I am encouraged that quality is improved by the feed back on this board. Thanks for your expertise.
I actually like the look of the Golf better than the Jetta, but then I really started off wanting the Beetle TDI !!
Also as bpebbles has mentioned, it might be worth the effort to buy the TDI's in area's where the price is not so "dear."
Happy New Year to all.
Here's the situation. About a week ago; passenger low-beam went out. I thought; okay...gotta be a bulb. Then I'm informed by the boss that the other one is out about a week later. Oops. I'm thinking bad things here. I checked the fuses today (all four are fine..and that's kind of interesting; four fuses for two lights and two status'--hi, lo). So I took a shoplight, and shown it up from the bottom with a dim bulb, and yep...sure enough, each side has one burnt-out filament. Strange that both would go bad in one week, and just the low beams...but okay...
I pulled off the back weather cover on the passenger side, and the bulb thing is even nice enough to have arrows to say "on" and "off"...but no matter how hard I turn by hand, I cannot get it out. I tried doing a little push and turn, a little pull and turn...but really thought, if I have to try this hard, perhaps I'm doing it wrong. Suggestions? Take a pair of Channel-locks to it? (I thought....nah....won't do that). Or just more hand torque?
I also saw other items on the 'net about taking off the bumper to change bulbs...but I really don't have to do that, do I?
Finally....okay to get replacements down at my local AutoZone, or should I pony up the bucks at the dealer? I don't mind, if it's an important OEM part (e.g., filters), but I paid $50 for wiper blades and thought "that's nuts"....time to start shoppping!
Thanks again for everything; I'm at about 65K and this is the first thing to replace (other than oil)....and no, haven't decided on tires yet, either. Although I am studying.
Thanks, Jason
There is NO "push-n-turn" to remove the H7 bulbs ( http://www.autolamps-online.com/halogen/h7.htm ). Instead, there are a coulple of wire 'bails' that need to be unlatched so they swing out of the way. then the bulb just pulls straight out the rear of the headlamp assembly.
There are several ways to help prevent this occourance. The easiest is to use full-throttle accelleration at least twice per tank of fuel. Also there is an 'adjustment' that can be done using a laptop computer and some special software. Basically, you turn down the amount of EGR that occours to the bare minimum that will not flag the CEL.
Also keeping the 'snowscreen' cleaned out reduces the amount of vacuum in the intake track...this, in turn reduces the amount of oil vapor that is sucked from the engine.
Some folks have replaced the factory PCV breather with some hoses and stuff that helps to seperate the oil-vapor from the PVC system.
I've been considering purchasing one and would like some additional input.
www.davisnet.com
From the website I get the feeling that the technology is independent of the type of car.
They just tap into the onboard computer to measure speed, accelation etc. before triggering an alarm and recording the event when high speed or caaeleration happen.
I suppose that it does what it says it does.
Automatics get app 8 mpg less. But yes they are very reliable. Also new they cost a premuim over the 5 speed manual.
There is another anomoly. You can do hp mods and the auto tranny will handle them much better and probably you will not need to do a clutch upgrade. This as opposed to: if you have a 5 speed manual doing a hp mod, you will probably have to change the clutch sooner if you keep the standard clutch, for a hp rating upgrade on the clutch.
If previous owners know the clutch secret for the TDI's, there is no reason why one can't get many years of service. We are talking 400-500k.
On the automatic there is of course a periodic tranny oil and filter service. But again with reasonable care and luck there is no reason not to have long life also.
Ruking1....what is the clutch secret?
TDIBOB
If you are getting TDI for the MPGs, dont go with the automatic. (the automatic consistantly returns between 5-8 MPG less than manual tranny)
If you live in cold climate, get the heated seats and consider adding "TDI heater" or some other way to heat the engine. (Otherwise you will drive for many miles with no heat.)
If you drive under slippery conditions, insist on ESP.
TDIBOB
However, good luck finding an '05 Golf TDI automatic...maybe the rarest car in the whole VW line right now...
Having a wife that can drive a stick is almost a prenuputual necessity ;-)
In any case, all my VWs have been loads of fun to drive. Good luck with your search for one with an automatic tranny.
For hard-starting TDIs, some folks suggest glowing up to 3 times before attempting to start.
The white smoke is normal.
I am not sure what you mean about the oil light coming on when you "try to start it"... the oil pressure is only expected to come up to spec AFTER the engine is running.
I assume that you are running the properly-speced SYNTHETIC oil. (greatly helps with starting)
My suggestion, install and use a "TDI heater" ( http://www.frostheater.com/ )
Also, chronic hard-starting has been traced to non-functioning glowplugs. They are easy to diagnose and replace.
Secondarrly, have the "injection timing" checked, it has a bearing to cold-temp. starting.
TDIBOB
