Also, A/C is weaker when engine is idling, but should cool down well when in higher RPMs.
Steering on the Matrix is toward the heavy side, so that may give the impression that the turning radius is bigger than it should be.
Engine RPM during start-up should stay less than 2000 RPM when engine is cold, much less when it's warm (since it's Summer right now). This applies to Corolla engines as well (same as Matrix).
1matrix
'03 Matrix XR 4WD
Gas mileage in the teens? Yeah, I would DEFINITELY get that checked out. Even with the A/C on all the time (just about all summer long), the lowest mileage I ever recorded was 24.5 mpg, and I have an automatic trans. Take it back in for service, no way 12/15 is acceptable (my friend's F350 gets better gas mileage than that!)
Yes, black will be hotter - it's black because it's absorbing all of the colors of light. Black pigments will typically absorb into the infrared too, adding to the heat. Wear a white T in the sun for a while and trade it for a black one to see for yourself. A white/silver car with a light colored interior will stay much cooler than a black/black one will...
With Toyota’s current problems with Engine Sludge going back 8 years, I believe that Toyota vehicles are about to see a massive increase in engine failures. Our Corolla is not specifically included in the company’s Engine Sludge alert (Quasi Recall) but I wonder if it could be very soon.
Buyer BEWARE! Toyota will not help you when their famous high quality engines fail!
1matrix
'03 Matrix XR 4WD
P.S Overall the Corolla is a nice car, but not cracked up to be the "super car" that the dealerships claim it is.. We live in the Midwest and this car "DOES blow you all over the flat interstate roads contrary to what they want you to believe. A good car but not great....
Fed up in Indianapolis
anyways, you were over by 2,000 miles on the warranty so the dealer or toyota have every right to refuse to cover all the charges. you're not 2 miles over, you're 2,000 miles over. put yourself in their shoes and i don't think you would be covering the charges as well.
our family members have owned 17 toyota vehicles for the past 19 yrs. and none had engine problems or any major problems.
this sound about right to those of you with 03' corolla's?
Have a 2003 Corolla CE bought new in May.
Noticed that the black rubber door seals (the ones on the car body not the door) had both split at a point slightly above the door lock striker in the doorframe.
Driver side split clean through from too much squeezing. Passenger side showed a line where it will split soon.
Is this a design bug? Dealer is changing both gaskets this week, but I wonder if it will happen again unless parts are redesigned.
Service advisor said he'd not seen this before.
my auto trans shift knob light is out. i can't see at night if i'm in D, N, R, ... is this a bulb or fuse issue. i was told that a fuse controls more then just one light.
any ideas?
jrct9454 how long have you had your corolla? do you have problems with rock chips? it seems like my paint is stronger than my canada built 2002 corolla. i have a couple but they are really tiny compared to some of the ones i got when i had the 2002
Ours is Lunar Mist from NUMMI, made first week of March. Very happy with the car overall.
you have to remove the cover to get at the bulb
Understand, there are also professionals out there that the dealers hire for working on the used car lot; if you have some particularly challenging spots on the front of the car, ask the dealer for a reference and hire a pro.
picture instructions would be great on the web if possible.
Our Toyota is a 1999 and we changed our oil every 4,000 miles. We have all of the documentation to back this up. Still, when the engine failed at 62,000 miles, as described in my previous posting, Toyota has refused to even consider our case. I will never purchase a Toyota vehicle again and I will recommend to all others to never purchase a Toyota. This is a company who stakes its reputation on a quality vehicle and top notch service. We have seen no evidence of either facts. The low quality aluminum block engines that they are now placing in their vehicles along with all of the new evidence of oil sludge caused by faulty engine design have convinced me that within the past few years Toyota has begun to manufacture low quality vehicles that will in the near future begin to fail at much higher rates. The only reason they are not issuing national manufacturers recalls related to the engine sludge problem is because they would have to recall the entire engine which is too expensive. Toyota's only option is to duck, hide, and blame the customer. Read the current press and you will see that I am right. Good luck to all of you fellow Toyota owners. The era of Toyota's lasting forever is over!
She has over 71K on the odometer and the only thing that needed to be changed were the Goodyear tires. She has Michelin X-Ones on the vehicle and the ride has improved a lot.
There are no sludge problem, leaks or rattles. The paint finish on the car still looks like new. (Maybe it is the Zaino I put on it when she is home for the summer and holidays.
I will tell you that the Corolla has been more stellar as compared to my Honda Accord.
The Sandman :-)
Secondly, the only thing to recommend the Goodyears is their low rolling resistance. We replaced ours at 3200 miles [we now have 4800] with Michelin X-Ones. They stick better, track better, are a bit quieter, are vastly more secure when it's wet, and ride about the same. And with regular rotations, should last 70-80k miles.
There are a number of possible reasons for the dash noises - here you need to get to a dealer and start them working on the problem. If you track back a couple hundred posts in this board, you'll read some possible sources and solutions for some of the noises.
Our car has not had any significant noises - a NUMMI car made in early March. My perception is that the Canadian-built Corollas may have more of this syndrome than the NUMMI cars, but I could be wrong. In any case, get your dealer to do his job....
Ryan
Buy Yokahama tires!
My two has had Yokahama tires since 96.
The local newspapers here have been saying that after the first 500-1000 miles ppl have been getting 40 mp gallon. Really good!!!
i have a 2001 toyota corolla le with 30000 miles on it. i change ATF every 15000 miles as recommended by a friend because of my hard driving habits. i used mobil 100% synthetic ATF last time along with the premium ATF treatment solution. i like to use the best stuff on my car. please let me know whether i should use the same two things this time or i should buy toyota ATF. also, my car shifts roughly from P to any gear (R or D or L or 2) but very smoothly in between any other gears(R and D and L and 2). i have been unable to understand the reason. i guess, i am still a novice but very interested to learn more.
thanks.
I bought a 2000 Corolla CE recently. Its alarm system is too sensitive! 3 out of 4 nights it
shouted out loudly in the midnight, which is quite annoying. I use securikey+, somebody said its sensitivity is adjustable and dealer can do it. But if it's easy to do, I want to modify it myself. Any suggestions? Thanks.
I'd be suspicious of improperly repaired transportation damage.
Poorly repainted plastic bumper covers tend to peel. Also, of course, the factory could have painted over a contaminated cover causing lack of adhesion.
Dealer needs to properly prepare and repaint bumper cover.
Passenger side visor mirror fell out of visor.
Visor replaced.
After tire rotation, Firestone tire squeaks over bumps, as if plys are coming apart within tire. Put tire back on rear so I can't hear it.
I had very good experience with my Lumina 90', bought it around 100K, now it is almost 140K. I had less problems with it than the Corolla. Now I in the market for an Impala. I hope I had not offended Toyota fans.
Twilight sensor: has anyone had any luck coming up with a solution to this thing? It is mounted too close to the A-pillar and so flicks the headlights on and off all day long whenever you go around a corner so that the sun is to the left and right. After the dealer told me that if disconnected it will cause the lights not to work at all, I have been just leaving the lights on all the time, so that the dash lights do not go flicking up and down all the time, but I would rather they just be off. Any good solutions out there?
Also, a minor question: the brochure for this car states that it should have retained power for the windows for 45 secs after the key is turned off. Mine does not, however. Does anyone have this? Mine is an XR.
