In My 2007 Toyota corolla(36k miles) there is no power for radio,clock,power outlet and power side mirrors.
Suddenly this problem started today afternoon.
Nothing different happened today.
Please let me know if anybody have this same problem and the solution for this if known?
Prasad
Thanks for the help.
Also, there is major wrinkling on the driver seat and the front passenger fabric seats. Just the left side, an area about 8 inches long but it looks odd. I think this is a warranty issue as I have had the car 18 months and have never had any car do this before. I have rented similar Toyotas with a lot more miles and never saw this before. The Dealership, same tech says this is normal wear and tear.
Anyone had these issues before?
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
I'd have to see a photo of the seat to comment further.
Appreciate any and all help!
ROCK AUTO has your filter for $6.60! (the 1.8L engine. I didn't look up the 2.4L--might be the same).
I am not confident that I can do this. I do okay with the taking apart, it is the putting back together that is always the problem. That and losing parts mid way.
It's so easy even a cave man can do it.
"you do not want tires at the rear of your vehicle that have less of a contact patch with the road than the front. In your case there is only a 3/32 of an inch difference. You will experience greater tire wear on the front tires than you will in the rear. This is due to it being a front wheel drive vehicle. With your tires in the current positions the tires on the front will wear out long before the rear tires will. You will then be replacing two tires at a time. If they are rotated and the tires that have more tread are placed in the front they will catch up to the wear of the rear tires and the whole set will match."
http://car-reviews.suite101.com/article.cfm/bad_smell_from_cars_air_conditioner
Just kidding---the scent is very subtle and OZIUM is an odor-killer, not a masking scent.
Thatz some very useful information.
I've a 09 corolla and I also feel same problem at times. But for me it's mostly when I turn on the FAN only.
Anyhow, can we buy 09 corolla cabin filter from Canadian Tire or somewhere ?
and if I replace it by myself, does it affect the warranty of the Car?
And no, there's no affect on warranty--it's pretty hard to mess this up. Of course, if you break a plastic case or something by doing something you shouldn't have----well then.
Recently I got it changed (1st time) from Toyota Service Center and they charged like 66$ for a new one (which includes service charges too).
Also I end up paying 45$ to fix my flat tire.
It was my first time but I learnt my lesson that one should not go to Toyota Service Center for a flat tire or for that matter - replacing a cabin filter.
1. warranty service
2. dirty nasty things I didn't want to do
3. something I didn't want to take the time to learn, or needed a special tool for.
I'd suggest using Google to search for "change corolla cabin filter" and do it yourself if it's easy enough.
You can pick up a Purolator cabin filter at PepBoys made in the USA.
Huh? Nobody mentioned warranty in my post... confused.
Are you still confused ????
That was geodrive, a quote from another post.
Nobody mentioned "warranty" in my post.
What did that purolater cabin air filter set you back at Pep boys? How does it compare in quality to the Fram "Fresh Breeze" cabin or the OEM cabin filter?
Here's the link:
http://www.empirepao.com/tsb/T-SB-0384-09.pdf
I think that the upholstery is ruined on the two seats in that area. The dealership that I took it to said it is normal wear and tear on a year and a half car! The same tech who said that the tires were rotated wrong.
What do you think? Is there a repair bulletin on this?
