We don't have an aerial with a tiller on my department - the latest, greatest truck we have is a 105-foot ladder/pumper combination with all-wheel steering controlled from the cab.
On topic - they're the same color as my Subaru.
Cheers!
Paul
My first time to the site! Have been looking at some of the posts and liked what I saw. I felt this was the right place to make my inquiry. I'm actually on this crusade for my Mom...she has a 96 Legacy (2.2 of course) with 35,000m on it. It developed an oil leak coming down from behind the timing belt cover and was getting worse. I recommended she make the trip to the dealer thinking this has to be a problem they know about and that they would cover, I mean, come on,only 35,000 miles and the seals going??? Well $450 later...replaced front engine seal, oil pump seal/ORing, replaced the timing belt since they had it opened up (I was ok with that part). From what I am seeing of some older postings here, this seems like a known problem with seals/gaskets on several model years. Agree? Yet Subaru customer service says there is no recall on it. Has anyone been in this same boat? Has anyone had a dealer replace the seals for free (under some special extended warranty or the infamous "silent recall" perhaps)? I'm very surprised at the number of hits I found in numerous places..even the NHTSA had a TSB on an oil pump leak but specific to 95 model year.This seems like a known problem and I was very surprised that SOA doesn't seemed to have addressed it. I thought they were doing a good job in the past with stepping up to other recalls...but perhaps its the old story of only addressing problems that are safety concerns as some other manufacturers seem to do. Thanks for any input...appreciate it.
Think mine's leaking too. ('99 2.5L impreza, 41k miles)
But how is this a safety concern?
-Colin
-Dennis
Steve
-mike
If your seatbelt failed, or the airbag light went on, that's a different story.
-juice
-mike
-juice
-Colin
-mike
-juice
mikek
I'm posting my reply for the second time as I lost the server connection just as I hit the post button, so if this posts twice please disregard the additional post.
I had called Subaru and basically was told there is no recall on the issue. However they did open a case for me and are sending it to the dealer and are suppose to contact me within 24-36 hrs.
I will post/share the outcome with everyone for reference.
p.s. sorry there was confusion over me mentioning the safety thing..I was basically being sarcastic..it really fustrates me when there is no recall done on what sure seems like a problem they need to address. Manufacturers only seem to do recalls when its related to safety (aka possible lawsuits from it).
As far as some of the other responses, I still feel that a 6 yr old car with 35k on it should not have front engine seal leaks. The car is well maintained and kept (never overfilled with oil to build pressure to make a seal leak, never overheated, etc etc)
I have been working around cars for 26 yrs now and have rebuilt engines and sold some that went 100k+ without front seal problems! I've owned Toyota's and Mazda's up to 155k without main seal problems.
Lessoned learned, I should have just worked on this one myself but told Mom to take it to the dealer because I was so sure that they would have made good, especially since I saw so many posts/hits out there with people having the same problem at various years and mileage. Thanks again all.
Jim
Good to know the system worked for you, Jim.
-juice
Thanks in advance,
Theo in Colo.
1)std clutch plate, slightly upgraded from stock
2) $60 additional 6-puck copper
3) $40 un-sprung plate
The rest of the kit includes the Throwout bearing, pilot bearing, pressure plate, alignment tool and clutch for $299 + $18 shipping
What is your vote, knowing it will be used exclusively for Auto-x and/or Track events. He said the 6-puck would be a bit rough in stop and go traffic, but that won't be an issue for this car.
-mike
can't he get you the 6 puck ClutchNet with 3 copper pucks and 3 kevlar. that's what I've got... of course I haven't installed it yet. ;-)
-Colin
-mike
-Colin
-mike
-juice
Ken
-Colin
Craig
-juice
recently i checked that my coolant is on the low side. Does anyone know the mixture for the coolant to add? We have to stick to the same brand right? But no idea what does our Suby comes with. It's green.
It's the green stuff so regular Prestone, Peak, even the generic stuff will work.
-juice
She also got new front brake pads and rotors. The car has 55K and hasn't had any brake work done yet. I'm glad my dealer recommended changing the rotors, instead of schlocking them up like Meineke did to mine.
She is now ready for her daily autocrossing on Rt. 22. (For those not familiar, imagine NJ drivers where the posted speed limit is around 50, there are business on both sides of the highway as well as in the median).
-Dennis
I would consider using Valvoline Maxlife or Quaker State Higher Mileage Engine Oil. These oils have special seal conditioners and are good for using even in low mileage cars. Considering the weakness of the seal it might help to use the best version of oil to protect the seals. Has many characteristics of synthetic too at a cheaper price.
Hi Theo,
I may have already posted this for you but here are the instructions with diagrams. I searched but couldn't find photos of the installation. http://www.scoobymods.com is usually a good resource.
http://www.subaru-parts.com/_instructions/LegacyAirFilter.pdf
Try a search on http://www.i-club.com , perhaps in the Legacy forum. Please post what you find here.
Also, if you have it, please post a link to luck11's original post. I might be able to track down the image based on info in the original post.
HTH.
..Mike
..Mike
http://www.learn2.com/07/0714/0714.asp
http://www.beststuff.com/articles/915/
http://www.autoshop-online.com/auto101/cooling1.html
Depending on the age of the coolant, you might wish to flush the cooling system; see your owner's manual for the schedule. Drain the coolant into a container and recycle it. Don't drain it on the ground, it's toxic to pets, children, and wildlife.
..Mike
..Mike
-juice
..Mike
Are there joints etc. on the suspension requiring lubrication? I haven't seen anything about chassis lubrication mentioned in my owners manual.
Lastly, if there are grease fittings, will my good old US grease gun fit them or are they a different size?
I spray some white lithium grease on the sway bar bushings each time I rotate the tires. That and the doors is about all I've greased on mine.
-juice
Guess that justifies another trip to NAPA.. or maybe Schucks, since Castrol's on sale for .79/qt.
Cheers!
Paul
Q: Can you use it in a LSD, Does the viscous coupling get new oil, if so what about that?
Q: And what about front diff/tran?
just doing my research through the we educated and sometimes biased (towards subies) info boards.
steve-V
The manual has it as
6.2 US qt
5.8 litre
5.2 Imp qt
Drain Plug? Love the manual's diagram. It's better I not say what I see.
-Dave
thinking about putting in synthetic...what are your thoughts re: advantages/disadvantages, and brand.
Of course I don't have any data on that except my own. I was just wondering it, given the problem and Subaru's lack of endorsement for synthetic. Then again they also don't warn you that it could cause specific problems, they just say they haven't tested it and as such recommend mineral oil.
-Colin
I seem to recall Patti mentioning that FHI hasn't endorsed synthetics because they found some of them leaked.
I first noticed the leak in my wife's OB when I tried Mobil1. At the time, I thought oil was seeping from around the oil pan seal (because of what I read about synthetics cleaning away conv. oil sludge). I switched to Castrol Syntec and the leaking stopped for a while, but returned again within a year or so. Found out recently that the leak was from the oil pump/crankshaft seal. My dealer didn't ask if I've used synthetics and they were familiar with the seal leak problem. I've also previously spoken to the shop foreman about synthetics and he didn't say anything negative about them and said they have several customers that supply their own.
I doubt that everyone that's had the same leak used synthetics though. Maybe everyone will post again if they did.
Serge - IMO, I would compare the thickness of synthetics at operating temp., and go with the thicker one (from the Manufacturers product data sheets on-line or by mail).
I wouldn't go with anything lighter that a 10W30 in FL either.
-Dennis
