other than that, it's straight forward. oh and how are the plug boots? I doubt you have enough miles to warrant replacing the plug wires if they're OK, but if the boots are chewed up/fatigued a bit from the oil I'd replace them.
~Colin
~c
Do the round rubber seals for the spark plug towers just press in place in the valve covers or is there some type of notch that they seat into?
Thanks again.
Len
~Colin
1) Turn key to ACC position (note seatbelt light and chime will starting going off)
2) Insert buckle, wait until seatbelt light goes out
3) Remove buckle, wait for light to come back on
4) Repeat steps 2-3 for a total of twenty repetions.
5) Remove key, start engine
There will still be an initial set of chimes but it should go quiet after that.
Ken
My wife had trouble starting her 95 Impreza LX Wagon (with 125K on it) yesterday morning. She called AAA and the mechanic came out and was able to get it started without jumping the battery.
She took it into a repair shop near where she works and left it. They checked both the alternator and the starter and found no problems. They reported it appeared to be the battery and replaced it.
After she picked it up and was driving home late last night, the "Check Engine" light came on. I'm assuming that changing batteries disrupted something electrical and that this is a sign of something simple. (hopefully)
She called them today and they were avoidant, insisting that changing the battery was not apt to cause that, yadda, yadda, yadda.
I'm hoping some posters here might have some ideas as to what may be causing the light to come on what to do next.
Thanks in advance for your response.
David
You definitely don't want the engine running. Turning the key to ON (not ACC) is one of the steps.
Craig
Did anything change in the driveability or performance of the car? Did it start ok on Saturday morning?
Step number one is to read and interpret the code. Some of the parts places, like AutoZone, will read it out for free or a nominal charge. If it looks like something trivial, record the data but let them clear it. If it doesn't return, and the car drives fine, then you are probably done. If it returns, then you have to determine if this is related to the fact that it would not start yesterday morning, or if something in the testing at the shop triggered a new problem.
Steve
I'd get a fresh start, reset the ECU.
Disconnect the negative battery terminal, wait 20 minute, reconnect. Start and let it idle til warm.
This time have the keyless entry fob ready, and cycle the lock/unlock a few times to quiet the alarm and/or the flashing lights.
-juice
The car has started fine since she had the battery replaced. I suspect the change in battery has some part of the electrical system "confused" (for lack of a better word). I don't believe this is anything major, just something that needs attention.
The Impreza is an older model without electric locks.
Thanks again for your ideas. David
1) How to cut: Repeat fastening and unfastening the driver’s seat belt for 20 times within 30 seconds after turning the ignition switch ON. Enabling and disabling cutting is done with the same operation.
(The setting is changed for both the driver’s seat and passenger’s seat.)
2) Setting lasts: Until the microprocessor is reset
The cutoff function is reset when the battery is removed (battery positive terminal disconnected) or when the body integrated unit is removed. The cutting function may also be reset when the engine
is cranked with low battery voltage.
Ken
I just got off spending two hours on the turnpike.
Around the 65 mph speed limit and a bit above I began to hear an irregular ticking (at first I thought it was my keys cluster hitting against the steering column - but the sound came from "deeper" in the instrument panel or engine compartment), interrupted by an intermittent metalic whirring sound. No sounds at lower speeds when I pulled through rest plazas.
Anyone have any clues?
What is bothering me, on the other hand, is a lower frequency noise I am hearing from the vicinity of the number one piston (driver's side, closest to front) It's a much lower frequency than the valve noise I'm used to @ 650 rpm or so, and a lot deeper.
If I put my foot long screwdriver on the block (I really have to buy a stethoscope one of these days) and listen I can hear the noise emanating from there. If I rev the engine the noise gets a lot louder. I was trying to think of some number of rotations that would divide down and come out about right. It seems to occur 3 or 4 times per second at approx 650 rpm.
From what I've heard (no pun intended) on the forums its not loud enough for piston slap - it also doesn't get louder if I rev the engine a bit and then let off quickly.
Any ideas from the mechanically inclined? I need to schedule the dealer to do some of the 30k maintenance in March and will bring it to their attention then.
TIA
Larry
Jun
Something is changing on the ride in to the dealership on the flatbed. A stuck relay is breaking free, a tarnished or loose electrical connector is making contact, a cracked circuit board is re-establishing contact, an IC has a cold solder joint, etc. So it is obvious that this approach is not going to yield any useful data. The problem must be diagnosed out there in the field, under the exact conditions in which they are occuring.
My approach would be as follows:
Call SoA back again, and request to speak to a supervisor. I suspect that they will balk at this suggestion, but after 3 event in a month on a brand new car, someone must have the authority to make this happen. Ask them to notate in your record that the car must not be moved. An experienced electrical tech from your dealership must come out with the tow operator and verify that the car will not crank. I would think that some basic verification tests can be run with portable equipment that can help them determine what to replace, or at least where to look. Is there power (sufficient voltage and amperage) reaching the starter solenoid? Probably not. Why? What gates this? etc....
Insist that this is in their best interest - otherwise the lemon law will become your only reasonable remedy.
Steve
I have a 2000 Impreza R.S. standard, 57k miles and check engine light has been coming off and on intermittingly throughout the latest cold weather. I've run fuel system cleaner and have been using only 93 octane fuel and it will go off for a day or two, then come on- there is a noticeable lag when I step on gas and car smells like...an 79 Bronco or something- not like rotten eggs. My suspicion is catalytic converter is clogged and exhaust is flowing back into manifold...I know this is probably tough to diagnose in a disucssion board, but thought I'd try anyway...many thanks!!
Mike F
Besides that, could be plugs, plug wires, clogged fuel filter, or a clogged exhaust, sure.
-juice
My car was running quite poorly this summer for a few days (again, the CEL indicator was lit intermittently, though more on than off). The car ran fine after warm-up, but hideously upon start up and plenty of immisions! My problem was due to mechanics, but sensors: "Knock" sensor failed, timing and temperature sensors working intermittently. Upon replacement of the sensors, the car ran perfectly even without changing plugs (which were certainly fouled by the poor operation).
In this case, it may be worth your while to have the codes drawn.
On our last long trip, I found that if I shifted into 4th gear at moderate highway speeds (sending RPMs above 3500 or so), the temp gauge would almost immediately drop down to the normal range and stay there until I shifted into fifth and the RPMs dropped again. I could repeat this pattern every time I tried. Any ideas? Faulty gauge? Heat pump?
Depending on your mileage, it might be time for a new timing belt as well (and a good time to replace it since you must go through the belt to reach the pump).
But it's out of spec, and might just mask a more serious problem.
-juice
How many miles on the car?
Craig
FYI - The water pump is driven by the timing belt.
DaveM
I am getting some wind noise on that side. Right now, I am fixing the wind noise by moving the window down just a tad.
You might start by downloading the speaker .pdf file as it shows the basics of door panel removal:
http://content.subarunet.com/snet/business/fixedops/guides/Legacy- %20Speaker%20Upgrade.pdf
Next, this is one of Craig's personal links for gusset replacement:
http://members.cox.net/craig.hunter/gusset/
And Craig's rear window adj (but the concepts are the same...)
http://members.cox.net/craig.hunter/window/
Good luck,
Steve
Craig
Wow, I had no idea! First time I have heard of that.
Craig
Steve
I keep a log of the good stuff that shows up in these forums - things I figure I might need myself at a later date. I even downloaded all of your photos and put them in a Powerpoint file for easy viewing over a year ago. Talk about infringement!!!
Funny thing was that I had recorded the link to "gussets", but not "window". I knew it was probably still out there, but just couldn't get to it. I must have typed in 30 words in that space, each time getting 'page not found', or 'access denied' before I hit upon the right word and the page of 6 thumbnails popped up. I felt like a hacker trying to crack your code!
Steve
I'm glad the info is useful to you. I wish I had the initiative to document even more projects. I just added an iPod stereo system to my ski helmet and that was a real good project...
Craig
If you hook the battery up the right way and the car starts and runs fine, then you are probably OK. Hard to say. Some of the electrical components would work OK backwards, many were probably switched off so it won't matter, and the ones that would fail will become obvious!
I have to think that the complex electronics, like the ECU, only allow juice to flow one way, so they would either be unaffected or fry immediately.
If the car starts and runs OK, then I would quietly drive off and thank my lucky stars....
Craig
Side-bar:
And by the way, that Redline Water Wetter stuff... I have it and am not impressed. What it does is make water bubbles in your system smaller and less likely to accumulate in one spot. Air bubbles in your cooling system are bad because the indicate a pressure leak from someplace and can also cause more problems by creating "hot spots" in the engine which can cause warping to your cylinder head and head gasket... So Water Wetter helps to reduce more engine damage when you've already got a bad air bubble situation. When my old car was running hot for a little while (needed a new radiator) I added Water Wetter to no avail. I think they use it more in race cars that don't use anti-freeze but water only in the cooling systems. Before anyone goes and gives me sh** about water only cooling systems I will just say that water cools an engine better than anything. However for extreme temps (winter in Nebraska and summer in the keys) Glycol-Ethelyn (coolant/antifreeze) raises the boiling temperature and lowers the freezing temperature of water and helps prevent rust and corrosion. It does not help cool your engine any better. So race cars often use water only because they change it so often and want more cooling power - they use the water wetter to reduce chances of boiling over and hot spots.
*WHEW*
My brother had a Chevette a while back and it didn't have that safety feature, he started it in 1st and slammed into a wall. I had been in front of the car about 5 seconds earlier, had I stayed I might be in a wheelchair today.
-juice
Steve
Thanks for the links! I hope to have some time this weekend to try out some adjustments.
I'm not sure if I will be able to adjust away the wind noise though. With the window all the way up, the noise comes from the top of the window. But with the window rolled down just a hair, the noise moves to halfway down the front pillar side of the window.
I think that I might just end up replacing one wind noise with another after adjustments.
vetmats
Steve
Any advice would be very helpful, I don't want to screw up the airbag/horn or have it go off inadvertently in my face. I will also replace the thermostat as well, is there a smart way to do this without losing my coolant everywhere?
Does anyone have any answer to this problem that does not involve replacing the transmission, the car is now out of warranty
