Glenn
At any rate, I thank all that replied and I hope this will help anyone searching for a similar cure in the future.
Glenn
I have had this happen all summer. Remote start only works a few times. One remote key is fine, other does not unlock. Add to that heat comes out of the vent if I do not fittle with the air conditioner setting.
They think, as usual, I am crazy. How can a car have this many problems?
The fuel tank was replace and the gas cap error message and incorrect fuel gauge reading stopped but now the check gas cap message has returned along with "Check Engine" light which never appeared in the past.
Anyone experienced the same conditions and gotten corrected? Mileage is 55,000.
Even down to the rear seat sun roof. Damn it GM, why did you give up on this car? Why didn't you bother to market this car? A next gen Malibu Maxx would have gone up against the Venza with no trouble. Instead GM pulls it (the plug I mean). :sick:
As to the discontinuance I think it was pure numbers. While it was the answer to the problem for us, not enough people must have bought them as a percentage of total Malibu sales over the years to make it worth it for Chevy to carry on to the new model. I'm not particularly blind loyal to any make. I hope my wife's Maxx lasts a real long time, but when the time comes to replace it I'll give all the manufactures a shot
then. (and yes it will be hard to top the current 30mpg V6 economy size and performance)
my 04 is going strong at 132K.....and I still cant beat the 3.5L gas mileage in any other like size auto at this point.....
did a comparison of the toyota and the 04 maxx for specs......toyota/maxx
lenght 189/187
width 75/69.8
height 63.4/58.1
Wheelbase 109.3/112/3
weight 3500/3477
very much a comparable vehicle....now a true hatchback IMO..but still worthy at looking at....depending on MPG in the V6.....reminds me of the Dodge Caliber or a Matrix on steroids........
I took some electrical conduit and cut the plastic off and tried to feed the copper wire down what looks like drain holes in the front corner of the sunroof hole. I can't get the copper wire more than a few inches in before it bends.
Maybe I need a stronger wire like a bike cable? How far should it feed down? Can I see the other side oif the drain hose somewhere? My local dealer subs this wrok out.
Please help.
Joan Crawford was wrong!!! ;-)
I found they drain down between the doors. The left front drains fine. The right front does not drain when I pour water in.
Good luck
One big ommision was AWD, which the Maxx really needed up here in Oregon. Sadly, the Equinoxes I checked out here were no match for the Subaru Forester even without the latter's AWD.
As for the Malibu sedan; nicer interior and more refined suspension and engine, but a ridiculously tiny trunk lid and bigger size compared to the Maxx
Anyway to DIY folks, I noticed the inner lower slider bolt siezed partially. I worked-it loose and relubed it with white grease. Both sides were the same note free to move. Heck if it were'nt for the inner pad wearing to the metal...the rest of the pads (I cleaned and checked operation of all) would have went 160K ...God willing. D~
I've got an annoying rattle to track down, but that's it for complaints. Very comfortable car, and quite roomy.
To fix it, look at the shifter and pull straight down on the lowest part of plastic (the pyramid shaped piece just below the handle piece). That will pop downward to expose an allen / hexkey screw facing the rear of the car..
Use an allen wrench on that screw until it feels snug (don't make it ridiculously tight as you could crush the shifter tube (it's hollow to hold the wiring for the electronic manual shifter).
When done, push the pyramid plastic back up and it will snap back into place.
Is there any preventative maintenance that I should undertake at 50k miles? I have an '05 Maxx that went out of warranty in April. I have an awful dealership repair shop, so I want to keep it out of there as much as possible.
Thanks for your advice!
trans flush 2x at 50,000
lof every 5,000
complete brake pads change out...front and rear
rear at 50000 and again at 115000
fronts changed out at 95000
set of tires at 60000
will flush the coolant and have the radiator flushed at 150000
other than that I can say the car has been fantastic
hope to see 200000 or more trouble free driving...
will probably be looking at replacing this car in next three to four years
So GM had the same concept with the Maxx, except that the fuel economy was 3-4 mpg higher, and did absolutely nothing to sell the car. Nice going.
