In the interim I suggested that she run a can of BG44 through the fuel system, since I've heard that, depending on the spcific problem, this product can at times cure the symptons this car exhibits.
When it drops to low idle it can't/doesn't maintain rpm's. It starts at about 1000rpm and drops to 800, then surges back to 1000. It repeats this cycle faster and faster to the point I have to rev the engine to smooth it back out, then it starts all over again. The warmer the engine is, the worse the problem. The engine seems to run fine when I am driving, except if I try to accelerate hard (up to 3000rpm) like on an onramp, then it hesitates a little.
I have changed the plugs and wires, with no improvement and have been running fuel injector cleaner through it for a week now.
I have talked to several people and the suggestions seem to center around the fuel injectors and/or fuel filter, the coil, or an oxygen sensor.
My questions:
If I ohm the coil what should I get?
Since it is older than an '99 I should be able to short out the diagnostic tool interface to get a code, but where do I find out what the codes mean?
Has anybody pulled their fuel injectors? How big a job is it?
I think the fuel filter and 02 sensor are long shots. The injectors are a possibility, but vacuum leaks are the easiest to work on and a likely suspect. You should do a diagnostic though. It won't give you a direct "answer" but might point you in a good direction.
But lately, I started noticing a problem of hesitation. I took it to a mechanic who diagnosed a broken distributor cap and replaced it. But the hesitation still remained. So i put a fuel injector cleaner in a 1/3 filled tank instead of a full tank as advised on the bottle.
After that a new problem developed. Whenever i start the car, the RPM shoots to more than 3000 but comes down after 15-20 seconds and again crosses 3000 the moment i press clutch to put it in gear.It comes to idle/normal rpm of ard. 800 speed after 2-3 minutes of driving.Till then it keeps shooting up the moment the clutch is pressed.
To further compound the problem, it developed another snag and that is it doesnt start again when its hot (i.e driven for some time and parked and again restarted). It wont starte on first 2-3 tries but starts after about 15 minutes.And i smell gas too after it starts. It starts in one go in the mornings. But i found a way out of it not hot starting recently. While turning the ignition on, i slighlty press Accelerator and it immediately starts.
And thiers no light of any type flashing on the dashboard.So dont know whats going on.
I originally thought sensor, but it would not be common to have a sensor fouled up without a $$$ light. where this could happen is a lazy 02 sensor or a temperature sender.
there are also possibilities in vacuum leaks and the EGR valve, whatever they call it now it's the same damn part doing the same damn job. check the vacuum lines for integrity and the EGR for carbon fouling. it could be just dirty enough, or you could have a vacuum line just leaky enough at a connection, so the engine can overcome the issue when warm, but not when cold.
if you're over 40,000 miles on the same plugs, take some advice, check the gaps and condition on them as well.
yesterday my saturn stalled at a light for no apparent reason. No lights, sputtering, smoke, high temperature reading or evident electrical problems. It started and ran fine 20 min later. So far i've heard theories ranging from poor gas, to the cat.converter, to a fuel injector. Any ideas would be useful since the car is supposed to go to Canada on friday.
PS..the car has 163,000 miles and is a '97 SL1.
and then, there's the possibility of the start/run switch, which is probably remoted from the key behind the dash or on the lower steering column someplace, varies with the car type and who made the steering column. that could be rotten. a good number of them are really stinky to get to. you might, MIGHT, be able to diagnose that if you can either tap it lightly and have the lights come on, or you can touch the key and have them go out. but that's iffy due to all the linkage between it and the key.
it is also not impossible you have an intermittent plate strap connection within the battery. lift the thing several inches ONLY and drop it back onto the mounting plate --
>> danger, warning, horrid issues! car batteries contain dangerous sulfuric acid. possible acid leak or spray could occur. possible short-circuiting which could cause dangerous overheating and venting with pressure or explosion possible. possible fracture of plates could render the battery unable to crank the engine. possible label of "dang fool" or worse may follow you to the public house the rest of your days. if you're going to try this extreme maneuver, be sure you are wearing liquid-proof goggles and protective clothing, and have a charged garden hose immediately at hand. <<
-- and if the characteristics of the fault change (such as nothing works now, nothing fails now, the battery melts and rots your work boots) then replace the battery. you could also try substituting a similar sized battery from another car and see if the issues go with the saturn's original battery.
He removed the carbon from the exhaust valve as you suggested.Then he disconnected the cruise ccontrol switch. The result was that idle RPM increased so he adjusted that manually. Their was no surge in RPM for a few days.Now the starting surge has returned and it keeps shooting beyond 3K till the time car is driven for 3-4 minutes.
Unfortunately, my friend was with me for a day and their was as much he could do.
Now dont know whom to turn to...
My car started to have this problem after the 40k service and now, it has less than 42k on the odo. The service dept of the local dealer hired a whole bunch of idiots. They have no idea what's cause and told me they can not duplicate the problem. I read it from somewhere that this was a problem for earlier cars and they had the solution. Anyone here could tell me what instruction I should give the dealer to fix my car. Much appreciated.
http://www.driveaccord.net/PDF/egr_port_clogging.pdf
thank you
amy
Help
Aaron
PLEASE help. Thanks in advance!
there is one suggestion, and one i need to do for myself, is replace a better thermostate that opens at a lower temperature. it is only a few dollars of 10 or less, and in my car, it is simple to get to. i had no choice than to put the same type of thermostate that was in my 91 ford tempo, time before last as i was told that is all they had......sure, oh well. when i changed it the time before last, i was sold a low temperature thermostate (if that is what they are called) and found my engine and air conditioning to run much better.
i hope this may help in a way, and maybe get the repair book on your car and learn its components before relating a problem to the dealership.
i would greatly appreciate if someone can give me some insight to these problems and what i may not be aware of when repairing them that may not be mentioned in a repair manual?
I have a problem with my '94 altima gle, I dont know much about cars and need some help! I was driving today and out of nowhere my car starts shaking/vibrating and when I hit the gas the engine sounded like it was going to blow, The Rpms were also all over the place. The car eventually stalled but when I started it again everythign seemed fine. Any idea what it is and if it will happen again? Im thinking maybe the timing belt or distributor from other posts ive read but Im not sure. Any advice would be helpful, thanks
This only happens in the first 5 minutes or so that I'm driving, but it happens no matter how long I let the car warm up. I have a remote starter, so it usually gets to warm up for about 5-10 mins. I have noticed it's more likely to happen if I don't let the car warm up.
It will stall when I am stopped with the wheel turned as I about to make a turn (right or left); when I am turning while backing out of a parking space; or just when I am stopped at a light.
Sometimes it's fine - but I would say I stall out maybe five times a week (I have the normal there-and-back 5-day commute).
The car always starts right back up, and usually I can complete the turn or start going again although sometimes it takes a couple tries or it will act like it's going to stall but doesn't.
The car idles fine; the spark plugs, fuel filter and gas tank have all been recently replaced. When I had the gas tank replaced I believe they checked my fuel line as well.
Any ideas as to what could be causing this? The car's got an automatic transmission if that helps. I at least want to educate myself before I stumble into a mechanic with my poor little sick car....
thanks!!
I Have ruled out: Catalytic converter, fuel pressure, fuel pump, ECM, have done complete ignition systems check and I get NO codes! Can Someone Please Help!
The check engine light on my 1996 cavalier has recently come on. It stays on for a period of time and then goes off for a while and so on. At about the same time this began, my car has been shaking really badly at stop lights and at low speeds. I have no idea what this is. When it first started, I thought it was from bad gas that I had gotten or something but since then I have had about 10 new tanks of gas and have used fuel injector cleaner. I am looking for some ideas because I just got my car back from the garage today along with a 700+ bill for work done on the steering column.
Any help would be greatly appreciated.
Thanks!!
CaptG
The car has stopped while going down the interstate, sitting at an intersection, slowing down to make a turn and just going straight down the road.
I have replaced the spark plugs, the spark plug wires, the rotor, the distributor cap and the coil wire. The coil seems to be getting electricity when I crank the engine.
It was suggested to me that it could be the ignition control module that is intermittently acting up. It's been a problem with Fords in the past.
Does anyone have any helpful advice about this car and its problem? In particular, how do you get at the ignition control module to replace it? Does this sound plausible?
