Toyota 4Runner Accessories
Does anyone know if there are aftermaket installations for POWER SEATS?
Can I install auto dimming mirror aftermarket also?
I live in the NE.
Dealer trying to clear inventory, so cannot add or remove option.
Can you please repost the picture of the WAAG guard? I'd like to know if it was a grilled guard or center guard.
Lucas
hmmmm....you'd think when rigging out the 4R to tow 5,000lbs, they'd have thought of electonic brakes. maybe even factory installed one, or at least available as an option.
I own a trunk mount Saris rack right now that I used with my car which worked reasonable well, but when loaded with more than two bikes they would bump into each other and get scratched. Wondering if people have better luck keeping them apart with hitch mount racks.
I am 5'11" and reasonable fit so I don't think I would have too much trouble loading them on and off the roof rack, but I haven't ever tried so I don't know I guess. Also do the Yakima and Thule attachements they sell to adapt to the factory rack work pretty well? Also keep reading horror stories about how people forget the bikes are up there and crunching them. Definitely don't want to do that.
I guess I am not looking for the for the pros and cons of each because I found those in my research already, but just people's experiences with them and their utility. Thanks.
Did you replace the factory stereo? I checked the same model in the Crutchfield. and they say it is completely unfit. SO what did you do.
If you can please tell me it will be really helpful
PG
Unfortunately, it doesn't apply to those w/ JBL system.
I have a 2005 but picked up two fobs on ebay that are from a 2003. They are new and have not been programmed, however, I noticed that the FCC ID numbers are different.
Before I pay the dealer to try to program them, Im wondering if this is the determining factor, or if the car will recognize multiple fob signals.
Brian
Being that you have an SUV, I would go with a rear hitch mount system. The car is high enough, and then to have to throw your bike on top is a bit of a hassle. My friend does this with his Lexus SUV, and its a bit of a joke. Especially if you go riding with short people, you are the one who is always loading/unloading the bikes. Not to mention the stories I have heard about people forgetting about the bikes on top of the car and they "TRY" to go into a drivethrough or park in the garage.
I would suggest going with a rear hatch rack that folds down to allow access to the tailgate. It truly is the most convenient. This is what I have had for my past two 4runners and it is great. In fact, I picked up a new rack this summer at Costco for $140 (it was a Softride rack that held 4 bikes and lowered effortlessly). I doubt they still have them since its a summer item, but I would look around. I chose a fold-down rack over the swing type. Also, my bike rack "arms" come off so its not sticking out when not in use. As a side note - I prefer the HOLLYWOOD racks over the Thule/Yakima bc their arms fold down when not in use.
Hope this helps
Brian
I have a 2005 Limited with NAV but would love to upgrade the sysyem to play MP3's, local TV and DVD's. Where did you find this, and did you already have NAV installed on your car? And do the steering wheel controls still work? Seems like a decent upgrade.
Thx for the info
brodertr
THanks!
otherwise, you could have an FM transmitter installed, so that your ipod plugs into a wire, which is connected to your console and transmits a signal to your antenna, which is manifested through your stero speakers.
http://www.vaistech.com/sli.html
anyone know if you can use a lexus key cut to fit a 4runner? or a place to buy a remote transmitter and key combo type key.
or can you just slip in a toyota key in one those nifty vw keys?
Also, what are the advantages of larger wheels - 17 inch -- for both onroad and offroad driving? I don't care about the appearance.
TLT
The more rubber you have, the cushier the ride, the less rubber, the more precise the handling will be.
Regarding X-REAS, I would suggest to just drive both vehicles and see which you like. By getting the Sport, you aren't just getting the REAS as an add-on, you are getting the extra options here and there, and as you mentioned larger rims, and larger brakes ( which can't fit with 16" rims ).
Another item we discovered was the standard Toyota hitch cover. It is very stylish and will keep the inside of the hitch from rusting. Fits snugly and is a rubber like material. Looks much nicer than the one the dealership had on.
If so, is it possible the screws used could rust from water penetration between the spoiler and vehicle?
I have a 2005 4R LTD with navi.
I plan to add an overhead DVD player and a local TV tuner. Is Alpine a good choice?
Also, is there a way to make the stock navigation screen also accept outside inputs to act as a regular display??
Thanks much!
I am preparing to purchase a hitch rack that carries 4 bicycles for my 4Runner. Due to cost, I am not going to purchase the rack that holds the bikes by the tires, but the one that supports the frame. I believe that I have a 2 inch hitch.
Yak and Thule seem to be the most popular brands.
1. Do I need a rack that swings out (sideways) or one that leans forward in order to be able to open the tailgate while loaded with bikes?
2. Which version of each brand is the most durable (i.e. more metal than plastic)?
3. Are there any other brands that you guys would recommend.
4. What is the weight rating of the 4Runner's hitch?
Thanks in advance.
I am removing the stereo from my 350Z which is double din Pioneer AVIC-D1 navigation unit, along w/ the XM radio module, and I want to put it into the ner car.
My question is this.. Can it be done? I checked on Crutchfield and it says it can't be done, but does anyone know if the car an accomodate an double din sized head unit? I don't want to buy a unit with a flip up screen because that would just look cheezy (IMO)
Any thoughts or experiences would be appreciated.
Thanks in advance,
Jeff
