1999 Silverado/Sierra--Dual Exhaust questions
I have the Borla on my 99 Silverado 5.3 and it not only passes all the test it does not void your mfg. warranty because of its approved rating.
That may be a better option in case you want to take a long trip and don't want to hear that droning exhaust for hours on end.
You can see it at http://www.flowtech.com
-powerisfun
they were bought out by Holley Performance. I'll give you the direct link:
http://www.flowtech.com/warlock.html
Take a look at http://www.gmpowertrain.com and look at the 6.0's torque curve and compare that to the 5.7L's (the best way to compare them is by printing them out and setting one on top of the other and holding it up to the light so you can see both curves). Anyway, the 6.0 has WAY MORE torque than the 5.7L even at the low end. It's just a bonus that it's torque extend further into the high end. I'm the owner of a 5.7L which is a great engine, but I have to admit when something is leagues better and the 6.0L is just that. It's a shame it's only available in a truck that weighs 800lbs more (not counting the forthcoming SS Thunder, that's too impractical for me). By the way, I'm 32 so I'm still young enough to appreciate the sound of a mean engine, but I have a fairly long drive to work each morning (~26 miles) and no muffler(s) would turn me into an old fogey real fast. I have a dual-in/dual-out straight thru design by JCWhitney and it sounds just right for me. Quiet on the highway, but step on the pedal and you'd swear that 350 turns into a big-block.
-powerisfun
Since I added a K&N filter, cold-air induction, headers and cat-back, it feels like I've added at least a 10% increase in torque (especially above
2000 rpm, but definitely below too). I also think I widened my torque curve a bit as well. I'm at 5650 ft. altitude, though, and where I work is at 7400 ft., so I'm not feeling all the power of the engine. I can't wait to take it down to a normal altitude to see the added punch it has. I'd like to eventually supercharge it, but we'll see...
-powerisfun
~Teaboy~
The muffler(s) basically act(s) as a big slowing point for the gas. The bigger the space (muffler(s)) that the gas flows into, the harder it is to keep the flow momentum going. Two turbo mufflers is a bigger space than one dual-in/dual-out muffler (unless they're really small turbos). The two turbos would be good if you plan on going over 4000 rpm often, but for everything else go with the flowmaster. Either choice will increase high-end torque, so you don't have to worry about that. If it were me, I'd just go with the Flowmaster.
For the record I have a dual-in/dual-out (albeit not Flowmaster) and the torque improvement is awesome all the way across the band. I have the 5.7L engine though.
Good luck whatever you decide.
-powerisfun
Next question I was wondering about was... How loud can I expect this to be?
I would like a deep sound... but not to be real loud. I have a friend with a Ram that is dualled out and it gets annoying after a while. I guess what I am looking for is a system that would look good(dual rear exit chrome tips0, not be too loud, and give me the best performance possible...
Any Suggestions... try something other than flowmaster?
~Teaboy~
After much thought and research I finally made a decision on an exhaust system.
I went with the above Flowmaster System.
Everything was included.
It was a simple installation.
Took aprox. 2hrs. Was in no hurry.
Interior resonance minimal. Nice mellow exterior sound with noticeable performance gain.
Very pleased with this system.
Jeff
You went with the two chamber flowmaster and it sounds good with very little interior resonance? Thats good to hear...what engine is that on?
The 3 chamber is quieter right...maybe thats the one for me..
~Teaboy~
Another thing to keep in mind. As your muffler (and your engine, if you have a new truck) breaks in, the sound will get noticeably louder.
Just my opinion,
Ryan
The first day when i got them put on, i drove it and it sounded alright, and i took it home for my dad to listen too, he said it sounded like i had a 4 banger.
the next day i started it up.....didnt sound that way, it sound extremely good!!!! especially in the 1400-2500 rpms....it has quite a bit of interior resonance, but thats what i like
I have the flowmaster 50series, but i am not sure if it is 2 or 3 chambers
The resonance inside the cab drove me nuts on long trips. The wife said it embarrassed her when I drove through the addition. She could hear me coming from around the bend.
I traded the beast off last week for a '00 GMC Sierra with a 5.3. Think I'll leave it stock. My mid-life crisis is over, thank God!
What's your experience ?
Ray T.
Just my opinion on my experience. Hope it helps.
-powerisfun
and i just had the 50 series flowmaster put on mine. Great sound, very impressed from my standpoint
but anyhow,i called up flowmaster to find out which muffler to actually get, and they told me this one that i have, but they said that on their exhaust kit, it is single in dual out, but it has 2.5" pipes out the back.
On my truck i have it dualed out the back, but the custom shop put 2 1/4" pipes out the back. Maybe that helped on what your talking about because i didnt fell any change in low end torque, but possibly a increase.
either way, i have what i wanted!!!!
Yeah, the 5.7L torque curve is definitely different than the 5.3/4.8. Much peakier, which is nice in some respects but not so nice in others. It's great when you're climbing a hill in lower gear at ~2800 rpm because that's the engine's sweet spot (torque peak) and you really feel the extra torque as you get pinned to the seat back. Kick it into lower gear, though, at an rpm of ~4000 and it feels like the engine suddenly becomes a six cylinder. I added headers and a dual-in/dual-out performance exhaust to help with the higher end torque and it did help quite a bit, but it's still wanting at high rpms for my taste. I may have to consider a centrifugal supercharger to help add some torque to the high-end (We've got a lot of steep hills here in New Mexico, so power is really appreciated).
-powerisfun
Jardines are hard to find, but make the best power. Gibson are a little cheaper and are second to quoted power increases. Borla is about the same as Gibson on the power, but are extremely expensive! All can be had in a just slghtly increased tone.
If it were me, I would go with the Gibson, simply because they are more readily found and have a lot of bang for the buck for someone who doesn't want all the interior resonance.
I thought the Gibson singles setups were pretty tame as far as interior res.
It's not that loud or bothersome, I just would rather not have a sound like that coming out of my "new" truck (it's over a year old, but I still call it new). Thanks.
-powerisfun
POWER: I would contact Flow Tech on this gasket question, a exhaust leak only gets worse as time goes by because it is slowly eroding the material where it is escaping the exhaust system (path of least resistance).
Just my thoughts.
Ray T.
How did you decide on which brand of headers to buy?
I chose the Flowtechs mainly because the price was only $159 + $7 shipping thru Summit Racing. That was the best deal I could find. At the time I just figured headers are headers, they all look the same and have the same tube diameters... I got what I paid for, apparently.
The fire-cone on the JBA's sounds like a good thing and I probably should have just went with them. Live and learn!
Thanks again.
-powerisfun
Ray T.
You must take the good with the bad I guess. Some don't like the louder rumbly exhaust tones anyway.
Anybody got anything on why my 96 Tahoe's cats burned out after I installed dual exhaust?
Cats burned out on your Tahoe? that seems odd I wonder if it was defective from the start, I never had any problems w/the catalytic on my 88 4.3 ext cab and had over 130000 miles on it when I sold it.
Ray T.
