2. last spring I had a problem with the top going up....I was told the right cylinder was bad and it was replaced....now..often the top goes up half way ..then stops...I put it down and try again and it slowly closes...someone said that it may be that the fluid has air bubbles.....anyone have experience with this??????
Chrysler Sebring Convertible Top and Sunroof Problems
ClaireS, Host
Automotive News & Views | Coupes & Convertibles
Thank you in advance!
I took it to the dealership & was told they don't sell replacement hinges. That I would have to buy the entire support shelf to the tune of $570.00. A friend of mine bought 3 brass hinges & a friend of his installed them with rivets. Works like a charm & much stronger.
If anyone has had this problem be sure to use the rivits as screws will pull out.
I had called 5 junk yards to see if they had any & was told that when they get any in the hinges are bought immediately.
Now I have 2 of the original hinges & I'm going to be calling the junk yards back to see if they would like to buy them.
David
oil pan bolts(?)....just tired of being ripped off
Spoke with Dealer, their remark was that their experience was that the problem was never related topping off fluid level. So I found that when the car was parked downhill there was never a problem.
The problem disappeared after installing a new battery!!!
You might consider replacing an old battery.
http://www.vintagesilversmith.com/Chrysler/97_sebring_dash.htm
Good luck!
Dave
ClaireS, Host
Kim
Changing subject refilling conv. Top oil resevore can be filled with needle & syring without removing motor. Just inject rubber fiil plug with atf u
ntil no more goes in. Fill plug will self seal
