You could theoretically do something like I did with my 02 if you wanted the best of both worlds. First, what exactly, is the "Sport Suspension" on the touring model??? Define it please someone??? I know it comes with the 17" rims. Besides that. Is it different calibrated struts only, or spring rates, both, larger sway bars??? front and rear, change in bushings. What are you gettin??? My guess, and the Toyota salesman that contributes to this site would know the best, is that they took the parts from the Camry SE, and placed them in the Avalon.
My guess is that you could put a premium shock in the XLS, and come up with something similar to the SE type ride. Just a thought. Most would not. But "sports suspension" must be better defined. There are many ways to change the quality of handling versus ride. It would be nice for someone with a knowlege base of parts to let the readers now what they are exactly getting.
In 02, I put Tokico Struts in with Energy Suspension PU bushing in the sway bars and the front control arms, parts that have the same number at the Camry suspension with very demonstrable results. Not impossible to do with good reliable people and a little patience.
Consumer Reports results usually show the 1st year models have more trouble no matter what brand, although Toyota seems to have the highest number of models in the excellent category for reliability, a decision crtiteria that appeals alot to us working class.
abfisch
abfisch
With XM, when you initially tune to a channel, the station name then station number appear on the display. You can then press the "TEXT" button on the control panel to cycle through channel number, channel name, song title, then artist name.
To my knowledge, you can not directly access any station directly, other than using the 18 presets on the control panel (SAT1, SAT2, SAT3 using the 6 preset buttons) to get close, then use the tuning knob to get to your desired channel.
The ratings reflect 2005 model year vehicles that have been tested, or previous model year versions of the same vehicle that have not been significantly altered. In addition to the Toyota Avalon, for example, you will not find a rating for the Toyota Tacoma, VW Jetta, etc, as those models are recent redesigns which have not been reviewed yet.
The new 2005 model year vehicles which have been tested, appear in the ratings: The Honda Odyssey, Ford Mustang and Five Hundred, Buick LaCrosse, Saturn Relay, Pontiac G6 all come to mind, to name a few.
The ratings are effectively for 05.
~alpha
The truth is that safety is a multifactorial equation, as is a car purchase, of which safety is one, however important, component. For myself, the handling edge of a Touring vs a Limited might be offset by the fact that I would probably drive the Touring more aggressively than I will my Limited, and therefore not not get into situations where every little extra bit of handling was vital. The other features of the Limited compared to the Touring, handling considered, prompted me to opt for the former. But in the identical situation, the Touring would have the edge in handling, of whatever size. Maybe we should all just buy Hummers, and run them over instead of trying to avoid them. :-)
Re first-year models, I had no problems with a first-year 1982 Celica Supra, or my first-year 1995 Maxima SE.
Was your XM radio installed by the dealer or by the factory?
I ordered XM radio on my Avalon, but the dealer claims that they can only install after-market XM radio with an external display unit. And if I want to have it integrated with JBL sound and nav system I have to wait several months before after-market receivers will be able to integrate with Avalon.
Can you give me the name of the Toyota dealer that did the installation for you?
Wiktor
While not a horrible problem, I do notice some hesitation in my V6 Camry. It's a little slow leaving from a stop, but I'm used to it.
For the first time (after 13,000 miles) in my Camry I put in two full tanks of Premium BP/Amoco fuel. My tank was pretty empty, so I wasn't mixing too much mid-grade with the premium grade.
It may be only my imagination or simply wishing, but I don't feel the hesitation that I have experienced since I bought the car new. Does this sound possible by just changing from mid-grade to premium? If this continues, I may decide the extra 7-10 cents per gallon is worth it. We'll see.
wiktor256,
My XM Radio was installed by my local dealer. My Avalon is the Limited model that has the upgraded JBL Synthesis Audio System that is designed to accept the XM radio without adding an external display unit. The XM Radio is seamlessly integrated into the existing JBL System so that I can use the existing controls on the head unit in the dash. If your dealer is telling you that you will need an external display unit, it may be that your Avalon is an XL, Touring, or XLS model that does not have the JBL Synthesis Audio System.
My local dealer that did the installation is Toyota of Des Moines in Des Moines, Iowa.
http://www.toyotageorgetown.com/pdfs/prod/prodresults.pdf
Thanks for the info. I have the Avalon Limited as well.
On another note, I did another test drive today. I finally got a chance to drive an XLS with VSC and the JBL Synthesis Stereo. I would like to point out that I didn't notice ANY hesitation what-so-ever!! You people are nuts. lol That gas peddle was a "go-baby-go" button and when I pushed it.. that baby went!!
I wasn't too impressed with the stereo though. I brought my own jazz fusion cd and it didn't really handle the low end bass very well. Anyone else experience that? The subwoofer did fine, I just felt that the bass wasn't diverted from the other speakers well enough.
The one that I drove today only had 27 miles on it. By the time the test drive was over, the MPG was reading 25. yippy
I'm very happy to report that on 03/01 I took my LTD on a 152 mile round trip that was 99% highway/freeway driving at an average of 62mph with a 28.6 mpg rating.
On 03/02 I took another trip with the same parameters and had a 28.9 mpg rating.
If I didn't do 82 mph down a 10 mile section of freeway it probably would have been better.
MikeS.
I've had mine for 3 weeks now and we've had about 9" of snow in that time. The car handled very well in slushy, partly scraped roads and on packed snow.
I lived in Calif. for 41 years and hadn't had to mess with snow until 7 winters ago. It's not my favorite thing to do. I fell much better with the VSC.
MikeS.
When you turn on the headlights they automatically level themselves to the ride of the car at that time. You can watch them adjust height in the first few seconds when they come on. I park in front of a white garage door and in the evening it is very visible to see them adjust.
MikeS.
If you check the dealers websites you'll see that they continue to show some of the Limiteds available. Koon's shows 3 currently and Fitzmall has one, Younger shows 3. So if you look around you'll find some available.
I bought mine on 02/10 and there were several in the region then.
MikeS.
I have used it on my LTD and have mixed feelings about it. I usually use the closest setting but I find that it leaves several car lengths between us. Other drivers feel fine changing into this available space and the car winds up going slower & slower on you. At night, or in light traffic I'm still using it. Otherwise I wind up putting it into "Normal" mode and control spacing myself.
MikeS.
MikeS.
Thanks, Mikes; I'll see if that works. Kay Jennings website has not been kept up to date and doesn't reflect what's really there (my only complaint about this dealer).
On the issue of the XM radio, it was listed as retailing at $449, as others have noted. But some folks have been charged an installation fee above that. I don't think that's right--the price I was quoted included installation and activation.
1. I have read several reviews, but have found little reference to the NAV system that is offered. Past reviewers of the Toyota NAV system have been less than kind. Is the NAV system good?
2. On Consumerguide.com, they rate the fuel system of the car as a 4 on a scale of 1-10. Yet, other cars that get less than the 22/31 get higher ratings. Is there something here that I am missing about the fuel system of the Avalon.
3. This is car is about foot longer than the car I am driving now. I have never driven a car of this size before. I have heard that it takes a bit to get use to, yet the salesmen tell me that with the Avalon you do not notice the size difference.
4. I compared this to a Acura TL, and can get one with a NAV system, and fully decked out for just over 34000. Yet, the Avalon, decked out minus the cruise control is just over 36000. My question is not about which is the better deal, but in the decision to buy the Avalon what did you find that represented the Avalon as a better value in class for your comparisons.
I did not order the NAV system, as I have a Garmin 2610 portable GPS. Does the XM radio "data" such as artist, song title, etc, show up on the information display screen on the dash? How much data is presented?
Before you do something that upgrading to a 20" wheel, please refer to the article last year in Consumer Reports about increasing wheel size.
In summary, unless you really know suspension componetry, drive on the track, or it is just a show car, upgrading past a PLUS ONE size, is very costly, and could be dangerous. Not only is the cost much more, but the ride becomes terrible and the chanCe of bending a rim increases multifold. If you must increase, the largest I would go to is 18", but ONLY if the driving conditions are correct. You will also go through tires quicker.
If you are looking for better handling, there are much better ways to get more precise and even handling out of any vehicle that has fully independent suspension and sway bars like the Avalon. Look at past posts.
abfisch
I can't comment on your questions 1 & 2, but offer the following on 3 & 4:
3) I previously owned a 2001 Avalon that was about 5 inches shorter. I did notice the larger size of the new Avalon when I first drove it, but adjusted to the feel very quickly. In fact, it makes the car feel more substantial to me, IMHO.
4) I also considered the Acura TL for the past year. There has been much discussion on an Acura TL forum about a drive line vibration that some owners have experienced. I myself noticed this on a TL that I test drove locally about 1 year ago. I thought that it may have been initial new model start up problems, as this was just after the new 2004 model TL was released. However, there are some owners that are still experiencing the problem today. The TL also has much less leg room in the rear seat. Other than that, I think the TL is a fine automobile. I decided to go with the new Avalon for the above 2 reasons, as well as Toyotas reputation for quality.
jeffcarp,
I also live in Clive.
If you press the "TEXT" button on the radio controls you can scroll through station #, station name, song title, and artist name when listening to XM Radio. When you select a new XM channel, the only thing that automatically displays is the station # and station name. To also get the song title and artist name, you have to press the "TEXT" button.
As mentioned in my previous (and first ever) posting, my wife and I test drove an XLS yesterday (again, no Limited's available in Canada).
We thought the car was quite attractive outside and inside, although some of the dash plastic was of a lesser quality than we would have liked (I have seen other reviews/comments discussing some of the interior trim not being up to expectations). Also, the dash design itsef didn't impress my wife very much, although I am not unhappy with it.
We liked the leather and woodgrain trim. The interior, as a whole, I would say, is of good quality and appears well put together, and is luxurious, although perhaps not as luxurious as we would have liked....
The car is quite powerful and was a pleasure to drive. Handling is about as expected for a large luxury sedan (i.e good but not great). The car was also impressively quiet. The spaciousness inside was also very nice. The trunk room was a bit dissapointing for such a large car, and is not helped by the lack of folding rear seats. (Perhaps this has to do with their being reclining, a nice feature). The car we drove (the only one at this large dealership so far) did not have the nav system, so I can't comment on it obviously.
We also took the opportunity to drive a Lexus ES330 (this dealership is a joint Toyota/Lexus dealership). The interior was of a higher order of quality - leather, real wood, etc..., decent power, although definitely a smaller car - which probably puts it off of our short list. Also more expensive by about 5k CDN. (The salesman said probably this model would be replaced/updated later this year).
Looks like we're down to a choice between a Maxima SL or the Avalon. Maxima drives/handles like a sports car, I had a great time on the test drives. However, it's smaller inside (although I think the trunk is larger and the rear seats do fold down), and the interior is nice, but kind of odd. I believe the Avalon has more luxury/features overall, which is nice - but the Nav is also available in the Maxima, which is good. Price wise, they are pretty close (the difference between a fully loaded Max SL and the Avalon XLS (with accessories) is about 4k, CDN).
We'll have to drive them both again, and hopefully see the Avalon in the exterior/interior colour combination we would be getting, as it will make a difference in our impression of the car. (The one we drove was black/grey interior; we would get blue or gold exterior with taupe interior). (Anyone know where we can see pics of the taupe interior??).
(We're not in a hurry with the purchase).
Thanks!!
mikeroch,
http://www.edmunds.com/new/2005/toyota/avalon/100510859/photogallery.html?pg_type=Sedan&im- gsrc=&tid=edmunds.n.researchlanding.photo..2.Toyota**
The old, my old, 02 Avalon XL, did come with steel wheels and wheel covers. I specifically wanted these to use during the winter months. I got a pair of alloys to supplement my steel wheels for the summer and other months.
I think all the Avalons that I saw come with alloys now. They no longer come with steel wheels. Too bad. However, I am not sure that the Toyota Camry does not and that is where I would search first, if they make a 16" steel rim and I would again, use a Toyota wheel cover rather than a generic. The Europeans, just throw on steel rims during the winter with winter tires and don't even bother with wheel covers but for $100 or less, I couldn't bring my self to ride around with bare steel black wheels.
Another source is to order from Tirerack, some winter tires and steel wheels already balanced and ready to mount for next year. Toyota alloys, are very expensive unless you can get them on ebay or similar but then you have the brake dust problem again.
Steel rims sometimes have a more vibration and balancing problems at higher speeds, over 60MPH as the "run out" are not with specs. so they are not without there own problems.
The best would be to search ebay for a set of 4 steel rims that are the same diameter and width or approximate, 16" or 17"(if they even make) from a Camry. I would be willing to bet they would fit perfect. Check with someone who knows even more about wheels and tires before purchasing. Believe it or not, I have NO brake dust on my steel wheels and wheel covers on the outside although I bet it is all on the inside of the rim. During the summer, every month I have to take it off, and then really hose them down with wheel cleaner when I change them out for the winter ones.
Hope this helps.
abfisch
Don't care if the ride is less smooth
It looks like an old Fa*ts car.
Need to dress it up a bit
Seem to recall in years past that it was indicated that the sunroof reduced the headroom by a specific amount (approximately 2 inches?). I haven't seen it discussed in this manner for the 2005. Is this still the case?
migeroch,
Maybe I am color blind, but I thought that was the Ivory interior. If you want, I can take some pictures of my interior (which is Ivory) and post a link here for you to see. Just let me know if want me to do that.
Im very interested in the nav system. My next car will have one! I haven't heard any comments on the toyota nav system myself. Ive heard from auto tech junkies that the current best system is the one offered by honda/acura. Ive heard its easy to hack. One can turn it into a dvd movie player and do all sorts of stuff, easy to use and accurate. I know must wont be interested in the hacking fun side of the nav system. But Im interested in the basic abilitys and features of the toyota system.
psy
Guess I can always test drive both and decide from there. But I was curious regarding specifically how the sunroof impacts the headroom measurement.
