regards,
kyfdx
I was at a friends house last week - he had a new toy. It was a laser light (infrared ?)thermometer. It was about the size of a fountain pen. You just aim the light beam at whatever and it tells you the temperature. I had him take the temp of my front and rear brake disks - the car had only been sitting about 15 minutes -
Front was 215 degrees - rear was 155. The front are vented - so they should cool faster than the rear - I would guess that since the front disk was hotter that it must be doing more of the work.
It is hard to complain about the stopping power of the Mazda3 brakes -
First, my seat squeaks all the time.. really annoying squeak.. nails on the chalkboard squeak...
Second, my city driving mileage is at, on a good day, 15 MPG. I got rid of my V8 Explorer to get better gas mileage. My Explorer got 12 MPG. I know the EPA estimates are not real, but this is way off.
Third, going over some city driving bumps, I get loud cracking and thudding noises coming from right front of car...
Anyone else had problems such as these? It goes to the dealer next week.
PS: My A/C seems to be working fine... we'll see how it goes when I move to South Florida next month.
As I was driving on a hot day several days ago, I was wondering if the problem was related to heat from the engine bay entering the cabin or somehow negating the AC.
I drove over a speed bump yesterday the same way I also do and was a little startled by the noise it generated -- my old car (96 Sunfire) certainly never sounded like that over a bump! But once noise over one bump isn't enough to have me too worried yet.
This one has an April build date. Odo reads about 3700 miles.
Also, the standard (interior) rearview mirror has a ball joint for adjusting the mirror at the point where the mirror bracket comes into the mirror itself. There also APPEARS to be a second ball joint on the other end of the mirror bracket, where the bracket fits into the window attachment mounting. On my 3 this second apparent ball joint at the window mounting is frozen in place and can't be moved. Is this normal? I wish it were a true ball joint so I could nudge the whole mirror assembly up a tad, but no luck so far.
Would appreciate any comments from those who know.
Using recirc and the highest fan speed had the interior in reasonable shape within a few minutes - probably not as fast as our '03 Corolla, but not unacceptable either. Went to fresh air and fan speed 3 for the rest of the trip home, and I would describe the AC performance as below average but still acceptable. Not up to Toyota / Denso standards, but not awful and not a showstopper if I were in the market for the car.
This car is an April build, and has about 3800 miles on it. My main reactions are positive - I think there is more road noise than I'd like, and the ride is still on the firm side for my taste [but a VAST improvement over the Protege], but it is quick [even with the smaller engine], fun to drive, has good braking action, and seems at least average in the interior finish dept [this one has some plastic-on-plastic noises from the area of the glove compartment that I could easily solve if it were my car].
Overall, I would say that Consumer Reports' test results and comments were right on - by a slight margin, probably the best in class right now...notwithstanding the weak-but-still-OK AC. How acceptable it would be in Phoenix or Houston is another matter, of course...
So far I have had the fuel pump replaced because the car never started right, the glove box alignment was off and wouldn't close properly, there is a rattle coming from the back of the car whenever I go over bumps and the fuel milage is horrible. At this moment it is in the shop because the engine light went on and when I called to find out what is wrong (since they never called me) I was told that they had to take the engine apart and that they need to keep the car longer since they don't have the parts to replace.
I realize Mazda isn't known for having the same reliability as an Acura, though the Protege was outstanding, but this is ridiculous. If I could I'd ask for my money back and buy the TSX I was considering instead or one of those Scion tC's with a supercharger.
I own a 2000 Protege ES that just rolled over to 80,000 miles last night, and I love the car. I bought it new back in May 2000, in its SECOND year since redesign. And yes, the '99s had problems the 2000s didn't have.
I plan to trade my trusty old (but still zoomin' like you-know-what) Protege for a 2005 Mazda3 next May, when I'll wager these first-year hiccups will be memories.
Meade
In my business experience when we introduced a new product we were far more concerned about how well it performed. If a new product does not do what customers expect word gets out and the product fails to sell - We use to say "birth is hard but it is much easier then resurrection"
I have read a service bulletin that noise from the door( as if air is coming in may be the insulation around the door).I havent' checked it yet (with the business card test).I think I have air coming in the right passenger door.
The tires still sound loud when driving.Ihave the Mazda 3Isedan 2.0
Evap leak purge valve failure
replace F0621XRX purge valve
They had to keep the car an extra 2 days because they did not have a special tool that is requires to do a "smoke test". I do not know what a smoke test is - but it stated it on the invoice. Maybe they are just blowing smoke up my _____!
Ironically, the MINI's disk brakes are also vented front and solid rear BUT there is far more brake dust in the front wheel than the rear. For MINI owners, third party manufacturer EBC makes the "Green Stuff" non-metallic, kevlar lined, brake pad that creates far less brake dust than the original brakes.
Does anyone know if Mazda has issued a TSB for replacing the type of brake pads? It's been several months since this question was first brought up.
With all those complaints about the A/C system, could it be a case of excessive cycling of the system? And if that's the case, wouldn't this be a rather easy ECU chip reprogram? Any HVAC engineers out there who can comment?
The color of your car (dark bodies absorb more heat); dark upholstery will absorb more heat; leather breathes, but not in the same way as cloth upholstery; whether you park under shade or under direct sunshine; whether you leave your sunroof partially open or fully open while the A/C is working (this one doesn't make sense); relative humidity (100 degrees F in Phoenix is probably more bearable than 100 degrees F in New Orleans if the latter has a higher rel. humidity); whether or not you pre-cool your car by opening windows and sunroof before turning the A/C on.
Someone already posted that the smaller evaporator of smaller cars and location relative to the engine is a major factor in cooling effectiveness. I'm inclined to believe this. But I'll bet that all the above parameters do have some influence on our perception of this car's A/C effectiveness.
I suspect that if many of us pay attention to the above precautions/tips, our perception of the effectiveness of the MZ3's A/C might change somewhat.
First, do you drive the 2.0 or 2.3L engine? Second do you drive at sustained speeds and at what speeds and thirdly, city/highway driving percentages. OK so you gave the last two parameters, but the most important is the engine size IMO.
So, folks, when we talk about mpg, please give us those three important parameters: (1) engine size and transmission type, (2) Avg speed and (3) city/highway mix.
_______________________-
"I got 60 miles per gallon: thirty going and thirty coming home :-)"
We're in the middle of a heatwave that started last Sunday when I left for Sac. AC performed quite well at ambient temp of 100+ even on "Fresh". Left car parked in the sun up in Sac. for an hour at 101 F. and went for a short trip to the store--AC blew cold but trip wasn't long enough to cool the car's interior--only 5 minute drive and car is bright red with black leather interior. I would not have expected any better under the circumstances.
My car is a 2.3 stick and overall mpg averaged 28 per US gallon--mostly freeway at 70 with about an hour of heavy traffic in-town driving included in that tankful. Vehicle still has less than 700 miles on it so not really broken in, and I tend to run it up to 35-40 in second when accelerating in traffic. As with the rotary engined Mazdas of the early 70s, it's fuel economy is not tops in it's size class, but is better than anything that will keep up with it.
To give a bit of context I've never gotten anywhere near the city mpg ratings on any of the 15 or so cars I've owned since the ratings started being published, and only get the hwy mpg if I fill immediately before and after gettin on the freeway. I'm sure this is mainly due to my driving habits and fairly short commute distance as I doubt if one could actually end up getting upwards of 15 defective cars.
It was very hot for the duration of this trip and the M.I.L. (Malfunction Indicator Lamp) did not come on. M.I.L, by the way, is the official EPA name for the check engine light on a car equipped with OBD II self-diagnostics.
OBDII is a self-diagnostic protocol required on all new drivetrains starting with the 94 model year and required on all new or old drivetrains starting with the 96 model years.
Among the things monitored by OBDII is injector duration, or how long the injectors are open to deliver fuel to the engine. Injector duration is regulated via input from the Air/Fuel ratio sensors (more sensitive than the old O2 sensors), Mass Airflow Sensor, coolant temp, air temp, and throttle position sensors as well as some others. If injector duration deviates from design norms by more than a certain percentage due to lean or rich condition the M.I.L. will come on. Thus if any malfunction occurs that will significantly increase injector duration (i.e. enough to affect fuel economy) the M.I.L. will come on.
The upshot is that if your M.I.L is not on, the chances of the car having a malfunction that is causing poor mpg are about nil.
In my experience as a dealership tech for a large Japanese make, the most common cause of M.I.L. on is by far a failure to tighten the gascap, followed by actual malfunctions in the Evaporative Emmission control system. Niether of these affects fuel economy.
The Evap system is designed to eliminate pollution caused by fuel fumes escaping the tank and charcoal canister. The epa requires that this system be very closely monitored by the OBDII system on the car and even the best mfgs are having difficulty avoiding false malfunction indications due to the complexity of the system itself and the sensors and software designed to monitor it. These monitoring systems are so sensitive that a check engine light can come on due to a 1mm deformation in the filler pipe where the cap gasket contacts it (code PO-442, slow evap leak).
Lets face it - the AC in the Mazda3 is weak - using a sun shade, getting your windows tinted, not cracking the moon roof, and all the other little performance tips would not be needed if the AC did what it should do. I am not saying they don't help the situation - but the very fact that we need to do these things proves that the Mazda3 has a problem.
I was not that happy with my MPG - it has dropped from 22 down to 18 MPG - my low was 17 - but that was only one tank.
I just got back from a 250 mile (one way) highway trip. I left early and was in no big hurry - I filled up before I left - set the cruise at 65 MPH and got 29.7 MPG on the first leg of the trip. I filled up again for the trip home - set the cruise on 75 MPH - sometimes drove closer to 80 - and got 20.9 MPG.
Since the Mazda3 is rated at 29 Highway - and I got 29.7 going a steady 65 - I don't think I can complain much - obviously driving faster burns more gas - and I did rev the engine more on the return trip. But did not expect a 30% drop in MPG.
I have the 2.3L sedan.
appreciate the opportunity to respond to you.
In regard to your inquiry, the Product Engineers in Japan have come up
with a resolution for the A/C concern. However, we are waiting for
parts to be available. We expect parts to be available in the next few
weeks. I'm so sorry for the delay.
This is good news -
If Mazda really does have a fix for this problem it would be great - but even if they do fix my car it would be hard for me to jump into another new Mazda product - I know - first hand how Mazda treats its customers - by far the worst new car experience I have ever had.
I guess I have to recontact my dealer and Mazda.
car manufactured date:3/04
Every manufacturer has great, good, average, poor & horrible dealers - if the service department at your dealership is bad then you can almost always go to another one. If the car company has no level of commitment to customer satisfaction then if you have a problem you are just plain out of luck. Mazda is by far the worst company (car or other) I have ever done business with. I am not sure if they just don't care - or they care more about short term profit - or they are just incompetent fools that don't know any better. At times I think it must be all of the above!
Mazda probloms and solutions
"09-024/03 2004 MAZDA3 - WATER DROPLETS / MOISTURE INSIDE FRONT AND REAR LIGHTS
APPLICABLE MODEL(S)/VINS
2004 MAZDA3
DESCRIPTION
After car wash or when driving in the rain, some customers may notice the outer edge of the headlights and/or rear combination lights become foggy due to water entry.
This symptom appears at the sealing location of the light unit. Water is not trapped inside the lights which does not affect its function. The water droplets will evaporate and will not damage the light unit.
DO NOT perform any parts replacement for this symptom as this is considered normal."
No problems with the A/C out here in W. Texas, by the way. Temps have been up to 106F or about 41C. The point brought up about the matter being subjective was very good. I tolerate heat and cold better than most people. Build date of my Mz3 was 01/04.
The way it juts out into the cabin and its hard edge makes for both a cramped and a sore leg, at least if you have long legs.
Other than this fact and the weak a/c, I like the car but I do think my 01 Pro had a better designed (ergonomic) cabin.
Around town and on short trips I never even noticed the center stack - then on a long trip - after a few hours it started to bug me.
