Why insult someone here, much less start your message with something that indicates a less than perfect command of the English language?
(I believe that you intended to write, "You're a dork." or "You are a dork." Unless, of course, you were alluding to his/her ownership of a dork -which seems odd, but possible, I suppose.)
However, none of that has anything to do with the subject of this discussion, even if it were true.
Let's play nicely.
This one looks like it might be a 2.5" lift.
I plan on adding a 3" Toytec lift, sometime soon. Good stuff.
Alcan leaf springs in the rear and 6061 aluminum spring spacers in front.
Thule has a roof rack as well as an adapter to use the Xsportster with the track system.
http://www.tacomaterritory.com/forum/showthread.php?p=253235#post253235
I had stock tires/wheels for a while and it really didn't look bad at all.
If you look over on the Toytec Lifts site that was posted earlier. That is my silver 05 at the top of the page.
Interesting.
the truck on the top with the Eagles plate is mine. It has the 3" basic toytec lift kit on it. I got the diff drop free from toytec because I was their test dummy since I was the first 05 double cab to buy a kit. The basic ki only cost's sround $165.00, but that does not include the diff drop.
jadamjr
I purchased the Pro Basic kit and I believe it was like $220.
BTW: The decal is not a badge, like the Tacoma badge, but rather a black sticker.
If there is some super sticky stuff left behind WD-40 might not be strong enough. In this case you can use Goo Gone. But DONT use Goof Off. They are not the same thing. Goof Off can damage your paint. Goo Gone is pretty gentle.
And don't rub real hard when you are removing the sticky. It can cause a haze or micro-scratches on todays' softer non-lead based paints.
Did you unplug the ECU and reset it? If so, your drop may be attributed to the "re-learning" of the computer... it may come back up.
What are y'all aiming for?
Cleaner look? Don't want to advertize?
Forgive my naive curiosity...
Wayne
Debadging a vehicle makes it look a lot cleaner, and custom. Plus it's a lot easier to wash and wax a vehicle that doesn't have lots of emblems to work around. Check my CarDomain to see if you like the debadged look.
http://www.cardomain.com/ride/832238
Anybody have any suggestions?
I am about the same height as you 5'11". I also have a manual tranny. The clutch travels so far that I need to have the seat up a little further than I would like but I need to be able to extend my leg to put the clutch to the floor. I have also found that my seat back is a little more upright than I'm used to. The seat does sit you a little low if you are leaned back too far. By no means am I completely upright but I'd say my seat is at a 110 degrees rather than maybe the 125 I had it at in my BMW. After a few days it becomes normal.
Has anyone experienced a humming & vibration in the windshield of their 2005 Toyota Tacomas? My Tacoma was manufactured in 08/05 and purchased in 09/05 in California. At speeds greater than 70mph I hear a humming & vibration in the windshield.
I have taken it to the dealer TWICE already -- first time they couldn't recreate the issue, second time they re-sealed the windshield.
The problem still exists. When I contacted the dealer a 3rd time, they said it's a known problem with 2005 Tacomas, and that they are fixing 2-4 Tacomas/week with the same problem!!! Toyota is instructing them to re-seal the windshield to solve the issue.
I now have to go back a 3rd time to the dealer for service -- I am going to insist on having a new windshield installed. If that doesn't work, I think I'll have to Lemon Law the truck.
Has anyone had or heard of the same problem? If one dealership is fixing 2-4 Tacomas/week at Toyota's instruction, this must be a larger problem. Makes me think it's a structural design flaw in the re-designed model.
Thoughts?
Axel
I think the sound got much better after a few weeks. At first was slightly disapppointed. But the metal just needed several hot/cold expansion/contraction cycles, to break in.
When first put on, while much louder, it seemed to resonate too much and while bassy, had a little low riceiness. Over time, any riceiness is gone, and she has a slight rumble cruising on the highway now (esp around 2K rpm). When you drop the hammer, the sound is great, not a small v-8, not a 350Z (performance v-6), something in between. Had friends with v-8 trucks and even new Camaro impressed with the v-6 sound.
IMHO I think the TRD is the perfect match to the truck. Sounds good, looks grood, but not overbearing in the cab. Only the $ 400+ price its downfall. But all cat backs are pricey...
AL.
The truck ended up costing me $2200 under MSRP, and about $600 less than the TMV. Not bad I guess, and and I might have gotten a little better deal by whining more, but I try and keep my dignity (such as it is..).
As expected, the ride is firm with the Off Road package but not at all harsh in my (& wifes) opinion.
I respectfully declined any of the special deals offered by the dealership - like the annual car-care detailing for $700 (or maybe $800) for 5 years.
