The shifter continues to be a problem, but it seems to be getting better. I have used geomatic's technique which is one I use on my old Fiat occasionally. I don't expect to have to use it on a new car. Hopefully the shifting will continue to improve. I replaced the oil with synthetic, but it did nothing noticeable.
Otherwise a great car and I am very happy with it. Especially now that it doesn't vibrate.
I have an 05 Elantra GT rarely (maybe 4 times) have gotten over 30 mpg. Most of the time its between 25-28 mpg. I have an auto, moonroof and ABS/traction. I have a tad over 16K miles.
I am not sure why the Spectra gets better gas mileage but the engine may be tuned differently. They use the same engine and transmission. Aerodynamics may also play a role as the Spectra is more aerodynamic than the Elantra.
As for every other car dealer saying not to buy KIA because they are 'throwaway cars' - I wouldn't expect them to say anything else! There is no way any other car dealer would be able to match the KIA's prices, options and everything else - besides, they want you to buy from THEM! Also, if they are truly disposeable cars as they allude to, the manufacturer would actually LOSE money by offering such a long warranty!
As for lasting a long time, only time will tell as it IS a new car. But I'm happy with mine.....
Two days later, the light came back on. I called the dealer. He said he can't look at it until a week from Wednesday and that it won't hurt to drive it with the check engine light on, unless the check engine light starts to flash.
I know the book says the check engine light will come on if your fuel cap isn't on tightly, but mine IS on tightly.
Anyone else had this problem? I'm irritated!
The Spectra has a smoother ride, less road noise (maybe due to tires) and is more quiet especially at idle (more damping and engine noise isolation). The Elantra GT on the other hand does have better cornering capability. I use to have an 01 Elantra GLS and the Spectra is similiar to that in corning. Both (GLS and Spectra) are tuned for more comfort and a smooth ride where the GT is more towards sportier. A better comparison would be the Spectra5 or Spectra SX. Both seem to have about the same room on the inside. I would probably give the Elantra a slight edge just from perception (it feels bigger and is slighter longer in length). Anyway, if I had to choose between the 2 I think I would choose the Spectra.
The Elantra has had some problems due to aftermarket oil filters not working as well as the OEMs. This has not been cited for the Spectra, but the engine is the same. For a small price bump, I've decided to stick with OEM filters, and have found through specials and such that I can get them for as little as $2 a piece through dealerships. There is an aluminum crush washer on both cars that is supposed to be changed at each oil change; make sure you get that as well, and MAKE sure the oil plug is torqued to the proper value, and that the oil filter gasket from the previous filter does not stick to the engine (resulting in a double gasket which has been known to fail).
Finally, make sure you stay with recommended oil grades AND transmission oil grades. Note that Hyundai/Kia automatic transmission fluid is a unique type and cannot be replaced by more commonly available types like Mercon.
All these issues are things I've heard people having problems with on their Elantras. They are good cars, but a little off the beaten path as far as maintenance and technicians at many oil change places are not familiar with these quirks. I've even heard of Hyundai dealerships using the wrong transmission fluid, then saying the transmission failure was not covered under warranty because the wrong fluid was used. So you have to be careful.
If a stereo was superior and all other things equal, the stereo would influence my decision. As it turned out I bought a Hyundai Elantra and the same weekend replaced the stock AM/FM cassette with a Pioneer CD/MP3 player and added a Pioneer six-disc changer in the cargo area. I still have the stock speakers but will upgrade them at some point, and maybe I'll add a small subwoofer down the road.
The stock stereos in the Suzukis (Reno and Aerio) were by far the best in class of the cars I test drove, and I thought it was worth mentioning.
There is a TSB on the Elantra which indicates that some engine rattling can be heard when using non-oem filters during lite throttle. I have heard this noise on my Elantra. I have heard only once on the Spectra. I have always attributed this to pinging. So back in October when I did an oil change on my Elantra I used a genuine Hyundai filter. It did not solve my rattle and there is no difference than the Purolator L14459 which I normally use. So I went back to the Purolator. I have used the Purolator exclusively on the Spectra and haven't heard the rattling sound except for the one time. Maybe I will use a better grade of gasoline to see if the rattling stops.
With respect to oil filters: Is the Purolator the same size as the OEM filter? Some of the aftermarket filters are visibly smaller than the OEM; I'm guessing those are the ones that cause problems. The "knocking" caused by the filter from what I've heard is not a pinging kind of noise, but more of a bearing knock inside the engine. I read on a Suzuki board somewhere that they had pinging issues on Aerios and had a certain fuel injector cleaner (I think) that was supposed to clear it up. Not sure if it would work on our cars.
Yes. The Purolator oil filter (model L14459) is near identical (length and diameter) to the Hyundai one. The Purolator also has the pressure/bypass valve at the bottom. When I first started using the Purolator and compared to the Hyundai I thought perhaps they sourced from the same manufacturer. Only big difference is the color. Purolator is white and Hyundais are black or blue. Fram has one, which I never used, which is quite a bit smaller than the OEM so I never used it on the Hyundai.
On my 03 Aerio SX I also had that rattling noise. Quite a few Aerio SX owners experienced this from reading other forums. I had heard that some attributed this to the engine heat shield. I checked my heat shield and it was on pretty darn tight. Anyway, I just learned to live with it as it would come and go. Similiar to the GT.
The most recent Elantra oil pan, I think, has logos for both Kia and Hyundai on it, as does the oil filter.
On my old Ford Aspire, the exhaust heat shields were always rattling and after a while I found I needed to just crawl under about once a year and tighten everything up.
One more question for you, since you have both cars... do you know if the rear suspension on the Spec5 is the same as on the Elantra? One thing several Elantra owners (including myself) have done is upgrade the 15 mm rear sway bar with the 19 mm rear sway bar from the 03 Tiburon which improves body roll in the corners quite a bit. If the Spec5 has the same rear sway bar as the Elantra, the same mod could help the Spec5. And I'm kind of curious as to whether this would work.
19mm rear sway bar, eh?
I am pretty sure the suspension pieces are identical to the Elantra and Spectra. I will confirm this weekend. The Elantra unit body chassis is used for the Spectra pretty much intact from my understanding so mounting points for the suspension are the same so I would think that the suspension pieces are the same. The front tower brace on the Spectra5 can be used on the Elantra. There are a few people in other forums that are using it.
I would really like to trade in my '98 malibu for another kia. Either the spectra or the Rio. We have a 2005 spectra 5 and we really like it. But, like I said in an earlier post, the gas mileage just isn't so great. I read one report on the Rio where the evaluator got over 30 mpg on it. But there is also the money. The spectra is bigger and the price is so freakin close. It seems like the spectra is just more car for basically the same money and possibly the same gas mileage. Am I right?
Not quite the same thing. You cannot adjust the front and back of the Spectra's drivers seat bottom cushion independently. You can do so with the Elantra and other cars like the Forenza that have independent controls for those two adjustments.
Note that this is not an "economy car" or "import car" issue; many models are having problems because the Occupant Classification System is a new requirement for U.S. cars and all the bugs aren't worked out yet.
Love the S5
Geo.
FWIW, here is my review of the 2004.5 Spectra, with comments on the seat height adjuster. Maybe the adjuster has been improved since that model year?
backy, "2005 Kia Spectra/Cerato" #198, 27 Mar 2004 2:09 pm
my 2 cents.
Geo.
BTW-would you be goofy enough to let a seat decide what kind of rig you buy...anyway?
I didn't mean you, though I certainly recall that you have an issue with new-world-order Kia Spectra seats.
No, really I think it's goofy if anybody lets something like a new car's seat affect whether or not they would buy the car or not. How about looking at it this way: if somebody likes a car's seat and they also like several more important features of that car, well then great. They can lump the seat in with all of the other things that they love about that car.
But, what if someone love's a new car's manual transmission, it's moonroof, it's stereo, it's leather-wrapped steering wheel, it's speed-sensitive power steering, etc. The one thing they don't like is the car's seat. They may even dig that new car's Warranty, it's initial price, etc. but it's that nasty seat they don't like. I don't know about you, but IMHO, I think that's just...goofy!
Remember the 2006 Hyundai Sonata thread a couple months ago...people were complaining about the new Sonata's seat, that they felt like they were leaning forward in the seat too much, that Hyundai mis-built the driver's seat. I haven't test drove the Sonata, so I don't know personally what they're talking about, but I think they were being goofy.
Imagine that, backy, me thinking someone else is goofy!
Oh, I almost forgot! Seattle 27, Pittsburgh 18. I'll tweak it throughout the week as needs be. That's how I think the Big Boy is gonna come out. Can't wait for the Seahawks to get their first title!
But the seat bottom wouldn't turn me away from the Spectra5. The $18.2k sticker price (without much in the way of rebates) would do that all by itself.
Geo.
By region, Europe continued its steady growth with 21,940 units sold in January for a 13.8% rise over the same period of last year. Meanwhile, sales of Kia vehicles in the general market and North America recorded 14,014 units (4.3% year-on-year increase) and 18,880 (2.2% year-on-year increase), respectively.
Popular RV models -- Sportage compact SUV (8,250 units) and Sorento full-size SUV (8,196 units) -- were Kia’s top selling vehicles in overseas markets in January. The A-segment Picanto -- Kia’s top selling model overseas in 2005 -- and the B-segment Rio were the third and fourth best-selling models in January, posting sales of 7,568 and 7,916 units, respectively.
Yong-Hwan Kim, Senior Executive Vice President and COO of Kia Motors Corporation, said, “All indications show that Kia is once again off to a fast start to begin the year.”
“And thanks to our continuing aggressive new model launch strategy, we aim to sell 1,226,900 vehicles globally in 2006, with 907,900 of this amount in overseas markets.”
New Kia models to be introduced in 2006 include the short body version of the new Carnival (Sedona) MPV, the completely redesigned new Carens compact MPV and an all-new C-segment car designed specifically for the European market that will be produced at Kia’s new factory in Slovakia. Also, the ever-popular Sorento SUV will receive a face-lift in 2006 along with the C-segment Cerato (Spectra) and Opirus (Amanti) luxury sedan.
Editor’s notes:
1) Figures do not include domestic sales and KD (knock down) exports assembled at overseas plants.
2) “General market” includes the regions of Central & South America, Asia & Pacific, and Middle East & Africa.
****so much for the hope of the body style being around long enough for the aftermarket accessories giants to make some really cool stuff for our little cars.**
Geo.
I too have noticed how stingy KIA's being with the rebates these days.
I suspect that it's a combination of KIA wanting to test the waters on how high they can price their vehicles BEFORE sales are adversely affected, coupled with the rising cost of energy and raw materials (steel, etc.). KIA obviously has to make a profit on their vehicles, else they'll be tempted to pack it in.
The big thing they're facing in this country is how long they can tread water (aka: subsidize their vehicle prices) to allow the stigma of the KIA name to wear off, and thus warrant the higher prices.
I'm a "believer", and have done more than my share of defending the brand against KIA bigots out on the various forums, but it's hard work! KIA really, REALLY has an image problem out there with the rank and file car drivers.
I think Hyundai/KIA are going to have start spending some money on motor sports and performance car development to start getting some positive attention beyond the intermittent positive Car and Driver article, etc.
Obviously they shouldn't attempt to compete in the Corvette/Viper territory, but why not create some kick butt little turboed 4-cyl autocross type vehicles???
-SM
