Mazda MPV Gas Mileage
This topic is for MPV owners to post and compare their actual MPG.
"Real World" Fuel Economy vs. EPA Estimates
so I took my first HIGHWAY ONLY trip on the 4th of july weekend. I put 178 miles on highway, from 8am to 11 am in a 75 F temperature, using AC 80% of time. I was cruising between 70-80mph.
Much to my surprise, I got terrible gas milage: 15.67 mpg... (i filled the vehicle up before entering higway, and after puting 178 miles filled it up again - i got 15.67 mpg...)
What is the probable cause?
I take very good notes on my fuel economy.In the last 6 month, which translates to 5610 miles driven, my average mpg is 20.89 mpg. This is combined city and highway driving in chicagoland area.
What is your opinion?
If you don't get that much, I suggest you check the tire pressure. Also having the fuel injectors cleaned and a tune up may be on order. This is my second MPV abd so-far my favorite
and that is not good.
I there any soultion to avoid this.
My recollection is that at 70mph the engine turns at about 2600. With a gentle push on the gas, the car will speed up slowly and generally maintain rpm. However, if the cruise control calls for an increase in speed or you press down on the gas, the transmission shifts down (incredibly smoothly--you only hear the revs), and the rpm jumps to maybe 3500. Our car has low miles--25,000--and has been dealer maintained. Strangely we had to replace the O2 sensor at the last service (perhaps the secret of the performance), and haven't made the trip since then.
My '01 DX with 97.5K miles still gets about 22~23 mpg on the highway - around 20 in town. I fell in behind an 18 wheeler going 75 and let him suck me along the last half on that particular trip.
The '01 at 70 MPH turns about 3000 RPM. The '02 and above with the transmission change is (I think) about 250 RPM less at that speed even with the slightly bigger engine.
My O2 sensor makes the infamous "moose" call for 1 minute if the temp gets below 50 degrees (in Texas??) after engine start. This has been going on for three years and I never replaced it. Apparenly, in my case, it didn't affect the gas milage. Plus, I don't recall if we really had a winter in the last three years...
By the way, I put Goodyear Assurance tires on all the way around about 15K miles ago - pumped up to 37PSI - really smooth - best tires yet.
-Brian
-Brian
One question though, the fuel tank had less than 1/4 left and when I filled it only took 14.1 Gallons, Specs say 19.8 gallon full. I am guessing the fuel warning light comes on with 2-3 gallons in reserve..
The light does come on early it seems. I think the trend with most manufacturers lately seems to be this way. Not to mention that the only real time the fuel gauge is accurate is when it's full, noone makes a truly "linear" gauge anymore. Too bad the MPV doesn't have a trip computer like the GM and ChryCo vans, you'd see fairly accurate gallons used and could go off of that.
-Brian
Round trip from Raleigh to D.C and back, 2 kids, 2 adults and a lot of stuff in trunk..Average speed after subtracting the stops : 81 MPH to D.C, 77 MPH return
To D.C: 22.63 mpg
Return: 23.21 MPG
3rd all city tank refill is 21.17 MPG, No A.C and all city driving.
I am happy with the numbers, only thing is that I expected the HWY numbers to be sig higher after getting 21 MPG in city..BUT the van was full, AND we were moving pretty quick..My guess is, if I had reduced the "indicated" speed to 75ish, istead of 82ish, the MPG would have been higher..
Entertainment note: Before the trip I bought a portable DVD player with a 9" screen ($89.95). I also bought a wireless FM transmitter for $20, which pipes the sound through the van's stereo system. The DVD player was just the right size to straddle the armrests of the front captain's chairs. (For a safer setup, one could easily attach the unit to the armrests with a strap.) The wireless transmitter caught some interference at time but generally worked well. It was well worth the money and an inexpensive alternative to a built-in system.
I'm getting bad mpg off my 2001 MPV, have ever since I got it. About 15 city/suburb and rarely more than 20 on highway.
What's up with our vans?
Any suggestions? I was thinking she may just need a tune-up, but it has been suggested to me that the fuel filter may be to blame.
Greg
The engine seems a bit gas thirsty for the size of the vehicle, etc. I had a Grand Caravan before and it got consistently around 19 MPG all the time on a 3.3L engine.
It all has to do with the gearing, etc and how your driving habits are. If you push the peddle on take offs from stops, the gauge will drop rapidly on the gas. If you ease up on the starts, it will improve. During the winter months, the mpg's drop off too.
The best mileage we ever got on one tank of gas was 26.6 miles after we'd had it for almost a year. The worst mileage was 14.4.
My 2003 Infiniti M45 (with a 4.5 liter V8) has averaged 18.8 MPG since I've owned it. I don't usually drive with as many passengers on my M45, so maybe the weight made the difference. :confuse:
16- 18mpg and we maintained the car and kept the tires inflated. Pretty frustrating !!
Susan Keltner
Since i bought it i was complaining, but Mazda Suck so will never buy another Mazda. new tranny after 18.5 k ($600 in rental car that was supposed to be covered)
car died on hwy with kids in the car doing 65, we all almost died, no brakes no steering.
It just died again this time 52k doing 50. no kids in the car thank god. but they cant find a problem, maybe a loose cable.
never again
this was a $25,000 mistake.
Rudy W
-Brian
-Brian
still not sure what i should get books say 40-45mpg
but im not getting that
plugs, filters, tire pressure etc check out okay?
the books say it should be doing 40-45 mpg
at present im not getting that it is doing about 25-28 mpg
it has recently had a new cylinder head gasket
new turbo and new timing belt
the engine only done 63000 miles
any ideas on how to get my mpg better than it is
malcolm
It did have an annoying problem that the Engine check light kept coming on at intervals saying that my oxygen sensor was not functioning properly, though I changed it twice.
Yet I loved the van so much that I turned around and bought another used 2001 MPV. This one however is an LX and had only 117,111 miles on it. I am very happy with my decision.
