How much more gas did you pump in from the time the pump shut off automatically? Hope you didn't damage anything by squeezing in an extra quart or so.
p.s. ive owned over 50 cars in my lifetime..and have ALWAYS topped them off...never had even 1 lil problem doing it?????
One gas attendant figured out that if the dispenser handle was held horizontal it filled faster and with less premature stoppage (I live in oregon where it is against the law for me to fill my own tank!). I wonder if the fill tube is at a bad angle or doesn't vent well in this car forcing slow fueling??
Any thoughts?
caaz
p.s. discount tires called Americas tires in Ca. online has an awesome tire calculator...you put in your current tire size and the tire size you want to change to...and it tell you your MPH difference at ANY SPEED...its awesome...told me 30 was 30.5 60 was 61.8 etc...all the way to my 80 mph which was off by 4 mph...which is why i chose this new tire size because i travel 80 mph alot from ca to az...try it..its pretty cool..later
van
van
Now for the better news!! I drove my 02 Santa Fe LX V6 to the dealership to trade (18.2 mpg). Drove away with my new Elantra and immediately started getting 28, 29, 30, than 31+ My wife and I have been driving it around town today and we're still getting 31 mpg. I'm almost speechless. The Elantra only has 140 miles on it thus far. Based on when I now know, once it's broken in, who knows how high the mpg will go
Thus far I've noticed that it's extremely quiet inside for a compact car, everything's solid and tight (no rattles), the ride is exceptional for a small car, and the 2.0 four cylinder is quite peppy. I'm a big guy ( 6'2" weighting in at 328 lbs.) and I can ACTUALLY fit comfortably in this car!!! The drivers seat goes up and down easily, the seat back is comfortable to adjust, and the steering column is both tilt and telescopic. Lower back support is lacking just a little but it's certainly tolerable. The standard sound system is great and the dash is very attractive at night when the light are on.
This car has all the makings of a fine automobile IF it remains steadfast and consistent. Overall, I'm nicely pleased with my new car purchase
Adjustments to your car like tire pressure, tuneups etc. will help some too, and these are well-documented in CarSpace and elsewhere, but the most important adjustment you can make for better fuel economy is in how you drive.
Thanks!!
p.s. Increase the tire pressure to 2 lbs over the max for the best mpg....as well as slow take offs etc.
Hope that helps
On the topic of MPG, I seem to be averaging about 33 mpg recently. I drive mostly two lane back roads, 50 miles each way to work, and I must say that I tend to put the peddle down to accelerate through winding corners, at the occasional stop sign, and while passing.
Needless to say, I've very pleased with my Elantra.
Also... what was your previous car and what kind of fuel economy did you get on similar trips?
I am averaging about 24 miles to the gallon with my 5 speed manual Elantra but my driving is almost exclusively city. I coast whenever I can, and I try not to rev the engine. Are other city drivers experiencing similar mileage?
I'm guessing his has to do with a recent reprogram of the odometer performed by my dealer as part of a factory recall, but might also be related to winter time fuel additives (ethanol)?
Anybody else noticing the same, or should I be heading for the dealer to get it checked out?
I'm due for an oil change in the next week or two, so I will probably have the dealer give it a quick check..
Seriously though I have been underwhelmed with my gas mileage. My 1993 Geo Prizm (rated at 27/31) gets better MPG's than this car which is rated at 28/36.
My last average MPG over 1000 miles has been 24.5. Average speed was 25mph. (I usually cruise at 35 to 45 in the city, but I have lots of lights and stop signs to deal with.) I don't pedal to the metal. I gradually accelerate and stop. I'd say TIME-wise I spend 17% on freeway and 83% on the street. City trips are usually less than 5 miles (bad for mpg I know). To be fair when I was getting 30mph driving the Geo, I did about 4x the fwy mileage. I have 3500 miles on the new car.
Still a nice car and a great value. Read about my other experiences on my blog.
Aye, there's the rub. When stopped, your mpg is 0. And then there's the fact you do mostly short trips. And it's winter now. Under those conditions, 24.5 mpg is not bad at all. One thing to try, if you aren't already, is coast as much as possible, e.g. as you approach those stop lights (assuming traffic permits it).
I'm keeping all gas receipts, and will update periodically with my overall, average, everyday mileage.
Update: I am going to start tracking my fill ups and posting data to fueleconomy.gov.
On my most recent fill up, it took 8.28 gallons to fill the tank back up. Trip meter and odometer read 237 miles. That would mean my avg MPG on that tank is 28.6 if the gas pump reading is accurate.
However my trip meter MPG was at 24.7. That is a significant difference.
Any of you have found manual calculations differ from your trip meter?
Mostly cloudy and cool conditions. Checked 3 tanks of gas and came up with 37mpg each time while doing 70 mph with the air off most of the time.
Started out with fresh Valvoline full synthetic oil and pumped all the tires up to 33 lbs.
The higher tire pressure made some bad road conditions a little louder but I was very pleased with the mpg while paying the painful $3.50 to $3.80 a gallon.
Anyways, their gas gave me 31.4 mpg. It was the worst gas out of 6 fillups. All other fillups got me 37 to 39mpg at well kept travel stations.
My low fuel alarm comes on after using 12 gallons and 444 miles went by at 37mpg with 2 gal left in the tank.
Remember following Katrina, there was a temporary lifting of the blending requirement. That was all about ethanol and designed to get more MPG where fuel deliveries were tight.
One more point on the 70 mph long trip my oil stayed on the full mark during the whole trip. Years ago I used to have to carry an extra qrt or 2 in the trunk for my chevys.
So that's a pleasant change to have a well built engine.
After three fillups, 34.9 gal total, I have 1122 miles on the meter. Average of 32.16 mpg over my first thousand (plus a few) miles. A/C will likely knock it down a smidge this summer, but engine loosening up might help a bit. I'll report back in a few more months.
Also, for what it's worth, my trip computer seems to be pretty close in terms of indicated mileage versus what I'm actually getting. I've heard that some are not.
Like any analysis, the larger your sample (number of miles & gallons) the more accurate your calculations will be. Funny that so many people distrust their trip computer based on a test of a couple hundred miles. Think of the difference in the calculation if the fill-up is off by only 1/4 gallon for 200 miles. The computer measures the amount of gas used, not the amount of gas in the tank before or after each fill-up.
