very helpful guy....I paid 140 usd , i asked him to send it to Canada...all included, custom and stuff
change all filter,distributer,coils,cup,plugs,wires,the problem is still there,why?
one try leave 10 minutes then start?????????????????
neck. Also keep the reservoir level between High & Low.
You might have to refill a couple times.
Have you or anyone found a solution to this problem?
I had the transmission flushed and fluids added and it drove fine for 2 weeks, then the problem came back again but the transmission fluid isn't low.
Any ideas? Is it a transmission problem?
This car is driving me crazy.
94shadow
Can it be done pretty easily in your driveway. How do you get to the bolts on the bottom side of the intake?
Thanks, Scott.
You say you only get the surging idle AFTER the engine warms up?
This is contradictory to the behavior of a leaking intake gasket. As the engine warms up, there is an expansion of metal, and so really the surging should be worse with a cold engine than a warm one.
I only mention this not to contradict your obvious correct diagnosis of an intake leak, but only to suggest that this leak may not be the cause of your surging idle, or not the entire cause.
You might *carefully* snug down the intake bolts --16 foot lbs ONLY
The "book" says a 4 hour job for a professional mechanic, so without knowing your skill level, figure ALL DAY.
Let us know how the "snugging up" does (use a torque wrench please) and if no good, let's talk further.
having trouble with 92 honda accord automatic trany. when put in drive, takes off very slowly. i have to shift to 2nd or 1st gear for car to take off more rapidly. in the meantime the "D" light on pannel flashes while i'm driving and when it's on park.i have read previous post and from what i gather the trany computer is trying to kick out a trouble code, or maybe the computer itself is malfunctioning. can someone tell me where i can find the numeric codes and thier translations. i tried a link that had been posted previously but it was no longer available. i have not attempted to get the codes by connecting a paper clip to the tranny computer yet, but will be sometime during the week. thanks for any tips, advice, information anyone might have.
http://techauto.awardspace.com/transmission.html#troubleshooting
Touched that spot with my finger and could feel it sucking in. Leaking there for sure.
What's the next step? Have worked on other cars, but ever a Honda.
Scott
In general though, aside from getting everything back correctly after disassembly, your biggest challenges, which are easily overcome, are:
1. cleanliness. The new gasket won't take if it is put on a dirty surface
2. Is the intake manifold warped? You should straight-edge it with a large metal ruler.
3. Be careful of the type and amount of sealant you use. Remember, any debris or extra goop is going right into your combustion chambers.
Will it be expensive to have my power window motor on driver side fixed? Window was going up and then it got stuck 3/4 way up. Is this a DIY type of work?
Jim
http://home.earthlink.net/~michaelpkeefe/HowTo_Codes.htm
i also got the d4 light to give me the code. how i did it was sort of by accident. disconnected the shift solenoid connector and jumped service connector. this is what gave me 8 quick flashes. although, according to code translation, an 8 code has something to do with crankshaft position, top dead center sensor problem (fuel injection), or ignition coil signal (carburetor). nothing to do with tranny or solenoid. oh well, maybe the source of where i'm getting the transmission code translation is not very accurate.
my next project is finding out where the brake fluid is going to. the brake pedal goes pretty low, i am having to refill with brake fluid every two days, and the fluid is not leaking. so it's going somewhere in the car. the brake light on the panel is also on. i will try to find how to retrieve the brake codes, if possible. thank you again and if you have any tips/advice/info on this new issue i'd greatly appreciated.
Here I go again.
I replaced my TCU, Shift solenoid valve assembly (lower) and the NM or NC sensor, the one close to the radiator on the right side.
Car ran fine for awhile, then went back to my initial problem.
Car starts off in D4 from a dead stop.
When I put the gear shift in 1st gear (it actually is in 2nd gear) it starts to go in then when I upshift to D3 it shifts into high gear (D4).
When I remove the shift solenoid and clean it then reset the computer by removing the radio fuse then reinstalling the fuse, the car runs normally for a while then it reverts back to its old self.
My D4 light does not come on at all and check engine light comes on after I travel for a short distance and stays on. When I turn the engine off, and check for a code with my jumper wire nothing flashes or blinks.
The check engine light stays on but the D4 light does not come on at all.
When I start traveling again, it starts in D4 and I have to manually shift the trans.
The D4 light doesn't come on, the check engine light comes on after awhile. The car runs fine while cruising, everything works. Easy starting, runs well after I get going, A/C works fine.
This car is driving me nuts. I'm ready to drive it into the Pacific Ocean.
Suggestions?
Thanks for listening or reading my troubles.
Any and all solutions would be much welcomed.
94shadow
The check engine light comes on at a peculiar time.
When I start the engine, The check engine light comes on then goes off in about 2 seconds. When I start to drive for awhile then the check engine light comes on and stays on. When I park the car and turn the engine off and install the wires to the check engine connector and start the car, the D4 light never comes on, the check engine light comes on then goes off normally without blinking but the car is still in its trouble mode. Slow take off in D4.
I will take the ATC computer off and check the inside for any burnt or melted parts.
I'll keep you posted.
Thanks elroy5,
94shadow
How do you drain the auto. trans. oil completely.
I only know how to drain the oil through the drain plug.
By the way, my car is not running.
A car was in my way so I hit him from the rear.
When I get my car back, I will change 3 things.
1. The A & B solenoid.
2. The shift selector switch.
3. The TCU.
I think all of this is contributing to my problems.
The TCU I bought was from the recommendation from another
member. I bought it from Mandigital who is listed on e-bay.
94shadow
I would certainly try to pin-point the source of the problem, before just throwing parts at it. That can get expensive quickly.
I have replaced the radiator, thermostat, and the passenger side fan, but the overheating problem persists. I'm not sure what to do next. Could it be the temp sensor? Or something else?
http://techauto.awardspace.com/overheating.html
Is the temp sensor the next thing you would check/replace?
Maybe you can trust him with your life, but I would not trust him with my car, and unlimited money to fix it. It seems he is just throwing parts at the problem, and not doing any diagnostic work. Guessing which part is the problem can become very expensive, when you keep guessing the wrong part. Maybe the radiator was bad, but it was obviously not causing the overheating. You may have paid for a radiator, and other parts, you didn't need. It's easy to guess parts, when it's someone else's money.
Not trying to turn you away from your present mechanic, but he may not be the man for this particular job.
If the heater was working, the thermostat was working; if the fans were working, then no need to fix them at this point. The radiator can be flow tested or at least inspected. the radiator was the best of his guesses actually but not the right one.
A yellow, black/yellow and white/black wires, what color goes where on the coil.
I know the white/black is to the negative and both yellow and yellow/black wire is hot.
What is the 2 wires yellow and yellow/black wires for.
I have installed a MSD 5520 or 5540 multiple discharge ignition, I forgot the number on the
ignition and a MSD blaster 2 coil.
The ignition box has a heavy black and red wire to the battery, a red, white, grey, orange, black and a 2 wire connector with a purple and I forgot the other color wire.
I have the heavy black and red wire connected to the battery terminals, but, where does the other colored wires go to.
I am most intrested with the yellow and yellow/black wire and what they represent. I looked in the manual but was confused with the wiring.
Any and all reply will be greatly appreciated.
94shadow
done anything to my transmission. I hope to get it back early this week.
94shadow
I'm having exact same problem as fhorta and 94Shadow with D4, ABS and engine light. My 93 Honda Accord EX - D4 lights goes on first thing when starting up then goes away later on causing me to crawl at very low speeds then picks up normally. I read from one of the helpful links that repairing or replacing theTCM or ECM should be considered first before any major tranny work. Everything else works fine on my car, AC, windows, heat.
Can someone direct me to a auto junkyard or store in Central florida where I can find a used TCM or ECM unit for low price?
I'm ready to throw in the towel on my Honda if all else fails.
Thanks - Cybercool
