Corkscrew.
It seems to mount to the radiator with just 2 bolts on top (easily accessible).
Has anyone done a replacement without removing the radiator?
Im trying to get an idea how difficult the job is going to be. Thanks
Background on the problem:
I have a 97 Accord with about 280K. Often the AC compressor will shutdown (most likely from overheating), mostly when I am driving low speeds or idling. On the freeway I NEVER have this problem. Engine coolant temperature and coolant levels are fine. I discovered that EVERYTIME I have this problem, the accessory (2nd) radiator fan isnt spinning. I believe its this fan that helps cool the AC evaporator. If I move the blades with a pencil, they do start spinning. Which means the fan is getting electrical power. The bearings are probably starting to go. No doubt I need to replace this electric fan.
Ironically I was on my way to a local Reno Autozone to read the OBDII code becuase my check engine light has been on for a week. California Autozones won't lend the equipment anymore (some lawsuit) and I wanted to avoid the $80 most places charge to read the codes. I would bet that those codes had something to with a malfunctioning transmission and I was ignoring the warning. Lesson learned: buy one of those engine code readers and keep it in your car. I called a local Reno Honda mechanic and two transmission places and all of them including the AAA tow truck driver said the transmission is toast and needs replacement (especially with 280K on my car). I couldnt risk an extra tow to a mechanic to have this verified for sure (I have only 4 free tows from AAA a year). One place quoted $2600 for a rebuilt transmission, another shop quoted me $1800 installed for a transmission from a low-mileage Accord. A new tranny in California is no doubt more expensive. So now I am having it towed back to my house in California. I will probably keep it in my driveway until I can sell it for parts. Its really a sad day. I love my Gen-5 Accord and I feel like dumping $2K+ on a transmission would be a waste of money. Even with a replacement transistion, there is atleast 2K of other work that it eventually needs, and its up for California Smog in 4 months (2 years ago it barely passed). To me its not just another Gen-5 accord. I have some mods, my interior looks brand new and the wear and tear give it its unique character. Perhaps some of you were once in the same position and can offer your thoughts.
I doubt the warning lights would have saved you. It was just the car's time--you beat the odds by 100K.
150k miles
standard transmission
Recently, my car has been stalling when I start it. The car starts, but then the car slowly dies. It hasn't stalled after I've driven and am sitting at a red light. I talked to a mechanic and he says he wants to do a diagnostic check and get data from the onboard computer but I feel like that's a waste of money since I'm pretty sure a checklist could diagnose my problem. I thought it might be a fuel pressure issue but he said that's extremely rare. The car only seems to stall when it's hot outside - tonight after it was quite cool the car started very well and the RPMs didn't dip at all.
On an unrelated note, the car makes a ticking noise when turning left. I think it's because of the CV joint. Will anything bad happen if I ignore it? I'm (obviously) trying to spend as little money as possible but I don't want my axle to break in half while turning or anything.
All of them at once? If so, I'd check the fuses first.
I would just keep on driving it with the CV joint ticking noise. When the wheel locks up you will know for sure what the problem was. At that time it will cost only a couple thousand to repair the damage.
You conclusion make perfectly good sense :sick:
I had my friend's boyfriend check out the cooling system and it ended up being an 8 dollar fix. Guess that checklist thing would've worked after all if the man at the auto place had actually listened to me. I saved $92. I'm also moderately sure that there aren't 10,000 different things that could go wrong with the cooling system.
Pardon me if I don't fully believe you when you imply that the wheel will lock up if I keep driving on a bad CV joint when I consider the rest of your post, but I'm not going to spend money if it is unnecessary. I was ASKING if it was unnecessary. I define necessary to be life threatening, car totaling, or cost me a great deal more if I wait. If someone who doesn't belong to the Internet Hate Machine and actually read my question would enlighten me as to what can happen if someone were to drive on a bad CV joint, I would truly appreciate it.
I'm pretty sure most people who ask questions here are looking to save money or they would just hand the car over to a mechanic and say "have at it". I'm very sorry if my attempting to not waste my money horribly offends you.
Can a fuse appear OK but still be blown?
Joe
Terry
I have a '96 LX 4-cyl 4-door with 193k miles on it. Lately, I've noticed that my blinkers will hesitate from the time I push down the stalk to the time they start flashing. It is worse when temps are cooler, and when the car hasn't been driven for the day. As time goes on, the hesitation goes away.
I'll move to signal a turn, nothing will happen for about one second, then I hear the click but at double-time speed (no flashing on the instrument panel or outside) much like when a bulb is out, then it will pick up and blink like normal. Today was the longest time-period with no blinking (over 5 seconds) and it nearly got me rear-ended; I had to go to the next block and double back to make my turn.
Any thoughts or suggestions on what the problem could be? Any/all replies are most appreciated!
TheGraduate
PS: No bulbs are out, and the hazard flashers work immediately when you press the button.
Mrbill
Sure would like some help,
Tybum
Corkscrew
Flashers and fuses are different but they tend to be located in the same box, either under hood or under dash. You should find a diagram under each cover that shows where the flasher is and which fuse controls what circuit.
Mrbill
I simply took the "Extra Fuse" that is in the fusebox (the 7.5 amp one) to replace the 7.5 amp turn signal fuse. We will see how it works. I didn't drive the car today, but did run the car for a second to make sure they were operational; they were.
Thanks both of you for your help. I knew how to check/change fuses, but didn't realize that's what it might take to fix it.
Thanks again!
TheGrad
My main issue is getting down there. I'm 6'5" and fitting down there is tough! I'll try it tomorrow.
thank you!
PJ
http://techauto.awardspace.com/solutions.html
Corkscrew
PJ
Good luck! :shades:
How do I know? I have replaced two in my car's lifetime under this recall, for free.
Mrbill
